查看: 4610|回復(fù): 2
KEA128直立小車源碼
ID:362383 發(fā)表于 2018-6-30 18:10 | 顯示全部樓層 |閱讀模式
kea128的庫(kù)
單片機(jī)源程序如下:
  1. #include "headfile.h"
  2. /*系統(tǒng)變量初始化部分*/
  3. void PIDStructurePointerInit(PID_Type_Def *PID_Balance, PID_Type_Def *PID_Speed, PID_Type_Def *PID_Path, PID_Type_Def *PID_Diff ){ //PID初始值給定
  4.   PID_Balance->Kp = 8;
  5.   PID_Balance->Kd = 1.2;
  6.   PID_Balance->out = 0;
  7.
  8.   PID_Speed->Kp = 10;
  9.   PID_Speed->Ki = 0.05;
  10.   PID_Speed->out   = 0;
  11.
  12.   PID_Path->Kp = 2.0;
  13.   PID_Path->Kd = 0.0;
  14.   PID_Path->offset = 1.0;
  15.   PID_Path->out    = 0;
  16.
  17.   PID_Diff->Kp = 15.0;
  18.   PID_Diff->Kd = 2.0;
  19.   PID_Diff->Ki = 0.0;
  20.
  21.   PID_Diff->offset = 0.35;
  22.   PID_Diff->out    = 0;
  23.
  24.   for(uint8 n=0; n<10; n++){
  25.
  26.     PID_Balance->err_k[n] = 0;
  27.     PID_Speed->err_k[n]   = 0;
  28.     PID_Path->err_k[n]    = 0;
  29.     PID_Diff->err_k[n]    = 0;
  30.     PID_Speed->out_k[n]   = 0;
  31.   };
  32.
  33. };
  34. void SensorStructurePointerInit(Acc_Type_Def *Acc, Gyro_Type_Def *Gyro, Angle_Type_Def *Angle, Speed_Type_Def *Speed, Inductor_Type_Def *InductorA, Inductor_Type_Def *InductorB){ //結(jié)構(gòu)體指針初始化成員
  35.
  36.   /*Gyro*/
  37.   Gyro->X_Final=0;
  38.   Gyro->X_Offset=0;
  39.   Gyro->X_Value[0]=0;
  40.   Gyro->X_Value[1]=0;
  41.   Gyro->X_Value[2]=0;
  42.   Gyro->Z_Final=0;
  43.   Gyro->Z_Offset=0;
  44.   Gyro->Z_Value[0]=0;
  45.   Gyro->Z_Value[1]=0;
  46.   Gyro->Z_Value[2]=0;
  47.
  48.   InductorA->LeftFinal=0;
  49.   InductorA->RightFinal=0;
  50.   InductorA->LeftValue[0]=0;
  51.   InductorA->LeftValue[1]=0;
  52.   InductorA->LeftValue[2]=0;
  53.
  54.   InductorB->LeftFinal=0;
  55.   InductorB->RightFinal=0;
  56.   InductorB->LeftValue[0]=0;
  57.   InductorB->LeftValue[1]=0;
  58.   InductorB->LeftValue[2]=0;
  59.   //角度目標(biāo)值  也就是平衡值  沒(méi)有轉(zhuǎn)換成角度值 但是是線性關(guān)系。
  60.   Angle->PiontValue = 2300;
  61.
  62.   //速度目標(biāo)值  沒(méi)有轉(zhuǎn)換成真實(shí)速度  與速度線性關(guān)系
  63.   Speed->PiontSpeed = 2000;
  64.
  65.   Speed->PiontSpeedMax=5000;
  66.   Speed->PiontSpeedMin=1500;
  67.
  68.
  69.
  70.   //此處應(yīng)照車放在賽道上 電感在導(dǎo)線正上方 最大值 電感離導(dǎo)線最遠(yuǎn)點(diǎn)為最小值
  71.   InductorA->LeftMax  = 1200;
  72.   InductorA->LeftMin  = 125;
  73.   InductorA->RightMax = 1200;
  74.   InductorA->RightMin = 125;
  75.
  76.
  77.   InductorB->LeftMax = 1200;
  78.   InductorB->LeftMin = 125;
  79.   InductorB->RightMax = 1200;
  80.   InductorB->RightMin = 125;
  81.
  82.
  83. };
  84. void CarBalanceSystemInit(Gyro_Type_Def *Gyro){//系統(tǒng)初始化
  85.
  86.   //uart_init(UART1,9600);
  87.   gpio_init(H2,GPO,1);
  88.
  89.   //關(guān)于ADC管腳接的東西 在headfile.h里有定義
  90.   adc_init(ADC0_SE0);
  91.   adc_init(ADC0_SE1);
  92.   adc_init(ADC0_SE2);
  93.   adc_init(ADC0_SE3);
  94.   adc_init(ADC0_SE4);
  95.   adc_init(ADC0_SE5);
  96.   adc_init(ADC0_SE6);
  97.   adc_init(ADC0_SE7);
  98.
  99.   adc_init(ADC0_SE8);
  100.   adc_init(ADC0_SE9);
  101.   adc_init(ADC0_SE10);
  102.   adc_init(ADC0_SE11);
  103.   adc_init(ADC0_SE12);
  104.   adc_init(ADC0_SE13);
  105.   adc_init(ADC0_SE14);
  106.   adc_init(ADC0_SE15);
  107.
  108.
  109.
  110.   OLED_Init();
  111.
  112.   OLED_ShowString(0,0,"SysInit Finish!");
  113.   OLED_ShowString(0,16,"Car balance2.0V");
  114.   OLED_Refresh_Gram();
  115.   // 使用數(shù)字陀螺儀  要初始化IIC
  116.   //IIC_init();
  117.
  118.
  119.   //此處陀螺儀中值獲取很重要   不過(guò)數(shù)字陀螺儀默認(rèn)就是中值 無(wú)需獲取
  120.   // 如果數(shù)字陀螺儀中值為0  那么  此處 直接賦值0即可
  121.   Gyro->Z_Offset = adc_once(ADC0_SE2, ADC_12bit);
  122.   Gyro->X_Offset = adc_once(ADC0_SE3, ADC_12bit);
  123.
  124.
  125.   systick_delay_ms(10);
  126.   //左電機(jī)
  127.   ftm_pwm_init(ftm2,ftm_ch2,13000,0);
  128.   ftm_pwm_init(ftm2,ftm_ch3,13000,0);
  129.
  130.   //右電機(jī)
  131.   ftm_pwm_init(ftm2,ftm_ch4,13000,0);
  132.   ftm_pwm_init(ftm2,ftm_ch5,13000,0);
  133.
  134.   systick_delay_ms(10);
  135.
  136.   //ftm的計(jì)數(shù)引腳可查看KEA128_port_cfg.h文件內(nèi)的FTM0_COUNT_PIN與FTM1_COUNT_PIN的宏定義得知
  137.   //一個(gè)ftm同一時(shí)間只能實(shí)現(xiàn)一種功能,如果用于測(cè)速就不能用于輸出PWM
  138.   ///////////////////////////////////////////////////////////////////////////////////////////////
  139.   ftm_count_init(ftm0);   //對(duì)E0引腳輸入的脈沖進(jìn)行計(jì)數(shù)    E0接編碼器LSB
  140.   gpio_init(E1,GPI,0);    //用于判斷方向                  C5接編碼器DIR
  141.   port_pull(E1);          //IO上拉
  142.
  143.   ftm_count_init(ftm1);   //對(duì)E7引腳輸入的脈沖進(jìn)行計(jì)數(shù)    E7接編碼器LSB
  144.   gpio_init(H6,GPI,0);    //用于判斷方向                  H5接編碼器DIR
  145.   port_pull(H6);          //IO上拉
  146.   //////////////////////////////////////////////////////////////////////////////////////////////
  147.   //定時(shí)器中斷
  148.   pit_init(pit0,0x9000);//1.539ms
  149.
  150.   systick_delay_ms(10);
  151.
  152.
  153. };
  154. //絕對(duì)值函數(shù)   必須要取地址放入形參
  155. void AbsoluteValue(float *Value, float *Return){
  156.
  157.   if( (*Value) <0) (*Return) = -1*(*Value);
  158.   else *Value = *Return;
  159. }
  160. /*原始數(shù)據(jù)獲取部分*/
  161. void GetAccelerationValue(Acc_Type_Def *Acc){ //獲取ACC原始數(shù)據(jù)
  162.
  163.   Acc->Z_Value[0] = Acc->Z_Value[1];
  164.   Acc->Z_Value[1] = Acc->Z_Value[2];
  165.   Acc->Z_Value[2] = ACC_Z;//本句是獲取當(dāng)前加速度  上兩句都是 上次值和上上次值
  166.   //利用多次值進(jìn)行濾波  參數(shù)自行調(diào)整看效果
  167.   Acc->Z_Final = 0.33*Acc->Z_Value[2]+0.33*Acc->Z_Value[1]+0.33*Acc->Z_Value[0];
  168.
  169. };
  170. void GetAngleSpeedValue(Gyro_Type_Def *Gyro){  //獲取Gyro原始數(shù)據(jù)
  171.
  172.   Gyro->Z_Value[0] = Gyro->Z_Value[1];
  173.   Gyro->Z_Value[1] = Gyro->Z_Value[2];
  174.   Gyro->Z_Value[2] = GYRO_Z - Gyro->Z_Offset;//如果是數(shù)字陀螺儀請(qǐng)給Gyro->Z_Offset賦值  在初始化的時(shí)候
  175.
  176.   Gyro->X_Value[0] = Gyro->X_Value[1]; //前前次
  177.   Gyro->X_Value[1] = Gyro->X_Value[2]; //前次
  178.   Gyro->X_Value[2] = GYRO_X - Gyro->X_Offset; //本次
  179.
  180.
  181. };
  182. void GetInductorValue(Inductor_Type_Def *InductorA, Inductor_Type_Def *InductorB){ //獲取inductor原始數(shù)據(jù)
  183.
  184.
  185.   InductorA->LeftValue[0] = InductorA->LeftValue[1];
  186.   InductorA->LeftValue[1] = InductorA->LeftValue[2];
  187.   InductorA->LeftValue[2] = L1;//本句是獲取當(dāng)前電感值  L1在haedfile.h文件中有定義
  188.
  189.   InductorA->RightValue[0] = InductorA->RightValue[1];
  190.   InductorA->RightValue[1] = InductorA->RightValue[2];
  191.   InductorA->RightValue[2] = L2;//本句是獲取當(dāng)前電感值  L2在haedfile.h文件中有定義
  192.
  193.   InductorB->LeftValue[0] = InductorB->LeftValue[1];
  194.   InductorB->LeftValue[1] = InductorB->LeftValue[2];
  195.   InductorB->LeftValue[2] = L3;//本句是獲取當(dāng)前電感值  L3在haedfile.h文件中有定義
  196.   InductorB->RightValue[0] = InductorB->RightValue[1];
  197.   InductorB->RightValue[1] = InductorB->RightValue[2];
  198.   InductorB->RightValue[2] = L4;//本句是獲取當(dāng)前電感值  L4在haedfile.h文件中有定義
  199.
  200.
  201. };
  202. void GetSpeedValue(Speed_Type_Def *Speed){ //獲取Speed原始數(shù)據(jù)
  203.
  204.
  205.   for(uint8 n=0; n<15 ; n++){  //循環(huán)誤差保存
  206.
  207.     //存儲(chǔ)前14次的值
  208.     Speed->ActualLiftPulse[n] = Speed->ActualLiftPulse[n+1]; //0~14位賦值
  209.
  210.     if( n==14 ){ //當(dāng)前值 15次  最新值
  211.       Speed->ActualLiftPulse[n+1] = ftm_count_get(ftm1)*(-1); //本次 15位賦值
  212.
  213.       ftm_count_clean(ftm1);  //清除ftm1計(jì)數(shù)值
  214.     }//此處一定要修改好 根據(jù)你們實(shí)際的硬件  對(duì)應(yīng)好左右輪子  因?yàn)榫幋a器是對(duì)著安裝的  那么
  215.     //在車子往前走的時(shí)候  左右是相反的  所以要把其中一個(gè)負(fù)值編碼器變?yōu)檎?br />
  216.     //兩個(gè)電機(jī)存在同樣的問(wèn)題  都是對(duì)著安裝的
  217.   }
  218.
  219.
  220.
  221.   for(uint8 n=0; n<15 ; n++){  //循環(huán)保存
  222.
  223.     Speed->ActualRightPulse[n] = Speed->ActualRightPulse[n+1]; //0~14位賦值
  224.
  225.     if( n==14 ){
  226.       Speed->ActualRightPulse[n+1] = ftm_count_get(ftm0);  //本次 15位賦值
  227.       ftm_count_clean(ftm0);  //清除ftm0計(jì)數(shù)值
  228.     }
  229.
  230.   }
  231.   if(gpio_get(H6)) //檢測(cè) ftm1的轉(zhuǎn)向   H6  E1是針對(duì)左右編碼器的  要弄清楚 不要到時(shí)候改過(guò)以后
  232.     //左邊編碼器的方向  去控制右邊編碼器的 正負(fù)號(hào)   那就完蛋了
  233.     Speed->ActualLiftPulse[15] = Speed->ActualLiftPulse[15];
  234.   else
  235.     Speed->ActualLiftPulse[15] = -Speed->ActualLiftPulse[15];
  236.
  237.
  238.   if(gpio_get(E1))  //檢測(cè) ftm0的轉(zhuǎn)向
  239.     Speed->ActualRightPulse[15] = Speed->ActualRightPulse[15];
  240.   else
  241.     Speed->ActualRightPulse[15] = -Speed->ActualRightPulse[15]; //這個(gè)負(fù)號(hào)取決于你車向前走時(shí)  編碼器值是否為正
  242.
  243. };
  244. void GetButtonStatus(Button_Type_Def *Button){ //Button原始數(shù)據(jù)獲取
  245.
  246.   Button->Up[0] = Button->Up[1];
  247.   Button->Up[1] = Button->Up[2];
  248.   Button->Up[2] = Button->Up[3];
  249.   Button->Up[3] = Button->Up[4];
  250.   Button->Up[4] = UP;//第四次是最新的值  按鍵值  在haedfile.h文件中有定義
  251.
  252.   Button->Down[0] = Button->Down[1];
  253.   Button->Down[1] = Button->Down[2];
  254.   Button->Down[2] = Button->Down[3];
  255.   Button->Down[3] = Button->Down[4];
  256.   Button->Down[4] = DOWN;//第四次是最新的值  按鍵值  在haedfile.h文件中有定義
  257.
  258.   Button->Life[0] = Button->Life[1];
  259.   Button->Life[1] = Button->Life[2];
  260.   Button->Life[2] = Button->Life[3];
  261.   Button->Life[3] = Button->Life[4];
  262.   Button->Life[4] = LIFE;//第四次是最新的值  按鍵值  在haedfile.h文件中有定義
  263.
  264.   Button->Right[0] = Button->Right[1];
  265.   Button->Right[1] = Button->Right[2];
  266.   Button->Right[2] = Button->Right[3];
  267.   Button->Right[3] = Button->Right[4];
  268.   Button->Right[4] = RIGHT;//第四次是最新的值  按鍵值  在haedfile.h文件中有定義
  269.
  270.   Button->Enter[0] = Button->Enter[1];
  271.   Button->Enter[1] = Button->Enter[2];
  272.   Button->Enter[2] = Button->Enter[3];
  273.   Button->Enter[3] = Button->Enter[4];
  274.   Button->Enter[4] = ENTER;//第四次是最新的值  按鍵值  在haedfile.h文件中有定義
  275. };
  276. void GetSwitchStatus(Switch_Type_Def *Switch){ //開(kāi)關(guān)原始數(shù)據(jù)獲取
  277.
  278.   Switch->Bm1[0] = Switch->Bm1[1];
  279.   Switch->Bm1[1] = Switch->Bm1[2];
  280.   Switch->Bm1[2] = SW1; //撥碼開(kāi)關(guān)  第四次是最新的值  在haedfile.h文件中有定義
  281.
  282.   Switch->Bm2[0] = Switch->Bm2[1];
  283.   Switch->Bm2[1] = Switch->Bm2[2];
  284.   Switch->Bm2[2] = SW2; //撥碼開(kāi)關(guān)  第四次是最新的值  在haedfile.h文件中有定義
  285.
  286.   Switch->Bm3[0] = Switch->Bm3[1];
  287.   Switch->Bm3[1] = Switch->Bm3[2];
  288.   Switch->Bm3[2] = SW3; //撥碼開(kāi)關(guān)  第四次是最新的值  在haedfile.h文件中有定義
  289.
  290.   Switch->Bm4[0] = Switch->Bm4[1];
  291.   Switch->Bm4[1] = Switch->Bm4[2];
  292.   Switch->Bm4[2] = SW4; //撥碼開(kāi)關(guān)  第四次是最新的值  在haedfile.h文件中有定義
  293.   Switch->Bm5[0] = Switch->Bm5[1];
  294.   Switch->Bm5[1] = Switch->Bm5[2];
  295.   Switch->Bm5[2] = SW5; //撥碼開(kāi)關(guān)  第四次是最新的值  在haedfile.h文件中有定義
  296.
  297.   Switch->Bm6[0] = Switch->Bm6[1];
  298.   Switch->Bm6[1] = Switch->Bm6[2];
  299.   Switch->Bm6[2] = SW6; //撥碼開(kāi)關(guān)  第四次是最新的值  在haedfile.h文件中有定義
  300. };
  301. /*原始數(shù)據(jù)處理部分*/
  302. void GyroHighPassFilter(Gyro_Type_Def *Gyro){ //Gyro濾波
  303.   float K =0.58;//權(quán)值濾波  看情況調(diào)節(jié)
  304.
  305.   Gyro->Z_Value[2] = K * Gyro->Z_Value[2] +  (1-K) * Gyro->Z_Value[1];
  306.
  307.   Gyro->Z_Final = Gyro->Z_Value[2];
  308.   Gyro->X_Value[2] = K * Gyro->X_Value[2] +  (1-K) * Gyro->X_Value[1];
  309.
  310.   Gyro->X_Final = Gyro->X_Value[2];
  311.
  312.   //權(quán)值濾波 去除高頻干擾
  313. };
  314. void AngleHardwareFilter(Angle_Type_Def *Angle){ //角度濾波
  315.   //本函數(shù)是直接采集角度的  只有模擬陀螺儀和加速度計(jì)進(jìn)行硬件融合直接解算角度值
  316.
  317.   Angle->ActualValue[0] = Angle->ActualValue[1];
  318.   Angle->ActualValue[1] = Angle->ActualValue[2];
  319.   Angle->ActualValue[2] = ANGLE; //此處是獲取 最新角度值
  320.
  321.   //濾波 Angle->FinalValue為最終值
  322.   Angle->FinalValue = 0.6*Angle->ActualValue[2] + 0.2*Angle->ActualValue[1] + 0.2*Angle->ActualValue[0];
  323.
  324. };
  325. void AngleSoftwareFilter(Acc_Type_Def *Acc, Gyro_Type_Def *Gyro , Angle_Type_Def *Angle){//角度濾波
  326. //本函數(shù)是適用于數(shù)字陀螺儀 通過(guò)軟件互補(bǔ)融合濾波解算角度
  327.
  328.   Acc->Z_Final = 0.9*Acc->Z_Value[2] + 0.05*Acc->Z_Value[1] + 0.05*Acc->Z_Value[0];//權(quán)值低通濾波
  329.
  330.   Gyro->Z_Final = 0.92*Gyro->Z_Value[2] + 0.05*Gyro->Z_Value[1] + 0.03*Gyro->Z_Value[0];//權(quán)值低通濾波
  331.
  332.   //加速度  角速度采集
  333.
  334.
  335.   //此處參數(shù)需要根據(jù)  清華方案里的方法去調(diào)節(jié)參數(shù)  看波形法
  336.   Angle->FinalValue = 0.92*(Angle->FinalValue + 0.05*Gyro->Z_Final) + 0.08*(Acc->Z_Final);//融合濾波
  337.
  338. };
  339. void InductorSoftwareFilter(Inductor_Type_Def *InductorA, Inductor_Type_Def *InductorB, Angle_Type_Def *Angle, Switch_Type_Def *Switch){//電感值歸一濾波
  340.   /*權(quán)值濾波 警告無(wú)視  */
  341.   InductorA->LeftFinal = 0.8*InductorA->LeftValue[2] + 0.15*InductorA->LeftValue[1] + 0.05*InductorA->LeftValue[0];//-InductorA->LeftMin;
  342.   InductorA->RightFinal = 0.8*InductorA->RightValue[2] + 0.15*InductorA->RightValue[1] + 0.05*InductorA->RightValue[0];//-InductorA->RightMin;
  343.
  344.   InductorB->LeftFinal = 0.8*InductorB->LeftValue[2] + 0.15*InductorB->LeftValue[1] + 0.05*InductorB->LeftValue[0];
  345.   InductorB->RightFinal = 0.8*InductorB->RightValue[2] + 0.15*InductorB->RightValue[1] + 0.05*InductorB->RightValue[0];
  346.   /*數(shù)據(jù)歸一化到0~1000*/
  347.   InductorA->LeftFinal  =  1000*( (float)(InductorA->LeftFinal-InductorA->LeftMin)/(InductorA->LeftMax-InductorA->LeftMin) );
  348.   InductorA->RightFinal  = 1000*( (float)(InductorA->RightFinal-InductorA->RightMin)/(InductorA->RightMax-InductorA->RightMin) );
  349.
  350.   InductorB->LeftFinal  =  1000*( (float)(InductorB->LeftFinal-InductorB->LeftMin)/(InductorB->LeftMax-InductorB->LeftMin) );
  351.   InductorB->RightFinal  = 1000*( (float)(InductorB->RightFinal-InductorB->RightMin)/(InductorB->RightMax-InductorB->RightMin) );
  352.
  353.   if(InductorA->LeftFinal>999)InductorA->LeftFinal=999;
  354.   if(InductorA->LeftFinal<  0)InductorA->LeftFinal=  0;
  355.   if(InductorA->RightFinal>999)InductorA->RightFinal=999;
  356.   if(InductorA->RightFinal< 0)InductorA->RightFinal=   0;
  357.
  358.
  359.   if(InductorB->LeftFinal>999)InductorB->LeftFinal=999;
  360.   if(InductorB->LeftFinal<  0)InductorB->LeftFinal=  0;
  361.   if(InductorB->RightFinal>999)InductorB->RightFinal=999;
  362.   if(InductorB->RightFinal< 0)InductorB->RightFinal=   0;
  363.
  364.   //電感AB  A 是靠外側(cè)的電感  B是靠?jī)?nèi)側(cè)電感    RL就是左右
  365.
  366.   InductorA->AndValues = InductorA->LeftFinal+InductorA->RightFinal;//電感和值
  367.
  368.   InductorA->LeftDerivative = InductorA->LeftValue[2] - InductorA->LeftValue[0]; //左點(diǎn)感變化率
  369.
  370.   InductorA->RightDerivative= InductorA->RightValue[2] - InductorA->RightValue[0];//右電感變化率
  371.
  372.   InductorB->LeftDerivative = InductorB->LeftValue[2] - InductorB->LeftValue[0];
  373.
  374. };
  375. void SpeedSoftwareFilter(Speed_Type_Def *Speed){   //速度低通濾波
  376.
  377.   /*警告無(wú)視*/
  378.   Speed->ActualLiftPulse[15]=0.33*Speed->ActualLiftPulse[15] + 0.33*Speed->ActualLiftPulse[14] + 0.33*Speed->ActualLiftPulse[13];
  379.   Speed->ActualRightPulse[15]=0.33*Speed->ActualRightPulse[15] + 0.33*Speed->ActualRightPulse[14] + 0.33*Speed->ActualRightPulse[13];
  380.   // 6 2 2
  381.
  382.   //實(shí)際速度 = R+L
  383.   Speed->ActualSpeed[0] = Speed->ActualSpeed[1];
  384.   Speed->ActualSpeed[1] = Speed->ActualSpeed[2];
  385.   Speed->ActualSpeed[2] =
  386.     (Speed->ActualRightPulse[0]+Speed->ActualLiftPulse[0])+
  387.     (Speed->ActualRightPulse[1]+Speed->ActualLiftPulse[1])+
  388.     (Speed->ActualRightPulse[2]+Speed->ActualLiftPulse[2])+
  389.     (Speed->ActualRightPulse[3]+Speed->ActualLiftPulse[3])+
  390.     (Speed->ActualRightPulse[4]+Speed->ActualLiftPulse[4])+
  391.     (Speed->ActualRightPulse[5]+Speed->ActualLiftPulse[5])+
  392.     (Speed->ActualRightPulse[6]+Speed->ActualLiftPulse[6])+
  393.     (Speed->ActualRightPulse[7]+Speed->ActualLiftPulse[7])+
  394.     (Speed->ActualRightPulse[8]+Speed->ActualLiftPulse[8])+
  395.     (Speed->ActualRightPulse[9]+Speed->ActualLiftPulse[9])+
  396.     (Speed->ActualRightPulse[10]+Speed->ActualLiftPulse[10])+
  397.     (Speed->ActualRightPulse[11]+Speed->ActualLiftPulse[11])+
  398.     (Speed->ActualRightPulse[12]+Speed->ActualLiftPulse[12])+
  399.     (Speed->ActualRightPulse[13]+Speed->ActualLiftPulse[13])+
  400.     (Speed->ActualRightPulse[14]+Speed->ActualLiftPulse[14])+
  401.     (Speed->ActualRightPulse[15]+Speed->ActualLiftPulse[15]);
  402.
  403.   //濾波
  404.   Speed->ActualSpeed[2] = 0.85*Speed->ActualSpeed[2]+0.1*Speed->ActualSpeed[1]+0.05*Speed->ActualSpeed[0];
  405.   //7 2 1
  406.
  407.
  408.   //實(shí)際差速  = L-R
  409.   Speed->ActualDifferential[0] = Speed->ActualDifferential[1];
  410.   Speed->ActualDifferential[1] = Speed->ActualDifferential[2];
  411.   Speed->ActualDifferential[2] = Speed->ActualLiftPulse[15]-Speed->ActualRightPulse[15];
  412.   Speed->ActualDifferential[2] = 0.8*Speed->ActualDifferential[2]+0.15*Speed->ActualDifferential[1]+0.05*Speed->ActualDifferential[0];
  413.   //實(shí)際差速
  414.
  415.
  416.   Speed->ActualInstantaneous[0] = Speed->ActualInstantaneous[1];
  417.   Speed->ActualInstantaneous[1] = Speed->ActualInstantaneous[2];
  418.   Speed->ActualInstantaneous[2] = (Speed->ActualLiftPulse[15]+Speed->ActualRightPulse[15] + (Speed->ActualLiftPulse[14]+Speed->ActualRightPulse[14])) ;
  419.   //瞬時(shí)速度計(jì)算
  420.
  421.   Speed->ActualAcceleration = Speed->ActualInstantaneous[2] - Speed->ActualInstantaneous[0];
  422.   //加速度計(jì)算
  423.
  424.
  425.
  426. };
  427. void ButtonLowPassFilter(Button_Type_Def *Button){ //按鍵低通濾波
  428.
  429.   Button->Up_Final = Button->Up[0] || Button->Up[1] || Button->Up[2] || Button->Up[3] || Button->Up[4];
  430.   //有一個(gè)1  最終值就是1 全部為0 最終值才為0
  431.   if(Button->Up_Final==1) Button->Up_Final = 0;//取反    以1為有效值
  432.   else Button->Up_Final = 1;
  433.
  434.
  435.   Button->Down_Final = Button->Down[0] || Button->Down[1] || Button->Down[2] || Button->Down[3] || Button->Down[4];
  436.   //有一個(gè)1  最終值就是1 全部為0 最終值才為0
  437.   if(Button->Down_Final==1) Button->Down_Final = 0;//取反    以1為有效值
  438.   else Button->Down_Final = 1;
  439.
  440.
  441.   Button->Life_Final = Button->Life[0] || Button->Life[1] || Button->Life[2] || Button->Life[3] || Button->Life[4];
  442.   //有一個(gè)1  最終值就是1 全部為0 最終值才為0
  443.   if(Button->Life_Final==1) Button->Life_Final = 0;//取反    以1為有效值
  444.   else Button->Life_Final = 1;
  445.
  446.
  447.   Button->Right_Final = Button->Right[0] || Button->Right[1] || Button->Right[2] || Button->Right[3] || Button->Right[4];
  448.   //有一個(gè)1  最終值就是1 全部為0 最終值才為0
  449.   if(Button->Right_Final==1) Button->Right_Final = 0;//取反    以1為有效值
  450.   else Button->Right_Final = 1;
  451.
  452.
  453.   Button->Enter_Final = Button->Enter[0] || Button->Enter[1] || Button->Enter[2] || Button->Enter[3] || Button->Enter[4];
  454.   //有一個(gè)1  最終值就是1 全部為0 最終值才為0
  455.   if(Button->Enter_Final==1) Button->Enter_Final = 0;//取反    以1為有效值
  456.   else Button->Enter_Final = 1;
  457.
  458. };
  459. void SwitchLowPassFilter(Switch_Type_Def *Switch){ //開(kāi)關(guān)低通濾波
  460.
  461.   Switch->Bm1_Final = Switch->Bm1[0] || Switch->Bm1[1] || Switch->Bm1[2];
  462.   if(Switch->Bm1_Final==1) Switch->Bm1_Final = 0;//取反    以1為有效值
  463.   else Switch->Bm1_Final = 1;
  464.
  465.   Switch->Bm2_Final = Switch->Bm2[0] || Switch->Bm2[1] || Switch->Bm2[2];
  466.   if(Switch->Bm2_Final==1) Switch->Bm2_Final = 0;//取反    以1為有效值
  467.   else Switch->Bm2_Final = 1;
  468.
  469.   Switch->Bm3_Final = Switch->Bm3[0] || Switch->Bm3[1] || Switch->Bm3[2];
  470.   if(Switch->Bm3_Final==1) Switch->Bm3_Final = 0;//取反    以1為有效值
  471.   else Switch->Bm3_Final = 1;
  472.
  473.   Switch->Bm4_Final = Switch->Bm4[0] || Switch->Bm4[1] || Switch->Bm4[2];
  474.   if(Switch->Bm4_Final==1) Switch->Bm4_Final = 0;//取反    以1為有效值
  475.   else Switch->Bm4_Final = 1;
  476.
  477.   Switch->Bm5_Final = Switch->Bm5[0] || Switch->Bm5[1] || Switch->Bm5[2];
  478.   if(Switch->Bm5_Final==1) Switch->Bm5_Final = 0;//取反    以1為有效值
  479.   else Switch->Bm5_Final = 1;
  480.
  481.   Switch->Bm6_Final = Switch->Bm6[0] || Switch->Bm6[1] || Switch->Bm6[2];
  482.   if(Switch->Bm6_Final==1) Switch->Bm6_Final = 0;//取反    以1為有效值
  483.   else Switch->Bm6_Final = 1;
  484. };
  485. void OutOfControlSignal(Speed_Type_Def *Speed, PID_Type_Def *PID){   //速度失控信號(hào)檢測(cè)
  486.
  487.   if( (Speed->ActualSpeed[2]-Speed->ActualSpeed[1]) > 400  &&  Speed->ActualSpeed[2]>10000){
  488.     //加速度過(guò)大 車輪空轉(zhuǎn)
  489.
  490.     ftm_pwm_duty(ftm2,ftm_ch2,0);
  491.     ftm_pwm_duty(ftm2,ftm_ch3,0);
  492.     ftm_pwm_duty(ftm2,ftm_ch4,0);
  493.     ftm_pwm_duty(ftm2,ftm_ch5,0);
  494. //
  495.
  496.
  497.     while(1){
  498.
  499. //     led(LED0,LED_ON);  //根據(jù)你們的硬件設(shè)置報(bào)警燈
  500.
  501.       systick_delay_ms(80);
  502.
  503. //      led(LED0,LED_OFF);
  504.
  505.       systick_delay_ms(80);
  506.
  507.     };
  508.   }
  509. };
  510. /*被控制量處理部分*/
  511. void BalanceFeedbackControl(PID_Type_Def *PID, Angle_Type_Def *Angle, Gyro_Type_Def *Gyro, Ramp_Type_Def *Ramp){ //直立反饋控制
  512.
  513.   PID->err = (Angle->PiontValue-Angle->FinalValue);//硬件
  514.   //偏差  =  角度目標(biāo)-角度反饋值
  515.
  516.
  517.   PID->out =   1000 + PID->Kp * PID->err + PID->Kd * Gyro->Z_Final;
  518.   //1000是為了給一個(gè)PWM中點(diǎn)   Gyro->Z_Final就是 直立的角速度  也就是D控制  PD
  519.
  520.   //一般情況下  調(diào)直立時(shí)   先給一個(gè)P參數(shù)  D給0   就能立起來(lái)   如果發(fā)現(xiàn)不能立瘋轉(zhuǎn)
  521.   //多半是 pid方向相反    把(Angle->PiontValue-Angle->FinalValue)  里面調(diào)換下位置  即可
  522.
  523.
  524. };
  525. void DirectionFeedbackControl(PID_Type_Def *PID, Inductor_Type_Def *InductorA, Inductor_Type_Def *InductorB, Gyro_Type_Def *Gyro, Speed_Type_Def *Speed, Ramp_Type_Def *Ramp){ //方向反饋控制
  526.
  527.   InductorA->RightFinal = PID->offset*InductorA->RightFinal;
  528.   InductorA->LeftFinal = (2-PID->offset)*InductorA->LeftFinal;
  529.   //調(diào)整零偏
  530.
  531.   //主要是在用 A電感
  532.
  533.   PID->err = 10.0*(sqrt(1.0*InductorA->RightFinal)-sqrt(1.0*InductorA->LeftFinal) )/ (InductorA->RightFinal+InductorA->LeftFinal);
  534.
  535.
  536.
  537.
  538.   if( InductorA->AndValues < 25 && Ramp->Flag[0]!=1) {//丟線找回 且不在坡道
  539.
  540.     PID->err += 0.55*PID->err_k[6]; //找回強(qiáng)度
  541.   }
  542.   else if( InductorA->AndValues < 50 && Ramp->Flag[0]!=1) {//丟線找回
  543.
  544.     PID->err += 0.50*PID->err_k[6]; //找回強(qiáng)度
  545.
  546.   }
  547.   else if( InductorA->AndValues < 75 && Ramp->Flag[0]!=1) {//丟線找回
  548.
  549.     PID->err += 0.45*PID->err_k[7]; //找回強(qiáng)度
  550.
  551.   }
  552.   else if( InductorA->AndValues < 100 && Ramp->Flag[0]!=1) {//丟線找回
  553.
  554.     PID->err += 0.40*PID->err_k[7]; //找回強(qiáng)度
  555.
  556.   }
  557.   else if( InductorA->AndValues < 125 && Ramp->Flag[0]!=1) {//丟線找回
  558.
  559.     PID->err += 0.35*PID->err_k[8]; //找回強(qiáng)度
  560.
  561.   }
  562.   else if( InductorA->AndValues< 150 && Ramp->Flag[0]!=1) {//丟線找回
  563.
  564.     PID->err += 0.30*PID->err_k[8]; //找回強(qiáng)度
  565.
  566.   }
  567.   else if( InductorA->AndValues < 175 && Ramp->Flag[0]!=1) {//丟線找回
  568.
  569.     PID->err += 0.25*PID->err_k[9]; //找回強(qiáng)度9
  570.
  571.   }
  572.   else if( InductorA->AndValues < 200 && Ramp->Flag[0]!=1) {//丟線找回200
  573.
  574.     PID->err += 0.2*PID->err_k[9]; //找回強(qiáng)度9
  575.
  576.   }
  577.
  578.   if(InductorA->AndValues<150)  PID->err = 0;
  579.
  580.   PID->out = PID->Kp * PID->err * Speed->ActualInstantaneous[2] + PID->Kd * Gyro->X_Final;
  581.   //轉(zhuǎn)向PID輸出計(jì)算 Gyro->X_Final; 是轉(zhuǎn)向角速度 也是D控制
  582.
  583.
  584.   Speed->PiontDifferential = (int16)(PID->out);  //給定差速環(huán)目標(biāo)值
  585.   //把轉(zhuǎn)向環(huán)  計(jì)算出來(lái)的輸出值  給差速目標(biāo)環(huán)
  586.
  587.   for(uint8 n=0; n<9 ; n++){  //循環(huán)誤差保存
  588.
  589.     PID->err_k[n] = PID->err_k[n+1]; //0~8位賦值
  590.
  591.     if( n==8 )
  592.       PID->err_k[n+1] = PID->err;  //本次 9位賦值
  593.
  594.   }
  595.
  596. };
  597. void DifferentialFeedbackControl(PID_Type_Def *PID, Speed_Type_Def *Speed, Gyro_Type_Def *Gyro){//差速反饋控制
  598.
  599.   //PID->offset只是一個(gè)比例分配  PID->offset=2
  600.
  601.   int16 SpeedDifferentialValue = PID->offset * Speed->ActualDifferential[2] + (1-PID->offset)*(-0.18*Gyro->X_Final);
  602.   //  得到差速值  是編碼器和   轉(zhuǎn)向角速度共同決定差速反饋值
  603.
  604.
  605.   //Speed->PiontDifferential = 0;
  606.   //差速目標(biāo)-  差速實(shí)際值
  607.   PID->err = ( Speed->PiontDifferential -  SpeedDifferentialValue);
  608.   PID->integral += PID->err;
  609.
  610.   //積分上下限
  611.   if(PID->integral>50000)PID->integral=50000;
  612.
  613.   if(PID->integral<-50000)PID->integral=-50000;
  614.
  615.   if(Speed->ActualSpeed[2]< 50)PID->integral = 0;
  616.   //低速積分清零
  617.
  618.   PID->out =  PID->Kp * PID->err + PID->Kd * ( SpeedDifferentialValue + PID->err_k[0]);// + PID->Ki * PID->integral;
  619.   //PID計(jì)算
  620.
  621.   for(uint8 n=0; n<9 ; n++){  //循環(huán)誤差保存
  622.
  623.     PID->err_k[n] = PID->err_k[n+1]; //0~8位賦值
  624.
  625.     if( n==8 )
  626.       PID->err_k[n+1] = PID->err;  //本次 9位賦值
  627.
  628.   }
  629.
  630.   PID->err_k[0] = SpeedDifferentialValue;//借用一下PID->err_k[0]咯  存入上次值 差速
  631.
  632.   //輸出幅度限制
  633.   if(PID->out>2000)PID->out=2000;//1800
  634.   if(PID->out<-2000)PID->out=-2000;
  635.
  636. };
  637. void SpeedFeedbackControl(PID_Type_Def *PID, Speed_Type_Def *Speed, Ramp_Type_Def *Ramp, Switch_Type_Def *Switch){ //速度反饋控制
  638.
  639.   PID->out_k[9] = PID->out;//保存成上一次輸出值
  640.
  641.   PID->out_k[0] = 0;
  642.
  643.
  644.
  645.   PID->err = Speed->ActualSpeed[2] - Speed->PiontSpeed;
  646.
  647.
  648.   PID->integral = PID->err_k[0]+PID->err_k[1]+PID->err_k[2]+PID->err_k[3]+PID->err_k[4]+
  649.
  650.           PID->err_k[5]+PID->err_k[6]+PID->err_k[7]+PID->err_k[8]+PID->err_k[9]+PID->err;
  651.   PID->out = PID->Kp * PID->err;// + PID->Ki * PID->integral;
  652.
  653.   PID->out *= 0.05; //縮小速度環(huán)輸出
  654.
  655.
  656.   if(PID->out >  4800) PID->out= 4800; //后退最低角度4200
  657.
  658.   if(PID->out < -1800) PID->out= -1800;//前進(jìn)最低角度-1800
  659.
  660.
  661.   for(uint8 n=0; n<9 ; n++){  //循環(huán)誤差保存
  662.
  663.     PID->err_k[n] = PID->err_k[n+1]; //0~8位賦值
  664.
  665.     if( n==8 )
  666.       PID->err_k[n+1] = PID->err;  //本次 9位賦值
  667.
  668.   }
  669.
  670. };
  671. void PWMFeedbackControl(PWM_Type_Def *PWM, PID_Type_Def *PID_Balance, PID_Type_Def *PID_Speed, PID_Type_Def *PID_Path, PID_Type_Def *PID_Diff, Speed_Type_Def *Speed, Switch_Type_Def *Switch){ //PWM疊加反饋控制
  672.
  673.   float DiffK=1;
  674.
  675.   PID_Speed->out_k[0] += (PID_Speed->out - PID_Speed->out_k[9]) * 0.0625;//分段成1/16分增量
  676.
  677.   //PID_Speed->out_k[9]是上次值 //PID_Speed->out是本次值  PID_Speed->out_k[0] 是平滑輸出增量值
  678.   //疊加的時(shí)候把   平滑輸出增量值 + 上次的值 得到16個(gè)周期內(nèi) 每4ms周期應(yīng)給的值
  679.
  680.   PWM->PiontValue  = (int16)(PID_Balance->out)+ (int16)(PID_Speed->out_k[0] + PID_Speed->out_k[9]) ;
  681.   //把所有環(huán)輸出相加
  682.
  683.
  684.   PWM->Differential = (int16)(PID_Diff->out);
  685. //差速PWM
  686.
  687.
  688.   if(PWM->Differential>0){
  689.
  690.     PWM->LiftValue = PWM->PiontValue + (DiffK) * PWM->Differential;
  691.
  692.     PWM->RightValue = PWM->PiontValue - (2-DiffK) * PWM->Differential;
  693.
  694.   }
  695.
  696.   if(PWM->Differential<0){ //差速小于零時(shí)  左邊給目標(biāo)占空比+ 系數(shù)*差速
  697.
  698.     PWM->LiftValue = PWM->PiontValue + (2-DiffK) * PWM->Differential;
  699.
  700.     PWM->RightValue = PWM->PiontValue - (DiffK) * PWM->Differential;
  701.
  702.   }
  703.
  704.
  705.   if(PWM->Differential==0){  //差速=0時(shí)  左右給一樣的目標(biāo)占空比
  706.
  707.     PWM->LiftValue = PWM->PiontValue;
  708.
  709.     PWM->RightValue = PWM->PiontValue;
  710.   }
  711. };
  712. void ButtonFunctionControl(PID_Type_Def *PID_Balance, PID_Type_Def *PID_Speed, PID_Type_Def *PID_Path, PID_Type_Def *PID_Diff, Angle_Type_Def *Angle, Speed_Type_Def *Speed, Inductor_Type_Def *InductorA, Inductor_Type_Def *InductorB, Button_Type_Def *Button, uint8 *Page){ //按鍵功能實(shí)現(xiàn)
  713.   //OLED  按鍵 調(diào)節(jié)PID參數(shù)用的
  714.
  715.
  716.   if(Button->Life_Final==1)if(*Page>0)(*Page)--;
  717.
  718.   if(Button->Right_Final==1)if(*Page<135)(*Page)++;
  719.   //page0
  720.   if(*Page<=5){  //UP  kp
  721.
  722.     if(Button->Up_Final==1 ){
  723.       if(PID_Balance->Kp<30) PID_Balance->Kp = PID_Balance->Kp+0.01;
  724.     }
  725.
  726.     if(Button->Down_Final==1 ){
  727.       if(PID_Balance->Kp>0) PID_Balance->Kp = PID_Balance->Kp-0.01;
  728.     }
  729.   }
  730.   if(*Page<=10 && *Page>5){  //UP  kd
  731.
  732.     if(Button->Up_Final==1){
  733.
  734.       if(PID_Balance->Kd<30) PID_Balance->Kd = PID_Balance->Kd+0.01;
  735.     }
  736.
  737.     if(Button->Down_Final==1){
  738.
  739.       if(PID_Balance->Kd>0) PID_Balance->Kd = PID_Balance->Kd-0.01;
  740.     }
  741.
  742.   }
  743.
  744.   if(*Page<=15 && *Page>10){  // angle piont
  745.
  746.     if(Button->Up_Final==1){
  747.
  748.       if(Angle->PiontValue<2400) Angle->PiontValue = Angle->PiontValue+1;
  749.     }
  750.
  751.     if(Button->Down_Final==1){
  752.
  753.       if(Angle->PiontValue>1600) Angle->PiontValue = Angle->PiontValue-1;
  754.     }
  755.
  756.   }
  757.
  758.   if(*Page<=20 && *Page>15){  //speed kp
  759.
  760.
  761.     if(Button->Up_Final==1){
  762.
  763.       if(PID_Speed->Kp<30)PID_Speed->Kp = PID_Speed->Kp+0.1;
  764.     }
  765.
  766.
  767.     if(Button->Down_Final==1){
  768.
  769.       if(PID_Speed->Kp>0)PID_Speed->Kp = PID_Speed->Kp-0.1;
  770.
  771.     }
  772.
  773.
  774.   }
  775.   if(*Page<=25 && *Page>20){  //speed ki
  776.
  777.
  778.     if(Button->Up_Final==1){
  779.
  780.       if(PID_Speed->Ki<10)PID_Speed->Ki = PID_Speed->Ki+0.001;
  781.     }
  782.
  783.
  784.     if(Button->Down_Final==1){
  785.       if(PID_Speed->Ki>0)PID_Speed->Ki = PID_Speed->Ki-0.001;
  786.     }
  787.
  788.   }
  789.
  790.   if(*Page<=30 && *Page>25){  //speeed piont
  791.
  792.     if(Button->Up_Final==1){
  793.
  794.       if(Speed->PiontSpeed<10000)Speed->PiontSpeed = Speed->PiontSpeed+10;
  795.     }
  796.
  797.     if(Button->Down_Final==1){
  798.       if(Speed->PiontSpeed>0)Speed->PiontSpeed = Speed->PiontSpeed-10;
  799.     }
  800.
  801.
  802.   }
  803.
  804.
  805.
  806.   //page1
  807.   if(*Page<=35 && *Page>30){  //path kp
  808.
  809.     if(Button->Up_Final==1){
  810.       if(PID_Path->Kp<30)PID_Path->Kp = PID_Path->Kp+0.01;
  811.     }
  812.
  813.     if(Button->Down_Final==1 ){
  814.       if(PID_Path->Kp>0)PID_Path->Kp = PID_Path->Kp-0.01;
  815.     }
  816.
  817.   }
  818.
  819.   if(*Page<=40 && *Page>35){  //path kd
  820.
  821.
  822.     if(Button->Up_Final==1){
  823.       if(PID_Path->Kd<30)PID_Path->Kd = PID_Path->Kd+0.01;
  824.     }
  825.
  826.     if(Button->Down_Final==1){
  827.
  828.       if(PID_Path->Kd>0)PID_Path->Kd = PID_Path->Kd-0.01;
  829.     }
  830.   }
  831.
  832.   if(*Page<=45 && *Page>40){  //path piont
  833.
  834.
  835.     if(Button->Up_Final==1){
  836.
  837.       if(PID_Path->offset<2)PID_Path->offset = PID_Path->offset+0.001;
  838.
  839.     }
  840.
  841.     if(Button->Down_Final==1){
  842.
  843.       if(PID_Path->offset>0)PID_Path->offset = PID_Path->offset-0.001;
  844.
  845.     }
  846.
  847.
  848.   }
  849.
  850.   if(*Page<=50 && *Page>45){  //diff kp
  851.
  852.     if(Button->Up_Final==1){
  853.       if(PID_Diff->Kp<30)PID_Diff->Kp = PID_Diff->Kp+0.01;
  854.     }
  855.
  856.     if(Button->Down_Final==1 ){
  857.       if(PID_Diff->Kp>0)PID_Diff->Kp = PID_Diff->Kp-0.01;
  858.     }
  859.
  860.   }
  861.
  862.   if(*Page<=55 && *Page>50){  //diff kd
  863.
  864.     if(Button->Up_Final==1){
  865.       if(PID_Diff->Kd<30)PID_Diff->Kd = PID_Diff->Kd+0.01;
  866.     }
  867.
  868.     if(Button->Down_Final==1 ){
  869.       if(PID_Diff->Kd>0)PID_Diff->Kd = PID_Diff->Kd-0.01;
  870.     }
  871.
  872.   }
  873.
  874.   if(*Page<=60 && *Page>55){  //diff kd
  875.
  876.     if(Button->Up_Final==1){
  877.       if(PID_Diff->Ki<30)PID_Diff->Ki = PID_Diff->Ki+0.01;
  878.     }
  879.
  880.     if(Button->Down_Final==1 ){
  881.       if(PID_Diff->Ki>0)PID_Diff->Ki = PID_Diff->Ki-0.01;
  882.     }
  883.
  884.   }
  885.
  886.   if(*Page<=65 && *Page>60){  //diff offset
  887.
  888.     if(Button->Up_Final==1){
  889.       if(PID_Diff->offset<1)PID_Diff->offset = PID_Diff->offset+0.001;
  890.     }
  891.
  892.     if(Button->Down_Final==1 ){
  893.       if(PID_Diff->offset>0)PID_Diff->offset = PID_Diff->offset-0.001;
  894.     }
  895.
  896.   }
  897.
  898.
  899.
  900.
  901.   //page2
  902.   if(*Page<=70 && *Page>65){ //左電感最大值
  903.
  904.     if(Button->Up_Final==1 && InductorA->LeftMax < 4000)InductorA->LeftMax ++;
  905.
  906.
  907.     if(Button->Down_Final==1 && InductorA->LeftMax > 100)InductorA->LeftMax --;
  908.
  909.
  910.   }
  911.
  912.   if(*Page<=75 && *Page>70){ //左電感最小值
  913.
  914.
  915.     if(Button->Up_Final==1 && InductorA->LeftMin < 4000)InductorA->LeftMin ++;
  916.
  917.
  918.     if(Button->Down_Final==1 && InductorA->LeftMin > 100)InductorA->LeftMin --;
  919.
  920.   }
  921.
  922.   if(*Page<=80 && *Page>75){ //右電感最大值
  923.
  924.     if(Button->Up_Final==1 && InductorA->RightMax < 4000)InductorA->RightMax ++;
  925.
  926.
  927.     if(Button->Down_Final==1 && InductorA->RightMax > 100)InductorA->RightMax --;
  928.
  929.
  930.   }
  931.
  932.   if(*Page<=85 && *Page>80){ //右電感最小值
  933.
  934.
  935.     if(Button->Up_Final==1 && InductorA->RightMin< 4000)InductorA->RightMin ++;
  936.
  937.
  938.     if(Button->Down_Final==1 && InductorA->RightMin> 100)InductorA->RightMin --;
  939.
  940.   }
  941.
  942.   if(*Page<=90 && *Page>85){ //中間電感最大值
  943.
  944.
  945.     if(Button->Up_Final==1 && InductorB->LeftMax< 4000)InductorB->LeftMax ++;
  946.
  947.
  948.     if(Button->Down_Final==1 && InductorB->LeftMax> 100)InductorB->LeftMax --;
  949.
  950.   }
  951.
  952.   if(*Page<=95 && *Page>90){//中間電感最小值
  953.
  954.
  955.     if(Button->Up_Final==1 && InductorB->LeftMin< 4000)InductorB->LeftMin ++;
  956.
  957.
  958.     if(Button->Down_Final==1 && InductorB->LeftMin> 100)InductorB->LeftMin --;
  959.
  960.   }
  961.
  962.   if(*Page<=100 && *Page>95){//最大速度
  963.
  964.
  965.     if(Button->Up_Final==1 && Speed->PiontSpeedMax<10000)Speed->PiontSpeedMax ++;
  966.
  967.
  968.     if(Button->Down_Final==1 && Speed->PiontSpeedMax >0)Speed->PiontSpeedMax --;
  969.
  970.   }
  971.
  972.   if(*Page<=105 && *Page>100){//最小速度
  973.
  974.     if(Button->Up_Final==1 && Speed->PiontSpeedMin < Speed->PiontSpeedMax)Speed->PiontSpeedMin ++;
  975.
  976.
  977.     if(Button->Down_Final==1 && Speed->PiontSpeedMin > 0)Speed->PiontSpeedMin --;
  978.
  979.
  980.   }
  981.
  982. //
  983. //  //page3
  984. //  if(*Page<=110 && *Page>105){//減速距離
  985. //
  986. //    if(Button->Up_Final==1 && Speed->SlowDistance < 6000)Speed->SlowDistance ++;
  987. //
  988. //
  989. //    if(Button->Down_Final==1 && Speed->SlowDistance > 0)Speed->SlowDistance --;
  990. //  }
  991. //
  992. //  if(*Page<=115 && *Page>110){//加速距離
  993. //
  994. //    if(Button->Up_Final==1 && Speed->AccDistance < 6000)Speed->AccDistance ++;
  995. //
  996. //
  997. //    if(Button->Down_Final==1 && Speed->AccDistance > 0)Speed->AccDistance --;
  998. //  }
  999. //
  1000. //  if(*Page<=120 && *Page>115){//錯(cuò)誤距離
  1001. //
  1002. //    if(Button->Up_Final==1 && Speed->FaultDistance < 150000)Speed->FaultDistance+=100;
  1003. //
  1004. //
  1005. //    if(Button->Down_Final==1 && Speed->FaultDistance > 100)Speed->FaultDistance-=100;
  1006. //  }
  1007.
  1008. };
  1009. /*輸出量處理部分*/
  1010. void PrintParameterToOLED(PID_Type_Def *PID_Balance, PID_Type_Def *PID_Speed, PID_Type_Def *PID_Path, PID_Type_Def *PID_Diff, Angle_Type_Def *Angle, Speed_Type_Def *Speed , PWM_Type_Def *PWM, Inductor_Type_Def *InductorA, Inductor_Type_Def *InductorB, Curve_Type_Def *Curve, uint8 Page){    //打印參數(shù)到OLED上
  1011.   uint8 mode[10];
  1012.   static uint8 Last=0;
  1013.
  1014.   if(Page<=30){
  1015.
  1016.     if(Page<=5) mode[0] = 0;
  1017.     else mode[0] = 1;
  1018.
  1019.     if(Page<=10 && Page>5) mode[1] =0;
  1020.     else mode[1] = 1;
  1021.
  1022.     if(Page<=15 && Page>10) mode[2] =0;
  1023.     else mode[2] = 1;
  1024.
  1025.     if(Page<=20 && Page>15) mode[3] =0;
  1026.     else mode[3] = 1;
  1027.
  1028.     if(Page<=25 && Page>20) mode[4] =0;
  1029.     else mode[4] = 1;
  1030.
  1031.     if(Page<=30 && Page>25) mode[5] =0;
  1032.     else mode[5] = 1;
  1033.
  1034.     if( Last!=1 ){
  1035.       OLED_Fill(0,0,127,63,0);
  1036.       Last = 1;
  1037.     }
  1038.     OLED_ShowString(0,0,"UP P    D         ");
  1039.     OLED_ShowNum(36,0,(int)(PID_Balance->Kp*10),3,12,mode[0]);
  1040.     OLED_ShowNum(72,0,(int)(PID_Balance->Kd*10),3,12,mode[1]);
  1041.     OLED_ShowString(0,12 ,"AnglePiont        ");
  1042.     OLED_ShowNum(96,12,(int)(Angle->PiontValue),4,12,mode[2]);
  1043.
  1044.     OLED_ShowString(0,24 ,"Speed P   I        ");
  1045.     OLED_ShowNum(56,24,(int)(PID_Speed->Kp*10),3,12,mode[3]);
  1046.     OLED_ShowNum(96,24,(int)(PID_Speed->Ki*1000),3,12,mode[4]);
  1047.     OLED_ShowString(0,36 ,"SpeedPiont        ");
  1048.     OLED_ShowNum(96,36,(int)(Speed->PiontSpeed),4,12,mode[5]);
  1049.
  1050.     OLED_ShowNum(32,48,(int)(InductorA->LeftFinal),3,12,0);
  1051.     OLED_ShowNum(56,48,(int)(InductorA->RightFinal),3,12,0);
  1052.     OLED_ShowNum(86,48,(int)(InductorB->LeftFinal),3,12,0);
  1053.   }
  1054.
  1055.   else if(Page>30 && Page<=65){
  1056.
  1057.     if(Page<=35 && Page>30) mode[0] = 0;
  1058.     else mode[0] = 1;
  1059.
  1060.     if(Page<=40 && Page>35) mode[1] =0;
  1061.     else mode[1] = 1;
  1062.
  1063.     if(Page<=45 && Page>40) mode[2] =0;
  1064.     else mode[2] = 1;
  1065.
  1066.     if(Page<=50 && Page>45) mode[3] =0;
  1067.     else mode[3] = 1;
  1068.
  1069.     if(Page<=55 && Page>50) mode[4] =0;
  1070.     else mode[4] = 1;
  1071.
  1072.     if(Page<=60 && Page>55) mode[5] =0;
  1073.     else mode[5] = 1;
  1074.
  1075.     if(Page<=65 && Page>60) mode[6] =0;
  1076.     else mode[6] = 1;
  1077.
  1078.
  1079.
  1080.     if( Last!=2 ){
  1081.       OLED_Fill(0,0,127,63,0);
  1082.       Last = 2;
  1083.     }
  1084.
  1085.     OLED_ShowString(0,0,"Path P    D         ");
  1086.     OLED_ShowNum(48,0,(int)(PID_Path->Kp*10),3,12,mode[0]);
  1087.     OLED_ShowNum(96,0,(int)(PID_Path->Kd*100),3,12,mode[1]);
  1088.     OLED_ShowString(0,12 ,"PathPiont        ");
  1089.     OLED_ShowNum(84,12,(int)(PID_Path->offset*100),3,12,mode[2]);
  1090.
  1091.
  1092.     OLED_ShowString(0,24 ,"Diff P     D        ");
  1093.     OLED_ShowNum(56,24,(int)(PID_Diff->Kp*10),3,12,mode[3]);
  1094.     OLED_ShowNum(96,24,(int)(PID_Diff->Kd*10),3,12,mode[4]);
  1095.     OLED_ShowString(0,36 ,"Diff I     S        ");
  1096.     OLED_ShowNum(56,36,(int)(PID_Diff->Ki*10),3,12,mode[5]);
  1097.     OLED_ShowNum(96,36,(int)(PID_Diff->offset*100),3,12,mode[6]); //差速與陀螺儀融合比率
  1098.
  1099.
  1100.     OLED_ShowNum(32,48,(int)(InductorA->LeftFinal),3,12,0);
  1101.     OLED_ShowNum(56,48,(int)(InductorA->RightFinal),3,12,0);
  1102.     OLED_ShowNum(86,48,(int)(InductorB->LeftFinal),3,12,0);
  1103.
  1104.   }
  1105.
  1106.   else if(Page>65 && Page<=105){
  1107.
  1108.     if(Page<=70 && Page>65) mode[0] = 0;
  1109.     else mode[0] = 1;
  1110.
  1111.     if(Page<=75 && Page>70) mode[1] =0;
  1112.     else mode[1] = 1;
  1113.
  1114.     if(Page<=80 && Page>75) mode[2] =0;
  1115.     else mode[2] = 1;
  1116.
  1117.     if(Page<=85 && Page>80) mode[3] =0;
  1118.     else mode[3] = 1;
  1119.
  1120.     if(Page<=90 && Page>85) mode[4] =0;
  1121.     else mode[4] = 1;
  1122.
  1123.     if(Page<=95 && Page>90) mode[5] =0;
  1124.     else mode[5] = 1;
  1125.
  1126.     if(Page<=100 && Page>95) mode[6] =0;
  1127.     else mode[6] = 1;
  1128.
  1129.     if(Page<=105 && Page>100) mode[7] =0;
  1130.     else mode[7] = 1;
  1131.
  1132.
  1133.     if( Last!=3 ){
  1134.       OLED_Fill(0,0,127,63,0);
  1135.       Last = 3;
  1136.     }
  1137.
  1138.     OLED_ShowString(0,0   ,"LAMAX");
  1139.     OLED_ShowNum(38,0,(int)(InductorA->LeftMax),4,12,mode[0]);
  1140.     OLED_ShowString(68,0  ,"LAMIN");
  1141.     OLED_ShowNum(108,0,(int)(InductorA->LeftMin),3,12,mode[1]);
  1142.
  1143.
  1144.     OLED_ShowString(0,12  ,"RAMAX");
  1145.     OLED_ShowNum(38,12,(int)(InductorA->RightMax),4,12,mode[2]);
  1146.     OLED_ShowString(68,12 ,"RAMIN");
  1147.     OLED_ShowNum(108,12,(int)(InductorA->RightMin),3,12,mode[3]);
  1148.
  1149.
  1150.
  1151.     OLED_ShowString(0,24  ,"ZBMAX");
  1152.     OLED_ShowNum(38,24,(int)(InductorB->LeftMax),4,12,mode[4]);
  1153.     OLED_ShowString(68,24 ,"ZBMIN");
  1154.     OLED_ShowNum(108,24,(int)(InductorB->LeftMin),3,12,mode[5]);
  1155.
  1156.
  1157.     OLED_ShowString(0,36 ,"SpeedMax");
  1158.     OLED_ShowNum(84,36,(uint32)(Speed->PiontSpeedMax),4,12,mode[6]);
  1159.
  1160.     OLED_ShowString(0,48 ,"SpeedMin");
  1161.     OLED_ShowNum(84,48,(uint32)(Speed->PiontSpeedMin),4,12,mode[7]);
  1162.
  1163.   }
  1164.
  1165.   OLED_Refresh_Gram();
  1166. };
  1167. void MotorControlFlow(PWM_Type_Def *PWM, Ramp_Type_Def *Ramp){ //電機(jī)直接控制
  1168.
  1169.   //如測(cè)試線序 在此處 對(duì)*PWM賦值 測(cè)試完畢再注釋
  1170.   //PWM->LiftValue = 1200;//左輪正傳  往前走
  1171.   //PWM->LiftValue = 1000;
  1172.   //PWM->LiftValue = 800;
  1173.
  1174.   //PWM->RightValue = 1200;//右輪正傳 往前走
  1175.   //PWM->RightValue = 1000;
  1176.   //PWM->RightValue = 800;
  1177.   //左邊右邊都給 1000的時(shí)候 應(yīng)該是不轉(zhuǎn)的
  1178.
  1179.   if(PWM->LiftValue>(PWMMAX))PWM->LiftValue = (PWMMAX);
  1180.   if(PWM->LiftValue<(PWMMIN))PWM->LiftValue = (PWMMIN);
  1181.   if(PWM->RightValue>(PWMMAX))PWM->RightValue = (PWMMAX);
  1182.   if(PWM->RightValue<(PWMMIN))PWM->RightValue = (PWMMIN);
  1183.
  1184.   //此處必須先調(diào)整好  保證 PWM值是 >1000時(shí)  是前進(jìn)
  1185.   //PWM值< 1000 是后退   而且 兩輪必須一致
  1186.   //能改硬件 就改驅(qū)動(dòng)線  和 電機(jī)引線  例如
  1187.   //給同樣都是  1200  左邊電機(jī)慢速往前  右邊慢速往后 這時(shí)候 調(diào)換右電機(jī)線
  1188.   //如果出現(xiàn)如下情況  給1200  理論上是 正轉(zhuǎn) 20%占空比  但出現(xiàn)轉(zhuǎn)速很快 說(shuō)明
  1189.   //驅(qū)動(dòng)線序不對(duì)   可以在這里調(diào)換 通道  或者 直接改線序
  1190.
  1191.   if(PWM->LiftValue>1000){ //邊輪前進(jìn)  1000~2000
  1192.      ftm_pwm_duty(ftm2,ftm_ch2,0);
  1193.      ftm_pwm_duty(ftm2,ftm_ch3,PWM->LiftValue-1000);
  1194.   }
  1195.   else if(PWM->LiftValue<1000){ //左輪是后退  0~1000
  1196.      ftm_pwm_duty(ftm2,ftm_ch2,1000-PWM->LiftValue);
  1197.      ftm_pwm_duty(ftm2,ftm_ch3,0);
  1198.   }  //如果發(fā)現(xiàn) 此處給定的是  控制 右輪轉(zhuǎn)動(dòng) 則調(diào)換下硬件驅(qū)動(dòng)線線序  注意 是兩根兩根的調(diào)換
  1199.
  1200.   if(PWM->RightValue>1000){ //右輪是前進(jìn)  1000~2000
  1201.      ftm_pwm_duty(ftm2,ftm_ch4,0);
  1202.      ftm_pwm_duty(ftm2,ftm_ch5,PWM->RightValue-1000);
  1203.   }
  1204.   else if(PWM->RightValue<1000){ //右輪是后退  0~1000
  1205.      ftm_pwm_duty(ftm2,ftm_ch4,1000-PWM->RightValue);
  1206.      ftm_pwm_duty(ftm2,ftm_ch5,0);
  1207.   }   //如果發(fā)現(xiàn) 此處給定的是  控制 左邊輪轉(zhuǎn)動(dòng) 則調(diào)換下硬件驅(qū)動(dòng)線線序  注意 是兩根兩根的調(diào)換
  1208.
  1209. };
  1210. uint8 timer3ms = 0, timer4_5ms=0,timer24ms=0 ,timer64ms=0;
  1211. int main(void){
  1212.
  1213.   //由于本程序閉環(huán)較多  調(diào)試過(guò)程比較繁瑣  建議一開(kāi)始的時(shí)候 屏蔽掉其他環(huán)
  1214.   //只調(diào)節(jié)最基礎(chǔ)的環(huán)節(jié)  平衡車主要就是對(duì)于兩個(gè)電機(jī)的控制  其中有一個(gè)函數(shù)
  1215.   //MotorControlFlow函數(shù)是直接控制電機(jī)的  這個(gè)函數(shù)需要調(diào)試好  其要求就是
  1216.   //占空比0~1000退后   1000~2000向前  通過(guò)調(diào)換驅(qū)動(dòng)線  和 調(diào)換電機(jī)線  或者
  1217.   //調(diào)換程序中 ch2 3 4 5 的  23順序  45順序來(lái)  達(dá)到最終的效果  兩個(gè)電機(jī)
  1218.   //給1000以上是向前走   1000一下向后走  2000往前最快   0往后最快
  1219.
  1220.   //當(dāng)電機(jī)輸出調(diào)整好了以后  再調(diào)節(jié)編碼器反饋  我們?cè)贛otorControlFlow函數(shù)里
  1221.   //直接給  PWM->LiftValue = 1200;PWM->RightValue = 1200;  讓兩個(gè)電機(jī)固定占空比
  1222.   //轉(zhuǎn)動(dòng)  這時(shí)候 通過(guò)IAR在線調(diào)試觀察  編碼器測(cè)速值 是否正確  是否對(duì)應(yīng)左輪右輪
  1223.   //(左電機(jī)轉(zhuǎn)動(dòng)對(duì)應(yīng)左編碼器  右電機(jī)轉(zhuǎn)動(dòng)對(duì)應(yīng)右邊編碼器  不能錯(cuò)!)
  1224.   //用手阻止一個(gè)電機(jī)觀察是否是那個(gè)電機(jī)的編碼器轉(zhuǎn)速下降  確保 編碼器的方向一致!
  1225.
  1226.   //編碼器 和 電機(jī)調(diào)整好以后就方便了很多  接下來(lái)就是直立  前提是陀螺儀參數(shù)已經(jīng)整定好
  1227.   //我們調(diào)試直立的時(shí)候  要把其他環(huán)都關(guān)閉 方法如下  函數(shù)PWMFeedbackControl 是把所有環(huán)輸出
  1228.   //整合到電機(jī)PWM上的函數(shù) 其中  PWM->PiontValue  = (int16)(PID_Balance->out)+ (int16)(PID_Speed->out_k[0] + PID_Speed->out_k[9]) ;
  1229.   //這句話是把  三個(gè)環(huán)的輸出 疊加在一起  我們只需要保留 直立環(huán)  這樣調(diào)節(jié)直立比較順手
  1230.   //其中還有一個(gè) 差速 也要給0  對(duì)直立就無(wú)影響
  1231.
  1232.   //當(dāng)直立調(diào)節(jié)完畢后  速度環(huán)和直立的融合是比較難的  直立和速度是并環(huán) 需要精心調(diào)試,也可以
  1233.   //跳過(guò)速度環(huán)的調(diào)試  直接進(jìn)入轉(zhuǎn)向環(huán)  與差速環(huán)    他們之間是串級(jí)PID的關(guān)系
  1234.
  1235.   //如果出現(xiàn)中斷  跑飛 或者  卡住在ADC死循環(huán)里  說(shuō)明堆棧溢出  調(diào)整KEA128.ICF文件的  堆棧值 擴(kuò)大  不超過(guò)12K即可
  1236.
  1237.
  1238.   get_clk();              //獲取時(shí)鐘頻率 必須執(zhí)行
  1239.
  1240.   uint8 Page=0;
  1241.
  1242.   PID_Type_Def  PID_Balance, PID_Speed, PID_Path, PID_Diff;
  1243.
  1244.   RUN_Type_Def       RUN;
  1245.   Stop_Type_Def      Stop;
  1246.   Ramp_Type_Def      Ramp;
  1247.   Curve_Type_Def     Curve;
  1248.   Acc_Type_Def       Acc;
  1249.   Gyro_Type_Def      Gyro;
  1250.   Angle_Type_Def     Angle;
  1251.   PWM_Type_Def       PWM;
  1252.   Speed_Type_Def     Speed;
  1253.   Button_Type_Def    Button;
  1254.   Switch_Type_Def    Switch;
  1255.   Inductor_Type_Def  InductorA, InductorB;
  1256.
  1257.   SensorStructurePointerInit( &Acc, &Gyro, &Angle, &Speed, &InductorA, &InductorB );//傳感器參數(shù)初始化
  1258.   PIDStructurePointerInit( &PID_Balance, &PID_Speed, &PID_Path, &PID_Diff );//PID參數(shù)初始化
  1259.   CarBalanceSystemInit( &Gyro ); //系統(tǒng)初始化
  1260.
  1261.
  1262.   RUN.Flag[4] = 1;//運(yùn)行出界標(biāo)志位
  1263.
  1264.   RUN.Flag[5] = 0;//啟動(dòng)電機(jī)標(biāo)志位
  1265.
  1266.   Stop.Flag[0] = 0;//停止線標(biāo)志位延時(shí)啟動(dòng)標(biāo)志位
  1267.
  1268.   Stop.Flag[1] = 0;//停止標(biāo)志位
  1269.
  1270.   Ramp.Flag[0] = 0;//接近坡道標(biāo)志位
  1271.
  1272.   Ramp.Flag[1] = 0;//上坡道標(biāo)志位
  1273.
  1274.   Curve.Flag[1] = 0;//正差速標(biāo)志位
  1275.
  1276.   Curve.Flag[2] = 0;//反差速標(biāo)志位
  1277.
  1278.   Curve.Flag[3] = 0;//差速數(shù)目
  1279.
  1280.   while(1){
  1281.     if( timer4_5ms  ){
  1282.
  1283.         gpio_set(H2,1);//
  1284.
  1285.       GetAccelerationValue( &Acc );  //加速度原始數(shù)據(jù)采集
  1286.       GetAngleSpeedValue( &Gyro );   //角速度原始數(shù)據(jù)采集
  1287.       GetSpeedValue( &Speed );       //獲取原始速度數(shù)據(jù)
  1288.       GetInductorValue( &InductorA, &InductorB );//電感電壓原始數(shù)據(jù)采集
  1289.
  1290.       GyroHighPassFilter( &Gyro );  //角速度濾波處理
  1291.       AngleHardwareFilter( &Angle );//角度濾波處理
  1292.       SpeedSoftwareFilter( &Speed );//速度遞歸權(quán)值濾波
  1293.       InductorSoftwareFilter( &InductorA, &InductorB, &Angle, &Switch);//電感濾波處理
  1294.       BalanceFeedbackControl( &PID_Balance, &Angle, &Gyro, &Ramp );//平衡度反饋計(jì)算
  1295.       DirectionFeedbackControl( &PID_Path, &InductorA, &InductorB, &Gyro, &Speed, &Ramp );//路徑反饋計(jì)算
  1296.       DifferentialFeedbackControl( &PID_Diff, &Speed, &Gyro);//差速反饋計(jì)算
  1297.       PWMFeedbackControl( &PWM, &PID_Balance, &PID_Speed, &PID_Path, &PID_Diff, &Speed, &Switch );//PWM疊加 直立 方向 速度PWM
  1298.       MotorControlFlow( &PWM, &Ramp ); //電機(jī)PWM輸出控制
  1299.
  1300.         gpio_set(H2,0);//
  1301.
  1302.       timer4_5ms = 0;//清除時(shí)間標(biāo)志位
  1303.     }
  1304.
  1305.     //車子跑起來(lái)以后就不會(huì)執(zhí)行  因?yàn)殚_(kāi)銷比較大 影響PID控制周期
  1306.     if( Speed.ActualSpeed[2]<100 && timer24ms && timer4_5ms != 1 ){
  1307.
  1308.       GetButtonStatus( &Button ); //獲取按鍵狀態(tài)
  1309.       ButtonLowPassFilter( &Button );//判斷按鍵狀態(tài)
  1310.
  1311.
  1312.       ButtonFunctionControl( &PID_Balance, &PID_Speed, &PID_Path, &PID_Diff, &Angle, &Speed, &InductorA, &InductorB, &Button, &Page );//實(shí)現(xiàn)按鍵狀態(tài)
  1313.
  1314.       GetSwitchStatus( &Switch ); //獲取開(kāi)關(guān)狀態(tài)
  1315.       SwitchLowPassFilter( &Switch );//判斷開(kāi)關(guān)狀態(tài)
  1316.       timer24ms = 0;
  1317.     };
  1318.
  1319.
  1320.     if(timer64ms && timer4_5ms != 1 ){
  1321.
  1322.       if(Speed.ActualSpeed[2]<100)PrintParameterToOLED( &PID_Balance, &PID_Speed, &PID_Path, &PID_Diff, &Angle, &Speed, &PWM, &InductorA, &InductorB, &Curve, Page );
  1323.       //人機(jī)交互界面 高速運(yùn)行不執(zhí)行
  1324.
  1325.       SpeedFeedbackControl( &PID_Speed, &Speed, &Ramp, &Switch ); //速度環(huán)反饋控制
  1326.
  1327.        timer64ms = 0;
  1328.     };
  1329.
  1330.
  1331.   }
  1332.
  1333. }
  1334. uint8 count = 0;
  1335. void PIT_CH0_IRQHandler(void)
  1336. {
  1337.   if( count<84 ) count++;
  1338.   else count = 0;
  1339.
  1340.
  1341. //  if( count%2==0 ) timer3ms = 1;
  1342.
  1343.   if( count%3==0 ) timer4_5ms = 1;
  1344.
  1345.   if( count%16==0 ) timer24ms = 1;
  1346.
  1347.   if( count%42==0 ) timer64ms=1;
  1348.
  1349.   PIT_FlAG_CLR(pit0);//清除中斷標(biāo)志位
  1350.
  1351.
  1352. }
KEA128直立.zip (4.71 MB, 下載次數(shù): 37)
ID:105146 發(fā)表于 2018-7-2 21:02 | 顯示全部樓層
首先感謝分享!參考一下
ID:105146 發(fā)表于 2018-7-2 21:29 | 顯示全部樓層
編譯出錯(cuò)啊~提示缺少一些文件
主站蜘蛛池模板: 精品日韩一区二区三区 | 亚洲欧美一区二区三区在线 | japanese极品丰满少妇 | a级片在线 | www.毛片.com | 精品在线观看视频 | 97中文字幕 | 日韩精品在线一区 | 精东影业一区二区三区 | 精品一区二区三区av | 亚洲欧美中文字幕 | 特级丰满少妇一级aaaa爱毛片 | 亚洲午夜视频在线观看 | 久久精品国产免费 | 在线视频福利 | 成人福利视频在线观看 | 秋霞一区二区三区 | 成人黄色小视频 | 久久久久久久网 | 久久久二区 | 在线视频亚洲 | 国产一区二区中文字幕 | 18精品爽国产白嫩精品 | 欧美一二三 | 涩涩的动漫 | 亚洲精品一级 | 国产精品一区av | 青青草伊人网 | 色综合久久天天综合网 | 久艹在线 | 日韩高清在线 | 中文字幕在线观看免费视频 | 黑人操亚洲女人 | 国产欧美在线 | 4438xxx| 中文字幕在线视频观看 | 操操操av | www欧美| 日韩中文字幕一区二区三区 | 日韩中文字幕在线观看 | 亚洲精品一区二区三区精华液 |
