查看: 6075|回復: 2
PWM直流電機調速系統設計
ID:336452 發表于 2018-5-23 14:28 | 顯示全部樓層 |閱讀模式
#include <reg52.h>
#define uchar unsigned char
#define uint unsigned int
void displaym();
sbit en=P2^5;                //1602  6管腳
sbit rs=P2^7;         //1602端口        4管腳
sbit rw=P2^6;//lcd1602控制端口 5管腳
sbit num1=P1^0;                                                //占空比加1
sbit num2=P1^1;        //占空比減一
sbit num3=P1^2;        //正傳
sbit num4=P1^3;        //反轉
sbit num5=P1^4;        //開始停止切換
sbit out=P3^4;                                                         //PWM輸出用于正傳
sbit out1=P3^7;                        //PWM輸出用于反轉
uint zhuansu,flag,z1,z2,m,flag_1,zheng,fan,kai;
void delay(uint z)//延時1ms函數
uint x,y;
for(x=0;x<z;x++)
     for(y=0;y<110;y++);
void write_com(uchar com)//向1602寫一字節(控制指令)
  rs=0;
  P0=com;
  delay(5);
  en=0;
  delay(10);
  en=1;
void write_data(uchar date)//向1602寫一字節(數據)
  rs=1;
  P0=date;
  delay(5);
  en=0;
  delay(5);
  en=1;
void init()//初始化函數
  en=0;
  rw=0;
  write_com(0x01);         //lcd初始化
  write_com(0x38);                                           //5X7顯示
  write_com(0x0c);                         //關閉光標
  TMOD=0x01;               //定時器方式1
  TH0=0xdc;
  TL0=0x00;                //定時器裝入初值
  EA=1;                    //開總中斷
  ET0=1;                   //定時器0開中斷
  TR0=1;
  EX1=1;
IT1=1;                 //定時器啟動
TH1=0xfc;
  TL1=0x66;//定時100us
  ET1=1;                   //定時器1開中斷
  TR1=1;
  write_com(0x80);
  write_data('V');
  write_data(':');
  write_com(0x87);                 //第一行顯示轉速
  write_data('r');
  write_data('p');
  write_data('m');
  write_com(0xc0);
  write_data('z');
  write_data('h');
  write_data('a');
  write_data('n');
  write_data('k');
  write_data('o');
  write_data('n');
  write_data('g');
  write_data('b');
  write_data('i');          //在第二行顯示zhankongbi:
  write_data(':');
  displaym();
void keyscan()  //鍵盤掃描函數
  if(num1==0)
    delay(5);      //消除抖動
         if(num1==0)
                if(m<=199)
                 m++;
                        displaym();        //設定占空比加一
  if(num2==0)
    delay(5);
         if(num2==0)
                  if(m>=1)
                m--;
                        displaym();                                        //設定占空比減一
    if(num3==0)
    delay(5);
         if(num3==0)
          zheng=1;                //正傳標志置1
          fan=0;          // 反轉標志置0
      if(num4==0)
    delay(5);
         if(num4==0)
          zheng=0;                 //正傳標志置0
          fan=1;          // 反轉標志置1
      if(num5==0)
    delay(5);
         if(num5==0)
         while(num5==0)         ;
          kai=1-kai;
void display()
  write_com(0x82);
  zhuansu=zhuansu*30;          //將兩秒內的計數乘以30得到轉每分
  if(zhuansu/10000!=0)
   write_data(zhuansu/10000+0x30);                                                  //如果轉速的萬位不為0        正常顯示否則顯示空格
   write_data(' ');
  if(zhuansu/1000==0)
  write_data(' ');
  write_data(zhuansu%10000%1000+0x30);        //如果轉速小于1000 千位為空格 否則正常顯示
  if(zhuansu/100==0)
  write_data(' ');
  write_data(zhuansu%10000%1000/100+0x30);                                           //如果轉速小于100 百位為空格 否則正常顯示
    if(zhuansu/10==0)
  write_data(' ');
  write_data(zhuansu%10000%1000%100/10+0x30);                                  //如果轉速小于10 十位為空格 否則正常顯示
  write_data(zhuansu%10000%1000%100%10+0x30);
  write_com(0xd0);                          //如果沒有這句,當中斷內的顯示函數執行完,就會在轉速的位置顯示占空比數據,導致亂碼
void displaym()
write_com(0xcb);
   if(m/200%10!=0)
  write_data(m/200%10+0x30);                           //如果占空比百位不為0則顯示百位否則顯示空格
  write_data(' ');
  if(m/200%10==0&&m/20%10==0)
  write_data(' ');
  write_data(m/20%10+0x30);                                 //如果占空比小于10 十位正常顯示  否則顯示空格
  write_data(m/2%10+0x30);                                 //顯示個位
    flag_1=0;
        m=100;                                                         //占空比為100
        zhuansu=0;                                           //轉速初值0
        flag=0;
        zheng=1;                                  //初始化電機正轉動
        fan=0;
    init();              //初始化
        keyscan();                                //鍵盤掃描程序
void int1()interrupt 2                                //外部中斷1脈沖技術記錄電機的轉速 電機轉一圈zhuansu加一
  zhuansu++;
void int2()interrupt 3                                  //定時器0顯示轉速
  TH0=0xdc;
  TL0=0x00;//定時10ms
  flag++;
  if(flag==200)                                   //計時到達2s
        display();                                        //顯示轉速
        zhuansu=0;                                          //轉速置0
        flag=0;
void int3()interrupt 1                                         //產生PWM
  TH1=0xff;
  TL1=0x00;//定時100us
          flag_1++;
        if(flag_1>199)
        flag_1=1;
        if(kai==1)                  //如果kai==1電機啟動
        if(zheng==1)                                //電機正轉
        if(flag_1<m)                                          //小于占空比m輸出PWM=0輸出電壓為1
     {out=0;
         out1=1;}
           out=1;
           out1=1;
                 if(fan==1)                           //電機反轉
            out=1;
                out1=0;
         else        //大于m輸出PWM=1輸出電壓為0
            out=1;
                out1=1;
         if(kai==0)                          //kai=0電機停止轉動
           out=1;
           out1=1;
參與人數 1黑幣 +12 收起 理由
謝小康4 + 12
ID:772784 發表于 2021-4-12 12:15 | 顯示全部樓層
樓主,你好。有文件壓縮包嗎?
ID:944866 發表于 2022-4-2 20:31 | 顯示全部樓層
有壓縮包嗎
主站蜘蛛池模板: 亚洲黄色片 | 天海翼一区 | 成人动漫免费观看 | 日韩精品久久久久久久酒店 | 黄色成人在线 | 天天躁日日躁bbbbb | 免费视频a | 在线免费成人 | 欧美日韩在线播放 | 亚洲区视频 | www久| 亚洲视频区 | 蜜桃成人在线 | a天堂在线 | 夜夜嗨av一区二区三区 | 国产一区二区欧美 | 黄色一级片免费 | 国产精品免费在线 | 一级片欧美 | 超碰免费在线观看 | 国产美女在线播放 | cao在线| 日韩精品久久久久久 | 色妞网站| 91亚洲精品在线 | 亚洲成人免费观看 | 天堂中文av | 日韩黄色在线 | 亚洲精品成人 | 国产成人精品亚洲男人的天堂 | 亚洲精品观看 | 国产女人水真多18毛片18精品 | 午夜成人在线视频 | 一区二区三区四区在线视频 | 视频在线观看网站免费 | 黄a视频| www久久久久 | 不卡av在线播放 | 狠狠操av | 色婷婷狠狠 | 成人av免费看 |
