查看: 4790|回復: 0
利用銅皮間隙做ESD防護的方法 焊盤間隙放電Spark Gaps
有時為了降低成本,利用銅皮做ESD防護,銅皮的制作。可以參考
An excellent way that I have found to protect inputs to electronics components from the very high
voltages of ESD and EMI spikes is to use spark gaps. These can be built into your circuit board as
a part of the PC board etch. The gaps should be designed as shown in the following dimension
drawing.
As shown above the two spark gap pads are half circles with a radius of 0.025 inches. The
designed gap spacing should be 0.004 inches. If you use care in the manufacturing process so that
the board's final etched gap dimension is less than 0.005 to 0.006 inches then you can expect to
have an air gap that can clamp ESD spikes to less than 200 volts. The gap area MUST be open to
the air and NOT covered with solder mask.
The spark gap can be a very effective protection measure, particularly if used in conjunction with
other filtering components. The schematic snippett below shows how the spark gaps can be drawn
directly onto the schematic as an actual "component".
完整的pdf格式文檔51黑下載地址:
焊盤間隙放電Spark Gaps.pdf (1.58 MB, 下載次數: 41)
主站蜘蛛池模板: 精品在线一区二区 | 天堂中文在线资源 | 欧日韩av | 黄色免费视频网站 | 99热99 | 日本大尺度吃奶做爰久久久绯色 | 中文字幕免费看 | 中文字幕黄色 | 中日韩一级片 | 成人免费福利视频 | h网站在线 | 色妞综合网 | 午夜在线观看视频网站 | 国产性色av | 欧美在线性爱视频 | 久久精品一区二区三区四区 | 在线一区视频 | 91成人小视频 | 国产又黄又爽视频 | 日韩一区二区在线观看视频 | 日韩视频第一页 | 亚洲一区中文 | 天天草天天草 | 亚洲射| av黄色在线 | 久久久久91 | 国产午夜精品一区二区三区视频 | 欧美激情综合网 | 黄a视频 | 欧美视频在线观看一区 | 欧美三级 欧美一级 | 一区二区视频网站 | 天天色播 | 日韩一区二区三区在线播放 | 一区二区国产在线 | av在线播放免费 | 五月天.com| 香港三日本三级少妇66 | 欧美男人天堂 | 成人小视频在线 | 国产精品网站在线观看 |
