查看: 13454|回復: 16
全球首發,全世界第一個Proteus仿真Arduino控制OLED顯示張學友表情包
ID:230913 發表于 2018-8-12 14:35 | 顯示全部樓層 |閱讀模式
注:I2C地址為 0x3D
Arduino仿真原理圖如下(proteus仿真工程文件可到本帖附件中下載)
Arduino程序源碼:
  1. #include <SPI.h>
  2. #include <Wire.h>
  3. #include <Adafruit_GFX.h>
  4. #include <Adafruit_SSD1306.h>
  5. #define OLED_RESET 4
  6. Adafruit_SSD1306 display(OLED_RESET);
  7. static const unsigned char PROGMEM logo[] =
  8. {
  9. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFC,0x07,0xFF,
  10. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xF0,0x00,0xFF,0xFF,0x00,0xFF,0xFF,
  11. 0xFF,0xFF,0xFF,0xFF,0xFF,0xE0,0x00,0xFF,0xE0,0xFF,0x83,0xFF,0xFF,0xFF,0xFF,0xFF,
  12. 0xFF,0xC0,0x00,0x3C,0x0F,0xFF,0xFC,0x7F,0xF0,0x3F,0xFF,0xFF,0xFF,0x80,0x00,0x01,
  13. 0xFF,0xFF,0xFF,0x8F,0xC0,0x07,0xFF,0xFF,0xFF,0x80,0x00,0x0F,0xFF,0xFF,0xFF,0xE3,
  14. 0x00,0x03,0xFF,0xFF,0xFF,0x00,0x00,0x1F,0xFF,0xFF,0xFF,0xF8,0x00,0x01,0xFF,0xFF,
  15. 0xFF,0x00,0x00,0x3F,0xFF,0xFF,0xFF,0xFE,0x00,0x00,0xFF,0xFF,0xFF,0x00,0x00,0x7F,
  16. 0xFF,0xFF,0xFF,0xFF,0x00,0x00,0xFF,0xFF,0xFF,0x00,0x00,0xFF,0xFF,0xFF,0xFF,0xFF,
  17. 0x80,0x00,0x7F,0xFF,0xFF,0x00,0x00,0xFF,0xFF,0xFF,0xFF,0xFF,0xC0,0x00,0x7F,0xFF,
  18. 0xFF,0x00,0x01,0xFF,0xFF,0xFF,0xFF,0xFF,0xC0,0x00,0x7F,0xFF,0xFF,0x00,0x03,0xFF,
  19. 0xFF,0xFF,0xFF,0xFF,0xE0,0x00,0x7F,0xFF,0xFF,0x00,0x07,0xFF,0xFF,0xFF,0xFF,0xFF,
  20. 0xF0,0x00,0x3F,0xFF,0xFF,0x00,0x0F,0xFF,0xFF,0xFF,0xFF,0xFF,0xF0,0x00,0x3F,0xFF,
  21. 0xFF,0x00,0x0F,0xFF,0xFF,0xFF,0x83,0xFF,0xF8,0x00,0x3F,0xFF,0xFF,0x00,0x1F,0xFF,
  22. 0xFF,0xFF,0x80,0xFF,0xF8,0x00,0x3F,0xFF,0xFF,0x80,0x1F,0xFF,0x80,0xFF,0xC0,0x3F,
  23. 0xFC,0x00,0x7F,0xFF,0xFF,0xC0,0x3F,0xFC,0x00,0x7F,0xFF,0x3F,0xFC,0x00,0x7F,0xFF,
  24. 0xFF,0xC0,0x7F,0xF0,0x00,0x3F,0xFF,0xFF,0xFE,0x00,0xFF,0xFF,0xFF,0xE0,0x7F,0xF0,
  25. 0xFC,0x1F,0xFF,0xFF,0xFE,0x00,0xFF,0xFF,0xFF,0xF0,0x7F,0xFF,0xFF,0x7F,0xFF,0xFF,
  26. 0xFF,0x01,0xFF,0xFF,0xFF,0xF8,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x03,0xFF,0xFF,
  27. 0xFF,0xFE,0xFF,0xFF,0xC1,0xFF,0xC0,0xFF,0xFF,0x07,0xFF,0xFF,0xFF,0xFE,0xFF,0xFF,
  28. 0x01,0xFF,0xF0,0xFF,0xFF,0xBF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFC,0x03,0xFF,0xF3,0xFF,
  29. 0xFF,0xBF,0xFF,0xFF,0xFF,0xFD,0xFF,0xFF,0xEF,0xFF,0xFF,0xFF,0xFF,0xBF,0xFF,0xFF,
  30. 0xFF,0xF9,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xDF,0xFF,0xFF,0xFF,0xFB,0xFF,0xFF,
  31. 0xFF,0xFF,0xFF,0xFF,0xFF,0xDF,0xFF,0xFF,0xFF,0xFB,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  32. 0xFF,0xDF,0xFF,0xFF,0xFF,0xF7,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xDF,0xFF,0xFF,
  33. 0xFF,0xF7,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xDF,0xFF,0xFF,0xFF,0xF7,0xFF,0xFF,
  34. 0xFF,0xFF,0xFF,0xFF,0xFF,0xDF,0xFF,0xFF,0xFF,0xE7,0xFF,0xFF,0xFE,0xFF,0xFE,0xFF,
  35. 0xFF,0xCF,0xFF,0xFF,0xFF,0xEF,0xFF,0xFF,0xF8,0xFF,0xFE,0xFF,0xFF,0xEF,0xFF,0xFF,
  36. 0xFF,0xEF,0xFF,0xFF,0xF9,0xB0,0xE7,0x7F,0xFF,0xEF,0xFF,0xFF,0xFF,0xCF,0xFF,0xFF,
  37. 0xFF,0x00,0x0F,0xFF,0xFF,0xEF,0xFF,0xFF,0xFF,0x8F,0xFF,0xFF,0xFF,0xC0,0x3F,0xFF,
  38. 0xFF,0xE7,0xFF,0xFF,0xFF,0x0F,0xFF,0xFF,0xFF,0xFF,0x7F,0xFF,0xFF,0xE7,0xFF,0xFF,
  39. 0xFE,0x1F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xE3,0xFF,0xFF,0xFC,0x1F,0xFF,0xFF,
  40. 0xFF,0xFF,0xFF,0xFF,0xFF,0xE1,0xFF,0xFF,0xF8,0x1F,0xFF,0xFF,0xFF,0xF0,0x03,0xFF,
  41. 0xFF,0xE1,0xFF,0xFF,0xF8,0x0F,0xFF,0xFF,0xFF,0x80,0x01,0xFF,0xFF,0xE0,0xFF,0xFF,
  42. 0xF8,0x0F,0xFF,0xFF,0xFF,0x07,0xF1,0xFF,0xFF,0xE0,0xFF,0xFF,0xF8,0x07,0xFF,0xFF,
  43. 0xFF,0x01,0x01,0xFF,0xFF,0xE0,0x7F,0xFF,0xF8,0x07,0xFF,0xFF,0xFF,0x00,0x23,0xFF,
  44. 0xFF,0xC0,0x7F,0xFF,0xF8,0x07,0xFF,0xFF,0xFF,0x0F,0xFF,0xFF,0xFF,0xC0,0x3F,0xFF,
  45. 0xF8,0x03,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xC0,0x1F,0xFF,0xF8,0x01,0xFF,0xFF,
  46. 0xFF,0xFF,0xFF,0xFF,0xFF,0xC0,0x1F,0xFF,0xF8,0x00,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  47. 0xFF,0x80,0x1F,0xFF,0xF8,0x00,0xFF,0xFF,0xFF,0xC3,0xFF,0xFF,0xFF,0x00,0x0F,0xFF,
  48. 0xF8,0x00,0x3F,0xFF,0xFF,0xE0,0x0F,0xFF,0xFE,0x00,0x0F,0xFF,0xF8,0x00,0x1F,0xFF,
  49. 0xFF,0xF8,0x0F,0xFF,0xFC,0x00,0x0F,0xFF,0xF8,0x00,0x0F,0xFF,0xFF,0xFF,0xFF,0xFF,
  50. 0xF8,0x00,0x0F,0xFF,0xF8,0x00,0x03,0xFF,0xFF,0xFF,0xFF,0xFF,0xF0,0x00,0x0F,0xFF,
  51. 0xF8,0x00,0x01,0xFF,0xFF,0xFF,0xFF,0xFF,0xC0,0x00,0x0F,0xFF,0xF8,0x00,0x00,0xFF,
  52. 0xFF,0xFF,0xFF,0xFF,0x00,0x00,0x0F,0xFF,0xF8,0x00,0x00,0x1F,0xFF,0xFF,0xFF,0xF8,
  53. 0x00,0x00,0x0F,0xFF,0xF8,0x00,0x00,0x07,0xFF,0xFF,0xFF,0xC0,0x00,0x00,0x0F,0xFF,
  54. 0xF8,0x00,0x00,0x00,0xFF,0xFF,0xFF,0x00,0x00,0x00,0x0F,0xFF,0xF8,0x00,0x00,0x00,
  55. 0x0F,0xF8,0x00,0x00,0x00,0x00,0x0F,0xFF,0xF8,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  56. 0x00,0x00,0x0F,0xFF
  57. };
  58.
  59. #if (SSD1306_LCDHEIGHT != 64)
  60. #error("Height incorrect, please fix Adafruit_SSD1306.h!");
  61. #endif
  62. void setup()   {
  63.   Serial.begin(9600);
  64.   display.begin(SSD1306_SWITCHCAPVCC, 0x3D);
  65.   display.clearDisplay();
  66. }
  67. void loop() {
  68.   display.drawBitmap(19, 0, logo, 89, 63, 1);  //在坐標X0,Y0的位置開始顯示圖片
  69.                                                //128是取模軟件顯示的寬度
  70.                                                //64是取模軟件顯示的高度
  71.   display.display();                           //把緩存的都顯示
  72.   delay(1);
  73.
  74.   display.clearDisplay();     //清除屏幕
  75. }
全部資料51hei下載地址:
lcd.zip (37.9 KB, 下載次數: 238)
ID:369368 發表于 2019-3-11 16:41 | 顯示全部樓層
沒有庫,打不開
ID:188720 發表于 2019-3-13 11:32 | 顯示全部樓層
支持。
ID:513131 發表于 2019-4-19 19:31 | 顯示全部樓層
厲害,
ID:513131 發表于 2019-4-20 21:03 | 顯示全部樓層
壓縮包里沒有PROTEUS仿真例程呀,
ID:524619 發表于 2019-4-29 18:36 | 顯示全部樓層
原來這是張學友啊
ID:521352 發表于 2019-4-29 22:32 | 顯示全部樓層
厲害了!,我想問一下在Proteus中你選Arduino開發板是在哪里選的?
ID:473159 發表于 2019-5-15 01:46 | 顯示全部樓層
還真別說,眼睛,鼻子,嘴巴還有那么個樣子,最好將圖像修修就更像了
ID:602550 發表于 2019-8-22 19:01 | 顯示全部樓層
驅動芯片規格書SSD1306
驅動芯片規格書SSD1306.pdf
1.34 MB, 下載次數: 21, 下載積分: 黑幣 -5
驅動芯片規格書SSD1306
ID:639525 發表于 2019-11-22 16:52 | 顯示全部樓層
請問這個地址0x3d怎么確定的,和0x78的區別在哪里?
ID:639525 發表于 2019-11-22 16:58 | 顯示全部樓層
請問I2C地址為 0x3D怎么確定的?看到有的是設置為0x78
ID:601052 發表于 2019-12-30 09:46 | 顯示全部樓層
下載試試看 ,正需要這個
ID:444561 發表于 2020-1-8 14:23 | 顯示全部樓層
為什么我用STM32 PROTEUS總是不能點亮OLED
ID:456386 發表于 2020-2-23 14:09 | 顯示全部樓層
下載學習一下
ID:446681 發表于 2020-4-21 13:28 | 顯示全部樓層
樓主proteus的版本是多少?工程文件用8.1的打不開
ID:800738 發表于 2020-7-9 23:00 | 顯示全部樓層
請問,用到的頭文件應該放到哪里
ID:852547 發表于 2020-12-1 17:16 | 顯示全部樓層
我想問一下oxFF這種是什么東西?
主站蜘蛛池模板: 97精品在线| 蜜桃精品噜噜噜成人av | www.久久.com| 久久黄色影院 | 在线观看成人免费视频 | 欧美做受喷浆在线观看 | 国产成人午夜 | 91看片在线观看 | 午夜伦理福利 | 天天天天躁天天爱天天碰2018 | 午夜视频在线播放 | 成人深夜福利 | 91久久久久国产一区二区 | 超碰人人干 | 狠狠操天天操 | 精品国产乱码久久久久久蜜臀网站 | 日韩精品久久久久久 | 国产精品久久久久久久久久久久午夜片 | www.精品| 伊人网在线观看 | av少妇| a毛片在线观看 | 一区在线观看 | 国产精品婷婷 | 懂色av一区二区三区 | 天天干天天草 | 国产自在线 | 亚洲三区在线 | 成人精品免费视频 | 国产免费一区 | 亚洲天天| 久久国产一区 | 精品天堂| 中文字幕激情 | 久久久久久亚洲精品 | 午夜视频在线看 | 一级毛片久久久 | 三级在线观看 | 国产精品日韩在线 | 日韩免费一区二区三区 | 黄色录像免费看 |
