查看: 6310|回復: 1
瑞薩單片機RX23T芯片手冊及e2 studio開發環境教程
ID:280233 發表于 2018-10-18 17:02 | 顯示全部樓層 |閱讀模式
RX23T芯片手冊及e2 studio 開發環境教程,文件在附件中
2.  Data Output by a Pin View
2.1  Applicable Products
  V1.08.00 and later versions of the CS+ Code Generator for RX
  V3.0.1.9 and later versions of e2
studio (V2.0.2 and later versions of the Code Generator plug-in)
  V1.07.00 and later versions of the AP4 coding assistance tool for RX
2.2  Applicable MCUs
  RX family: RX71M group (BGA package)
2.3  Details
Data to be displayed in [Device Top View] differs from the actual pin of the MCU because display and output data in
[Device List View] of [Code Generator (Design Tool)] are incorrect.
Note that codes generated by the settings in [Peripheral Functions] have no problem.
3.3  Details
In [Code Generator (Design Tool)], the position of the initialization function "R_LCD_Create();" which is output
when the LCD controller/driver (the peripheral function of the RX113 group) is used, is incorrect. Incorrect position
may disable the port settings specified by the initialization function "R_LCD_Create();".
3.4  Workaround
Modify the source file "r_cg_hardware.c" so that the function "R_LCD_Create();" called by the function
"R_Systeminit()" is located after the function "R_PORT_Create();".
The red text is the modification. This modification is required every time code is generated.
Example: When the LCD controller/driver, port, MTU2, and SCI1 are set
- Source file "r_cg_hardware_setup.c"
Before modification:
全部資料51hei下載地址:
RX23T芯片手冊.pdf (12.8 MB, 下載次數: 26)
e2 studio 開發環境教程.pdf (355.88 KB, 下載次數: 61)
主站蜘蛛池模板: 综合二区| 日韩城人网站 | 四虎www | 黄色一级免费 | 一级片免费在线观看 | 国产黄色在线观看 | 黑人巨大猛烈捣出白浆 | 99精品视频免费观看 | 国产精品一区在线播放 | 香蕉视频一区二区三区 | 亚洲精品视频免费 | 欧美精品一区二区三区四区 | 在线播放av网站 | 天天色小说 | 三级av网站 | 青青草国产精品 | 亚洲一区二区三区 | 日本免费一级片 | 一区免费视频 | 国产精品网站在线观看 | 激情小说在线视频 | 黄色免费观看视频 | 中文在线观看免费视频 | 午夜亚洲精品 | 欧美精品福利 | 亚洲成人免费 | 欧美在线视频播放 | 日韩av资源 | 欧美激情视频在线 | 亚洲国产精品久久久 | 国产精品99久久久久久久久久久久 | a毛片视频 | 国产黄色一区 | 欧美精产国品一二三区 | 国产尤物视频 | 黄色日皮视频 | 精品日韩一区 | 成人黄色大片 | 国产伦精品一区二区三区88av | 一级黄色片免费看 | 中文字幕欧美在线 |
