查看: 4188|回復: 1
大家好!c8051F的ad采樣,幫我看下程序哪里的設置有問題!
ID:35884 發表于 2012-3-9 09:35 | 顯示全部樓層 |閱讀模式
c51F350 部分程序
#define SYSCLK       49000000             // SYSCLK frequency (Hz)
#define BAUDRATE     57600                 // UART0 Baudrate (bps)
#define MDCLK        2457600              // Modulator Clock (Hz)
void ADC_Buffered(void)
    unsigned int i;
  float average;
         for (i = 0; i < Sampling_times; i++)
          while(!AD0INT);
         AD0INT = 0;
         ADC_OutputVal = ADC0H;
          ADC_OutputVal =ADC_OutputVal<< 16;
          ADC_OutputVal += (long)ADC0L + ((long)ADC0M << 8);
          sample_array = ADC_OutputVal;
        for(i=0;i<Sampling_times;i++)
          average=average+(float)sample_array;
       average=average/(Sampling_times);
    average=average/256/256/256;
    average=average*VREF;
    average=average*2;
     average=average;
    ADC_VIN= (int)average;
void ADC0_Init (void)
     unsigned ADC0_decimation;
      REF0CN &= ~0x01;                       // disable internal vref
       // REF0CN |= 0x01;                        // (enable if using internal vref)
      // ADC0CN = 0x00;                         // unipolar output codes, GAIN=1
   ADC0CN = 0x10;                         // Bipolar output codes, GAIN=1
       //ADC0CF = 0x00;                         // interrupts upon SINC3 filter output
                                          // and uses internal VREF
       ADC0CF = 0x04;                         // interrupts upon SINC3 filter output
                                          // and ê1ó?ía2?VREF
      ADC0CLK = (SYSCLK/MDCLK)-1;  // Ideally, MDCLK =2.457MHz
                                          // Generate MDCLK for modulator.
   // program decimation rate for desired OWR
     ADC0_decimation = (unsigned long) SYSCLK/ (unsigned long) OWR /
                     (unsigned long) (ADC0CLK+1)/(unsigned long)128;
     ADC0_decimation--;
       ADC0DEC = ADC0_decimation;
       ADC0BUF = 0x00;                        // 1?±?ê?è??o3?
     ADC0MUX = 0x0b;                       // 2?·?ê?è?
                                          // AIN+ => AIN0.0
         ADC0DAC = 0x00;
         ADC0STA = 0x00;                                 // AIN- => AIN0.1
//   ADC0MUX = 0x08;
          ADC0MD |= 0x80;                      // ê1?ü(IDLE Mode)
輸入信號進行采樣調制器在頻率的MDCLK / 128.
ADC0CLK 是調制器時鐘分頻系數
為獲得最佳性能,應選擇使調制器時鐘等于2.4576 MHz(調制器采樣速率= 19.2千赫)的分頻系數
系統時鐘分按照公式:
MDCLK=系統時鐘/ (ADC0CLK + 1)
這樣的話 速度應該很快啊 ~  怎么 程序打出來的ADC_VIN 很慢???
知道大神解釋下  為什么呢???
怎么設置才能最快@!@
ID:35884 發表于 2012-3-9 09:37 | 顯示全部樓層
Sampling_times=128的話 采樣速率應該是  19200 Hz啊  實驗結果目測還不到1Hz~  啊啊啊 啊啊啊
主站蜘蛛池模板: jizz中国女人高潮 | 亚洲成人av在线播放 | 亚洲综合色网 | 精品在线一区 | 欧洲色综合| 免费在线小视频 | 欧洲av网站 | 中文字幕少妇 | 日韩欧美在线播放 | 香蕉视频久久 | 日本精品国产 | 午夜黄色大片 | 97超碰人人 | 国产一区二区免费看 | 久久黄色影院 | 免费在线观看黄色片 | 伊人国产在线 | 四虎久久久 | 亚洲成人欧美 | 亚洲91av| 国产精品国产三级国产 | 精品欧美一区二区精品久久 | 久久理论片| 久久精品av| 黄色一级免费 | 亚洲免费在线观看 | 青青青草视频 | 中国黄色录像 | 欧美综合一区二区 | 日本黄色免费 | 欧美日韩在线一区 | 黄色免费在线视频 | 日韩在线看片 | 在线观看日韩av | www.四虎.com | 久久久久久久久国产 | 成年人视频在线播放 | 一区二区免费看 | 精品亚洲一区二区三区四区五区 | 精品一区在线播放 | 免费看片网站91 |
