查看: 4313|回復: 1
Msp430f5529跟FDC2214源碼與資料下載
ID:240626 發表于 2018-7-21 12:57 | 顯示全部樓層 |閱讀模式
例程跟2018ti杯d題
全部資料51hei下載地址:
FDC2214_F5529_Good程序.rar (66.03 KB, 下載次數: 70)
MSP430F5529 TI官方開發板的實例程序(非常好).rar (611.21 KB, 下載次數: 56)
Msp430f5529單片機驅動fdc2214的源碼:
  1. #include <msp430F5529.h>
  2. #include "IIC_Soft.h"
  3. #include "FDC2214.h"
  4. #include "delay.h"
  5. #define uint8_t unsigned char
  6. #define UCA1_OS   1    // 1 = oversampling mode, 0 = low-freq mode
  7. #define UCA1_BR0  17   // Value of UCA1BR0 register
  8. #define UCA1_BR1  0    // Value of UCA1BR1 register
  9. #define UCA1_BRS  0    // Value of UCBRS field in UCA1MCTL register
  10. #define UCA1_BRF  6    // Value of UCBRF field in UCA1MCTL register
  11. void bcUartSend(uint8_t * buf, uint8_t len);
  12. void delay_ms(unsigned int count);
  13. void UartSend(uint8_t * buf);
  14. void sys_clk_config(void);
  15. void uart_config(void);
  16. unsigned char HexToChar(unsigned char bHex);
  17. /*
  18. * main.c
  19. */
  20. int main(void) {
  21.         unsigned long ch0_value = 0;
  22.         unsigned char dat[8]=0;
  23.     WDTCTL = WDTPW + WDTHOLD;
  24.     sys_clk_config();
  25.     uart_config();
  26.     __bis_SR_register(GIE);
  27.     FDC2214_Init();
  28. //    __bis_SR_register(LPM0_bits + GIE); // Enter LPM0, interrupts enabled
  29. //    __no_operation(); // For debugger
  30.     while(1)
  31.     {
  32.             ch0_value = FDC2214_GetResult(0);  //讀取通道0,發送到串口,轉為字符型方便觀察。
  33.             UartSend("Ch0_value is:");
  34.             dat[0] = (unsigned char)(((ch0_value>>24)>>4)&0X0F);
  35.             dat[0] = HexToChar(dat[0]);
  36.             Uart_Send_Char(dat[0]);
  37.             dat[0] = (unsigned char)(((ch0_value>>24)>>0)&0X0F);
  38.             dat[0] = HexToChar(dat[0]);
  39.             Uart_Send_Char(dat[0]);
  40.             dat[0] = (unsigned char)(((ch0_value>>16)>>4)&0X0F);
  41.             dat[0] = HexToChar(dat[0]);
  42.             Uart_Send_Char(dat[0]);
  43.             dat[0] = (unsigned char)(((ch0_value>>16)>>0)&0X0F);
  44.             dat[0] = HexToChar(dat[0]);
  45.             Uart_Send_Char(dat[0]);
  46.             dat[0] = (unsigned char)(((ch0_value>>8)>>4)&0X0F);
  47.             dat[0] = HexToChar(dat[0]);
  48.             Uart_Send_Char(dat[0]);
  49.             dat[0] = (unsigned char)(((ch0_value>>8)>>0)&0X0F);
  50.             dat[0] = HexToChar(dat[0]);
  51.             Uart_Send_Char(dat[0]);
  52.             dat[0] = (unsigned char)(((ch0_value>>0)>>4)&0X0F);
  53.             dat[0] = HexToChar(dat[0]);
  54.             Uart_Send_Char(dat[0]);
  55.             dat[0] = (unsigned char)(((ch0_value>>0)>>0)&0X0F);
  56.             dat[0] = HexToChar(dat[0]);
  57.             Uart_Send_Char(dat[0]);
  58.             UartSend("\n");delay_ms(100);
  59.             ch0_value = FDC2214_GetResult(1);
  60.             UartSend("Ch1_value is:");
  61.             dat[0] = (unsigned char)(((ch0_value>>24)>>4)&0X0F);
  62.             dat[0] = HexToChar(dat[0]);
  63.             Uart_Send_Char(dat[0]);
  64.             dat[0] = (unsigned char)(((ch0_value>>24)>>0)&0X0F);
  65.             dat[0] = HexToChar(dat[0]);
  66.             Uart_Send_Char(dat[0]);
  67.             dat[0] = (unsigned char)(((ch0_value>>16)>>4)&0X0F);
  68.             dat[0] = HexToChar(dat[0]);
  69.             Uart_Send_Char(dat[0]);
  70.             dat[0] = (unsigned char)(((ch0_value>>16)>>0)&0X0F);
  71.             dat[0] = HexToChar(dat[0]);
  72.             Uart_Send_Char(dat[0]);
  73.             dat[0] = (unsigned char)(((ch0_value>>8)>>4)&0X0F);
  74.             dat[0] = HexToChar(dat[0]);
  75.             Uart_Send_Char(dat[0]);
  76.             dat[0] = (unsigned char)(((ch0_value>>8)>>0)&0X0F);
  77.             dat[0] = HexToChar(dat[0]);
  78.             Uart_Send_Char(dat[0]);
  79.             dat[0] = (unsigned char)(((ch0_value>>0)>>4)&0X0F);
  80.             dat[0] = HexToChar(dat[0]);
  81.             Uart_Send_Char(dat[0]);
  82.             dat[0] = (unsigned char)(((ch0_value>>0)>>0)&0X0F);
  83.             dat[0] = HexToChar(dat[0]);
  84.             Uart_Send_Char(dat[0]);
  85.             UartSend("\n");delay_ms(100);
  86.             ch0_value = FDC2214_GetResult(2);
  87.             UartSend("Ch2_value is:");
  88.             dat[0] = (unsigned char)(((ch0_value>>24)>>4)&0X0F);
  89.             dat[0] = HexToChar(dat[0]);
  90.             Uart_Send_Char(dat[0]);
  91.             dat[0] = (unsigned char)(((ch0_value>>24)>>0)&0X0F);
  92.             dat[0] = HexToChar(dat[0]);
  93.             Uart_Send_Char(dat[0]);
  94.             dat[0] = (unsigned char)(((ch0_value>>16)>>4)&0X0F);
  95.             dat[0] = HexToChar(dat[0]);
  96.             Uart_Send_Char(dat[0]);
  97.             dat[0] = (unsigned char)(((ch0_value>>16)>>0)&0X0F);
  98.             dat[0] = HexToChar(dat[0]);
  99.             Uart_Send_Char(dat[0]);
  100.             dat[0] = (unsigned char)(((ch0_value>>8)>>4)&0X0F);
  101.             dat[0] = HexToChar(dat[0]);
  102.             Uart_Send_Char(dat[0]);
  103.             dat[0] = (unsigned char)(((ch0_value>>8)>>0)&0X0F);
  104.             dat[0] = HexToChar(dat[0]);
  105.             Uart_Send_Char(dat[0]);
  106.             dat[0] = (unsigned char)(((ch0_value>>0)>>4)&0X0F);
  107.             dat[0] = HexToChar(dat[0]);
  108.             Uart_Send_Char(dat[0]);
  109.             dat[0] = (unsigned char)(((ch0_value>>0)>>0)&0X0F);
  110.             dat[0] = HexToChar(dat[0]);
  111.             Uart_Send_Char(dat[0]);
  112.             UartSend("\n");delay_ms(100);
  113.             ch0_value = FDC2214_GetResult(3);
  114.             UartSend("Ch3_value is:");
  115.             dat[0] = (unsigned char)(((ch0_value>>24)>>4)&0X0F);
  116.             dat[0] = HexToChar(dat[0]);
  117.             Uart_Send_Char(dat[0]);
  118.             dat[0] = (unsigned char)(((ch0_value>>24)>>0)&0X0F);
  119.             dat[0] = HexToChar(dat[0]);
  120.             Uart_Send_Char(dat[0]);
  121.             dat[0] = (unsigned char)(((ch0_value>>16)>>4)&0X0F);
  122.             dat[0] = HexToChar(dat[0]);
  123.             Uart_Send_Char(dat[0]);
  124.             dat[0] = (unsigned char)(((ch0_value>>16)>>0)&0X0F);
  125.             dat[0] = HexToChar(dat[0]);
  126.             Uart_Send_Char(dat[0]);
  127.             dat[0] = (unsigned char)(((ch0_value>>8)>>4)&0X0F);
  128.             dat[0] = HexToChar(dat[0]);
  129.             Uart_Send_Char(dat[0]);
  130.             dat[0] = (unsigned char)(((ch0_value>>8)>>0)&0X0F);
  131.             dat[0] = HexToChar(dat[0]);
  132.             Uart_Send_Char(dat[0]);
  133.             dat[0] = (unsigned char)(((ch0_value>>0)>>4)&0X0F);
  134.             dat[0] = HexToChar(dat[0]);
  135.             Uart_Send_Char(dat[0]);
  136.             dat[0] = (unsigned char)(((ch0_value>>0)>>0)&0X0F);
  137.             dat[0] = HexToChar(dat[0]);
  138.             Uart_Send_Char(dat[0]);
  139.             UartSend("\n");delay_ms(100);
  140.             UartSend("\n");                     //換行,延時,方便觀察數據
  141.             delay_ms(10000);delay_ms(10000);
  142.     }
  143. //        return 0;
  144. }
  145. /************USCI_A1中斷*************/
  146. #pragma vector=USCI_A1_VECTOR
  147. __interrupt void USCI_A1_ISR(void)
  148. {  switch(__even_in_range(UCA1IV,4))
  149.   {
  150.   case 0:break;
  151.   case 2:
  152.     while (!(UCA1IFG&UCTXIFG));
  153.     UCA1TXBUF = UCA1RXBUF;       // 將接收到的數據發送出去
  154.     break;
  155.   case 4:break;
  156.   default: break;
  157.   }
  158. }
  159. // Sends 'len' bytes, starting at 'buf'
  160. void bcUartSend(uint8_t * buf, uint8_t len)
  161. {
  162.     uint8_t i = 0;
  163.     // Write each byte in buf to USCI TX buffer, which sends it out
  164.     while (i < len)
  165.     {
  166.         UCA1TXBUF = *(buf+(i++));
  167. //      while (!(UCA1IFG&UCTXIFG));
  168. //      delay_ms(20);
  169. //      Wait until each bit has been clocked out...
  170.         while(!(UCTXIFG==(UCTXIFG & UCA1IFG))&&((UCA1STAT & UCBUSY)==UCBUSY));
  171.     }
  172. }
  173. void UartSend(uint8_t * buf)
  174. {
  175.         while(*buf !='\0')
  176.         {
  177.                 while (!(UCA1IFG&UCTXIFG));
  178.                 UCA1TXBUF=*buf;
  179.                 *buf++;
  180.                 delay_ms(2);
  181.         }
  182. }
  183. void Uart_Send_Char(uint8_t dat)
  184. {
  185.                 while (!(UCA1IFG&UCTXIFG));
  186.                 UCA1TXBUF=dat;
  187. }
  188. void delay_ms(unsigned int count)
  189. {
  190.   unsigned int i,j;
  191.   for(i=0;i<count;i++)
  192.           for(j=0;j<10;j++)
  193.                   delay_us();
  194. }
  195. void sys_clk_config(void)  //外部晶振4M
  196. {
  197.     P5SEL |= BIT2|BIT3;
  198.     UCSCTL6 &= ~XT2OFF;
  199.     UCSCTL4 = UCSCTL4&(~(SELA_7))|SELA_1;
  200.     UCSCTL3 |= SELREF_2;
  201.     while (SFRIFG1 & OFIFG)
  202.     {
  203.       UCSCTL7 &= ~(XT2OFFG + XT1LFOFFG + DCOFFG);
  204.       SFRIFG1 &= ~OFIFG;
  205.     }
  206.     UCSCTL4 = UCSCTL4&(~(SELS_7|SELM_7))|SELS_5|SELM_5;
  207. }
  208. void uart_config(void)
  209. {
  210.     P4SEL |= BIT4+BIT5;
  211.     UCA1CTL1 |= UCSWRST;
  212.     UCA1CTL1 |= UCSSEL_2;
  213.     UCA1BR0 = 34;//115200,外部4M
  214.     UCA1BR1 = 0;
  215.     UCA1MCTL |= UCBRS_6+UCBRF_0;
  216.     UCA1CTL1 &= ~UCSWRST;
  217.     UCA1IE |= UCRXIE;
  218. }
  219. unsigned char HexToChar(unsigned char bHex)
  220. {
  221.         if((bHex>=0)&&(bHex<=9))
  222.         {
  223.                 bHex += 0x30;
  224.         }
  225.         else if((bHex>=10)&&(bHex<=15))//Capital
  226.         {
  227.                 bHex += 0x37;
  228.         }
  229.         else
  230.         {
  231.                 bHex = 0xff;
  232.         }
  233.         return bHex;
  234. }
ID:346674 發表于 2018-7-22 00:32 | 顯示全部樓層
232021045.248是什么。。。
主站蜘蛛池模板: 亚洲小说欧美激情另类 | 亚洲高清视频在线观看 | 能看的av| 免费在线小视频 | 91av免费观看| 成人精品视频在线观看 | 日产精品久久久一区二区 | 国产成人综合在线 | 欧美综合久久 | 国产麻豆视频 | 欧美成人一区二区 | 91最新视频 | 福利影院在线观看 | 在线观看免费av网站 | 欧美日在线 | 中文在线字幕观看 | 狠狠干2021| www国产视频 | 国产一级自拍 | 日韩免费精品视频 | 午夜影院在线观看视频 | 亚洲成人中文字幕 | 国产69精品久久久久久 | 国产又粗又黄又爽又硬的视频 | 国产精品久久久一区二区三区 | 国产午夜精品一区二区三区视频 | 99热精品在线观看 | 九九九精品视频 | 欧美日韩成人一区二区 | 天天综合视频 | eeuss一区二区三区 | 日日干av| 日韩成人精品一区二区 | 亚洲精选一区 | 一级黄色免费视频 | 成年在线观看 | 久久精品久久久久 | 黄色大片免费在线观看 | 亚洲天天看 | 91蝌蚪91九色白浆 | 日韩在线欧美 |
