- #include <showfun.h>
- #include <stdio.h>
- extern char fnLCMInit(); // LCM 初始化
- extern void at(unsigned char x,unsigned char y);/*設定文本x,y值*/
- extern void cls(); // 清屏
- extern void charout(unsigned char *str); //ASCII(8*8) 顯示函數
- extern void fnSetPos(unsigned char urow, unsigned char ucol); // 設置當前地址
- extern uchar dprintf(uchar x,uchar y,char *fmt);// ASCII(8*16) 及 漢字(16*16) 顯示函數
- extern uchar fnPR12(uchar uCmd); // 寫無參數的指令
- extern uchar fnPR13(uchar uData); // 寫數據
- extern unsigned int Adc0832(unsigned char channel);
- extern void Line( unsigned char x1, unsigned char y1, unsigned char x2, unsigned char y2, bit Mode);
- extern void Pixel(unsigned char PointX,unsigned char PointY, bit Mode);
- uchar dsp[10]={0,0,0,0,0,0,0,0,0,0,};
- char abc[3]={0,0,0,};
- uchar key=0;
- uint a=100;
- uchar n=5;
- uchar count=1;
- uint k1=0;
- uchar GeyKey();
- void delay(uchar i);
- void control();
- main()
- fnLCMInit();
- fnSetPos(0,0);
- dprintf(0,0,"直流電機加-減速及測速系統");
- dprintf(0,12,"鍵盤+:步長加速");
- dprintf(0,24,"鍵盤-:步長減速");
- dprintf(0,36,"鍵盤=:順時針轉");
- dprintf(0,48,"鍵盤on/c:逆時針轉");
- dprintf(0,72,"方向:");
- dprintf(0,84,"轉速:");
- P1_1=0;
- TMOD=0x15;
- TH1=0x3c;
- TL1=0xb0;
- TH0=0x00;
- TL0=0x00;
- ET0=1;
- ET1=1;
- TR0=1;
- TR1=1;
- while(1)
- { key=GeyKey();
- switch(key)
- { case '1': { a=10;
- //sprintf(abc,"%3.2f",a/255.0);
- dprintf(0,96," 5 r/min");
- //dprintf(0,96,abc);
- dprintf(60,96,"r/min");
- break; }
- case '2': { a=25;dprintf(0,96," 25 r/min"); break; }
- case '3': { a=40; dprintf(0,96," 40 r/min"); break; }
- case '4': { a=55; dprintf(0,96," 60 r/min"); break; }
- case '5': { a=70; dprintf(0,96," 80 r/min"); break; }
- case '6': { a=90; dprintf(0,96,"100 r/min"); break; }
- case '7': { a=110; dprintf(0,96,"120 r/min"); break; }
- case '8': { a=130; dprintf(0,96,"135 r/min"); break; }
- case '9': { a=150; dprintf(0,96,"150 r/min"); break; }
- case '+': { dprintf(0,72,"方向: 順時針");
- control();
- break;
- case '-': { P1_0=0;
- dprintf(0,72,"方向: 逆時針");
- control();
- break;
- case '=': {P1_0=1;dprintf(0,72,"方向: 順時針");break;}
- case 'c': {P1_0=0;dprintf(0,72,"方向: 逆時針");break;}
- case '/': {dprintf(0,72,"方向: 順時針");
- control();}
- default: break;
- uchar GeyKey()
- P1_4=0;
- P1_5=1;
- P1_6=1;
- P1_7=1;
- P3_0=1;
- P3_1=1;
- P3_2=1;
- P3_3=1;
- _nop_();_nop_();
- if(!P3_0)return '7';
- if(!P3_1)return '8';
- if(!P3_2)return '9';
- if(!P3_3)return '/';
- P1_4=1;
- P1_5=0;
- P1_6=1;
- P1_7=1;
- _nop_();_nop_();
- if(!P3_0)return '4';
- if(!P3_1)return '5';
- if(!P3_2)return '6';
- if(!P3_3)return '*';
- P1_4=1;
- P1_5=1;
- P1_6=0;
- P1_7=1;
- _nop_();_nop_();
- if(!P3_0)return '1';
- if(!P3_1)return '2';
- if(!P3_2)return '3';
- if(!P3_3)return '-';
- P1_4=1;
- P1_5=1;
- P1_6=1;
- P1_7=0;
- _nop_();_nop_();
- if(!P3_0)return 'c';
- if(!P3_1)return '0';
- if(!P3_2)return '=';
- if(!P3_3)return '+';
- return 0;
- { uchar j,k;
- for(;i>0;i--)
- for(j=15;j>0;j--)
- for(k=11;k>0;k--);
- void time()interrupt 3
- TR1=0;
- count++;
- k1+=TL0;
- if(count==51)
- sprintf(dsp,"%3d",k1);
- dprintf(0,108,dsp);
- dprintf(60,108,"r/min");
- count=1;
- k1=0;
- TH1=0x3c;
- TL1=0xb0;
- TH0=0x00;
- TL0=0x00;
- TR1=1;
- void control()
- EA=1;
- while(1)
- { if(a>=150)
- a=150;
- if(a<=10)
- a=10;
- P1_1=0;
- delay(160-a);
- P1_1=1;
- delay(a);
- key=GeyKey();
- if(key=='-') a-=n;
- else
- if(key=='+') a+=n;
PWM直流電機測速 中文液晶顯示.zip
(101.18 KB, 下載次數: 29)
2018-6-28 07:49 上傳
點擊文件名下載附件
源程序+仿真文件
