在github上找的grbl stm32版本
- #include "project_include.h"
- #include "grbl.h"
- // Declare system global variable structure
- system_t sys;
- int main(void)
- JTAG_Set(SWD_ENABLE); //JTAG接口狀態(tài)設置
- delay_init(); //延時初始化
- // Initialize system upon power-up.
- serial_init(); // Setup serial baud rate and interrupts
- settings_init(); // Load Grbl settings from EEPROM
- stepper_init(); // Configure stepper pins and interrupt timers
- system_init(); // Configure pinout pins and pin-change interrupt
- memset(&sys, 0, sizeof(system_t)); // Clear all system variables
- sys.abort = true; // Set abort to complete initialization
- sei(); // Enable interrupts
- // Check for power-up and set system alarm if homing is enabled to force homing cycle
- // by setting Grbl's alarm state. Alarm locks out all g-code commands, including the
- // startup scripts, but allows access to settings and internal commands. Only a homing
- // cycle '$H' or kill alarm locks '$X' will disable the alarm.
- // NOTE: The startup script will run after successful completion of the homing cycle, but
- // not after disabling the alarm locks. Prevents motion startup blocks from crashing into
- // things uncontrollably. Very bad.
- #ifdef HOMING_INIT_LOCK
- if (bit_istrue(settings.flags,BITFLAG_HOMING_ENABLE)) { sys.state = STATE_ALARM; }
- #endif
- // Force Grbl into an ALARM state upon a power-cycle or hard reset.
- #ifdef FORCE_INITIALIZATION_ALARM
- sys.state = STATE_ALARM;
- #endif
- // Grbl initialization loop upon power-up or a system abort. For the latter, all processes
- // will return to this loop to be cleanly re-initialized.
- for(;;)
- // TODO: Separate configure task that require interrupts to be disabled, especially upon
- // a system abort and ensuring any active interrupts are cleanly reset.
- // Reset Grbl primary systems.
- serial_reset_read_buffer(); // Clear serial read buffer
- gc_init(); // Set g-code parser to default state
- spindle_init();
- coolant_init();
- limits_init();
- probe_init();
- plan_reset(); // Clear block buffer and planner variables
- st_reset(); // Clear stepper subsystem variables.
- // Sync cleared gcode and planner positions to current system position.
- plan_sync_position();
- gc_sync_position();
- // Reset system variables.
- sys.abort = false;
- sys_rt_exec_state = 0;
- sys_rt_exec_alarm = 0;
- sys.suspend = false;
- sys.soft_limit = false;
- // Start Grbl main loop. Processes program inputs and executes them.
- protocol_main_loop();
GRBL-0.9j-for-STM32-master.zip
(543.22 KB, 下載次數(shù): 77)
2018-10-26 17:05 上傳
點擊文件名下載附件
