查看: 17868|回復(fù): 33
stm32f103ADC測試程序,16路ADC采樣+DMA傳送數(shù)據(jù)
ID:349802 發(fā)表于 2018-6-11 20:56 | 只看該作者 回帖獎勵 |倒序?yàn)g覽 |閱讀模式
#include "adc.h"
#include "delay.h"
16路ADC采樣DMA傳輸
調(diào)用Adc_Init()函數(shù)初始化設(shè)備,ADC循環(huán)采樣
數(shù)據(jù)被DMA搬運(yùn)到ADC_Value[ADC_CH_NUM]數(shù)組中
濾波后的數(shù)據(jù)在ADC_AfterFilter[ADC_CH_NUM]中
u16 ADC_Value[ADC_CH_NUM] = {0};
u16 ADC_AfterFilter[ADC_CH_NUM] = {0};
void  Adc_Init(void)
        ADC_InitTypeDef ADC_InitStructure;
  DMA_InitTypeDef  DMA_InitStructure;
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA |RCC_APB2Periph_GPIOB|
        RCC_APB2Periph_GPIOC|RCC_APB2Periph_ADC1,ENABLE );          //使能ADC1通道時鐘
  RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA1,ENABLE);
        RCC_ADCCLKConfig(RCC_PCLK2_Div6);   //設(shè)置ADC分頻因子6 72M/6=12,ADC最大時間不能超過14M
        //PA1-PA7 作為模擬通道輸入引腳
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|
                                        GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7;
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AIN;                //模擬輸入引腳
        GPIO_Init(GPIOA, &GPIO_InitStructure);
                //PC4-C5 作為模擬通道輸入引腳
        GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5;
        GPIO_Init(GPIOC, &GPIO_InitStructure);
                        //PB0-B1 作為模擬通道輸入引腳
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0|GPIO_Pin_1;
        GPIO_Init(GPIOB, &GPIO_InitStructure);
  /* DMA channel1 configuration */
DMA_DeInit(DMA1_Channel1);
/*定義DMA外設(shè)基地址,即為存放轉(zhuǎn)換結(jié)果的寄存器*/
DMA_InitStructure.DMA_PeripheralBaseAddr =(u32)&(ADC1->DR);
/*定義內(nèi)存基地址*/
DMA_InitStructure.DMA_MemoryBaseAddr =(u32)ADC_Value;
/*定義AD外設(shè)作為數(shù)據(jù)傳輸?shù)膩碓?/
DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralSRC;
/*指定DMA通道的DMA緩存的大小,即需要開辟幾個內(nèi)存空間,由ADC_CH_NUM這個宏決定*/
DMA_InitStructure.DMA_BufferSize = ADC_CH_NUM;
        /*設(shè)定寄存器地址固定*/
DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;
/*設(shè)定內(nèi)存地址遞加,即每次DMA都是將該外設(shè)寄存器中的值傳到開辟的內(nèi)存空間中*/
DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;
/*設(shè)定外設(shè)數(shù)據(jù)寬度 半字*/
DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord;
        /*設(shè)定內(nèi)存的的寬度 半字*/
DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord;
        /*設(shè)定DMA工作再循環(huán)緩存模式*/
DMA_InitStructure.DMA_Mode = DMA_Mode_Circular;
/*設(shè)定DMA選定的通道軟件優(yōu)先級*/
DMA_InitStructure.DMA_Priority = DMA_Priority_High;
DMA_InitStructure.DMA_M2M = DMA_M2M_Disable;
DMA_Init(DMA1_Channel1, &DMA_InitStructure);
/* Enable DMA channel1 */
DMA_Cmd(DMA1_Channel1, ENABLE);
        ADC_DeInit(ADC1);  //復(fù)位ADC1
        ADC_InitStructure.ADC_Mode = ADC_Mode_Independent;        //ADC工作模式:ADC1和ADC2工作在獨(dú)立模式
        ADC_InitStructure.ADC_ScanConvMode = ENABLE ;        //模數(shù)轉(zhuǎn)換工作在掃描模式
        ADC_InitStructure.ADC_ContinuousConvMode = ENABLE ;        //模數(shù)轉(zhuǎn)換工作在連續(xù)轉(zhuǎn)換模式
        ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_None;        //轉(zhuǎn)換由軟件而不是外部觸發(fā)啟動
        ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right;        //ADC數(shù)據(jù)右對齊
        ADC_InitStructure.ADC_NbrOfChannel = ADC_CH_NUM;        //順序進(jìn)行規(guī)則轉(zhuǎn)換的ADC通道的數(shù)目
        ADC_Init(ADC1, &ADC_InitStructure);        //根據(jù)ADC_InitStruct中指定的參數(shù)初始化外設(shè)ADCx的寄存器
        /*ADC通道編號*/
        ADC_RegularChannelConfig(ADC1, ADC_Channel_0, 1, ADC_SampleTime_55Cycles5);
  ADC_RegularChannelConfig(ADC1, ADC_Channel_1, 2, ADC_SampleTime_55Cycles5);
  ADC_RegularChannelConfig(ADC1, ADC_Channel_2, 3, ADC_SampleTime_55Cycles5);
  ADC_RegularChannelConfig(ADC1, ADC_Channel_3, 4, ADC_SampleTime_55Cycles5);
  ADC_RegularChannelConfig(ADC1, ADC_Channel_4, 5, ADC_SampleTime_55Cycles5);
  ADC_RegularChannelConfig(ADC1, ADC_Channel_5, 6, ADC_SampleTime_55Cycles5);
  ADC_RegularChannelConfig(ADC1, ADC_Channel_6, 7, ADC_SampleTime_55Cycles5);
  ADC_RegularChannelConfig(ADC1, ADC_Channel_7, 8, ADC_SampleTime_55Cycles5);
  ADC_RegularChannelConfig(ADC1, ADC_Channel_8, 9, ADC_SampleTime_55Cycles5);
  ADC_RegularChannelConfig(ADC1, ADC_Channel_9, 10, ADC_SampleTime_55Cycles5);
  ADC_RegularChannelConfig(ADC1, ADC_Channel_10,11, ADC_SampleTime_55Cycles5);
  ADC_RegularChannelConfig(ADC1, ADC_Channel_11,12, ADC_SampleTime_55Cycles5);
  ADC_RegularChannelConfig(ADC1, ADC_Channel_12,13, ADC_SampleTime_55Cycles5);
  ADC_RegularChannelConfig(ADC1, ADC_Channel_13,14, ADC_SampleTime_55Cycles5);
  ADC_RegularChannelConfig(ADC1, ADC_Channel_14,15, ADC_SampleTime_55Cycles5);
  ADC_RegularChannelConfig(ADC1, ADC_Channel_15,16, ADC_SampleTime_55Cycles5);
  ADC_DMACmd(ADC1, ENABLE);
        ADC_Cmd(ADC1, ENABLE);        //使能指定的ADC1
        ADC_ResetCalibration(ADC1);        //使能復(fù)位校準(zhǔn)
        while(ADC_GetResetCalibrationStatus(ADC1));        //等待復(fù)位校準(zhǔn)結(jié)束
        ADC_StartCalibration(ADC1);         //開啟AD校準(zhǔn)
        while(ADC_GetCalibrationStatus(ADC1));         //等待校準(zhǔn)結(jié)束
        ADC_SoftwareStartConvCmd(ADC1, ENABLE);                //使能指定的ADC1的軟件轉(zhuǎn)換啟動功能
16路ADC DMA采樣.zip
382.42 KB, 下載次數(shù): 713, 下載積分: 黑幣 -5
16路ADC
參與人數(shù) 2黑幣 +18 收起 理由
13149688123 + 10 很給力!
是各個環(huán)節(jié) + 8 贊一個!
收藏收藏18 分享淘帖 頂4 踩
ID:340339 發(fā)表于 2018-6-26 13:55 | 只看該作者
正好弄到ADC采樣,可是黑金不夠
ID:374095 發(fā)表于 2018-7-18 15:07 | 只看該作者
正好弄到ADC采樣,可是黑金不夠
ID:376277 發(fā)表于 2018-7-22 17:17 | 只看該作者
不錯,正需要
ID:388992 發(fā)表于 2018-9-28 11:54 | 只看該作者
最近在學(xué)習(xí)ADC DMA多通道采集。搞了好多天還沒有成功。
ID:364557 發(fā)表于 2018-11-6 18:33 | 只看該作者
黑金不夠呀大哥
ID:435528 發(fā)表于 2018-11-29 10:17 | 只看該作者
可以下載..........................................
ID:431123 發(fā)表于 2018-12-24 15:12 | 只看該作者
非常不錯,很有幫助
ID:194625 發(fā)表于 2018-12-26 11:03 | 只看該作者
不錯,可以學(xué)習(xí)下
ID:441972 發(fā)表于 2019-1-16 13:42 | 只看該作者
這個下載下來怎么是ALIENTEK 戰(zhàn)艦STM32F103開發(fā)板實(shí)驗(yàn)17啊?怎么用呀?
ID:349802 發(fā)表于 2019-2-26 16:05 | 只看該作者
jushihao 發(fā)表于 2019-1-16 13:42
這只是工程名字而已,內(nèi)容不一樣啊
ID:479575 發(fā)表于 2019-2-28 08:10 | 只看該作者
謝謝分享!
ID:493236 發(fā)表于 2019-3-20 15:53 | 只看該作者
正好弄到ADC采樣,可是黑金不夠,很需要。。。
ID:265124 發(fā)表于 2019-3-28 23:18 | 只看該作者
真的太需要這個了
ID:387915 發(fā)表于 2019-4-22 21:34 | 只看該作者
你可以改時鐘,IO口大致出不多,改完時鐘應(yīng)該就可以用
ID:387915 發(fā)表于 2019-4-22 21:36 | 只看該作者
學(xué)習(xí)了,感謝分享
ID:527812 發(fā)表于 2019-5-5 17:27 | 只看該作者
正好弄到ADC采樣,可是黑金不夠
ID:85129 發(fā)表于 2019-5-22 14:14 | 只看該作者
這個濾波的程序怎么沒有?
ID:411900 發(fā)表于 2019-7-12 17:40 | 只看該作者
可以用,謝謝樓主!!!
ID:543162 發(fā)表于 2019-7-14 16:47 | 只看該作者
謝謝分享
ID:226089 發(fā)表于 2019-8-12 13:50 | 只看該作者
正好弄到ADC采樣,可是黑金不夠
ID:462389 發(fā)表于 2019-8-19 17:10 | 只看該作者
verygood
ID:269751 發(fā)表于 2019-8-19 18:16 | 只看該作者
mark,謝謝分享
ID:62077 發(fā)表于 2019-8-27 11:09 | 只看該作者
正好弄到ADC采樣,可是黑金不夠
ID:313048 發(fā)表于 2019-9-26 11:28 | 只看該作者
前排留名
ID:261884 發(fā)表于 2019-11-13 12:40 | 只看該作者
正需要,謝謝分享!~
ID:235223 發(fā)表于 2019-11-14 13:11 | 只看該作者
正好弄到ADC采樣,可是黑金不夠
ID:701882 發(fā)表于 2020-3-12 20:15 | 只看該作者
正好弄到ADC采樣,可是黑金不夠
ID:691773 發(fā)表于 2020-5-11 17:45 | 只看該作者
下載之后才發(fā)現(xiàn)沒有
ID:662744 發(fā)表于 2020-7-6 10:19 | 只看該作者
正需要這個,感謝樓主
ID:808538 發(fā)表于 2020-7-27 16:28 | 只看該作者
正好弄到ADC采樣,可是黑金不夠
ID:1010606 發(fā)表于 2022-3-15 15:47 | 只看該作者
ID:333483 發(fā)表于 2022-8-29 15:05 | 只看該作者
試試看,怎么搞。。可以吧readme刪掉。。
ID:1002032 發(fā)表于 2022-10-22 12:58 | 只看該作者
下載的文件哪里用到了DMA呀!怎么還是printf
主站蜘蛛池模板: 欧美69视频 | 久草国产视频 | 男女插插插视频 | 亚洲黄视频 | 欧美在线a | 亚洲国产欧美日韩在线 | 日日操夜夜爽 | 国内精品一区二区三区 | 国产不卡在线观看 | 日本一级淫片色费放 | 色综合久久88色综合天天 | 久草视频免费 | 97国产视频| 一本色道久久综合亚洲精品酒店 | a天堂在线视频 | 青青草手机视频 | 欧美色综合 | 日本国产欧美 | av高清在线观看 | 精品久久久久久久久久久久久久久久 | 一级片免费视频 | 精品少妇一区二区三区免费观 | 亚洲三级黄色片 | 羞羞网站在线观看 | av资源在线 | 久久爱综合| 福利视频1000 | 国产天天操 | 无套内谢的新婚少妇国语播放 | 国产综合亚洲精品一区二 | 九九九视频 | 成人免费在线视频 | 国产a精品| 欧美一区二 | 18色av| 日本色综合 | 午夜精品一区二区三区在线播放 | 日韩精品久久久久久久酒店 | 日韩高清一区二区 | 4438成人网| 18在线观看免费入口 |
