漢字取模軟件,有需要的可以下載
單片機(jī)源程序如下:
- #include "c8051F340.h"
- #include <intrins.h>
- #include<absacc.h>
- #include<stdlib.h>
- #include<MMC_SD\MMC_SD.h>
- #include<main.h>
- #include<lcd\lcd_control.h>
- #include "USB_API.h"
- #define White 0xFFFF
- #define Black 0x0000
- #define Blue 0x001F
- #define Blue2 0x051F
- #define Red 0xF800
- #define Magenta 0xF81F
- #define Green 0x07E0
- #define Cyan 0x7FFF
- #define Yellow 0xFFE0
- sbit GO=P1^5;
- uint8 Packet[64]; // Last packet received from host
- uint8 nd,pic;
- uint16 bf;
- uint32 sd;
- code const UINT USB_VID = 0x10C4;
- code const UINT USB_PID = 0xEA61;
- code const BYTE USB_MfrStr[] = {0x1A,0x03,'S',0,'i',0,'l',0,'i',0,'c',0,'o',0,'n',0,' ',0,'L',0,'a',0,'b',0,'s',0}; // Manufacturer String
- code const BYTE USB_ProductStr[] = {0x10,0x03,'U',0,'S',0,'B',0,' ',0,'A',0,'P',0,'I',0}; // Product Desc. String
- code const BYTE USB_SerialStr[] = {0x0a,0x03,'1',0,'2',0,'3',0,'4',0};
- code const BYTE USB_MaxPower = 15; // Max current = 30 mA (15 * 2)
- code const BYTE USB_PwAttributes = 0x80; // Bus-powered, remote wakeup not supported
- code const UINT USB_bcdDevice = 0x0100; // Device release number 1.00
- extern void wr_com(unsigned int i,unsigned int j) ;
- //extern void uint8 image[3200];
- extern void LCD_PutString(unsigned short x, unsigned short y, unsigned char *s, unsigned int fColor, unsigned int bColor) ;
- extern void PutGB3232(unsigned short x, unsigned short y, unsigned char c[2], unsigned int fColor,unsigned int bColor);
- void Suspend_Device(void);
- void Init_Devices(void);
- void Initialize(void);
- void load_data(void);
- void Wait(void);
- void main(void)
- // int i,j,k;
- sd=1;
- bf=0;
- nd=0;
- pic=0;
- Init_Devices();
- MMC_SD_ReadSingleBlock(0);
- while(1)
- // load_data();
- Display_color(0x07e0);
- delay(7000);
- PutGB3232(20,40,"亮",Red,Green);delay(100);
- PutGB3232(60,40,"邦",Red,Green);delay(100);
- PutGB3232(20,80,"科",Blue,Green);delay(100);
- PutGB3232(60,80,"技",Blue,Green);delay(100);
- PutGB3232(20,120,"歡",Blue,Green);delay(100);
- PutGB3232(60,120,"迎",Blue,Green);delay(100);
- //PutGB3232(260,40,"你",Blue,Green);delay(100);
- //PutGB3232(300,40,"!",Blue,Green);delay(100);
- Wait();
- Display_color(0x8410);
- delay(6000);
- Wait();
- delay(6000);
- Display_color(0x001f);
- delay(6000);
- Display_color(0xffff);
- delay(6000);
- Display_color(0x0000);
- delay(6000);
- void Wait()
- while(1)
- if(GO==0)
- delay(200);
- while(GO==0)
- return;
- load_data();
- uint8 st[1],retry;
- st[0]=1;
- if(nd==1)
- while(1)
- if(nd==1)
- for(retry=0;retry<64;retry+=2)
- write_dc(Packet[retry], Packet[retry+1]);
- buffer[bf++]=Packet[retry];
- buffer[bf++]=Packet[retry+1];
- if(bf==512)
- MMC_SD_WriteSingleBlock(sd++);
- buffer[0]=pic;
- MMC_SD_WriteSingleBlock(0); //統(tǒng)計圖片數(shù)量 buffer[0]=pi
- bf=0;
- nd=0;
- Block_Write(st, 1);
- void USB_API_TEST_ISR(void) interrupt 17
- uint8 INTVAL = Get_Interrupt_Source();
- if (INTVAL & RX_COMPLETE)
- Block_Read(Packet, 64);
- nd=1;
- if (INTVAL & DEV_SUSPEND)
- Suspend_Device();
- if (INTVAL & DEV_CONFIGURED)
- Initialize();
- if (INTVAL & DEVICE_OPEN)
- goto_start();
- if (INTVAL & DEVICE_CLOSE)
- pic=pic+1;
- goto_start();
- uint8 n;
- PCA0MD &= ~0x40;
- //------OSC--------------------------
- OSCICN = 0x83;
- CLKMUL=0X00;
- CLKMUL|=0X80;
- for(n=0;n<255;n++);
- CLKMUL|=0Xc0;
- while((0X20&CLKMUL)!=0X20);
- CLKSEL = 0x00;
- RSTSRC |= 0x02;
- //------POINT--------------------------
- P0MDIN |= 0xfF; // P0 pins 0-3 set high impedance
- P0MDOUT |= 0xfF;
- P1MDOUT |= 0xfF; // P1 pins 0-3 set high impedance
- P1MDIN |= 0xfF;
- P2MDOUT |= 0xff;
- P3MDOUT |= 0xff;
- P4MDOUT |= 0xff; // Port 1 pin 7 skipped by crossbar
- XBR0 = 0x02;
- XBR1 = 0x40; // Enable Crossbar
漢字程序.zip
(162.65 KB, 下載次數(shù): 17)
2018-5-12 12:18 上傳
點(diǎn)擊文件名下載附件
下載積分: 黑幣 -5
