查看: 8761|回復: 7
GY-9960-3.3APDS-9960模塊源代碼(RGB紅外手勢傳感+感應運動方向識別)
ID:402205 發表于 2018-9-25 15:37 | 顯示全部樓層 |閱讀模式
   GY-9960-3.3APDS-9960模塊,RGB紅外手勢傳感+感應運動方向識別模塊,供大家學習使用。
arduino源程序如下:
  1. /****************************************************************
  2. ColorSensor.ino
  3. APDS-9960 RGB and Gesture Sensor
  4. Shawn Hymel @ SparkFun Electronics
  5. October 15, 2014
  6. https://github.com/sparkfun/APDS-9960_RGB_and_Gesture_Sensor
  7. Tests the color and ambient light sensing abilities of the
  8. APDS-9960. Configures APDS-9960 over I2C and polls the sensor for
  9. ambient light and color levels, which are displayed over the
  10. serial console.
  11. Hardware Connections:
  12. IMPORTANT: The APDS-9960 can only accept 3.3V!
  13. Arduino Pin  APDS-9960 Board  Function
  14. 3.3V         VCC              Power
  15. GND          GND              Ground
  16. A4           SDA              I2C Data
  17. A5           SCL              I2C Clock
  18. Resources:
  19. Include Wire.h and SparkFun_APDS-9960.h
  20. Development environment specifics:
  21. Written in Arduino 1.0.5
  22. Tested with SparkFun Arduino Pro Mini 3.3V
  23. This code is beerware; if you see me (or any other SparkFun
  24. employee) at the local, and you've found our code helpful, please
  25. buy us a round!
  26. Distributed as-is; no warranty is given.
  27. ****************************************************************/
  28. #include <Wire.h>
  29. #include <SparkFun_APDS9960.h>
  30. #include <LiquidCrystal.h>
  31. // Global Variables
  32. SparkFun_APDS9960 apds = SparkFun_APDS9960();
  33. uint16_t ambient_light = 0;
  34. uint16_t red_light = 0;
  35. uint16_t green_light = 0;
  36. uint16_t blue_light = 0;
  37. LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
  38. void setup() {
  39.
  40.   // set up the LCD's number of columns and rows:
  41.   lcd.begin(16, 2);
  42.   // Print a message to the LCD.
  43.
  44.
  45.   // Initialize Serial port
  46.   Serial.begin(9600);
  47.   Serial.println();
  48.   Serial.println(F("--------------------------------"));
  49.   Serial.println(F("SparkFun APDS-9960 - ColorSensor"));
  50.   Serial.println(F("--------------------------------"));
  51.
  52.   // Initialize APDS-9960 (configure I2C and initial values)
  53.   if ( apds.init() ) {
  54.     Serial.println(F("APDS-9960 initialization complete"));
  55.   } else {
  56.     Serial.println(F("Something went wrong during APDS-9960 init!"));
  57.   }
  58.
  59.   // Start running the APDS-9960 light sensor (no interrupts)
  60.   if ( apds.enableLightSensor(false) ) {
  61.     Serial.println(F("Light sensor is now running"));
  62.   } else {
  63.     Serial.println(F("Something went wrong during light sensor init!"));
  64.   }
  65.
  66.   // Wait for initialization and calibration to finish
  67.   delay(500);
  68. }
  69. void loop() {
  70.
  71.   // Read the light levels (ambient, red, green, blue)
  72.   if (  !apds.readAmbientLight(ambient_light) ||
  73.         !apds.readRedLight(red_light) ||
  74.         !apds.readGreenLight(green_light) ||
  75.         !apds.readBlueLight(blue_light) ) {
  76.     Serial.println("Error reading light values");
  77.   } else {
  78.
  79.     Serial.print("Ambient: ");
  80.     Serial.print(ambient_light);
  81.     lcd.setCursor(1, 0);
  82.      lcd.print(red_light);
  83.     Serial.print(" Red: ");
  84.     Serial.print(red_light);
  85.      lcd.setCursor(7, 0);
  86.       lcd.print(green_light);
  87.     Serial.print(" Green: ");
  88.     Serial.print(green_light);
  89.      lcd.setCursor(1, 1);
  90.      lcd.print(blue_light);
  91.     Serial.print(" Blue: ");
  92.     Serial.println(blue_light);
  93.   }
  94.
  95.   // Wait 1 second before next reading
  96.   delay(10);
  97. }
GY-9960-3.3APDS-9960模塊RGB紅外手勢傳感 感應運動方向識別模塊.zip (307.65 KB, 下載次數: 87)
ID:104477 發表于 2018-10-11 02:03 來自觸屏版 | 顯示全部樓層
具體應用是什么
ID:420962 發表于 2018-11-8 17:57 | 顯示全部樓層
這個感應距離是多少,具體能感應哪些手勢動作,有沒有51的源碼
ID:297148 發表于 2018-11-10 17:21 | 顯示全部樓層
APDS-9960現在流行嗎?有沒其他的手勢產品可以做
ID:461581 發表于 2019-1-5 17:10 | 顯示全部樓層
不錯,可以發給我郵箱嗎,黑幣不足,非常感謝
ID:513258 發表于 2019-8-26 21:02 | 顯示全部樓層
ID:671549 發表于 2020-1-11 11:18 | 顯示全部樓層
有沒有51的源碼  借鑒一下  非常感謝
ID:672792 發表于 2020-1-24 19:55 | 顯示全部樓層
好資料,感謝
主站蜘蛛池模板: 成人黄色一级片 | 久久久久国产视频 | 中日韩一级片 | 亚洲在线中文字幕 | 中文字幕国产 | 久久99热这里只频精品6学生 | 激情av网站| 日本在线免费观看视频 | 国产无精乱码一区二区三区 | 中文字幕第三页 | 91精品国产成人www | 免费的黄色网址 | 国产香蕉视频 | 亚洲成人一区二区三区 | 97caoporn| 国产一区免费视频 | 欧美激情第二页 | 成年人免费在线观看 | 久久久精品一区二区 | 天天天天躁天天爱天天碰2018 | 成人永久免费 | 国产精品视频99 | 中文字幕理论片 | av在线免费观看网站 | 一级黄色片免费看 | 最新中文字幕在线 | 久在线视频 | 毛片资源 | 日韩精品久久久 | 日本综合久久 | 亚洲高清免费视频 | 91免费黄色| 天堂一区二区三区 | 国产日韩欧美日韩大片 | 夜夜操网站 | 日韩精品少妇 | 欧洲一区二区三区 | 久久亚洲国产精品 | 亚洲欧美在线一区 | 国产精品久久 | 艳妇诱春(第5部分)(h) |
