查看: 1975|回復: 0
實驗4-2 GPIO_Test_2
ID:415128 發(fā)表于 2018-11-18 13:50 | 顯示全部樓層 |閱讀模式
本帖最后由 zhou__mi 于 2020-6-22 19:12 編輯
程序代碼:
// 實驗程序分為3個部分或者說3個步驟:
//(1)RCC_Configuration 函數使能外設GPIO PORTC時鐘;
//(2)GPIO_Configuration函數設置PC6為50MHz推挽輸出;
//(3)GPIO_ResetBits庫函數設置PC6輸出低電平0,熄滅與PC6連接的LED1,
//        GPIO_SetBits  庫函數設置PC6輸出高電平1,點亮與PC6連接的LED1。
* File Name          : main.c
* Author             : Zhou_yinxiang, 1881003@qq.com,CDUESTC
* Date First Issued  : 03/08/2014
* Description : 點亮 或 熄滅 與PC6連接的LED1
   使用ST的庫函數,MDK4.7,最簡RCC配置,在AS-05(STM32-SS),AS-07,PROTEUS上驗證通過
/* Includes ---------------------------------------------------------------*/
#include "stm32f10x_lib.h"//包含頭文件
/* Private function prototypes --------------------------------------------*/
void RCC_Configuration(void);//函數聲明
void GPIO_Configuration(void);//函數聲明
/* Private functions ------------------------------------------------------*/
* Function Name  : main
* Description    : Main program.
* Input          : None
* Output         : None
* Return         : None
int main(void)//main函數,在STM32F10x.s里,設置IMPORT  __main為程序的入口
  /* Configure the system clocks */
        RCC_Configuration();//調用設置系統(tǒng)時鐘函數
  /* Configure the GPIO ports */
  GPIO_Configuration();//調用設置GPIO端口函數
                //GPIO_ResetBits(GPIOC, GPIO_Pin_6); //PC6輸出低電平,熄滅LED1
                GPIO_SetBits(GPIOC, GPIO_Pin_6); //PC6輸出高電平,點亮LED1
* Function Name  : RCC_Configuration
* Description    : Configures the different system clocks.
* Input          : None
* Output         : None
* Return         : None
void RCC_Configuration(void)//設置系統(tǒng)時鐘函數
  /* Enable GPIOA clocks */
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC, ENABLE);//使能GPIOC的時鐘
* Function Name  : GPIO_Configuration
* Description    : Configures the different GPIO ports.
* Input          : None
* Output         : None
* Return         : None
void GPIO_Configuration(void)//設置GPIO端口函數
  GPIO_InitTypeDef GPIO_InitStructure;//GPIO_InitStructure是GPIO_InitTypeDef結構體
  /* Configure PC6 as Output push-pull */
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6;//結構體成員GPIO_Pin賦值
  GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;//結構體成員GPIO_Speed賦值
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;//結構體成員GPIO_Mode賦值
  GPIO_Init(GPIOC, &GPIO_InitStructure);//按照上面賦值的結構體初始化GPIOC端口,
                                                           //就是設置PC6為速度是50MHz的推挽(推拉)輸出工作模式
/**************** (C) COPYRIGHT 2007 STMicroelectronics *****END OF FILE****/
實驗4-2 GPIO_Test_2.rar
497.06 KB, 下載次數: 7, 下載積分: 黑幣 -5
主站蜘蛛池模板: 色婷婷一区二区三区四区 | 午夜激情在线观看 | 一区二区国产视频 | 一区二区三区欧美日韩 | 亚洲另类av | 中文字幕理伦片免费看 | 国产黄在线观看 | 人人澡人人爽 | av在线资源网 | 成人午夜免费视频 | 四虎海外| 免费视频一区二区 | 黄色小视频在线免费观看 | 国产1级片 | 久艹在线 | 国产成人在线播放 | 国产成人在线视频 | 人人草在线视频 | 一区二区在线看 | 一区二区三区四区精品 | 在线免费观看黄色片 | 少妇高潮久久久久久潘金莲 | 日韩亚洲欧美在线 | 国产乱乱 | 中文字幕在线观看网址 | 日韩av手机在线 | 国产黄色片视频 | 超碰97在线免费观看 | 亚洲精品在线免费 | 亚洲av毛片成人精品 | 亚洲精品美女 | 91欧美日韩 | 日韩一区二区在线观看视频 | 一区二区三区黄色 | www.青青草| 黄色成人免费网站 | 国产午夜一区二区三区 | 日韩精品在线一区 | 在线免费看a | 一级黄毛片 | 视频一区二区在线观看 |
