查看: 2541|回復: 0
實驗4-3 IOToggle :流水燈
本帖最后由 zhou__mi 于 2020-6-22 19:21 編輯
程序代碼:
//Pass at AS-07 V2.0,ZhouYinxiang,1881003@qq.com,20171009,9:55
//Pass at PROTEUS 8.7,ZhouYinxiang,1881003@qq.com,20181118,11:31
//實驗內容和現象:
//(1)配置時鐘RCC;
//(2)配置中斷NVIC;
//(3)設置全部GPIO為Analog Input mode,降低功耗和提高EMI/EMC;
//(4)使能GPIOA的時鐘,設置PA5為GPIO_Mode_Out_PP 50MHz;使能GPIOC的時鐘,設置PC6和PC7為GPIO_Mode_Out_PP 50MHz;
//(5)LCD顯示實驗信息,沒有學習LCD之前,請忽略;
//(5)流水燈程序:PC6驅動LED1、PC7驅動LED2、PA5驅動LED3依次點亮、延時、熄滅,形成亮流水效果。
// 說明:程序源于STM3210E-EVAL,請看本project的readme.txt
/******************** (C) COPYRIGHT 2008 STMicroelectronics ********************
* File Name          : main.c
* Author             : MCD Application Team
* Version            : V2.0.1
* Date               : 06/13/2008
* Description        : Main program body.
* THE PRESENT FIRMWARE WHICH IS FOR GUIDANCE ONLY AIMS AT PROVIDING CUSTOMERS
* WITH CODING INFORMATION REGARDING THEIR PRODUCTS IN ORDER FOR THEM TO SAVE TIME.
* AS A RESULT, STMICROELECTRONICS SHALL NOT BE HELD LIABLE FOR ANY DIRECT,
* INDIRECT OR CONSEQUENTIAL DAMAGES WITH RESPECT TO ANY CLAIMS ARISING FROM THE
* CONTENT OF SUCH FIRMWARE AND/OR THE USE MADE BY CUSTOMERS OF THE CODING
* INFORMATION CONTAINED HEREIN IN CONNECTION WITH THEIR PRODUCTS.
/* Includes ------------------------------------------------------------------*/
#include "stm32f10x_lib.h"
/* Private typedef -----------------------------------------------------------*/
/* Private define ------------------------------------------------------------*/
/* Private macro -------------------------------------------------------------*/
/* Private variables ---------------------------------------------------------*/
ErrorStatus HSEStartUpStatus;
/* Private function prototypes -----------------------------------------------*/
void RCC_Configuration(void);
void NVIC_Configuration(void);
void Delay(vu32 nCount);
/* Private functions ---------------------------------------------------------*/
* Function Name  : main
* Description    : Main program.
* Input          : None
* Output         : None
* Return         : None
int main(void)
#ifdef DEBUG
  debug();
#endif
//(1)配置時鐘RCC;
  /* System Clocks Configuration **********************************************/
  RCC_Configuration();
//(2)配置中斷NVIC;
  /* NVIC Configuration *******************************************************/
  NVIC_Configuration();
////(3)設置全部GPIO為Analog Input mode,降低功耗和提高EMI/EMC;
//  /* Configure all unused GPIO port pins in Analog Input mode (floating input
//     trigger OFF), this will reduce the power consumption and increase the device
//     immunity against EMI/EMC *************************************************/
//  RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA | RCC_APB2Periph_GPIOB |
//                         RCC_APB2Periph_GPIOC | RCC_APB2Periph_GPIOD |
//                         RCC_APB2Periph_GPIOE, ENABLE); //使能所有的端口時鐘
//  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_All; //選擇設置所有的端口位
//  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AIN;        //模擬輸入模式
//  GPIO_Init(GPIOA, &GPIO_InitStructure); //初始化端口GPIOA
//  GPIO_Init(GPIOB, &GPIO_InitStructure); //初始化端口GPIOB
//  GPIO_Init(GPIOC, &GPIO_InitStructure); //初始化端口GPIOC
//  GPIO_Init(GPIOD, &GPIO_InitStructure); //初始化端口GPIOD
//  GPIO_Init(GPIOE, &GPIO_InitStructure); //初始化端口GPIOE
//                         RCC_APB2Periph_GPIOE, DISABLE);  //失能(關閉)所有的端口時鐘
  /* Configure IO connected to LED1, LED2, LED3  leds *********************/
  /* Enable GPIOC clock */
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA, ENABLE);        //使能GPIOA的時鐘
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_5;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
  GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC, ENABLE);        //使能GPIOC的時鐘
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6 | GPIO_Pin_7;
  GPIO_Init(GPIOC, &GPIO_InitStructure); //初始化PC6和PC7為50MHz推拉輸出
  while (1)
    /* Turn on LED1 */
    GPIO_SetBits(GPIOC, GPIO_Pin_6); //PC6輸出高電平1,驅動LED1點亮
    /* Insert delay */
    Delay(0xAFFFF);         //延時一會兒(0.05038140-0.00031892 = 0.05006248s = 50ms)
    /* Turn off LED1 */
    GPIO_ResetBits(GPIOC, GPIO_Pin_6); //PC6輸出低電平0,驅動LED1熄滅
    /* Insert delay */
    Delay(0xAFFFF);         //延時一會兒(0.10044386-0.05038154 = 0.05006263s = 50ms)
    /* Turn on LED2 */
    GPIO_SetBits(GPIOC, GPIO_Pin_7); //PC7輸出高電平1,驅動LED2點亮
                /* Insert delay */
                /* Turn off LED2*/
    GPIO_ResetBits(GPIOC, GPIO_Pin_7); //PC7輸出低電平0,驅動LED2熄滅
                /* Insert delay */
    /* Turn on LED3 */
    GPIO_SetBits(GPIOA, GPIO_Pin_5); //PA5輸出高電平1,驅動LED3點亮
    /* Insert delay */
    /* Turn off LED3 */
    GPIO_ResetBits(GPIOA, GPIO_Pin_5); //PA5輸出低電平0,驅動LED3熄滅
        /* Insert delay */
實驗4-3 IOToggle.rar
1.51 MB, 下載次數: 8, 下載積分: 黑幣 -5
主站蜘蛛池模板: 欧美激情网站 | 青草视频在线观看免费 | 亚洲精品成人 | 国产高清一区二区三区 | 丁香婷婷在线 | 亚洲高清免费视频 | 毛片视频免费 | 一本色道久久综合亚洲精品小说 | 国产精品久久久久久99 | 九一国产精品 | 九色在线视频 | 亚洲精品一区二区在线观看 | 精品一二三区 | 毛片网站视频 | 日韩午夜片 | 国产高清一区二区 | 97精品国产97久久久久久免费 | 波多野结衣在线观看一区二区 | 国产一区二区福利 | 蜜桃一区二区 | 日韩中文字幕精品 | 一区二区在线视频 | 91操操操 | 精久久久久 | 欧美做爰xxxⅹ性欧美大片 | 久久小视频 | 日韩欧美在线看 | a在线视频 | 亚洲精品久久久蜜桃 | 中文字幕一区二区三区四区 | 黄色三级免费 | 亚洲一区色 | www.四虎.com| 成人福利视频在线观看 | 午夜理伦三级理论 | 成人一级视频 | 国产精品自拍第一页 | 久久国产免费 | 精品一区二区三区免费看 | 香蕉视频一区二区三区 | 亚洲一区国产精品 |
