查看: 7640|回復: 5
LT8910驅動程序(無線發送和接受源碼)
ID:93248 發表于 2018-5-16 15:50 | 顯示全部樓層 |閱讀模式
官方提供的LT8910驅動程序,需要的朋友拿去參考參考
LT8920 是一款低成本,高集成度的 2.4GHZ 的無線收發芯片。是之前LT8910的升級版!
外圍射頻電路簡單,直接接天線
包括射頻前端和數字基帶的單芯片解決方案:
※ 支持跳頻
※ 支持 SPI 和 I2C 接口
※ 內置 auto_ack 功能
※ 數據率 1Mbps, 250Kbps, 125Kbps, 62.5Kbps
※ 極低功耗(1uA)
※ 支持信號能量檢測
※ 單芯片傳輸距離 200 米
※ TSSOP16 的封裝
  1. #include "intrins.h"
  2. #include "IIC_Drive.h"
  3. #include "LCD_Drive.h"
  4. #include "Interrupt.h"
  5. #include "SPI.h"
  6. #define SPI_TEST
  7. #define RX_MODE     0x80
  8. #define SLEEP_MODE  0x40
  9. #define AFTER_SLEEP 0x20
  10. unsigned char *p_rx_sum;
  11. unsigned char working_state = RX_MODE;              // working state
  12. unsigned char rssivalue = 0;
  13. unsigned char channel_index[79] = {0x00, 0x01, 0x02,
  14.        0x03, 0x04, 0x05, 0x06, 0x07, 0x08, 0x09, 0x0a, 0x0b, 0x0c,                           //2402, 2412, 2422, 2432
  15.        0x0d, 0x0e, 0x0f, 0x10, 0x11, 0x12, 0x13, 0x14, 0x15, 0x16,
  16.        0x17, 0x18, 0x19, 0x1a, 0x1b, 0x1c, 0x1d, 0x1e, 0x1f, 0x20,
  17.        0x21, 0x22, 0x23, 0x24, 0x25, 0x26, 0x27, 0x28, 0x29, 0x2a,
  18.        0x2b, 0x2c, 0x2d, 0x2e, 0x2f, 0x30, 0x31, 0x32, 0x33, 0x34,
  19.        0x35, 0x36, 0x37, 0x38, 0x39, 0x3a, 0x3b, 0x3c, 0x3d, 0x3e,
  20.        0x3f, 0x41, 0x42, 0x43, 0x44, 0x45, 0x46, 0x47, 0x48, 0x49,
  21.        0x4a, 0x4b, 0x4c, 0x4d, 0x4e, 0x4f};
  22. void main(void)
  23. {
  24.         unsigned char rx_sum = 0;                                                           //接收次數累加器
  25.         unsigned char highReg = 0;
  26.         unsigned char lowReg  = 0;
  27.         unsigned char channelvalue = 0;
  28.
  29.         p_rx_sum = &rx_sum;                     //指向累加器的指針
  30.         LCD_Initialize();
  31.         LCD_WriteCommand(0x80);
  32.         LCD_WriteDat(0xf6);                                  //''
  33.         LCD_WriteCommand(0x8c);
  34.         LCD_WriteDat(0x43);                                                //'C'
  35.         LCD_WriteDat(0x48);                                                //'H'
  36.         LCD_WriteDat(bcd_table[(channelvalue+2)/10]);
  37.         LCD_WriteDat(bcd_table[(channelvalue+2)%10]);
  38.         LCD_WriteCommand(0xc0);
  39.         LCD_WriteDat(0x72);                                          //'r'
  40.         LCD_WriteDat(0x73);                                           //'s'
  41.         LCD_WriteDat(0x73);                                           //'s'
  42.         LCD_WriteDat(0x69);                                          //'i'           means rssi
  43.         LCD_WriteDat(bcd_table[rssivalue/10]);
  44.         LCD_WriteDat(bcd_table[rssivalue%10]);
  45.         Timer0_Init();
  46.         //EX0_Init();
  47.         EA = 1;
  48. #ifdef SPI_TEST
  49.         RST  = 0;
  50.         Delay_ms(2);
  51.         RST  = 1;
  52.         Delay_ms(5);
  53.         PKT = 1;
  54.         LT8900_Init();
  55.         SPI_ReadReg(4);
  56.         if (RegH==0x9c && RegL==0xc9)
  57.         {
  58.                 LED_SPI = 0;
  59.         }
  60.         while (1)
  61.         {
  62.                 switch(working_state)
  63.                 {
  64.                 case RX_MODE:
  65.                                         //rssivalue = 0;
  66.                                         SPI_WriteReg( 7, 0x00, 0x00);
  67.                                         SPI_WriteReg(52, 0x80, 0x80);
  68.                                         EX0 = 0;
  69.                                         SPI_WriteReg( 7, 0x00, 0x80+channelvalue);                          //TX Enable & channel set to 2480M
  70.                                         EX0 = 1;
  71.                                 //        while(PKT);
  72.                                         do
  73.                                         {
  74.                                                 SPI_ReadReg(48);
  75.                                         }
  76.                                         while(RegL & 0x40);
  77.                                         SPI_WriteReg( 7, 0x00, 0x00);                          //goto idle mode
  78.                                         SPI_ReadReg(48);
  79.                                         if(!(RegH & 0x80))
  80.                                         {
  81.                                                 LED_RF = ~LED_RF;
  82.                                                 SPI_ReadReg(50);
  83.                                                 if (RegH==0x03 && RegL==0xce)
  84.                                                         rx_sum++;                                                          //RX 累加器加一
  85.                                                 if (RegH==0x01)
  86.                                                 {
  87.
  88.                                                         channelvalue = RegL;                  //switch to channel RegL
  89.
  90.                                                         LCD_WriteCommand(0x8e);
  91.                                                         LCD_WriteDat(bcd_table[(channelvalue+2)/10]);
  92.                                                         LCD_WriteDat(bcd_table[(channelvalue+2)%10]);
  93.                                                 }
  94.                                                 SPI_ReadReg(6);        //get rssi_value
  95.                                                 RegH &= 0xfc;
  96.                                                 rssivalue = RegH>>2;
  97.                                                 LCD_WriteCommand(0xc4);
  98.                                                 LCD_WriteDat(bcd_table[rssivalue/10]);
  99.                                                 LCD_WriteDat(bcd_table[rssivalue%10]);
  100.                                                 rssivalue = 0;
  101.                                         }
  102.                                         break;
  103.
  104.                 case SLEEP_MODE:
  105.                                                 SPI_WriteReg(35, 0x43, 0x00);
  106.                                                 SPI_SS = 1;
  107.                                                 LCD_WriteCommand(0xc0);
  108.                                                 LCD_WriteDat(0x7a);
  109.                                                 working_state = AFTER_SLEEP;
  110.                                                 break;
  111.                 case AFTER_SLEEP:
  112.                                                 _nop_();
  113.                                                 break;
  114.                 default : break;
  115.
  116.                 }
  117.         }
  118. #else
  119.         MOSI = 0;               // A4 =0
  120.         RST  = 0;
  121.         Delay_ms(2);
  122.         RST  = 1;
  123.         Delay_ms(5);
  124.         PKT = 1;
  125.         RF_Init();
  126.         IIC_ReadReg( 4, &highReg, &lowReg);
  127.         if (highReg==0x9c && lowReg==0xc9)
  128.         {
  129.                 LED_IIC = 0;
  130.         }
  131.         while (1)
  132.         {
  133.                 IIC_WriteReg(52, 0x80, 0x80);
  134.                 IIC_WriteReg( 7, 0x00, 0xb0);                          //TX Enable & channel set to 2450M
  135.                 /*while(PKT);*/
  136.                 do
  137.                 {
  138.                         SPI_ReadReg(48);
  139.                 }
  140.                 while(RegL & 0x40);
  141.                 IIC_WriteReg( 7, 0x00, 0x00);                          //goto idle mode
  142.                 IIC_ReadReg(48, &highReg, &lowReg);
  143.                 if(!(highReg & 0x80))
  144.                 {
  145.                         rx_sum++;                                                          //RX 累加器加一
  146.                         LED_RF = ~LED_RF;
  147.                 }
  148.          }
  149.
  150. #endif
  151.
  152.         /*
  153.         LCD_WriteCommand(0x80);
  154.         LCD_WriteDat(0x32);                                  //'2'
  155.         LCD_WriteDat(0x34);                                  //'4'
  156.         LCD_WriteDat(0x35);                                  //'5'
  157.         LCD_WriteDat(0x30);                                  //'0'
  158.         LCD_WriteDat(0xa5);                                  //'.'
  159.         */
  160.
  161.
  162.                 /*
  163.                 if(rx_lcd_flag == 50)
  164.                 {
  165.                         LCD_WriteCommand(0x04);                                        // turn left
  166.                          LCD_WriteCommand(0x8f);
  167.                          LCD_WriteDat(0x7f);                                   //'<'
  168.                 }
  169.                 if(rx_lcd_flag == 100)
  170.                 {
  171.                          LCD_WriteDat(0x7f);
  172.                 }
  173.                 if(rx_lcd_flag == 150)
  174.                 {
  175.                          LCD_WriteDat(0x7f);
  176.                 }
  177.                 if(rx_lcd_flag == 200)
  178.                 {
  179.                          LCD_WriteDat(0x7f);
  180.                 }
  181.                 if(rx_lcd_flag >= 250)
  182.                 {
  183.                          rx_lcd_flag = 0;
  184.                         LCD_WriteCommand(0x06);                                                        //寫入新數據后 光標右移一位
  185.                         LCD_WriteDat(0xa0);
  186.                         LCD_WriteDat(0xa0);
  187.                         LCD_WriteDat(0xa0);
  188.                         LCD_WriteDat(0xa0);
  189.                         //LCD_WriteCommand(0x06);
  190.                 }
  191.                 */
  192.
  193. }
  194. ……………………
  195. …………限于本文篇幅 余下代碼請從51黑下載附件…………
LT8910驅動程序.rar (142.91 KB, 下載次數: 143)
ID:498382 發表于 2019-3-26 01:42 | 顯示全部樓層
學習了!謝謝分享!!!
ID:544323 發表于 2019-5-22 01:01 | 顯示全部樓層
學習了!謝謝分享!!!
ID:111843 發表于 2019-12-21 23:41 | 顯示全部樓層
不錯,感謝分享!
ID:524433 發表于 2020-5-14 09:42 | 顯示全部樓層
下載學習
ID:791040 發表于 2020-6-27 16:08 | 顯示全部樓層
感謝分享!下載學習
主站蜘蛛池模板: 国产一区二区福利 | 成人午夜激情视频 | www.亚洲成人| 福利片国产| 免费看的黄色片 | 国产成人精品av在线观 | 午夜激情网 | 黄色片网站在线观看 | 成人一级黄色片 | 国产操操操| 三级视频在线观看 | 亚洲成人黄色 | 国产激情在线观看 | 不卡中文字幕 | 天天干夜夜撸 | 天天视频黄 | 午夜国产福利 | 黄色影音 | 金银在线 | 中文字幕二区 | 国产无遮挡又黄又爽免费网站 | 少妇视频网站 | 欧美一区二 | 自拍偷拍av| 国产精品视频网站 | 91免费视频 | 日本大尺度床戏揉捏胸 | 欧美国产一区二区 | 三级网站免费 | 四虎视频 | 久久怡红院 | 伊人久久网站 | 午夜精品久久久久久久 | 伦一理一级一a一片 | 国产伦精品一区二区三区视频网站 | 91视频成人 | 日本a级大片 | 久久综合av | 国产精品女同 | 最新日韩在线 | 在线播放中文字幕 |
