直接上附件。
- Part of Libnodave, a free communication libray for Siemens S7 200/300/400 via
- the MPI adapter 6ES7 972-0CA22-0XAC
- or MPI adapter 6ES7 972-0CA23-0XAC
- or TS adapter 6ES7 972-0CA33-0XAC
- or MPI adapter 6ES7 972-0CA11-0XAC,
- IBH/MHJ-NetLink or CPs 243, 343 and 443
- (C) Thomas Hergenhahn (thomas.hergenhahn@web.de) 2002..2005
- S5 basic communication parts (C) Andrew Rostovtsew 2004.
- Libnodave is free software; you can redistribute it and/or modify
- it under the terms of the GNU Library General Public License as published by
- the Free Software Foundation; either version 2, or (at your option)
- any later version.
- Libnodave is distributed in the hope that it will be useful,
- but WITHOUT ANY WARRANTY; without even the implied warranty of
- MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
- GNU General Public License for more details.
- You should have received a copy of the GNU Library General Public License
- along with Libnodave; see the file COPYING. If not, write to
- the Free Software Foundation, 675 Mass Ave, Cambridge, MA 02139, USA.
- #include "nodave.h"
- #include <stdio.h>
- #include "log2.h"
- #include <string.h>
- #define DUMPLIMIT 11132
- #define DAVE_HAVE_MEMCPY // normally we have
- //#define DEBUG_CALLS // Define this and recompile to get parameters and results
- // of each function call printed. I could have made this an
- // option bit in daveDebug, but most applications will never,never
- // need it. Still they would have to do the jumps...
- // This option is just useful when developing bindings to new
- // programming languages.
- Library specific:
- #ifdef LINUX
- #define HAVE_UNISTD
- #define HAVE_SELECT
- #define DECL2
- #include <time.h>
- #include <sys/time.h>
- #endif
- #ifdef HAVE_UNISTD
- #include <unistd.h>
- #define daveWriteFile(a,b,c,d) d=write(a,b,c)
- #endif
- #ifdef AVR
- #endif
- int daveDebug=0;
- #ifdef BCCWIN
- #include <winsock2.h>
- #include "openS7online.h" // We can use the Siemens transport dlls only on Windows
- void setTimeOut(daveInterface * di, int tmo) {
- COMMTIMEOUTS cto;
- #ifdef DEBUG_CALLS
- LOG3("setTimeOut(di:%p, time:%d)\n", di,tmo);
- FLUSH;
- #endif
- // if(di->fd.connectionType==daveSerialConnection) {
- GetCommTimeouts(di->fd.rfd, &cto);
- cto.ReadIntervalTimeout=0;
- cto.ReadTotalTimeoutMultiplier=0;
- cto.ReadTotalTimeoutConstant=tmo/1000;
- SetCommTimeouts(di->fd.rfd,&cto);
- // } else if(di->fd.connectionType==daveTcpConnection) {
- #endif
- #ifdef HAVE_SELECT
- int DECL2 stdwrite(daveInterface * di, char * buffer, int length) {
- if (daveDebug & daveDebugByte)
- _daveDump("I send", (uc*)buffer, length);
- return write(di->fd.wfd, buffer,length);
- int DECL2 stdread(daveInterface * di, char * buffer, int length) {
- fd_set FDS;
- struct timeval t;
- int i;
- t.tv_sec = di->timeout / 1000000;
- t.tv_usec = (di->timeout % 1000000);
- FD_ZERO(&FDS);
- FD_SET(di->fd.rfd, &FDS);
- i=0;
- if(select(di->fd.rfd + 1, &FDS, NULL, NULL, &t)>0) {
- i=read(di->fd.rfd, buffer, length);
- // if (daveDebug & daveDebugByte)
- // _daveDump("got",buffer,i);
- return i;
- #endif
- #ifdef BCCWIN
- char * buffer,
- int length) {
- unsigned long i;
- ReadFile(di->fd.rfd, buffer, length, &i, NULL);
- return i;
- unsigned long i;
- _daveDump("I send",buffer,length);
- // EscapeCommFunction(di->fd.rfd, CLRRTS); // patch from Keith Harris. He says:
- //******* this is what microwin does (needed for usb-serial)
- WriteFile(di->fd.rfd, buffer, length, &i,NULL);
- // patch from Andrea. He says:
- // In this way the PC Adapter connected to CPU313C hangs waiting for RTS line before answering back.
- // Added the following to regain answers:
- // EscapeCommFunction(di->fd.rfd, SETRTS);
- return i;
- #endif
- Setup a new interface structure from an initialized serial interface's handle and a name.
- daveInterface * DECL2 daveNewInterface(_daveOSserialType nfd, char * nname, int localMPI, int protocol, int speed){
- daveInterface * di=(daveInterface *) calloc(1, sizeof(daveInterface));
- LOG7("daveNewInterface(fd.rfd:%d fd.wfd:%d name:%s local MPI:%d protocol:%d PB speed:%d)\n",
- nfd.rfd,nfd.wfd,nname, localMPI, protocol, speed);
- FLUSH;
- #endif
- if (di) {
- // di->name=nname;
- strncpy(di->realName,nname,20);
- di->name=di->realName;
- di->fd=nfd;
- di->localMPI=localMPI;
- di->protocol=protocol;
- di->timeout=1000000; /* 1 second */
- di->nextConnection=0x14;
- di->speed=speed;
- di->getResponse=_daveGetResponseISO_TCP;
- di->ifread=stdread;
- di->ifwrite=stdwrite;
- di->initAdapter=_daveReturnOkDummy;
- di->connectPLC=_daveReturnOkDummy2;
- di->disconnectPLC=_daveReturnOkDummy2;
- di->disconnectAdapter=_daveReturnOkDummy;
- di->listReachablePartners=_daveListReachablePartnersDummy;
- switch (protocol) {
- case daveProtoMPI:
- di->initAdapter=_daveInitAdapterMPI1;
- di->connectPLC=_daveConnectPLCMPI1;
- di->disconnectPLC=_daveDisconnectPLCMPI;
- di->disconnectAdapter=_daveDisconnectAdapterMPI;
- di->exchange=_daveExchangeMPI;
- di->sendMessage=_daveSendMessageMPI;
- di->getResponse=_daveGetResponseMPI;
- di->listReachablePartners=_daveListReachablePartnersMPI;
- break;
- case daveProtoMPI2:
- case daveProtoMPI4:
- di->initAdapter=_daveInitAdapterMPI2;
- di->connectPLC=_daveConnectPLCMPI2;
- di->nextConnection=0x3;
- break;
- case daveProtoMPI3:
- di->initAdapter=_daveInitAdapterMPI3;
- di->connectPLC=_daveConnectPLCMPI3;
- di->disconnectPLC=_daveDisconnectPLCMPI3;
- di->disconnectAdapter=_daveDisconnectAdapterMPI3;
- di->exchange=_daveExchangeMPI3;
- di->sendMessage=_daveSendMessageMPI3;
- di->getResponse=_daveGetResponseMPI3;
- di->listReachablePartners=_daveListReachablePartnersMPI3;
- break;
- case daveProtoISOTCP:
- case daveProtoISOTCP243:
- di->connectPLC=_daveConnectPLCTCP;
- di->exchange=_daveExchangeTCP;
- break;
- case daveProtoPPI:
- di->getResponse=_daveGetResponsePPI;
- di->exchange=_daveExchangePPI;
- di->connectPLC=_daveConnectPLCPPI;
- di->timeout=150000; /* 0.15 seconds */
- break;
- case daveProtoMPI_IBH:
- di->exchange=_daveExchangeIBH;
- di->connectPLC=_daveConnectPLC_IBH;
- di->disconnectPLC=_daveDisconnectPLC_IBH;
- di->sendMessage=_daveSendMessageMPI_IBH;
- di->getResponse=_daveGetResponseMPI_IBH;
- di->listReachablePartners=_daveListReachablePartnersMPI_IBH;
- break;
- case daveProtoPPI_IBH:
- di->exchange=_daveExchangePPI_IBH;
- di->getResponse=_daveGetResponsePPI_IBH;
- break;
- case daveProtoS7online:
- di->exchange=_daveExchangeS7online;
- di->connectPLC=_daveConnectPLCS7online;
- di->sendMessage=_daveSendMessageS7online;
- di->getResponse=_daveGetResponseS7online;
- di->listReachablePartners=_daveListReachablePartnersS7online;
- di->disconnectPLC=_daveDisconnectPLCS7online;
- // di->disconnectAdapter=_daveDisconnectAdapterS7online;
- break;
- case daveProtoAS511:
- di->connectPLC=_daveConnectPLCAS511;
- di->disconnectPLC=_daveDisconnectPLCAS511;
- di->exchange=_daveFakeExchangeAS511;
- di->sendMessage=_daveFakeExchangeAS511;
- break;
- case daveProtoNLpro:
- di->initAdapter=_daveInitAdapterNLpro;
- di->connectPLC=_daveConnectPLCNLpro;
- di->disconnectPLC=_daveDisconnectPLCNLpro;
- di->disconnectAdapter=_daveDisconnectAdapterNLpro;
- di->exchange=_daveExchangeNLpro;
- di->sendMessage=_daveSendMessageNLpro;
- di->getResponse=_daveGetResponseNLpro;
- di->listReachablePartners=_daveListReachablePartnersNLpro;
- break;
- #ifdef BCCWIN
- setTimeOut(di, di->timeout);
- #endif
- return di;
- daveInterface * DECL2 davePascalNewInterface(_daveOSserialType* nfd, char * nname, int localMPI, int protocol, int speed){
- LOG7("davePascalNewInterface(fd.rfd:%d fd.wfd:%d name:%s local MPI:%d protocol:%d PB speed:%d)\n",
- nfd->rfd,nfd->wfd,nname, localMPI, protocol, speed);
- FLUSH;
- #endif
- return daveNewInterface(*nfd,nname, localMPI, protocol, speed);
- debugging:
- set debug level by setting variable daveDebug. Debugging is split into
- several topics. Output goes to stderr.
- The file descriptor is written after the module name, so you may
- distinguish messages from multiple connections.
- naming: all stuff begins with dave... to avoid conflicts with other
- namespaces. Things beginning with _dave.. are not intended for
- public use.
- void DECL2 daveSetDebug(int nDebug) {
- LOG2("daveSetDebug(%d)\n",nDebug);
- FLUSH;
- #endif
- daveDebug=nDebug;
- int DECL2 daveGetDebug() {
- LOG1("daveGetDebug()\n");
- FLUSH;
- #endif
- return daveDebug;
- C# interoperability:
- void DECL2 daveSetTimeout(daveInterface * di, int tmo) {
- LOG3("daveSetTimeOut(di:%p, time:%d)\n", di,tmo);
- #endif
- di->timeout=tmo;
- #ifdef BCCWIN
- setTimeOut(di,tmo);
- #endif
- int DECL2 daveGetTimeout(daveInterface * di) {
- LOG2("daveGetTimeOut(di:%p)\n",di);
- FLUSH;
- #endif
- return di->timeout;
- char * DECL2 daveGetName(daveInterface * di) {
- LOG2("daveGetName(di:%p)\n",di);
- FLUSH;
- #endif
- return di->name;
- int DECL2 daveGetMPIAdr(daveConnection * dc) {
- LOG2("daveGetMPIAdr(dc:%p)\n",dc);
- FLUSH;
- #endif
- return dc->MPIAdr;
- int DECL2 daveGetAnswLen(daveConnection * dc) {
- LOG2("daveGetAnswLen(dc:%p)\n",dc);
- FLUSH;
- #endif
- return dc->AnswLen;
- int DECL2 daveGetMaxPDULen(daveConnection * dc) {
- LOG2("daveGetMaxPDULen(dc:%p)\n",dc);
- FLUSH;
- #endif
- return dc->maxPDUlength;
- PDU handling:
- set up the header. Needs valid header pointer
- void DECL2 _daveInitPDUheader(PDU * p, int type) {
- memset(p->header, 0, sizeof(PDUHeader));
- if (type==2 || type==3)
- p->hlen=12;
- else
- p->hlen=10;
- p->param=p->header+p->hlen;
- ((PDUHeader*)p->header)->P=0x32;
- ((PDUHeader*)p->header)->type=type;
- p->dlen=0;
- p->plen=0;
- p->udlen=0;
- p->data=NULL;
- p->udata=NULL;
- add parameters after header, adjust pointer to data.
- needs valid header
- void DECL2 _daveAddParam(PDU * p,uc * param,us len) {
- LOG4("_daveAddParam(PDU:%p, param %p, len:%d)\n", p, param, len);
- FLUSH;
- #endif
- p->plen=len;
- #ifdef DAVE_HAVE_MEMCPY
- memcpy(p->param, param, len);
- #else
- int i;
- for (i=0;i<len;i++) p->param[i]=param[i];
- #endif
- ((PDUHeader2*)p->header)->plenHi=len/256;
- ((PDUHeader2*)p->header)->plenLo=len%256;
- // ((PDUHeader*)p->header)->plen=daveSwapIed_16(len);
- p->data=p->param+len;
- p->dlen=0;
- add data after parameters, set dlen
- needs valid header,parameters
- void DECL2 _daveAddData(PDU * p,void * data,int len) {
- LOG4("_daveAddData(PDU:%p, data %p, len:%d)\n", p, data, len);
- // _daveDumpPDU(p);
- FLUSH;
- #endif
- uc * dn= p->data+p->dlen;
- p->dlen+=len;
- memcpy(dn, data, len);
- #else
- int i; uc * d=(uc*)data;
- for (i=0;i<len;i++) p->data[p->dlen+i]=d[i];
- #endif
- ((PDUHeader2*)p->header)->dlenHi=p->dlen/256;
- ((PDUHeader2*)p->header)->dlenLo=p->dlen%256;
- // ((PDUHeader*)p->header)->dlen=daveSwapIed_16(p->dlen);
- add values after value header in data, adjust dlen and data count.
- needs valid header,parameters,data,dlen
- void DECL2 _daveAddValue(PDU * p,void * data,int len) {
- us dCount;
- uc * dtype;
- LOG4("_daveAddValue(PDU:%p, data %p, len:%d)\n", p, data, len);
- _daveDumpPDU(p);
- FLUSH;
- #endif
- dtype=p->data+p->dlen-4+1; /* position of first byte in the 4 byte sequence */
- dCount= p->data[p->dlen-4+2+1];
- dCount+= 256*p->data[p->dlen-4+2];
- if (daveDebug & daveDebugPDU)
- LOG2("dCount: %d\n", dCount);
- if (*dtype==4) { /* bit data, length is in bits */
- dCount+=8*len;
- } else if (*dtype==9) { /* byte data, length is in bytes */
- dCount+=len;
- } else if (* dtype==3) { /* bit data, length is in bits */
- dCount+=len;
- } else {
- LOG2("unknown data type/length: %d\n", *dtype);
- if (p->udata==NULL) p->udata=p->data+4;
- p->udlen+=len;
libnodave-0.8.5.rar
(3.26 MB, 下載次數: 11)
2018-9-6 18:01 上傳
點擊文件名下載附件
西門子通訊方法
