下載附件
2018-11-4 22:57 上傳
下載:
藍牙調試助手.zip
(121.49 KB, 下載次數: 50)
2018-11-4 20:03 上傳
點擊文件名下載附件
下載積分: 黑幣 -5
部分源碼預覽:
- package com.example.android.BluetoothChat;
- * 描述:藍牙服務核心類
- import java.io.IOException;
- import java.io.InputStream;
- import java.io.OutputStream;
- import java.util.UUID;
- import android.bluetooth.BluetoothAdapter;
- import android.bluetooth.BluetoothDevice;
- import android.bluetooth.BluetoothServerSocket;
- import android.bluetooth.BluetoothSocket;
- import android.content.Context;
- import android.os.Bundle;
- import android.os.Handler;
- import android.os.Message;
- import android.util.Log;
- public class BluetoothChatService {
- // 測試數據
- private static final String TAG = "BluetoothChatService";
- private static final boolean D = true;
- private static final String NAME = "BluetoothChat";
- // 聲明一個唯一的UUID
- private static final UUID MY_UUID = UUID.fromString("00001101-0000-1000-8000-00805F9B34FB"); //change by chongqing jinou
- private final BluetoothAdapter mAdapter;
- private final Handler mHandler;
- private AcceptThread mAcceptThread;
- private ConnectThread mConnectThread;
- private ConnectedThread mConnectedThread;
- private int mState;
- // 常量,顯示當前的連接狀態
- public static final int STATE_NONE = 0;
- public static final int STATE_LISTEN = 1;
- public static final int STATE_CONNECTING = 2;
- public static final int STATE_CONNECTED = 3;
- public BluetoothChatService(Context context, Handler handler) {
- mAdapter = BluetoothAdapter.getDefaultAdapter();
- mState = STATE_NONE;
- mHandler = handler;
- * 設置當前的連接狀態
- * @param state 連接狀態
- private synchronized void setState(int state) {
- if (D) Log.d(TAG, "setState() " + mState + " -> " + state);
- mState = state;
- // 通知Activity更新UI
- mHandler.obtainMessage(BluetoothChatActivity.MESSAGE_STATE_CHANGE, state, -1).sendToTarget();
- * 返回當前連接狀態
- public synchronized int getState() {
- return mState;
- *開始聊天服務
- public synchronized void start() {
- if (D) Log.d(TAG, "start");
- if (mConnectThread != null) {mConnectThread.cancel(); mConnectThread = null;}
- if (mConnectedThread != null) {mConnectedThread.cancel(); mConnectedThread = null;}
- if (mAcceptThread == null) {
- mAcceptThread = new AcceptThread();
- mAcceptThread.start();
- setState(STATE_LISTEN);
- * 連接遠程設備
- * @param device 連接
- public synchronized void connect(BluetoothDevice device) {
- if (D) Log.d(TAG, "連接到: " + device);
- if (mState == STATE_CONNECTING) {
- mConnectThread = new ConnectThread(device);
- mConnectThread.start();
- setState(STATE_CONNECTING);
- * 啟動ConnectedThread開始管理一個藍牙連接
- public synchronized void connected(BluetoothSocket socket, BluetoothDevice device) {
- if (D) Log.d(TAG, "連接");
- if (mAcceptThread != null) {mAcceptThread.cancel(); mAcceptThread = null;}
- mConnectedThread = new ConnectedThread(socket);
- mConnectedThread.start();
- Message msg = mHandler.obtainMessage(BluetoothChatActivity.MESSAGE_DEVICE_NAME);
- Bundle bundle = new Bundle();
- bundle.putString(BluetoothChatActivity.DEVICE_NAME, device.getName());
- msg.setData(bundle);
- mHandler.sendMessage(msg);
- setState(STATE_CONNECTED);
- * 停止所有線程
- public synchronized void stop() {
- if (D) Log.d(TAG, "stop");
- setState(STATE_NONE);
- * 以非同步方式寫入ConnectedThread
- * @param out
- public void write(byte[] out) {
- ConnectedThread r;
- synchronized (this) {
- if (mState != STATE_CONNECTED) return;
- r = mConnectedThread;
- r.write(out);
- * 無法連接,通知Activity
- private void connectionFailed() {
- Message msg = mHandler.obtainMessage(BluetoothChatActivity.MESSAGE_TOAST);
- bundle.putString(BluetoothChatActivity.TOAST, "無法連接設備");
- * 設備斷開連接,通知Activity
- private void connectionLost() {
- bundle.putString(BluetoothChatActivity.TOAST, "設備斷開連接");
- * 監聽傳入的連接
- private class AcceptThread extends Thread {
- private final BluetoothServerSocket mmServerSocket;
- public AcceptThread() {
- BluetoothServerSocket tmp = null;
- try {
- tmp = mAdapter.listenUsingRfcommWithServiceRecord(NAME, MY_UUID);
- } catch (IOException e) {
- Log.e(TAG, "listen() failed", e);
- mmServerSocket = tmp;
- public void run() {
- if (D) Log.d(TAG, "BEGIN mAcceptThread" + this);
- setName("AcceptThread");
- BluetoothSocket socket = null;
- while (mState != STATE_CONNECTED) {
- try {
- socket = mmServerSocket.accept();
- Log.e(TAG, "accept() 失敗", e);
- break;
- // 如果連接被接受
- if (socket != null) {
- synchronized (BluetoothChatService.this) {
- switch (mState) {
- case STATE_LISTEN:
- case STATE_CONNECTING:
- // 開始連接線程
- connected(socket, socket.getRemoteDevice());
- break;
- case STATE_NONE:
- case STATE_CONNECTED:
- // 沒有準備好或已經連接
- try {
- socket.close();
- Log.e(TAG, "不能關閉這些連接", e);
- break;
- if (D) Log.i(TAG, "結束mAcceptThread");
- public void cancel() {
- if (D) Log.d(TAG, "取消 " + this);
- try {
- mmServerSocket.close();
- Log.e(TAG, "關閉失敗", e);
- private class ConnectThread extends Thread {
- private final BluetoothSocket mmSocket;
- private final BluetoothDevice mmDevice;
- public ConnectThread(BluetoothDevice device) {
- mmDevice = device;
- BluetoothSocket tmp = null;
- try {
- tmp = device.createRfcommSocketToServiceRecord(MY_UUID);
- Log.e(TAG, "create() 失敗", e);
- mmSocket = tmp;
- Log.i(TAG, "開始mConnectThread");
- setName("ConnectThread");
- mAdapter.cancelDiscovery();
- try {
- mmSocket.connect();
- connectionFailed();
- try {
- mmSocket.close();
- } catch (IOException e2) {
- Log.e(TAG, "關閉連接失敗", e2);
- BluetoothChatService.this.start();
- return;
- mConnectThread = null;
- connected(mmSocket, mmDevice);
- try {
- mmSocket.close();
- Log.e(TAG, "關閉連接失敗", e);
- * 處理所有傳入和傳出的傳輸
- private class ConnectedThread extends Thread {
- private final InputStream mmInStream;
- private final OutputStream mmOutStream;
- public ConnectedThread(BluetoothSocket socket) {
- Log.d(TAG, "創建 ConnectedThread");
- mmSocket = socket;
- InputStream tmpIn = null;
- OutputStream tmpOut = null;
- // 得到BluetoothSocket輸入和輸出流
- try {
- tmpIn = socket.getInputStream();
- tmpOut = socket.getOutputStream();
- Log.e(TAG, "temp sockets not created", e);
- mmInStream = tmpIn;
- mmOutStream = tmpOut;
- Log.i(TAG, "BEGIN mConnectedThread");
- int bytes;
- String str1 = "";
- // 循環監聽消息
- while (true) {
- try {
- byte[] buffer = new byte[256];
- bytes = mmInStream.read(buffer);
- String readStr = new String(buffer, 0, bytes);
- String str = bytes2HexString(buffer).replaceAll("00","").trim();
- if(bytes>0)
- if (str.endsWith("0D")) {
- byte[] buffer1 = (str1+readStr).getBytes();
- mHandler.obtainMessage(BluetoothChatActivity.MESSAGE_READ, buffer1.length, -1, buffer1)
- .sendToTarget();
- str1 = "";
- else{
- if (!str.contains("0A")) {
- str1 = str1+readStr;
- }else{
- if (!str.equals("0A")&&str.endsWith("0A")) {
- mHandler.obtainMessage(BluetoothChatActivity.MESSAGE_READ, bytes, -1, buffer)
- .sendToTarget();
- else
- Log.e(TAG, "disconnected");
- connectionLost();
- if(mState != STATE_NONE)
- break;
- Log.e(TAG, "disconnected", e);
- connectionLost();
- // 在重新啟動監聽模式啟動該服務
- break;
- * 寫入OutStream連接
- * @param buffer 要寫的字節
- public void write(byte[] buffer) {
- try {
- mmOutStream.write(buffer);
- // 把消息傳給UI
- mHandler.obtainMessage(BluetoothChatActivity.MESSAGE_WRITE, -1, -1, buffer)
- .sendToTarget();
- Log.e(TAG, "Exception during write", e);
- try {
- mmSocket.close();
- Log.e(TAG, "close() of connect socket failed", e);
- * 從字節數組到十六進制字符串轉換
- public static String bytes2HexString(byte[] b) {
- String ret = "";
- for (int i = 0; i < b.length; i++) {
- String hex = Integer.toHexString(b[ i ] & 0xFF);
- if (hex.length() == 1) {
- hex = '0' + hex;
- ret += hex.toUpperCase();
- return ret;
