查看: 3548|回復: 0
NodMCU的例子程序,端口接LED閃爍
ID:137736 發表于 2018-10-14 09:50 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
  NodMCU的例子程序,測試輸出口,接LED可閃爍。
ESP8266核心
// the setup function runs once when you press reset or power the board
void setup() {
  // initialize digital pin 13 as an output.
  pinMode(D0, OUTPUT);  //USER
  pinMode(D1, OUTPUT);
  pinMode(D2, OUTPUT);
  pinMode(D3, OUTPUT);  //FLASH
  pinMode(D4, OUTPUT);  //TXD1,BlueLED
  pinMode(D5, OUTPUT);
  pinMode(D6, OUTPUT);
  pinMode(D7, OUTPUT);  //RXD2
  pinMode(D8, OUTPUT);  //TXD2
  pinMode(D9, OUTPUT);  //RXD0
  pinMode(D10, OUTPUT); //TXD0
// the loop function runs over and over again forever
void loop() {
  digitalWrite(D0, HIGH);   // turn the LED on (HIGH is the voltage level)
  delay(100);              // wait for a second
  digitalWrite(D0, LOW);    // turn the LED off by making the voltage LOW
  digitalWrite(D1, HIGH);   // turn the LED on (HIGH is the voltage level)
  digitalWrite(D1, LOW);    // turn the LED off by making the voltage LOW
  digitalWrite(D2, HIGH);   // turn the LED on (HIGH is the voltage level)
  digitalWrite(D2, LOW);    // turn the LED off by making the voltage LOW
  digitalWrite(D3, HIGH);   // turn the LED on (HIGH is the voltage level)
  digitalWrite(D3, LOW);    // turn the LED off by making the voltage LOW
  digitalWrite(D4, HIGH);   // turn the LED on (HIGH is the voltage level)
  digitalWrite(D4, LOW);    // turn the LED off by making the voltage LOW
  digitalWrite(D5, HIGH);   // turn the LED on (HIGH is the voltage level)
  digitalWrite(D5, LOW);    // turn the LED off by making the voltage LOW
  digitalWrite(D6, HIGH);   // turn the LED on (HIGH is the voltage level)
  digitalWrite(D6, LOW);    // turn the LED off by making the voltage LOW
  digitalWrite(D7, HIGH);   // turn the LED on (HIGH is the voltage level)
  digitalWrite(D7, LOW);    // turn the LED off by making the voltage LOW
  digitalWrite(D8, HIGH);   // turn the LED on (HIGH is the voltage level)
  digitalWrite(D8, LOW);    // turn the LED off by making the voltage LOW
  digitalWrite(D9, HIGH);   // turn the LED on (HIGH is the voltage level)
  digitalWrite(D9, LOW);    // turn the LED off by making the voltage LOW
  digitalWrite(D10, HIGH);   // turn the LED on (HIGH is the voltage level)
  digitalWrite(D10, LOW);    // turn the LED off by making the voltage LOW
主站蜘蛛池模板: 日本精品国产 | 欧美日韩国产激情 | 国语对白做受69 | 欧美黄色一区 | 日韩精品一二区 | av一区二区三区 | 国产精品黄色片 | 亚洲免费久久 | 国产香蕉av | 一级片在线 | 天天干天天操天天干 | 一区二区毛片 | 国产精品手机在线观看 | 午夜视频网| www.欧美精品| 大桥未久在线视频 | 国产性猛交96 | 黄色一级大片在线免费看产 | 久久国产精品免费视频 | 精品视频国产 | 亚洲亚洲人成综合网络 | 中文字幕一区二区三区四区 | 福利片在线 | www.久久久久 | 亚洲一级在线 | 国产午夜一区二区三区 | 免费黄色av | 亚洲一区在线看 | 欧美日韩视频在线 | 欧美日韩小视频 | www一级片 | www精品 | 精品国产乱码久久久久久蜜柚 | 亚洲第一毛片 | 黄色影音 | 看免费毛片 | 伊人影院久久 | 超碰免费在线 | 久久精品国产视频 | 黄色免费网站视频 | 国产精品2区 |
