查看: 4893|回復: 3
基于kea128的電磁式智能小車
#include  "includefile.h"
/**********全局變量定義********/
int32 LeftDead = 0;
int32 RighDead = 0;
float Ratio_Encoder_Left = 207/(1175*0.02);// 左輪速度=counter*左輪周長(mm)/(左輪轉一圈對應的脈沖數*程序周期)
float Ratio_Encoder_Righ = 207/(1175*0.02);// 右輪速度=counter*右輪周長(mm)/(右輪轉一圈對應的脈沖數*程序周期)
float g_fRealSpeed = 0;                                //真實速度
float g_fLeftRealSpeed;
float g_fRighRealSpeed;
float g_fSpeedFilter = 0;                        //階梯濾波速度
float g_fExpectSpeed = 2800;                //期望速度
float g_fSpeedError;                                //速度偏差
float g_fSpeedErrorTemp[5] = {0};
float fSpeedErrorInteg = 0;
int32 g_nLeftpulse = 0,g_nRighpulse = 0;
float g_PWMOut;
int32 g_nLeftPWM, g_nRighPWM;
//速度控制
float g_speedControl_P = 320;                //速度P
float g_speedControl_I = 100;                //速度I
float g_fSpeedControlOut = 0;                //速度輸出
* @file                PWM輸出
* @date                2018
void PWMOut(void)
        int32 nLeftPWM = 0, nRighPWM = 0;
        if(Flag_Speed == OFF)                g_fSpeedControlOut = 0;                //如果Flag_Speed == OFF                不輸出速度
        if(Flag_Direction == OFF)        g_fDirectionControlOut = 0;        //如果Flag_Direction == OFF 不輸出方向
        g_nLeftPWM = (int32)(g_fSpeedControlOut - g_fDirectionControlOut);
        g_nRighPWM = (int32)(g_fSpeedControlOut + g_fDirectionControlOut);
//        g_nLeftPWM = g_nLeftPWM*1.05;//電機差異補償
//        g_nRighPWM = g_nRighPWM;
        if(Flag_Stop == OFF)        //如果Flag_Stop == OFF電機輸出0
                  g_nLeftPWM = 0;g_nRighPWM = 0;
          if(g_nLeftPWM < 0)
                nLeftPWM = LeftDead - g_nLeftPWM;
                nLeftPWM = (nLeftPWM > 900? 900: nLeftPWM);
                ftm_pwm_duty(ftm2, ftm_ch2, nLeftPWM);
                ftm_pwm_duty(ftm2, ftm_ch3, 0);
                nLeftPWM = LeftDead + g_nLeftPWM;
                ftm_pwm_duty(ftm2, ftm_ch2, 0);
                ftm_pwm_duty(ftm2, ftm_ch3, nLeftPWM);
        if(g_nRighPWM < 0)
                nRighPWM = RighDead - g_nRighPWM;
                nRighPWM = (nRighPWM > 900? 900: nRighPWM);
                ftm_pwm_duty(ftm2, ftm_ch4, 0);
                ftm_pwm_duty(ftm2, ftm_ch5, nRighPWM);
                nRighPWM = RighDead + g_nRighPWM;
                ftm_pwm_duty(ftm2, ftm_ch4, nRighPWM);
                ftm_pwm_duty(ftm2, ftm_ch5, 0);
* @file                計算速度偏差
* @note              產生全局變量g_fSpeedError
* @date                2017
void CalSpeedError(void)
        static float fSpeedOld = 0, fSpeedNew = 0;
        g_nLeftpulse = (gpio_get(Coder_dir_left) ==1?ftm_count_get(ftm0):-ftm_count_get(ftm0));//讀取左輪脈沖
        ftm_count_clean(ftm0);
        g_nRighpulse = (gpio_get(Coder_dir_right)==0?ftm_count_get(ftm1):-ftm_count_get(ftm1));//讀取右輪脈沖
        ftm_count_clean(ftm1);
        g_fLeftRealSpeed = g_nLeftpulse*Ratio_Encoder_Left;
        g_fLeftRealSpeed = (g_fLeftRealSpeed>3400?3400:g_fLeftRealSpeed);                //濾左編碼器的噪聲
        g_fRighRealSpeed = g_nRighpulse*Ratio_Encoder_Righ;
        g_fRighRealSpeed = (g_fRighRealSpeed>3400?3400:g_fRighRealSpeed);                //濾右編碼器的噪聲
        g_fRealSpeed = (g_fLeftRealSpeed + g_fRighRealSpeed)*0.5;                                //真實速度
        //速度采集梯度平滑,每次采集最大變化200
        fSpeedOld = g_fSpeedFilter;
        fSpeedNew = g_fRealSpeed;
        if(fSpeedNew>=fSpeedOld)
                g_fSpeedFilter = ((fSpeedNew-fSpeedOld)>300?(fSpeedOld+300):fSpeedNew);
                g_fSpeedFilter = ((fSpeedNew-fSpeedOld)<-300?(fSpeedOld-300):fSpeedNew);
        //flash中參數
//        g_fExpectSpeed = float05;  //2800
        g_fSpeedError =  g_fExpectSpeed - g_fSpeedFilter;
        g_fSpeedErrorTemp[4] = g_fSpeedErrorTemp[3];
        g_fSpeedErrorTemp[3] = g_fSpeedErrorTemp[2];
        g_fSpeedErrorTemp[2] = g_fSpeedErrorTemp[1];
        g_fSpeedErrorTemp[1] = g_fSpeedErrorTemp[0];
        g_fSpeedErrorTemp[0] = g_fSpeedError;
* @file                速度控制
* @note              速度梯度平滑
* @date                2017
void SpeedControl(void)
        int8 index=1;
        CalSpeedError();        //計算速度偏差
        g_fSpeedError = (g_fSpeedError>800?800:g_fSpeedError);//速度偏差限幅
        //flash中參數
//        g_speedControl_P = float06;        //320
//        g_speedControl_I = float07;        //100
        //積分分離
        if((g_fSpeedError<=300)&&(g_fSpeedError>=-300))
        index=1;
        index=0;
        fSpeedErrorInteg = index *float08 * g_fSpeedError * 0.00001;
        if(Flag_Stop==OFF|Flag_Speed==OFF)
                fSpeedErrorInteg = 0;        //停車積分清零
        //fSpeedErrorInteg = (fSpeedErrorInteg < 0.0? 0.0: fSpeedErrorInteg);//積分下限
        //fSpeedErrorInteg = (fSpeedErrorInteg > 400.0? 400.0: fSpeedErrorInteg);//積分上限
        //速度控制算法(增量式PI)
        g_fSpeedControlOut += g_speedControl_P*0.005*(g_fSpeedErrorTemp[0]-g_fSpeedErrorTemp[1]) + fSpeedErrorInteg;
        g_fSpeedControlOut = (g_fSpeedControlOut>=6000?6000:g_fSpeedControlOut);
電磁三輪車.zip
4.76 MB, 下載次數: 38, 下載積分: 黑幣 -5
ID:363252 發表于 2018-7-2 17:03 | 只看該作者
供大家學習參考
ID:339618 發表于 2018-7-6 10:09 | 只看該作者
比賽可以用嗎
ID:282650 發表于 2019-12-8 10:59 | 只看該作者
感謝!!不過還是有些看不懂
主站蜘蛛池模板: 精品久久久久久久久久久久久 | 九九在线免费视频 | 91精品国产综合久久久久久 | 亚洲欧美日韩国产 | 操操影院 | 欧美在线观看视频 | 999av| 国产美女毛片 | 毛片网站免费观看 | 亚洲深夜福利 | 欧美在线视频一区二区 | 日韩在线视频一区二区三区 | 小镇姑娘国语版在线观看免费 | 成人做爰www看视频软件 | 色综合久久综合 | 国内精品久久久久久久久 | 丝袜美腿亚洲综合 | 欧美一区二区三区在线观看 | 亚洲国产一区在线 | 亚洲一级大片 | 成年免费视频黄网站在线观看 | 五月网站 | 国产欧美日韩视频 | 日韩精品视频一区二区三区 | 黄色小说网站在线观看 | 97色伦图片| 免费一区二区 | 黄色一级大片在线免费看国产一 | 不卡视频在线观看 | 国产午夜三级 | 夜夜操狠狠操 | 色综合天天综合网国产成人网 | 国产精品三级在线 | 日日日日干 | 国产成人91 | 亚州精品视频 | av网站在线看 | 香蕉视频网站 | 亚洲成人免费观看 | www.爱爱| 天天爽天天操 |
