查看: 4800|回復(fù): 2
用24C04與1602LCD設(shè)計(jì)單片機(jī)電子密碼鎖仿真
ID:410412 發(fā)表于 2018-11-9 10:58 | 顯示全部樓層 |閱讀模式
電子密碼鎖仿真原理圖如下(proteus仿真工程文件可到本帖附件中下載)
單片機(jī)源程序如下:
  1. //-----------------------------------------------------------------
  2. //原始程序中相鄰兩位密碼不能相同.
  3. //本壓縮包中的HEX由修改后的新程序編譯生成,允許輸入任意密碼.
  4. //-----------------------------------------------------------------
  5. //改動(dòng)的主要是main函數(shù)中while循環(huán)內(nèi)的代碼.
  6. //-----------------------------------------------------------------
  7. // 主程序
  8. //-----------------------------------------------------------------
  9. void main()
  10. {
  11.    uchar i = 0;
  12.    uchar IIC_Password[10];
  13.    uchar IS_Valid_User = 0;
  14.    P0 = 0xFF;
  15.    P1 = 0xFF;
  16.    P2 = 0xFF;
  17.    TMOD = 0x02;                     //T0設(shè)置為8位自動(dòng)重裝模式
  18.    TH0 = 175;
  19.    TL0 = 175;
  20.    TR0 = 1;                         //啟動(dòng)T0
  21.    DelayMS(10);
  22.    LCD_Init();                      //初始化LCD
  23.
  24.    IIC_24C04_Init();                //初始化24C04
  25.
  26.    Display_String(Title_Text,0x00); //在第1行顯示標(biāo)題
  27.
  28.    //24C04的內(nèi)容已由初始化BIN文件導(dǎo)入
  29.    //將24C04中預(yù)先寫入的密碼讀入pass
  30.    RecString(0xa0, 0 , IIC_Password, 6);
  31.    IIC_Password[6] = '\0';
  32.    while(1)
  33.    {
  34.       P1 = 0xF0;
  35.       if(P1 != 0xF0) KeyNo = Keys_Scan();  //掃描鍵盤獲取鍵序號(hào)KeyNo
  36.       switch ( KeyNo )
  37.       {
  38.            case 0:  case 1: case 2: case 3: case 4:
  39.            case 5:  case 6: case 7: case 8: case 9:
  40.
  41.                    if ( i<= 5 )             //密碼限制在6位以內(nèi)
  42.                    {
  43.                         //如果i為0則執(zhí)行一次清屏
  44.                         if (i ==0) Display_String("                ",0x40);
  45.
  46.                         UserPassword[i] = KeyNo + '0';
  47.                         UserPassword[i+1] = '\0';
  48.
  49.                         DSY_BUFFER[i] = '*';
  50.                         DSY_BUFFER[i+1] = '\0';
  51.
  52.                         Display_String(DSY_BUFFER,0x40);
  53.
  54.                         i++;
  55.                     }
  56.                     break;
  57.
  58.            case 10: //按A鍵開鎖
  59.                     if (strcmp(UserPassword,IIC_Password) == 0)
  60.                     {
  61.                        LED_OPEN = 0;  //點(diǎn)亮LED
  62.                        Clear_Password();
  63.                        Display_String("Unlock OK!      ",0x40);
  64.                        IS_Valid_User = 1;
  65.                     }
  66.                     else
  67.                     {
  68.                        LED_OPEN =1;   //關(guān)閉LED
  69.                        Clear_Password();
  70.                        Display_String("ERROR !         ",0x40);
  71.                        IS_Valid_User = 0;
  72.                     }
  73.                     i = 0;
  74.                     break;
  75.
  76.            case 11: //按B鍵上鎖
  77.                     LED_OPEN =1;
  78.                     Clear_Password();
  79.                     Display_String(Title_Text,0x00);
  80.                     Display_String("                ",0x40);
  81.                     i = 0;
  82.                     IS_Valid_User = 0;
  83.                     break;
  84.
  85.            case 12: //按C鍵設(shè)置新密碼
  86.                     //如果是合法用戶則提示輸入新密碼
  87.                     if ( !IS_Valid_User ) Display_String("No rights !",0x40);
  88.                     else
  89.                     {
  90.                        i = 0;
  91.                        Display_String("New Password:   ",0x00);
  92.                        Display_String("                ",0x40);
  93.                      }
  94.
  95.                     break;
  96.
  97.            case 13: //按D鍵保存新密碼
  98.                     if ( !IS_Valid_User ) Display_String("No rights !",0x40);
  99.                     else
  100.                     {
  101.                        SendString(0xa0, 0 , UserPassword, 6);
  102.
  103.                        //重新讀入剛寫的密碼
  104.                        RecString(0xa0, 0 , IIC_Password, 6);
  105.                        IIC_Password[6] = '\0';
  106.
  107.                        i = 0;
  108.                        Display_String(Title_Text,0x00);
  109.                        Display_String("Password Saved! ",0x40);
  110.                      }
  111.
  112.                     break;
  113.
  114.            case 14: //按E鍵消除所有輸入
  115.                     i = 0;
  116.                     Clear_Password();
  117.                     Display_String("                ",0x40);
  118.        }
  119.        Beep();
  120.        DelayMS(100);
  121.        P1= 0xF0;
  122.        while (P1 != 0xF0);    //如果有鍵未釋放則等待
  123.        while (P1 == 0xF0);    //如果沒有再次按下按鍵則等待
  124.    }
  125. }
34 用24C04與1602LCD設(shè)計(jì)電子密碼鎖.rar (24.48 KB, 下載次數(shù): 100)
ID:657857 發(fā)表于 2019-12-7 12:32 | 顯示全部樓層
代碼不全啊
ID:465706 發(fā)表于 2019-1-10 21:59 來自觸屏版 | 顯示全部樓層
幾位密碼的啊
主站蜘蛛池模板: 伊人影院综合 | 性久久久久久久 | 精品免费| 狠狠的干 | 一区二区三区视频在线播放 | 91亚洲成人 | 少妇bbw搡bbbb搡bbbb | 一区二区视频在线播放 | 超碰在线免费 | 国产网站在线 | 亚洲精品自拍视频 | 麻豆精品一区二区 | 黄色欧美视频 | 黄色免费大片 | 91小视频在线观看 | 亚洲免费播放 | 超碰人人网 | 美女久久久久 | 国产成人亚洲精品自产在线 | 亚洲欧洲一区 | 成年人免费在线视频 | 婷婷综合视频 | 国产欧美日韩综合 | 自拍偷拍专区 | 成人免费福利视频 | 国产日韩精品一区二区 | 毛片网站在线播放 | 四虎8848| 日韩精品一区二区在线 | 午夜黄视频 | 国产91久久婷婷一区二区 | 久草视频网站 | a视频在线免费观看 | 久久精品国产77777蜜臀 | 国产成人午夜精品 | 999国产视频 | 久久香蕉国产 | 日韩三级大片 | 男男成人高潮片免费网站 | 免费在线观看av | 色天使在线视频 |
