查看: 4175|回復: 0
哪位大俠幫忙指點一下51單片機在4個字的LED顯示屏存在問題!
ID:33675 發(fā)表于 2012-1-8 21:35 | 顯示全部樓層 |閱讀模式
問題是這樣的:
字體取模后,導入程序中去。顯示時是反的:比如:專業(yè)制作 變成:作制業(yè)專。取模軟件里也水平翻轉了也不行。每次要用【文字倒寫軟件】:變成:作制業(yè)專
輸入到取模軟件里,再水平翻轉,然后生產字模數(shù)據(jù)。再導入程序中,真是N麻煩!有哪位高手幫我指點一下,本人是學生。謝謝了!
付程序:
#include " reg51.h"
#define BLKN 8
#define  TOTAL 4//注明顯示字個數(shù)//
#define  CONIO P0//定義輸出端口//
sbit G = CONIO^7;//G1=P1.7=8腳//
sbit CLK = CONIO^6;//RCLK=P1.6=7腳//
sbit SCLR = CONIO^5;//SRCLK=P1.5=6腳//
unsigned char idata dispram[(BLKN/2)*32]={0};//顯示區(qū)緩存,4字共*32單元//
unsigned char code Bmp[][32]={
0xFE,0xFF,0xFE,0xFF,0xC0,0x07,0xFD,0xFF,0xFD,0xFF,0x00,0x01,0xFB,0xFF,0xF7,0xDF,
0xF0,0x0F,0xFF,0xDF,0xFF,0xBF,0xFD,0x7F,0xFE,0xFF,0xFF,0x7F,0xFF,0xBF,0xFF,0xFF,/*"專",0*/
0xFB,0xBF,0xFB,0xBF,0xFB,0xBF,0xFB,0xBB,0xBB,0xB9,0xDB,0xB3,0xDB,0xB7,0xEB,0xAF,
0xE3,0xAF,0xEB,0x9F,0xFB,0xBF,0xFB,0xBF,0xFB,0xBB,0x00,0x01,0xFF,0xFF,0xFF,0xFF,/*"業(yè)",1*/
0xDB,0xFB,0xCB,0xFB,0xDB,0xDB,0xC0,0x5B,0xBB,0xDB,0xFB,0xDB,0x80,0x5B,0xFB,0xDB,
0xC0,0x5B,0xDB,0x5B,0xDB,0x5B,0xDB,0x5B,0xDB,0x7B,0xD8,0x7B,0xFA,0xEB,0xFB,0xF7,/*"制",2*/
0xF7,0x7F,0xF3,0x7F,0xF6,0xFF,0xEC,0x01,0xED,0x7F,0xCB,0x77,0xAF,0x03,0x6F,0x7F,
0xEF,0x7F,0xEF,0x7B,0xEF,0x01,0xEF,0x7F,0xEF,0x7F,0xEF,0x7F,0xEF,0x7F,0xEF,0x7F,/*"作",3*/
/****延時函數(shù)(約1MS)**********/
void delay(unsigned int dt)
register unsigned char bt;
for(;dt;dt--)
for(bt=0;bt<255;bt++);
/******主函數(shù)********/
void  main (void)
register unsigned char q,w ,i,j,k;     //i,j,k,l,q,w;
//初始化
SCON = 0x00;
TMOD = 0x01;
TR0 = 1;
CONIO = 0x3f;
IE = 0x82;
delay(2000);//2S
問題就是在下面程序不知怎么更改:才能把字體顯示順序正常!請求幫忙!
// 卷簾顯示文字,每次字數(shù)為BLKN/2,共顯示TOTAL*2/BLKN次
for(w=0;w< TOTAL*2/BLKN;w++)
for(i=0;i<32;i++)
for(q=0;q<BLKN/2;q++){dispram[i+q*32]=Bmp[q+w*BLKN/2];}
if(i%2) delay(100);//移動時間
delay(2000);//停止時間
 //第二種顯示效果,向上滾屏,每次BLKN/2個字
for(i=0;i<TOTAL*2/BLKN;i++)
for(j=0;j<16;j++)
   for(k=0;k<15;k++)
{dispram[k*2+q*32] = dispram[(k+1)*2+q*32];
dispram[k*2+1+q*32] = dispram[(k+1)*2+1+q*32];}
{dispram[30+q*32] = Bmp[q+i*BLKN/2][j*2];
dispram[31+q*32] = Bmp[q+i*BLKN/2][j*2+1];}
delay(100);
delay(1000);       //滾動暫停
以下是左移方式時,字又正常!
for(i=0;i<TOTAL;i++)
for(j=2;j>0;j--)
for(k=0;k<8;k++)
for(l=0;l<16;l++)
dispram[l*2+1+q*32]= dispram[l*2+1+q*32]>>1| dispram[l*2+q*32]<<7;
if(q==0) dispram[l*2+q*32]= dispram[l*2+q*32]>>1|Bmp[l*2+j-1]<<(7-k);
else dispram[l*2+q*32]= dispram[l*2+q*32]>>1| dispram[l*2+1+(q-1)*32]<<7;
delay(100);//移動時間
主站蜘蛛池模板: 国产精品看片 | 伊人国产在线 | 青青草免费在线视频 | 午夜美女福利视频 | yy6080午夜| 能看的av网站 | 91视频播放| 在线中文字幕网站 | 国产视频在线观看视频 | 天天色天天 | 午夜精品视频在线观看 | 亚洲一区免费视频 | 亚洲成人免费视频 | a级片免费| 国产综合亚洲精品一区二 | 久久国产亚洲 | 日本精品在线视频 | 欧美日韩色 | 黄色网址在线播放 | 午夜美女福利视频 | 毛片在线观看网站 | 三级网站视频 | 国产成人精品av在线观 | 国产精品久久久精品 | 日韩伊人 | 中文字幕一区二区在线播放 | 欧美性精品 | 噜噜视频 | 亚洲成a人 | 国产成人精品视频 | 98在线视频 | 青青草视频免费在线观看 | 一区二区视频在线 | 狠狠狠干 | h片在线免费观看 | 久久精品一区二区三区四区 | 婷婷综合视频 | 国产视频一区在线播放 | 免费毛片网站 | 在线观看欧美日韩 | 久久在线免费视频 |
