查看: 4530|回復: 0
VL53L0X激光測距的ARDUINO源碼與資料下載
ID:381728 發表于 2018-8-1 15:42 | 顯示全部樓層 |閱讀模式
請問有使用過VL53L0X這個模塊的嗎?
  1. //the original code by Ted Meyers
  2. //posted here: https://groups.google.com/d/msg/diyrovers/lc7NUZYuJOg/ICPrYNJGBgAJ
  3. #include <Wire.h>
  4. #define VL53L0X_REG_IDENTIFICATION_MODEL_ID         0xc0
  5. #define VL53L0X_REG_IDENTIFICATION_REVISION_ID      0xc2
  6. #define VL53L0X_REG_PRE_RANGE_CONFIG_VCSEL_PERIOD   0x50
  7. #define VL53L0X_REG_FINAL_RANGE_CONFIG_VCSEL_PERIOD 0x70
  8. #define VL53L0X_REG_SYSRANGE_START                  0x00
  9. #define VL53L0X_REG_RESULT_INTERRUPT_STATUS         0x13
  10. #define VL53L0X_REG_RESULT_RANGE_STATUS             0x14
  11. #define address 0x29
  12. byte gbuf[16];
  13. void setup() {
  14.   // put your setup code here, to run once:
  15.   Wire.begin();        // join i2c bus (address optional for master)
  16.   Serial.begin(9600);  // start serial for output
  17.   Serial.println("VLX53LOX test started.");
  18. }
  19. void loop() {
  20.   Serial.println("----- START TEST ----");
  21.   test();
  22.   Serial.println("----- END TEST ----");
  23.   Serial.println("");
  24.   delay(1000);
  25. }
  26. void test() {
  27.   byte val1 = read_byte_data_at(VL53L0X_REG_IDENTIFICATION_REVISION_ID);
  28.   Serial.print("Revision ID: "); Serial.println(val1);
  29.   val1 = read_byte_data_at(VL53L0X_REG_IDENTIFICATION_MODEL_ID);
  30.   Serial.print("Device ID: "); Serial.println(val1);
  31.   val1 = read_byte_data_at(VL53L0X_REG_PRE_RANGE_CONFIG_VCSEL_PERIOD);
  32.   Serial.print("PRE_RANGE_CONFIG_VCSEL_PERIOD="); Serial.println(val1);
  33.   Serial.print(" decode: "); Serial.println(VL53L0X_decode_vcsel_period(val1));
  34.   val1 = read_byte_data_at(VL53L0X_REG_FINAL_RANGE_CONFIG_VCSEL_PERIOD);
  35.   Serial.print("FINAL_RANGE_CONFIG_VCSEL_PERIOD="); Serial.println(val1);
  36.   Serial.print(" decode: "); Serial.println(VL53L0X_decode_vcsel_period(val1));
  37.   write_byte_data_at(VL53L0X_REG_SYSRANGE_START, 0x01);
  38.   byte val = 0;
  39.   int cnt = 0;
  40.   while (cnt < 100) { // 1 second waiting time max
  41.     delay(10);
  42.     val = read_byte_data_at(VL53L0X_REG_RESULT_RANGE_STATUS);
  43.     if (val & 0x01) break;
  44.     cnt++;
  45.   }
  46.   if (val & 0x01) Serial.println("ready"); else Serial.println("not ready");
  47.   read_block_data_at(0x14, 12);
  48.   uint16_t acnt = makeuint16(gbuf[7], gbuf[6]);
  49.   uint16_t scnt = makeuint16(gbuf[9], gbuf[8]);
  50.   uint16_t dist = makeuint16(gbuf[11], gbuf[10]);
  51.   byte DeviceRangeStatusInternal = ((gbuf[0] & 0x78) >> 3);
  52.   Serial.print("ambient count: "); Serial.println(acnt);
  53.   Serial.print("signal count: ");  Serial.println(scnt);
  54.   Serial.print("distance ");       Serial.println(dist);
  55.   Serial.print("status: ");        Serial.println(DeviceRangeStatusInternal);
  56. }
  57. uint16_t bswap(byte b[]) {
  58.   // Big Endian unsigned short to little endian unsigned short
  59.   uint16_t val = ((b[0] << 8) & b[1]);
  60.   return val;
  61. }
  62. uint16_t makeuint16(int lsb, int msb) {
  63.     return ((msb & 0xFF) << 8) | (lsb & 0xFF);
  64. }
  65. void write_byte_data(byte data) {
  66.   Wire.beginTransmission(address);
  67.   Wire.write(data);
  68.   Wire.endTransmission();
  69. }
  70. void write_byte_data_at(byte reg, byte data) {
  71.   // write data word at address and register
  72.   Wire.beginTransmission(address);
  73.   Wire.write(reg);
  74.   Wire.write(data);
  75.   Wire.endTransmission();
  76. }
  77. void write_word_data_at(byte reg, uint16_t data) {
  78.   // write data word at address and register
  79.   byte b0 = (data &0xFF);
  80.   byte b1 = ((data >> 8) && 0xFF);
  81.
  82.   Wire.beginTransmission(address);
  83.   Wire.write(reg);
  84.   Wire.write(b0);
  85.   Wire.write(b1);
  86.   Wire.endTransmission();
  87. }
  88. byte read_byte_data() {
  89.   Wire.requestFrom(address, 1);
  90.   while (Wire.available() < 1) delay(1);
  91.   byte b = Wire.read();
  92.   return b;
  93. }
  94. byte read_byte_data_at(byte reg) {
  95.   //write_byte_data((byte)0x00);
  96.   write_byte_data(reg);
  97.   Wire.requestFrom(address, 1);
  98.   while (Wire.available() < 1) delay(1);
  99.   byte b = Wire.read();
  100.   return b;
  101. }
  102. uint16_t read_word_data_at(byte reg) {
  103.   write_byte_data(reg);
  104.   Wire.requestFrom(address, 2);
  105.   while (Wire.available() < 2) delay(1);
  106.   gbuf[0] = Wire.read();
  107.   gbuf[1] = Wire.read();
  108.   return bswap(gbuf);
  109. }
  110. void read_block_data_at(byte reg, int sz) {
  111.   int i = 0;
  112.   write_byte_data(reg);
  113.   Wire.requestFrom(address, sz);
  114.   for (i=0; i<sz; i++) {
  115.     while (Wire.available() < 1) delay(1);
  116.     gbuf[i] = Wire.read();
  117.   }
  118. }
  119. uint16_t VL53L0X_decode_vcsel_period(short vcsel_period_reg) {
  120.   // Converts the encoded VCSEL period register value into the real
  121.   // period in PLL clocks
  122.   uint16_t vcsel_period_pclks = (vcsel_period_reg + 1) << 1;
  123.   return vcsel_period_pclks;
  124. }
GY-530 VL53L0X激光測距傳感器模塊 ToF測距 飛行時間測距傳感器.rar (1.01 MB, 下載次數: 29)
主站蜘蛛池模板: 这里只有精品视频在线观看 | 欧美在线一级 | 成年女人毛片 | 国产精品高清在线观看 | 日韩欧美亚洲国产 | 超碰成人网 | 懂色av懂色av粉嫩av | 色爱av | 国产精品自拍第一页 | 天天拍天天干 | 九九久久久 | 欧美二三区 | 一区二区三区蜜桃 | 国产欧美久久久 | 婷婷六月综合 | 青青视频网 | 久久九九精品 | 国产成人免费观看 | 诱人的大乳奶3做爰 | av男人天堂网 | 成人看片网 | 糖心vlog精品一区二区 | 日韩色在线| 高清视频一区二区 | 亚洲做受高潮无遮挡 | 99精品免费视频 | 91在线免费视频观看 | 欧美日韩免费一区二区三区 | 毛片视频免费观看 | 国产成人亚洲精品自产在线 | 免费毛片观看 | 欧美日韩精品在线 | 久久久一区二区 | 深夜福利在线播放 | 午夜免费观看视频 | 麻豆av在线| 日韩在线观看中文字幕 | aaa免费视频 | 91色网站 | 视频在线观看一区 | 国产亚洲视频在线观看 |
