查看: 3381|回復: 3
求51超聲波測距的同時另一IO口輸出PWM的程序,謝謝
ID:331066 發(fā)表于 2018-5-16 14:37 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
200黑幣
各位大神,小弟剛玩單片機,不太會編程,麻煩請幫忙編一段程序,利用一個超聲波測距離的同時,用一個IO口輸出可調占空比的PWM,不能利用外部中斷,外部中斷我有用處。超聲波測距離和輸出PWM要同時進行,不能分開運行,謝謝!
ID:336165 發(fā)表于 2018-5-24 22:14 | 只看該作者
#include<reg52.h>
#include <intrins.h>
#define uchar unsigned char
#define uint unsigned int
sbit PWM1=P2^6;
sbit lcdrs=P2^3;
sbit lcden=P2^2;
sbit trig=P2^0;               //超聲波發(fā)送
sbit echo=P3^2;               //超聲波接受
//P0____________DB0-DB7
uchar dis[]="Disp_HC-SR04";
uchar num[]="0123456789";
uint distance;
void delay(uint z)
uint x,y;
for(x=z;x>0;x--)
for(y=121;y>0;y--);
void HC_init()
        TMOD=0x09;
        TR0=1;
        TH0=0;TL0=0;
void time_init()
        TMOD=0x20; /* 設定T1為方式1 */
        TH1=0x3C;
        TL1=0xB0;
        EA=1; /* 開中斷 */
        ET1=1;
        TR1=1;
void time0() interrupt 3
        TR1=0;
        TH1=0xAA; /* 裝入定時器的初值,修改初值能修改pwm頻率 */
        TL1=0xAA;
        m1=~m1;                /* 頻率1 */
        TR1 = 1;
uint HC_jisuan()
        uint dist,timer;
        timer=TH0;
        timer<<=8;
        timer=timer|TL0;
        dist=timer/53;                //晶振11.0592MHz 距離cm=微秒us/58
        return dist;                  //1個機器周期是12個時鐘周期   timer*12/(58*11.0592)=timer/53
void HC_run()
        uint tempH=0x00,tempL=0x00;
        TH0=0;TL0=0;
        trig=0;
        trig=1;
        delay(1);
        trig=0;
        while((TH0-tempH!=0||TL0-tempL!=0)||(TH0==0&&TL0==0))
                        tempH=TH0;
                        tempL=TL0;
        delay(1);
void lcd_write_com(uchar com)  //LCD寫指令
        lcdrs=0;
        P0=com;
        delay(1);
        lcden=1;
        delay(1);
        lcden=0;
void lcd_write_data(uchar date)  //LCD寫數據
        lcdrs=1;
        P0=date;
        delay(1);
        lcden=1;
        delay(1);
        lcden=0;
void lcd_init()  //LCD初始化
        lcden=0;
        lcd_write_com(0x38);
        lcd_write_com(0x0c);
        lcd_write_com(0x06);
        lcd_write_com(0x01);
void lcd_display(uchar temp)
        uint i;
        lcd_write_com(0x82);
        for(i=0;i<12;i++)
                        lcd_write_data(dis[i]);
        lcd_write_com(0x80+0x41);
        lcd_write_data('D');
        lcd_write_data('i');
        lcd_write_data('s');
        lcd_write_data('t');
        lcd_write_data('a');
        lcd_write_data('n');
        lcd_write_data('c');
        lcd_write_data('e');
        lcd_write_data(':');
        lcd_write_data(num[temp/100]);
        lcd_write_data(num[temp/10%10]);
        lcd_write_data(num[temp%10]);
        lcd_write_data('m');
        lcd_init();
        HC_init();
                HC_run();
                distance=HC_jisuan();
                lcd_display(distance);
                delay(200);
ID:1117272 發(fā)表于 2024-4-19 12:44 來自觸屏版 | 只看該作者
優(yōu)雅的刺猬 發(fā)表于 2018-5-24 22:14
#include
#include
我也好需要
ID:1117272 發(fā)表于 2024-4-19 19:06 | 只看該作者
編譯不了啊求 HEX文件
主站蜘蛛池模板: 欧美色综合天天久久综合精品 | 在线国产一区 | 亚洲免费播放 | 青草国产 | 精品久久久久久久 | 黄色毛毛片| 日韩福利一区 | 欧美日韩大片 | 成年人免费看视频 | 天天操网 | 一区二区国产在线 | 中文字幕免费观看 | 亚洲www啪成人一区二区麻豆 | 日韩黄色片| 黄色一级免费 | 欧美三级免费 | 亚洲精品区 | 四虎影音 | 午夜黄色大片 | 欧美性久久 | 午夜精品久久久久久久久久蜜桃 | 日韩中文字幕在线视频 | 小sao货撅起屁股扒开c微博 | 亚洲小视频在线观看 | 99福利视频 | 三上悠亚激情av一区二区三区 | 免费的毛片 | 免费黄色大片 | 日韩综合久久 | 天堂中文在线资源 | 亚洲激情在线视频 | 一区二区三区影视 | 国产永久免费视频 | 精品在线观看视频 | 中文字字幕码一二三区 | 午夜精品一区二区三区在线播放 | 成人深夜视频 | 亚洲第一黄网 | 成人精品免费视频 | 艳妇乳肉亭妇荡乳av | 91视频精品|
