查看: 5704|回復(fù): 2
LORA SX1276,SX1278引腳圖與數(shù)據(jù)手冊下載(超強穿透能力)
ID:343535 發(fā)表于 2018-6-2 15:51 | 顯示全部樓層 |閱讀模式
具有超強穿透能力的SX1276芯片引腳圖:
SX1278引腳圖:
LoRaTM Modem
168 dB maximum link budget
+20 dBm - 100 mW constant RF output vs. V supply
+14 dBm high efficiency PA
Programmable bit rate up to 300 kbps
High sensitivity: down to -148 dBm
Bullet-proof front end: IIP3 = -11 dBm
Excellent blocking immunity
Low RX current of 9.9 mA, 200 nA register retention
Fully integrated synthesizer with a resolution of 61 Hz
FSK, GFSK, MSK, GMSK, LoRaTMand OOK modulation
Built-in bit synchronizer for clock recovery
Preamble detection
127 dB Dynamic Range RSSI
Automatic RF Sense and CAD with ultra-fast AFC
Packet engine up to 256 bytes with CRC
Built-in temperature sensor and low battery indicator
KEY PRODUCT FEATURES
The SX1276/77/78 transceivers feature the LoRaTM long
range modem that provides ultra-long range spread
spectrum communication and high interference immunity
whilst minimising current consumption.
Using Semtech’s patented LoRaTM modulation technique
SX1276/77/78 can achieve a sensitivity of over -148dBm
using a low cost crystal and  bill of materials. The high
sensitivity combined with the  integrated +20 dBm power
amplifier yields industry leading link budget making it
optimal for any application requiring range or robustness.
LoRaTM also provides significant advantages in both
blocking and selectivity over conventional modulation
techniques, solving the traditional design compromise
between range, interference immunity and energy
consumption.
These devices also support high performance (G)FSK modes for systems including WMBus, IEEE802.15.4g. The SX1276/77/78 deliver exceptional phase noise, selectivity, receiver linearity and IIP3 for significantly lower current consumption than competing devices. GENERAL DESCRIPTION
sx1276_ag.pdf
3.02 MB, 下載次數(shù): 29, 下載積分: 黑幣 -5
ID:786424 發(fā)表于 2020-6-23 08:47 | 顯示全部樓層
謝謝分享~~~!
ID:718725 發(fā)表于 2020-6-26 20:53 | 顯示全部樓層
謝謝!!!!!
主站蜘蛛池模板: 免费黄色片视频 | 国产黄色免费网站 | 三上悠亚一区二区 | 超碰99在线 | 日本人の夫妇交换 | www.97超碰| 色哟哟一区二区 | 日本在线免费视频 | 国产视频一区二区在线 | 大桥未久在线视频 | 欧美一级淫片bbb一84 | 天天干b| 四色永久访问 | 国产精品aaa| 黄色免费观看视频 | 成年在线观看 | 少妇高潮久久久久久潘金莲 | 97精品在线视频 | www.com国产| 九月色婷婷 | 性视频在线 | 麻豆chinese新婚xxx | 精品久久影院 | 久久精品2 | 国产精品99精品久久免费 | 天堂成人在线 | 亚洲午夜视频 | 男人天堂2020 | 欧美日韩在线视频观看 | 黄色xxxxx| 一级片国产 | 日韩av在线免费播放 | 国产精品欧美日韩 | 日日日操操操 | 国产成人在线视频 | 久久视频免费观看 | 久久国产精 | 亚洲欧美日韩综合 | 国产黄视频在线观看 | 亚洲精品一区二区三区精华液 | 在线观看av不卡 |
