查看: 3719|回復(fù): 1
NRF51822的一個(gè)串口通信例程源碼
ID:161493 發(fā)表于 2018-10-15 17:36 | 顯示全部樓層 |閱讀模式
單片機(jī)源程序如下:
  1. /* Copyright (c) 2009 Nordic Semiconductor. All Rights Reserved.
  2. *
  3. * The information contained herein is property of Nordic Semiconductor ASA.
  4. * Terms and conditions of usage are described in detail in NORDIC
  5. * SEMICONDUCTOR STANDARD SOFTWARE LICENSE AGREEMENT.
  6. *
  7. * Licensees are granted free, non-transferable use of the information. NO
  8. * WARRANTY of ANY KIND is provided. This heading must NOT be removed from
  9. * the file.
  10. *
  11. */
  12. #include <stdint.h>
  13. #include "nrf.h"
  14. #include "simple_uart.h"
  15. #include "nrf_delay.h"
  16. #include "nrf_gpio.h"
  17. uint8_t simple_uart_get(void)
  18. {
  19.   while (NRF_UART0->EVENTS_RXDRDY != 1)
  20.   {
  21.     // Wait for RXD data to be received
  22.   }
  23.
  24.   NRF_UART0->EVENTS_RXDRDY = 0;
  25.   return (uint8_t)NRF_UART0->RXD;
  26. }
  27. bool simple_uart_get_with_timeout(int32_t timeout_ms, uint8_t *rx_data)
  28. {
  29.   bool ret = true;
  30.
  31.   while (NRF_UART0->EVENTS_RXDRDY != 1)
  32.   {
  33.     if (timeout_ms-- >= 0)
  34.     {
  35.       // wait in 1ms chunk before checking for status
  36.       nrf_delay_us(1000);
  37.     }
  38.     else
  39.     {
  40.       ret = false;
  41.       break;
  42.     }
  43.   }  // Wait for RXD data to be received
  44.   if (timeout_ms >= 0)
  45.   {
  46.     // clear the event and set rx_data with received byte
  47.       NRF_UART0->EVENTS_RXDRDY = 0;
  48.       *rx_data = (uint8_t)NRF_UART0->RXD;
  49.   }
  50.   return ret;
  51. }
  52. void simple_uart_put(uint8_t cr)
  53. {
  54.   NRF_UART0->TXD = (uint8_t)cr;
  55.   while (NRF_UART0->EVENTS_TXDRDY!=1)
  56.   {
  57.     // Wait for TXD data to be sent
  58.   }
  59.   NRF_UART0->EVENTS_TXDRDY=0;
  60. }
  61. void simple_uart_putstring(const uint8_t *str)
  62. {
  63.   uint_fast8_t i = 0;
  64.   uint8_t ch = str[i++];
  65.   while (ch != '\0')
  66.   {
  67.     simple_uart_put(ch);
  68.     ch = str[i++];
  69.   }
  70. }
  71. void simple_uart_config(  uint8_t rts_pin_number,
  72.                           uint8_t txd_pin_number,
  73.                           uint8_t cts_pin_number,
  74.                           uint8_t rxd_pin_number,
  75.                           bool    hwfc)
  76. {
  77. /** @snippet [Configure UART RX and TX pin] */
  78.   nrf_gpio_cfg_output(txd_pin_number);
  79.   nrf_gpio_cfg_input(rxd_pin_number, NRF_GPIO_PIN_NOPULL);
  80.   NRF_UART0->PSELTXD = txd_pin_number;
  81.   NRF_UART0->PSELRXD = rxd_pin_number;
  82. /** @snippet [Configure UART RX and TX pin] */
  83.   if (hwfc)
  84.   {
  85.     nrf_gpio_cfg_output(rts_pin_number);
  86.     nrf_gpio_cfg_input(cts_pin_number, NRF_GPIO_PIN_NOPULL);
  87.     NRF_UART0->PSELCTS = cts_pin_number;
  88.     NRF_UART0->PSELRTS = rts_pin_number;
  89.     NRF_UART0->CONFIG  = (UART_CONFIG_HWFC_Enabled << UART_CONFIG_HWFC_Pos);
  90.   }
  91.   NRF_UART0->BAUDRATE         = (UART_BAUDRATE_BAUDRATE_Baud115200 << UART_BAUDRATE_BAUDRATE_Pos);
  92.   NRF_UART0->ENABLE           = (UART_ENABLE_ENABLE_Enabled << UART_ENABLE_ENABLE_Pos);
  93.   NRF_UART0->TASKS_STARTTX    = 1;
  94.   NRF_UART0->TASKS_STARTRX    = 1;
  95.   NRF_UART0->EVENTS_RXDRDY    = 0;
  96. }
  97. /**********************************************
  98. * 函數(shù)功能:串口處理
  99. * 入口參數(shù):無(wú)
  100. * 返回值:無(wú)
  101. **********************************************/
  102. void Usart_Pro(void)
  103. {
  104.         simple_uart_putstring("123456\r\n");
  105. }
NRF51822_USART.7z (321.13 KB, 下載次數(shù): 39)
ID:442911 發(fā)表于 2018-12-27 22:02 | 顯示全部樓層
good job
主站蜘蛛池模板: 欧美精品在线免费观看 | 国产免费av在线 | 黄色一节片 | 成人福利网 | 成人区精品一区二区婷婷 | 亚洲国产精品久久久久 | 中文字幕在线观看一区二区三区 | 中文字幕在线一区二区三区 | 色偷偷网站 | 精品在线免费观看 | 国产日韩欧美一区二区 | 偷拍一区二区三区 | a免费视频| 国产理论片 | 欧美日韩成人一区二区三区 | 最新国产精品视频 | 欧美日韩视频一区二区 | 538精品视频 | 日韩在线视频观看 | 黄色在线播放 | 国产精品久久久久久久久久久久久 | 亚洲成人中文字幕 | 青青草视频在线观看 | 天天干视频| 欧美精品一二三 | 蜜桃91丨九色丨蝌蚪91桃色 | 欧美激情一区二区 | 国产一区二区福利 | 夜夜操狠狠操 | 免费日韩视频 | 亚洲日本一区二区 | 成人一级片 | 天天干影院 | 国产一区二区三区在线视频 | 久久不射网 | 欧美一级片| 放几个免费的毛片出来看 | 亚洲精品美女 | 欧美精品一级片 | 黄色大片儿| 谁有毛片网站 |
