查看: 8440|回復(fù): 11
51單片機(jī)小車測距避障并調(diào)速的源碼
ID:321034 發(fā)表于 2018-5-22 21:32 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
  簡單的編程  ,使用51單片機(jī)STC89C52進(jìn)行編程,  期間用到1個(gè)超聲波HC-SR04, 1個(gè)電機(jī)驅(qū)動(dòng)模塊L298N    實(shí)現(xiàn)了  簡單的避障和 調(diào)速的功能,
源程序如下:
  1. #include <reg52.h>
  2. #include <intrins.h>
  4. #define uint unsigned int
  5. sbit ENA_pwm = P2^6;    //PWM信號端
  6. sbit ENB_pwm = P2^7;    //PWM信號端
  7.
  8. sbit L298N_INA = P1^0;
  9. sbit L298N_INB = P1^1;
  10. sbit L298N_INC = P1^2;
  11. sbit L298N_IND = P1^3;
  12. sbit Trlg1 = P2^0;
  13. sbit Echo1 = P2^1;
  14. unsigned char pwm_val_left  =0;    //變量定義
  15. unsigned char pwm_val_right =0;
  16. unsigned char push_val_left =0;// 左電機(jī)占空比N/10
  17. unsigned char push_val_right=0;// 右電機(jī)占空比N/10
  18. unsigned int  time = 0;        //傳輸時(shí)間
  19. unsigned long S = 0;           //距離
  20. bit flag = 0;                  //超出測量范圍標(biāo)志位
  21. void delay(uint z)        //毫秒級延時(shí)
  22. {
  23.         uint x,y;
  24.         for(x = z; x > 0; x--)
  25.           {
  26.                 for(y = 114; y > 0 ; y--);
  27.           }
  28. }
  29. void Delay10us_CSB(uchar i)   //10us延時(shí)函數(shù) 超聲波模塊使用
  30. {
  31.         uchar j;
  32.         do
  33.           {
  34.              j = 10;
  35.              do
  36.                  {
  37.                 _nop_();
  38.                     _nop_();
  39.              }
  40.                     while(--j);
  41.         }
  42.                while(--i);
  43. }
  44. void Go_forward()
  45. {
  46.     push_val_left=4;
  47.     push_val_right=4;
  48.     L298N_INA = 0;
  49.     L298N_INB = 1;
  50.     L298N_INC = 1;
  51.     L298N_IND = 0;
  52. }
  53. void Go_back()
  54. {
  55.     push_val_left=4;
  56.     push_val_right=4;
  57.     L298N_INA = 1;
  58.     L298N_INB = 0;
  59.     L298N_INC = 0;
  60.     L298N_IND = 1;
  61. }
  62. void Go_left()
  63. {
  64.     push_val_left=3;
  65.     push_val_right=3;
  66.     L298N_INA = 0;
  67.     L298N_INB = 1;
  68.     L298N_INC = 1;
  69.     L298N_IND = 1;
  70. }
  71. /*
  72. void Go_right()
  73. {
  74.     push_val_left=3;
  75.     push_val_right=3;
  76.     L298N_INA = 1;
  77.     L298N_INB = 0;
  78.     L298N_INC = 0;
  79.     L298N_IND = 0;
  80. }
  81. */
  82. void Stop()
  83. {
  84.     L298N_INA = 0;
  85.     L298N_INB = 0;
  86.     L298N_INC = 0;
  87.     L298N_IND = 0;
  88. }
  89. void pwm_out_left_moto(void)
  90. {
  91.                 if(pwm_val_left<=push_val_left)
  92.                         ENA_pwm=1;
  93.                 else
  94.                         ENA_pwm=0;
  95.                 if(pwm_val_left==10)            //  0~10  ,  0最小,10最大
  96.                         pwm_val_left=0;
  97. }
  98. void pwm_out_right_moto(void)
  99. {
  100.                 if(pwm_val_right<=push_val_right)
  101.                         ENB_pwm=1;
  102.                 else
  103.                         ENB_pwm=0;
  104.                 if(pwm_val_right==10)           //  0~10  ,  0最小,10最大
  105.                         pwm_val_right=0;
  106. }
  107.                             /*定時(shí)器1中斷輸出PWM信號*/
  108. void timer1() interrupt 3
  109. {
  110.           TH1=(65536-10)/256;
  111.         TL1=(65536-10)%256;
  112.         pwm_val_left++;
  113.         pwm_val_right++;
  114.          pwm_out_left_moto();
  115.          pwm_out_right_moto();
  116. }
  117.
  118. void timer0() interrupt 1        //T0中斷用來計(jì)數(shù)器溢出,超過測距范圍
  119. {
  120.         flag=1;                 //中斷溢出標(biāo)志
  121. }
  122. void  CSB_module()
  123. {
  124.         Trlg1=1;
  125.         Delay10us_CSB(10);
  126.         Trlg1=0;
  127. }
  128.                              /*計(jì)算超聲波所測距離并顯示*/
  129. void Conut()
  130. {
  131.         time=TH0*256+TL0;
  132.         TH0=0;
  133.         TL0=0;
  134.         S=(float)(time*1.085)*0.17;     //算出來是MM
  135.         if((S>=7000)||flag==1)          //超出測量范圍
  136.         {
  137.                 flag=0;
  138.         }
  139. }
  140.
  141. void  bizhang()
  142. {
  143.         if(S > 100)//設(shè)置避障距離(單位毫米)
  144.         {
  145.                 Go_forward();
  146.
  147.         }
  148.         else
  149.         {
  150.                         Stop();
  151.                      delay(20);
  152.                      Go_back();
  153.                      delay(30);
  154.                      Go_left();
  155.         }
  156. }
  157.
  158. void main()
  159. {
  160.         Stop();
  161.         delay(1000);//延時(shí)1秒
  162.         TMOD |= 0x20;//定時(shí)器1工作模式2,8位自動(dòng)重裝。用于產(chǎn)生PWM
  163.         TMOD |= 0x01;//定時(shí)器0工作模塊1,16位定時(shí)模式。T0用測ECH0脈沖長度
  164.         TH1 = 220; //
  165.         TL1 = 220; //100HZ T1
  166.         TH0 = 0;
  167.         TL0 = 0;//T0,16位定時(shí)計(jì)數(shù)用于記錄ECHO高電平時(shí)間
  168.         ET1 = 1;//允許T1中斷
  169.         ET0 = 1;//允許T0中斷
  170.         TR1 = 1;//啟動(dòng)定時(shí)器1
  171.         EA  = 1;//啟動(dòng)總中斷
  172.         while(1)
  173.         {
  174.                  CSB_module();        //啟動(dòng)超聲波測距
  175.                  while(!Echo1);        //當(dāng)(ECHO信號回響)為零時(shí)等待
  176.                  TR0=1;               //開啟計(jì)數(shù)
  177.                  while(Echo1);
  178.                  TR0=0;               //關(guān)閉計(jì)數(shù)
  179.                  Conut();             //計(jì)算距離
  180.                  bizhang();           //避障
  181.                  delay(30);
  182.           }
  183. }
全部資料51hei下載地址:
pwm調(diào)速小車避障.rar (24.86 KB, 下載次數(shù): 148)
參與人數(shù) 3黑幣 +60 收起 理由
忘語 + 5 贊一個(gè)!
﹌信念。 + 5 贊一個(gè)!
收藏收藏18 分享淘帖 頂2 踩
ID:358191 發(fā)表于 2018-6-25 15:50 | 只看該作者
能測速嗎
ID:501297 發(fā)表于 2019-4-13 12:32 | 只看該作者
終于靠譜了
ID:547956 發(fā)表于 2019-5-26 23:16 | 只看該作者
有沒有使用51單片機(jī)STC89C51進(jìn)行編程的
ID:547956 發(fā)表于 2019-5-26 23:29 | 只看該作者
哥,能不能仔細(xì)解釋下,許多地方看不懂
ID:541246 發(fā)表于 2019-7-16 11:26 | 只看該作者
這個(gè)可讀性不錯(cuò)
ID:580104 發(fā)表于 2019-7-17 13:46 | 只看該作者
備注很詳細(xì),資料不錯(cuò),學(xué)習(xí)一下。
ID:734122 發(fā)表于 2020-4-27 22:36 | 只看該作者
本帖最后由 質(zhì)壁分離 于 2020-4-27 23:06 編輯
很詳細(xì),對于學(xué)習(xí)很有幫助,謝謝。
ID:825654 發(fā)表于 2021-1-30 16:12 | 只看該作者
這個(gè)資料不錯(cuò)奧,謝謝樓主
ID:825654 發(fā)表于 2021-1-30 16:13 | 只看該作者
Leslieyang 發(fā)表于 2019-5-26 23:16
這個(gè)也可以用
ID:871292 發(fā)表于 2021-2-9 11:28 | 只看該作者
收下研究了,謝謝!
ID:973226 發(fā)表于 2021-10-20 10:50 | 只看該作者
有紅外的嗎樓主
主站蜘蛛池模板: 超碰在线中文字幕 | 欧美国产在线观看 | 五月婷婷网 | 一级免费av | 九九国产精品视频 | 黄色在线观看网址 | 老司机精品福利视频 | 在线观看视频一区二区 | 日韩在线小视频 | 国产精品海角社区 | 麻豆成人91精品二区三区 | 色网站女女 | 色婷婷中文字幕 | 亚洲最大黄色网址 | 亚洲天堂2014 | 精品国产一区二区在线观看 | 免费在线观看黄色片 | 日韩在线中文字幕 | 日韩一级黄色片 | 小sao货撅起屁股扒开c微博 | 黄色在线观看免费 | 国产91av在线 | 国精产品一区二区 | 91av免费在线观看 | 国产一级片免费观看 | 四虎8848精品成人免费网站 | 国产aa视频 | 999国产视频| 日本毛片在线观看 | 欧美a级成人淫片免费看 | 欧美高清视频在线观看mv | 在线黄色网 | 老司机午夜免费精品视频 | 欧美三级 欧美一级 | 国产成人99久久亚洲综合精品 | 999久久久精品 | 国产一级视频在线观看 | 亚洲免费在线播放 | 天天爽天天操 | 国产欧美精品一区 | 天天操天天拍 |
