查看: 4217|回復: 0
TTP224N觸摸按鍵模塊stm32例程源碼
ID:412790 發表于 2018-10-20 16:56 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
實現功能為按1亮一個燈,按2兩2個燈,以此類推,抬手熄滅。
  1. #include "main.h"
  2. #include "stm32f1xx_hal.h"
  3. #include "gpio.h"
  4. /* USER CODE BEGIN Includes */
  5. #define KEY1_PRES 1
  6. #define KEY2_PRES 2
  7. #define KEY3_PRES 3
  8. #define KEY4_PRES 4
  9. #define KEY1 HAL_GPIO_ReadPin(GPIOB,GPIO_PIN_3)
  10. #define KEY2 HAL_GPIO_ReadPin(GPIOB,GPIO_PIN_4)
  11. #define KEY3 HAL_GPIO_ReadPin(GPIOB,GPIO_PIN_5)
  12. #define KEY4 HAL_GPIO_ReadPin(GPIOB,GPIO_PIN_6)
  13. /* USER CODE END Includes */
  14. /* Private variables ---------------------------------------------------------*/
  15. /* USER CODE BEGIN PV */
  16. /* Private variables ---------------------------------------------------------*/
  17. /* USER CODE END PV */
  18. /* Private function prototypes -----------------------------------------------*/
  19. void SystemClock_Config(void);
  20. void Error_Handler(void);
  21. /* USER CODE BEGIN PFP */
  22. /* Private function prototypes -----------------------------------------------*/
  23. uint8_t KEY_Scan(uint8_t mode);
  24. /* USER CODE END PFP */
  25. /* USER CODE BEGIN 0 */
  26. /* USER CODE END 0 */
  27. int main(void)
  28. {
  29.   /* USER CODE BEGIN 1 */
  30.
  31.
  32.         uint8_t i;
  33.   /* USER CODE END 1 */
  34.   /* MCU Configuration----------------------------------------------------------*/
  35.   /* Reset of all peripherals, Initializes the Flash interface and the Systick. */
  36.   HAL_Init();
  37.   /* Configure the system clock */
  38.   SystemClock_Config();
  39.   /* Initialize all configured peripherals */
  40.   MX_GPIO_Init();
  41.   /* USER CODE BEGIN 2 */
  42.   /* USER CODE END 2 */
  43.   /* Infinite loop */
  44.   /* USER CODE BEGIN WHILE */
  45.   while (1)
  46.   {
  47.   /* USER CODE END WHILE */
  48.   /* USER CODE BEGIN 3 */
  49.   /*  按1亮一個燈,按二亮兩個燈,抬手熄滅 */
  50.
  51.                         i=KEY_Scan(1);
  52.
  53.                 switch(i)
  54.                 {
  55.                         case 0:
  56.                                   HAL_GPIO_WritePin(GPIOA,GPIO_PIN_1,GPIO_PIN_SET);
  57.                             HAL_GPIO_WritePin(GPIOA,GPIO_PIN_2,GPIO_PIN_SET);
  58.                             HAL_GPIO_WritePin(GPIOA,GPIO_PIN_3,GPIO_PIN_SET);
  59.                             HAL_GPIO_WritePin(GPIOA,GPIO_PIN_4,GPIO_PIN_SET);
  60.                             //HAL_Delay(500);
  61.                             break;
  62.
  63.                         case 1:
  64.
  65.                                         HAL_GPIO_WritePin(GPIOA,GPIO_PIN_1,GPIO_PIN_RESET);
  66.                             //HAL_Delay(500);
  67.                                   break;
  68.                         case 2:
  69.                                         HAL_GPIO_WritePin(GPIOA,GPIO_PIN_1,GPIO_PIN_RESET);
  70.                             HAL_GPIO_WritePin(GPIOA,GPIO_PIN_2,GPIO_PIN_RESET);
  71.                             //HAL_Delay(500);
  72.                                   break;
  73.                         case 3:
  74.
  75.                                         HAL_GPIO_WritePin(GPIOA,GPIO_PIN_1,GPIO_PIN_RESET);
  76.                             HAL_GPIO_WritePin(GPIOA,GPIO_PIN_2,GPIO_PIN_RESET);
  77.                             HAL_GPIO_WritePin(GPIOA,GPIO_PIN_3,GPIO_PIN_RESET);
  78.                             //HAL_Delay(500);
  79.                                   break;
  80.                         case 4:
  81.
  82.                                   HAL_GPIO_WritePin(GPIOA,GPIO_PIN_1,GPIO_PIN_RESET);
  83.                             HAL_GPIO_WritePin(GPIOA,GPIO_PIN_2,GPIO_PIN_RESET);
  84.                             HAL_GPIO_WritePin(GPIOA,GPIO_PIN_3,GPIO_PIN_RESET);
  85.                             HAL_GPIO_WritePin(GPIOA,GPIO_PIN_4,GPIO_PIN_RESET);
  86.                             //HAL_Delay(500);
  87.                                   break;
  88.
  89.                         default:HAL_Delay(10);
  90.                 }
  91.
  92.
  93.   }
  94.   /* USER CODE END 3 */
  95. }
  96. /** System Clock Configuration
  97. */
  98. void SystemClock_Config(void)
  99. {
  100.   RCC_OscInitTypeDef RCC_OscInitStruct;
  101.   RCC_ClkInitTypeDef RCC_ClkInitStruct;
  102.     /**Initializes the CPU, AHB and APB busses clocks
  103.     */
  104.   RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSI;
  105.   RCC_OscInitStruct.HSIState = RCC_HSI_ON;
  106.   RCC_OscInitStruct.HSICalibrationValue = 16;
  107.   RCC_OscInitStruct.PLL.PLLState = RCC_PLL_NONE;
  108.   if (HAL_RCC_OscConfig(&RCC_OscInitStruct) != HAL_OK)
  109.   {
  110.     Error_Handler();
  111.   }
  112.     /**Initializes the CPU, AHB and APB busses clocks
  113.     */
  114.   RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_HCLK|RCC_CLOCKTYPE_SYSCLK
  115.                               |RCC_CLOCKTYPE_PCLK1|RCC_CLOCKTYPE_PCLK2;
  116.   RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_HSI;
  117.   RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1;
  118.   RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV1;
  119.   RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV1;
  120.   if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_0) != HAL_OK)
  121.   {
  122.     Error_Handler();
  123.   }
  124.     /**Configure the Systick interrupt time
  125.     */
  126.   HAL_SYSTICK_Config(HAL_RCC_GetHCLKFreq()/1000);
  127.     /**Configure the Systick
  128.     */
  129.   HAL_SYSTICK_CLKSourceConfig(SYSTICK_CLKSOURCE_HCLK);
  130.   /* SysTick_IRQn interrupt configuration */
  131.   HAL_NVIC_SetPriority(SysTick_IRQn, 0, 0);
  132. }
  133. /* USER CODE BEGIN 4 */
  134. uint8_t KEY_Scan(uint8_t mode)
  135. {
  136.                 static uint8_t key_up=1; //按鍵松開標志
  137.           if(mode) key_up=1;  //支持連按
  138.                 if(key_up&&(KEY1==1||KEY2==1||KEY3==1||KEY4==1))
  139.             {
  140.                                         HAL_Delay(10);  //去抖動
  141.                                         key_up=0;
  142.                                         if(KEY1==1)return KEY1_PRES;
  143.                                         else if(KEY2==1)return KEY2_PRES;
  144.                                         else if(KEY3==1)return KEY3_PRES;
  145.                                         else if(KEY4==1)return KEY4_PRES;
  146.
  147.                         }else if(KEY1==0&&KEY2==0&&KEY3==0&&KEY4==0)key_up=1;
  148.                 return 0;// 無按鍵按下
  149. }
  150. /* USER CODE END 4 */
  151. /**
  152.   * @brief  This function is executed in case of error occurrence.
  153.   * @param  None
  154.   * @retval None
  155.   */
  156. void Error_Handler(void)
  157. {
  158.   /* USER CODE BEGIN Error_Handler */
  159.   /* User can add his own implementation to report the HAL error return state */
  160.   while(1)
  161.   {
  162.   }
  163.   /* USER CODE END Error_Handler */
  164. }
  165. #ifdef USE_FULL_ASSERT
  166. /**
  167.    * @brief Reports the name of the source file and the source line number
  168.    * where the assert_param error has occurred.
  169.    * @param file: pointer to the source file name
  170.    * @param line: assert_param error line source number
  171.    * @retval None
  172.    */
  173. void assert_failed(uint8_t* file, uint32_t line)
  174. {
  175.   /* USER CODE BEGIN 6 */
  176.   /* User can add his own implementation to report the file name and line number,
  177.     ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
  178.   /* USER CODE END 6 */
  179. }
  180. #endif
  181. /**
  182.   * @}
  183.   */
  184. /**
  185.   * @}
  186. */
  187. /************************ (C) COPYRIGHT STMicroelectronics *****END OF FILE****/
KEY.rar (3.11 MB, 下載次數: 36)
主站蜘蛛池模板: 中国av在线 | 中文字幕麻豆 | 国产一区精品在线 | 日韩精品大片 | 日韩精品久久久久久 | 日韩欧美久久 | 182tv午夜| 98国产精品 | 99re在线观看 | 国产精品一区二区不卡 | 一区二区久久久 | 香蕉视频色版 | 久久精品一区二区三区四区五区 | 国产精品国产三级国产aⅴ浪潮 | 亚洲国产激情 | 精品视频一区二区三区四区 | 国产在线a | 福利网站在线观看 | 欧美一区二区三区在线视频 | 国产又黄又猛 | 大色av | 九九综合网 | 久久黄色免费视频 | 日韩视频免费看 | 午夜影院免费 | 免费国产精品视频 | 亚洲欧美精品 | 性欧美xxxx | 日韩免费看 | 色婷婷国产精品综合在线观看 | 日本欧美亚洲 | 中文字幕亚洲欧美 | 欧美啪啪网站 | 精品亚洲国产成人av制服丝袜 | 午夜久久久久久久 | 69精品视频 | 色综合99 | 亚洲午夜18毛片在线看 | 在线一区二区三区 | 欧美日韩国产中文 | 久久精品国产一区 |
