查看: 5011|回復: 4
使用CreateFile讀取SD卡數據
ID:254919 發表于 2018-7-20 22:52 | 顯示全部樓層 |閱讀模式
使用CreateFile讀取SD卡數據
SD卡沒有文件系統,通過讀取自定義寫入SD卡的開頭標志數據來檢測
  1. //#include "stdafx.h"
  2. #include <windows.h>
  3. #include <conio.h>
  4. #include <stdio.h>
  5. #include <tchar.h>
  6. #include<string.h>
  7. #include <winioctl.h>
  8. //#include <ntddscsi.h>
  9.
  10.
  11. // òÔCreateFile·½ê½¶áè¡éèÇø¿a1Ø
  12. #define SECTOR
  13. char SD_Flag = 0;
  14. char Disk_Name[22] = {"\\\\.\\Physicaldrive2"};
  15. char SD_Flag_byte[2048] = {0};
  16. HANDLE hDev;
  17. char SD_judge();
  18. int SD_Read();
  19. int fire();
  20. int main (INT Argc, _TCHAR *Argv[])
  21. {
  22.    system("title SD¿¨êy¾Y¶áè¡3ìDò(WindowsרóÃ) lalala");
  23.     SD_judge();
  24.    // fire();
  25.     if(SD_Flag == 1)
  26.     {
  27.       SD_Read();
  28.     }
  29.      //printf("0x%x",EOF);
  30.      getch();
  31.         return 0;
  32. }
  33. char SD_judge()
  34. {
  35.     int i = 0;
  36.     HANDLE hDev;
  37.         char Disk_Flag = 0;
  38. for(int a = 0; a < 6; a++)
  39. {
  40.     Disk_Name[17]=a+'0';
  41.             for(int r = 0;r<22;r++)
  42.         {
  43.                 printf("%c%",Disk_Name[r]);
  44.         }
  45.     hDev=CreateFile( Disk_Name,
  46.                          GENERIC_READ,
  47.                                          FILE_SHARE_WRITE,
  48.                                          0,
  49.                                          OPEN_EXISTING,
  50.                                          0,
  51.                                          0);
  52.     if (hDev == INVALID_HANDLE_VALUE)
  53.     {
  54.         printf("CreatFile Error  ");
  55.         DWORD ret = GetLastError();
  56.         printf("CreateFile code%x  ",ret);
  57.     }
  58.
  59.     int j;
  60.         char Flag_byte[5] = {0x3c,0x53,0x44,0x43,0x3e};
  61.     DWORD dwRet_Flag = 0;
  62.     ReadFile(hDev,SD_Flag_byte,512,&dwRet_Flag,0);
  63.     if (dwRet_Flag < 0)
  64.     {
  65.         printf("ReadFile Error\n");
  66.         DWORD ret = GetLastError();
  67.         printf("CreateFile code%x\n",ret);
  68.     }
  69.     for(j=0; j<5; j++)  //¼ì2aSD¿¨í·ËÄλ±êÖ¾
  70.     {
  71.        printf("%x    " ,SD_Flag_byte[j]);
  72.        if(SD_Flag_byte[j] == Flag_byte[j])
  73.              Disk_Flag++;
  74.     }
  75.     if(Disk_Flag != 5)
  76.     {
  77.        CloseHandle(hDev);
  78.            printf("¸Ã′ÅÅì2»êÇSD¿¨\n");
  79.     }
  80.     else
  81.     {
  82.       printf("¼ì2aμ½SD¿¨\n");
  83.       SD_Flag = 1;
  84.       CloseHandle(hDev);
  85.       return 1;
  86.     }
  87.         if((a == 5)&&(Disk_Flag != 5))
  88.           {
  89.               printf("SD¿¨Î′2åèë\n");
  90.                 return 0;
  91.       }
  92.   }
  93. }
  94. //
  95. int SD_Read()
  96. {
  97.
  98. //        char ad[8]={0x4e,0x28,0x00,0x00,0x15,0x00,0x00,0x00};
  99. //        printf("%d\n%d\n%d", *(signed int *)ad, *(signed int *)(ad+4), *(signed int *)&ad[4]);
  100.
  101.     int Byte_num = 0;
  102.     char a[512] = {0};
  103.     DWORD dwRet_Flag = 0;
  104.     char Flag_byte[5] = {0x3c,0x53,0x44,0x43,0x3e};
  105.
  106.     FILE *fp;
  107.     fp = fopen("SD_data.dat","wb");
  108.
  109.     fwrite(Flag_byte,sizeof(char),5,fp); //qqqqqqqqqq
  110.            for(int r = 0;r<20;r++)
  111.         {
  112.                 printf("%c",Disk_Name[r]);
  113.
  114.         }
  115.         printf("\n");
  116.     dwRet_Flag = 0;
  117.
  118.     hDev=CreateFile( Disk_Name,
  119.                          GENERIC_READ,
  120.                                          FILE_SHARE_WRITE,
  121.                                          0,
  122.                                          OPEN_EXISTING,
  123.                                          0,
  124.                                          0);
  125.     if (hDev == INVALID_HANDLE_VALUE)
  126.     {
  127.         printf("CreatFile Error\n");
  128.         DWORD ret = GetLastError();
  129.         printf("CreateFile code%x\n",ret);
  130.                 return 0;
  131.     }
  132.     ReadFile(hDev,a,512,&dwRet_Flag,0);
  133.     for(int t=0; t< 20; t++)
  134.     {
  135.         printf("%x    " ,a[t]);
  136.     }
  137.     printf("\n");
  138.     int data_size = *(signed int *)&a[8];
  139.         int data_block = *(signed int *)&a[12];
  140.         int data_count = *(signed int *)&a[16];
  141.         printf("data_size:%d\ndata_block:%d\ndata_count:%d\n", data_size, data_block, data_count);
  142.     printf("\n");
  143.
  144.     Byte_num = data_block*512;
  145.     char *buffer=(char *)malloc(Byte_num);
  146.
  147.    if (dwRet_Flag < 0)
  148.     {
  149.         printf("ReadFile Error\n");
  150.         DWORD ret = GetLastError();
  151.         printf("CreateFile code%x\n",ret);
  152.                 return 0;
  153.     }
  154.         printf("ÕyÔú¶áè¡¡£¡£¡£¡£\n");
  155.     for(int x = 0;x < data_count;x++)  //¶áè¡êy¾Y
  156.          {
  157.            //fwrite(0,sizeof(int),1,fp);
  158.            fwrite((char *)&data_size,sizeof(int),1,fp);
  159.            ReadFile(hDev,buffer,Byte_num,&dwRet_Flag,0);
  160.            fwrite(buffer,sizeof(char),data_size,fp);
  161.                    printf("\rÇëμè′y %d", x);
  162.
  163.       }
  164.     //fclose(fp);
  165.     char b[4] = {0,0,0,0};
  166.     fwrite(b,sizeof(char),4,fp);
  167.     //fwrite(b,sizeof(b[0]),strlen(b),fp);
  168.      CloseHandle(hDev);
  169.       fclose(fp);
  170.      printf("  ¶áè¡íê3飡\n");
  171.          free(buffer);
  172. }
SD卡
ID:524389 發表于 2019-4-29 13:43 | 顯示全部樓層
樓主,請問一下char Flag_byte[5] =  {0x3c,0x53,0x44,0x43,0x3e};     0x3c,0x53,0x44,0x43,0x3e表示什么意思?謝謝
ID:524389 發表于 2019-4-29 13:38 | 顯示全部樓層
devcang 發表于 2018-7-20 23:34
CTRL+C
CTRL+V
編碼不對,造成
樓主,請問一下 char Flag_byte[5] = {0x3c,0x53,0x44,0x43,0x3e};中的0x3c,0x53,0x44,0x43,0x3e表示什么意思?謝謝
ID:1 發表于 2018-7-20 23:42 | 顯示全部樓層
最好傳個壓縮包
ID:277550 發表于 2018-7-20 23:34 | 顯示全部樓層
CTRL+C
CTRL+V
編碼不對,造成
里面的中文字,全亂碼了
主站蜘蛛池模板: 成人精品国产一区二区4080 | 人人爽人人爽人人片av | 99re国产视频 | 亚洲国产成人精品久久久国产成人一区 | 国产精品久久久久一区二区 | 免费av手机在线观看 | 成人在线观看免费视频 | 国产高清精品一区二区三区 | 亚洲精品中文字幕中文字幕 | 国产视频h | 日韩小视频 | 日韩久久久久久 | av在线黄| 性一交一乱一透一a级 | 中文字幕精品一区二区三区精品 | 国产激情视频在线 | 美女在线一区二区 | 国外成人在线视频网站 | 国产精品v | 欧美日韩1区2区 | 在线观看国产h | 福利视频一区二区三区 | 免费的色网站 | 麻豆毛片 | 二区视频 | 亚洲一区 | 涩涩视频网站在线观看 | 国产精品久久久久久久久久久免费看 | 日韩精品一区二区三区中文在线 | 久久久精品一区 | 国产精品美女久久久久久久久久久 | 操操操av | 国产亚洲精品精品国产亚洲综合 | 91精品国产综合久久婷婷香蕉 | 欧美精品a∨在线观看不卡 欧美日韩中文字幕在线播放 | 请别相信他免费喜剧电影在线观看 | 欧美大片一区 | 国产精品国产三级国产aⅴ入口 | 在线日韩av电影 | 国产精品欧美一区二区三区不卡 | 亚洲高清一区二区三区 |
