查看: 4355|回復: 2
vb建無線wifi熱點(附圖)
ID:419103 發表于 2018-11-1 14:28 | 顯示全部樓層 |閱讀模式
本程序是利用vb讀寫文件來實現的,再通過調用計算機中的explorer運行新建的文件,程序思想是通過dos命令建立虛擬無線熱點,因此你的計算機必須要求帶無線網卡,如果你的計算機有無線網卡但不能運行,請嘗試升級網卡驅動。由于運行當中會調用explorer程序,和某些計算機病毒的投放方法有所相同,所以程序在運行時會引起一些安全軟件的誤判。程序運行時會在C:\Users\Administrator\Documents目錄下生成文件。
還有許多不足,希望大家指出改進!
程序源碼如下:
Public a As Integer, e As Integer, f As Integer, b As String, c As String, d As String
Private Sub Command2_Click()
b = Text1.Text
c = Text2.Text
d = "netsh wlan set hostednetwork mode=allow"
If b = "" Or c = "" Then
MsgBox "請填寫新建無線網絡名稱或密碼!", 48, "錯誤!"
Else
If Len(c) = 8 Then
Open "C:\Users\Administrator\Documents\wifibuild.bat" For Output As #1
Print #1, "netsh wlan set hostednetwork mode=allow", "ssid="; b, "key="; c
Print #1, "netsh wlan start hostednetwork"
Close #1
Shell "explorer.exe " & "C:\Users\Administrator\Documents\wifibuild.bat", 1
Label5.Caption = "已連接"
Timer1.Enabled = True
Else
MsgBox "密碼長度應為8位!", 48, "錯誤!"
End If
End If
End Sub
Private Sub Command3_Click()
If Dir("C:\Users\Administrator\Documents\wifibuild.bat") <> "" Then
Open "C:\Users\Administrator\Documents\wifiend.bat" For Output As #1
Print #1, "netsh wlan set hostednetwork mode=disallow"
Shell "explorer.exe " & "C:\Users\Administrator\Documents\wifiend.bat", 1
Close #1
Timer1.Enabled = False
Else
MsgBox "您還沒有創建wifi熱點!", 48, "錯誤!"
End If
End Sub
Private Sub Form_Load()
a = 0
e = 0
f = 0
End Sub
Private Sub Form_Unload(Cancel As Integer)
Kill "C:\Users\Administrator\Documents\wifibuild.bat"
End If
If Dir("C:\Users\Administrator\Documents\wifiend.bat") <> "" Then
Kill "C:\Users\Administrator\Documents\wifiend.bat"
End If
End Sub
Private Sub Option1_Click()
Text2.PasswordChar = ""
End Sub
Private Sub Option2_Click()
Text2.PasswordChar = "*"
End Sub
Private Sub Timer1_Timer()
r: a = a + 1
If a = 60 Then
e = e + 1
a = -1
GoTo r
End If
If e = 60 Then
f = f + 1
e = 0
End If
Label6.Caption = f & "小時" & e & "分鐘" & a & "秒"
End Sub
附圖:
1.未連接
2.已連接
3.
4.打開網絡和共享中心——》更改適配器設置,會發現多了個無線網絡連接2
5.設置寬帶共享
之后你就可以用你的手機連接你的電腦共享網絡上網,再也不怕月末流量報警了有木有!
注意:
程序運行點擊創建wifi時會出現如下情況
點允許執行就行了,我試過用cmd.exe直接打開新建的文件,好像不行,所以只能用explorer了。
完整的Word格式文檔51黑下載地址:
vb建無線wifi熱點(附圖).doc (224.5 KB, 下載次數: 16)
ID:1 發表于 2018-11-1 14:33 | 顯示全部樓層
樓主能傳一下源碼的壓縮包嗎?
ID:419274 發表于 2018-11-1 18:14 | 顯示全部樓層
admin 發表于 2018-11-1 14:33
樓主能傳一下源碼的壓縮包嗎?
我沒有壓縮包。對不起。
主站蜘蛛池模板: 91免费福利 | 日韩一区不卡 | av狠狠干 | 超碰人人射 | 亚洲va韩国va欧美va精品 | 国产成人免费视频 | 国产黄在线观看 | 91精品国产成人www | 久久天天操 | 日韩精品久久久久久久 | 亚洲欧美精品一区 | 黄色激情视频在线观看 | 午夜精品久久久久久久99 | 青青草视频免费在线观看 | 手机看片国产 | 亚洲天堂av在线 | 午夜在线免费视频 | 亚洲国产第一页 | 午夜成人在线视频 | 狠狠的操 | 激情久久av| 69精品视频| 欧美一二三 | 一区两区小视频 | 亚洲免费在线播放 | h片在线| 国产精品久久久久久久 | 日韩欧美高清视频 | 日日干夜夜骑 | 欧美日一区二区三区 | 中国一级黄色录像 | 国产精品国产三级国产aⅴ浪潮 | 国产91在线播放 | 女人一级一片30分 | 国产一区二区在线观看视频 | 婷婷免费视频 | 亚洲天天干 | 亚洲一区影院 | 中国免费毛片 | 岛国av免费观看 | 国产精品毛片va一区二区三区 |
