查看: 5329|回復: 1
單片機4*4矩陣鍵盤電子琴仿真和源程序
ID:253741 發表于 2018-9-23 18:54 | 顯示全部樓層 |閱讀模式
4x4電子琴 發出不同的聲音。學校要求做無聊就做了.....
仿真
仿真
源碼
源碼
  1. #include <reg51.h>
  2. #define uint unsigned int
  4. #define output P1
  5. #define input P1
  6. enum KEY{key0,key1,key2,key3,key4,key5,key6,key7,key8,key9,key10,key11,key12,key13,key14,key15};
  7. unsigned int code Freqtab[] = {
  8.      64021,64103,64260,64400,
  9.      64524,64580,64684,64777,
  10.      64820,64898,64968,65030,
  11.      65058,65110,65157,65178};
  12. uint FreqTemp;
  13. sbit SPEAK = P3^7;
  14. void delay1ms(uint n)
  15. {
  16.     uint a,b,c;
  17.         for(c=n;c>0;c--)
  18.             for(b=199;b>0;b--)
  19.                 for(a=1;a>0;a--);
  20. }
  21. uint key_input(void)
  22. {
  23.         uchar temp1,temp2;
  24.         uchar num = 16;
  25.         output = 0x0f;
  26.            temp1 = input;
  27.         if(0x0f != temp1)
  28.         {
  29.                 delay1ms(5);
  30.                 temp1 = input;
  31.                 if(0x0f != temp1)
  32.                 {
  33.                         temp1 = temp1 & 0x0f;
  34.                         output = 0xf0;
  35.                         delay1ms(1);
  36.                         temp2 = input;
  37.                         temp2 = temp2 & 0xf0;
  38.                         temp1 = temp1 | temp2;
  39.                 }
  40.         }
  41.         switch(temp1)
  42.         {
  43.                 case 0xee:num=0;break;
  44.         case 0xde:num=1;break;
  45.         case 0xbe:num=2;break;
  46.         case 0x7e:num=3;break;
  47.                 case 0xed:num=4;break;
  48.         case 0xdd:num=5;break;
  49.         case 0xbd:num=6;break;
  50.         case 0x7d:num=7;break;
  51.                 case 0xeb:num=8;break;
  52.         case 0xdb:num=9;break;
  53.         case 0xbb:num=10;break;
  54.         case 0x7b:num=11;break;
  55.                 case 0xe7:num=12;break;
  56.         case 0xd7:num=13;break;
  57.         case 0xb7:num=14;break;
  58.         case 0x77:num=15;break;
  59.                 default:break;
  60.         }
  61.         return num;
  62. }
  63. void T0_INT(void) interrupt 1
  64. {
  65.      TL0 = FreqTemp;
  66.      TH0 = FreqTemp >> 8;
  67.      SPEAK = ~SPEAK;
  68. }
  69. int main()
  70. {
  71.         TMOD = 0X01;
  72.         EA = 1;
  73.         ET0 = 1;
  74.         TR0 = 0;
  75.         while(1)
  76.         {
  77.                 uint num,temp;
  78.                 num = key_input();
  79.                 temp = num;
  80.         if(16 != num)
  81.                 {
  82.                         FreqTemp = Freqtab[num];
  83.                         TR0 = 1;
  84.                         while(0xf0 != output);
  85.                         TR0 = 0;
  86.                         SPEAK = 1;
  87.                 }
  88.         }
  89.         return 0;
  90. }
電子琴30.rar (91.92 KB, 下載次數: 76)
ID:681740 發表于 2020-1-5 22:13 | 顯示全部樓層
你這個proteus不行啊
主站蜘蛛池模板: 日韩精品在线一区 | 一级片在线免费观看 | 97免费在线| 成人a视频| 欧美日日日 | 国产一区二区中文字幕 | 一级片aa | xxxx亚洲| a级片免费观看 | www.国产在线观看 | 日本综合久久 | 免费看黄视频网站 | 激情都市亚洲 | 综合久久久久 | 久久一二三区 | 日韩理论在线 | 亚洲91在线 | 亚洲欧美一区二区三区四区 | 免费国产黄色 | 91免费片 | 亚洲www啪成人一区二区麻豆 | 日本高清视频www | 成人免费毛片入口 | 久久久天堂 | 深夜福利网址 | 国产无遮挡 | 亚洲综合激情 | 国产精品99久久久久久久久久久久 | 中国女人真人一级毛片 | 天天操夜夜操 | 成人黄色大片 | 国产精品成人一区二区 | 久久久久久久免费视频 | 日韩城人免费 | 久久动态图 | 69人人| 黄色一级大片在线免费看国产一 | 黄色网址在线播放 | 国产一区在线看 | 亚洲一区二区三区四区在线 | 一区二区三区四区视频在线观看 |
