查看: 4885|回復: 0
[原創]觸摸屏
ID:34042 發表于 2012-2-5 08:47 | 顯示全部樓層 |閱讀模式
老師你好:
       程序寫入芯片后觸摸屏程序正常,但是 peizhi() 子程序里的aa2亂碼,加不了
減不了,請老師指點一下,那有錯誤。
                                                    裴京
#include <iom16v.h>
#include <macros.h>
#define  uchar unsigned char
#define  uint  unsigned int
uint x;
uint y;
uchar SEG2[16]={0x30,0x31,0x32,0x33,
0x34,0x35,0x36,0x37,0x38,0x39,0x41,
0x42,0x43,0x44,0x45,0x46};
uchar ab1,ab2,ab3,ab4,ab5,ab6;
uchar ac1,ac2,ac3,ac4,ac5,ac6;
uchar ad1,ad2,ad3,ad4;
uchar ae1,ae2,ae3,ae4;
uint aa2,aa4;
uint xl,xh;
uint yl,yh;
void delay(uint ms)
    uint i,j;
 for(i=0;i<ms;i++)
    for(j=0;j<1141;j++);
void smalldelay(unsigned char tmp)
  unsigned char i;
  while(tmp--)
    for(i = 0; i < 250; i++)
      NOP();
void chushihua()         //LCD
      DDRA=0XFF;
   DDRD|=BIT(4)|BIT(5)|BIT(6);
   PORTD&=~BIT(6);
void spiinit(void)      //7843
  DDRB|=BIT(PB4)|BIT(PB5)|BIT(PB7);    // MOSI and SCK port out
  DDRB&=~BIT(PB6);
  PORTB|=BIT(PB6);
  PORTB|=BIT(PB4);
  SPCR = (1 << SPE) | (0 << DORD)| (1 << MSTR) | (0 << CPOL)| (0 << CPHA)| (1 << SPR1)| (1 << SPR0);  // enable spi,master mode, MCLK/4,spi 0 mode
void portini(void)
  //spiinit();
  //sendspi();
  DDRD &= ~(1 << PD3);              // port input
  PORTD |= (1 << PD3);              // pull-up resistance
//MCUCR |= 1<<ISC11;                // down edge enable
  GICR |= 1<<INT1;                  // extern interrupt 1 enable
  flgtouch = 0;
void chushihua1()
      write_com(0X38);
   delay(1);
   write_com(0X01);
   delay(1);
   write_com(0X0C);
   delay(1);
   write_com(0X06);
   delay(1);
void sendspi(unsigned char data)
  PORTB&=~BIT(PB4);
  SPDR = data;                      // send data
  while( !(SPSR & (1 << SPIF)) );   // wait data transfer end
  //PORTB|=BIT(PB4);
unsigned char readspi(void)
  //PORTB&=~BIT(PB4);
  SPSR = 0x00;
  return SPDR;
  PORTB|=BIT(PB4);
void keydown()
  SPCR = (1 << SPE) | (0 << DORD)| (1 << MSTR) | (0 << CPOL)| (0 << CPHA)| (0 << SPR1)| (1 << SPR0);
  sendspi(0x9B);
  smalldelay(20);
  SPCR = (1 << SPE) | (0 << DORD)| (1 << MSTR) | (1 << CPOL)| (0 << CPHA)| (0 << SPR1)| (1 << SPR0);
  xl = readspi();
  smalldelay(20);
  sendspi(0x9B);
  smalldelay(20);
  xh = readspi();
  smalldelay(20);
  x = xl+xh*256;
  sendspi(0xDB);
  smalldelay(20);
  yl = readspi();
  smalldelay(20);
  sendspi(0xDB);
  smalldelay(20);
  yh = readspi();
  smalldelay(20);
  y = yl+yh*256;
void write_com(uchar com)
       PORTD&=~BIT(4);
    PORTD&=~BIT(5);
    PORTA=com;
    PORTD|=BIT(6);
    delay(1);
    PORTD&=~BIT(6);
void write_dat(uchar dat)
       PORTD|=BIT(4);
    PORTD&=~BIT(5);
    PORTA=dat;
    PORTD|=BIT(6);
    delay(1);
    PORTD&=~BIT(6);
void zhuanhuan()
{  uint aa1,aa2,aa3,aa4;
    aa1=xl;
 aa2=xh;
 ab1=aa1/100;
 ab2=(aa1%100)/10;
 ab3=aa1%10;
 ab4=aa2/100;
 ab5=(aa2%100)/10;
 ab6=aa2%10;
 aa3=yl;
 aa4=yh;
 ac1=aa3/100;
 ac2=(aa3%100)/10;
 ac3=aa3%10;
 ac4=aa4/100;
 ac5=(aa4%100)/10;
 ac6=aa4%10;
   ad1 = aa2/1000;
   ad2 = (aa2%1000)/100;
   ad3 = (aa2%100)/10;
   ad4 = aa2%10;
   ae1 = aa4/1000;
   ae2 = (aa4%1000)/100;
   ae3 = (aa4%100)/10;
   ae4 = aa4%10;
void zhuanhuan()
   //aa1 = positionxl;
   aa1 = x;
   ab1 = aa1/100000;
   ab2 = (aa1%100000)/10000;
   ab3 = (aa1%10000)/1000;
   ab4 = (aa1%1000)/100;
   ab5 = (aa1%100)/10;
   ab6 = aa1%10;
   //aa3 = positionyl;
   aa3 = y;
   ac1 = aa3/100000;
   ac2 = (aa3%100000)/10000;
   ac3 = (aa3%10000)/1000;
   ac4 = (aa3%1000)/100;
   ac5 = (aa3%100)/10;
   ac6 = aa3%10;
   ad1 = aa2/1000;
   ad3 = (aa2%100)/10;
   ad4 = aa2%10;
   ae1 = aa4/1000;
   ae3 = (aa4%100)/10;
   ae4 = aa4%10;
void xianshi()
    uchar i;
      write_com(0X80);
   delay(1);
   write_dat(SEG2[ab1]);
   delay(1);
   write_dat(SEG2[ab2]);
   delay(1);
   write_dat(SEG2[ab3]);
   delay(1);
   write_dat(SEG2[ab4]);
   delay(1);
   write_dat(SEG2[ab5]);
   delay(1);
   write_dat(SEG2[ab6]);
   delay(1);
   write_dat(SEG2[0x0e]);
    delay(1);
    delay(1);
    delay(1);
    delay(1);
    delay(1);
    delay(1);
    write_dat(SEG2[ad1]);
    delay(1);
    write_dat(SEG2[ad2]);
    delay(1);
    write_dat(SEG2[ad3]);
    delay(1);
    write_dat(SEG2[ad4]);
    delay(1);
    write_com(0X90);
    delay(1);
    write_dat(SEG2[ac1]);
    delay(1);
    write_dat(SEG2[ac2]);
    delay(1);
    write_dat(SEG2[ac3]);
    delay(1);
    write_dat(SEG2[ac4]);
    delay(1);
    write_dat(SEG2[ac5]);
    delay(1);
    write_dat(SEG2[ac6]);
    delay(1);
    delay(1);
    delay(1);
    delay(1);
    delay(1);
    delay(1);
    delay(1);
    write_dat(SEG2[ae1]);
    delay(1);
    write_dat(SEG2[ae2]);
    delay(1);
    write_dat(SEG2[ae3]);
    delay(1);
    write_dat(SEG2[ae4]);
    delay(1);
    write_com(0X88);
    delay(1);
    write_dat(0xd7);
    delay(1);
    write_dat(0xa2);
    delay(1);
    write_dat(0xb2);
    delay(1);
    write_dat(0xe1);
    delay(1);
    delay(1);
    delay(1);
    delay(1);
    delay(1);
    delay(1);
    write_dat(0x1e);
    delay(1);
    delay(1);
    delay(1);
    delay(1);
    delay(1);
    write_dat(0x1f);
    delay(1);
    delay(1);
    write_com(0X98);
    delay(1);
    write_dat(0xc9);
    delay(1);
    write_dat(0xbe);
    delay(1);
    write_dat(0xb3);
    delay(1);
    write_dat(0xfd);
    delay(1);
    delay(1);
    delay(1);
    delay(1);
    delay(1);
    delay(1);
    write_dat(0x1e);
    delay(1);
    delay(1);
    delay(1);
    delay(1);
    delay(1);
    write_dat(0x1f);
    delay(1);
    delay(1);
void peizhi()
  uchar a,b;
    if(x==56283)    //刪除 加
 if(y==56283)
 if(aa2<120)
 aa2++;
 aa2=0;
    if(x==56540)    //刪除 加
 if(yl==56540)
 if(aa2>0)
 aa2--;
 aa2=120;
void  main()
 delay(200);                // delay wait tranquilization
 chushihua();
 spiinit();
 chushihua();
 chushihua1();
 sendspi(0x00);
    smalldelay(20);
 aa2=50;
 aa4=60;
   peizhi();
   keydown();
   zhuanhuan();
   xianshi();
主站蜘蛛池模板: 可以免费看的av | 9l蝌蚪porny中文自拍 | 日韩在线观看一区 | 日韩一级黄色片 | 黄色影视大全 | 亚洲国产91 | 欧美一区二区在线播放 | 一区二区三区网站 | 99精品免费视频 | 国产日韩久久 | 久精品视频| 日韩欧美一级片 | 国产精品欧美日韩 | 一级片在线观看视频 | av自拍偷拍 | 日韩免费在线观看视频 | 国产精品99久久久久久久久 | 欧美一级淫片 | 懂色av懂色av粉嫩av | 国产对白videos麻豆高潮 | 伊人久久中文字幕 | 久久国产综合 | 欧美在线不卡 | 在线免费观看av片 | 国产wwwwww| 精品免费国产一区二区三区四区 | 日韩精品视频在线 | 在线欧美 | 99亚洲精品| 日韩aaaa| 四虎影院免费观看 | 亚洲黄色在线视频 | 免费成人深夜夜国外 | 人人看人人草 | 亚洲免费一区二区 | 成人三级视频在线观看 | 91日韩欧美| 伊人国产女 | 黄色在线免费网站 | 亚洲国产精品久久久久久久 | 国产盗摄一区二区 |
