查看: 4198|回復: 1
STM32F429驅動CH450代碼
ID:432285 發表于 2018-11-24 11:33 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
/***************COPYRIGHT2011***************************
*File Name :ch450.c
*Author    :gaochs
*Description :stm32控制ch450
              stm32IO口分配:
                   SDA = PB11   SCL = PB10   INT = PE0
                   微調旋鈕(INT2_L = PB8   INT3_R = PB9)
                   蜂鳴器 = PE1
*Vision    :V1.0.0
*Last Modify:
*Modification History
#include "stm32f4xx.h"
#include "CH450.h"
Variable Name :CH450_xxx
Dscription    :define CH450 IO
#define        CH450_SDA_SET                GPIO_SetBits(GPIOE, GPIO_Pin_5)        //SDA置高
#define        CH450_SDA_CLR                GPIO_ResetBits(GPIOE, GPIO_Pin_5)        //SDA置低
#define        CH450_SCL_SET                GPIO_SetBits(GPIOE, GPIO_Pin_6)   //SCL置高
#define        CH450_SCL_CLR                GPIO_ResetBits(GPIOE, GPIO_Pin_6)    //SCL置低
#define CH450_RD_SDA        GPIO_ReadInputDataBit(GPIOE, GPIO_Pin_5)
#define DELAY                                mDelayuS(1000)
#define        CH450_I2C_ADDR0                0x40                        // CH450的ADDR=0時的地址
#define        CH450_I2C_MASK                0x3E                        // CH450的2線接口高字節命令掩碼
#define CH450_GET_KEY            0x0700                                        // 獲取按鍵,返回按鍵代碼
// 類型定義
// CH450的全局變量End
void CH450_SDA_IN()
                GPIO_InitTypeDef  GPIO_InitStructure;
                GPIO_InitStructure.GPIO_Pin = GPIO_Pin_5;
          GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN;
          GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL;
                GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
          GPIO_Init(GPIOE, &GPIO_InitStructure);
void CH450_SDA_OUT()
          GPIO_InitStructure.GPIO_Mode = GPIO_Mode_OUT;
          GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
void CH450_SCL_OUT()
                GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6;
*Function Name :mDelayuS
*Description   :0.04us
*Input         :n    延時時間
*Output        :None
*Return        :None
void mDelayuS(u16 n)
   while( --n )
*Function Name :mDelaymS
*Description   :43us
*Input         :delay    延時時間
*Output        :None
*Return        :None
void mDelaymS(u16 delay)
    u16 ms;
    u16 sm;
    u16 c;
    for(ms = delay; ms != 0; ms--)
            for (sm = 200; sm != 0; sm--) c += 3;
            for (sm = 240; sm != 0; sm--) c += 3;
                for (ms = delay; ms != 0; ms--)
*Function Name :CH450_I2c_Start
*Description   :I2C START
*Input         :None
*Output        :None
*Return        :None
void CH450_I2c_Start( void )
                CH450_SDA_OUT();  /* 設置SDA為輸出方向 */
                DELAY;
                CH450_SDA_SET; /*發送起始條件的數據信號*/
                DELAY;
                CH450_SCL_SET;
                DELAY;
                CH450_SDA_CLR;   /*發送起始信號*/
                DELAY;
                CH450_SCL_CLR;  /*鉗住I2C總線,準備發送或接收數據 */
                DELAY;
*Function Name :CH450_I2c_Stop
*Description   :I2C STOP
*Input         :None
*Output        :None
*Return        :None
void CH450_I2c_Stop( void )
                DELAY;
                CH450_SDA_CLR;
                DELAY;
                CH450_SCL_SET;
                DELAY;
                CH450_SDA_SET; /*發送I2C總線結束信號*/
                DELAY;
*Function Name :CH450_I2c_WrByte
*Description   :I2C 寫一個字節
*Input         :c 待寫字節數據
*Output        :None
*Return        :None
void CH450_I2c_WrByte(u8 c)        //寫一個字節數據
                u8 i;
                DELAY;
                for (i = 0; i != 8; i++)
                        if (c & 0x80)
                                        CH450_SDA_SET;
                                        CH450_SDA_CLR;
                        DELAY;
                        CH450_SCL_SET;
                        c <<= 1;
                        DELAY;
                        CH450_SCL_CLR;
                        DELAY;
                CH450_SDA_IN();   /* 設置SDA為輸入方向 */
                DELAY;
                CH450_SCL_SET;  //接收應答
                DELAY;
        CH450_SCL_CLR;
        DELAY;
void CH450_I2C_SendACK()
                CH450_SDA_OUT();
                CH450_SCL_CLR;
                DELAY;
                CH450_SDA_SET;
                DELAY;
                CH450_SCL_SET;
                DELAY;
                CH450_SCL_CLR;
                DELAY;
                CH450_SDA_CLR;
u8 CH450_I2C_ReceACK()
                CH450_SDA_IN();
                CH450_SCL_CLR;
                DELAY;
                CH450_SCL_SET;
                DELAY;
                if (CH450_RD_SDA)
                        CH450_SCL_CLR;
                        DELAY;
                        //CH450_PORT &= ~SDA;
                        return 1;
                        CH450_SCL_CLR;
                        DELAY;
                        return 0;
*Function Name :CH450_I2c_RdByte
*Description   :I2C 讀一個字節
*Input         :None
*Output        :None
*Return        :dat
u8  CH450_I2c_RdByte(void)                //讀一個字節數據
                u8 dat,i;
                u16 j;
                CH450_SDA_OUT(); //CPU釋放SDA引腳
                DELAY;
                CH450_SDA_SET;
                DELAY;
                DELAY;
                dat = 0;
                for (i = 0; i != 8; i++)  // 輸入8位數據
                                CH450_SCL_SET;
                        DELAY;
                                dat <<= 1;
                        j = CH450_RD_SDA;
                        if (j)
                                        dat++;
                        }  // 輸入1位
                        DELAY;
                        CH450_SCL_CLR;
                        DELAY;
                CH450_SDA_OUT();
                DELAY;
                CH450_SDA_SET;
                DELAY;
                CH450_SCL_SET;
                DELAY;
                CH450_SCL_CLR;
                DELAY;
                return(dat);
*Function Name :CH450_Write
*Description   :CH450寫命令
*Input         :command 寫命令
*Output        :None
*Return        :None
void CH450_Write(u16 command)        //寫命令
     CH450_I2c_Start();               /*啟動總線*/
            CH450_I2c_WrByte((u8)(command >> 7) & CH450_I2C_MASK | CH450_I2C_ADDR0);  // CH450的ADDR=0時
            CH450_I2c_WrByte((u8)command);               /*發送數據*/
           CH450_I2c_Stop();                 /*結束總線*/
*Function Name :CH450_Read
*Description   :CH450讀命令
*Input         :None
*Output        :None
*Return        :val
u8 CH450_Read( void)
                u8 val;
                CH450_I2c_Start();/*啟動總線*/
                DELAY;
                //  CH450_I2c_WrByte((u8)(CH450_GET_KEY>>7)&CH450_I2C_MASK|CH450_I2C_ADDR0|0x01);    // 若有兩個CH450并連,當ADDR=0時,需修改為CH450_I2C_ADDR0
                CH450_I2c_WrByte(0x4F);//讀取按鍵代碼輸出字節1
                DELAY;
                val = CH450_I2c_RdByte();      /*讀取數據*/
                DELAY;
                return val;
*Function Name :CH450_Init
*Description   :CH450的初始化函數
*Input         :None
*Output        :None
*Return        :None
void CH450_Init( void )
           /* Enable GPIOG's AHB interface clock */
                RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOE, ENABLE);
                CH450_SCL_OUT();
                DELAY;
                CH450_Write(0x0403);//開顯示鍵盤
                DELAY;
#ifndef _CH450_H_
#define _CH450_H_
*Description   :
*Input         :n    延時時間
*Output        :None
*Return        :None
void mDelayuS(u16 n);
*Description   :
*Input         :delay    延時時間
*Output        :None
*Return        :None
void mDelaymS(u16 delay);
*Input         :None
*Output        :None
*Return        :None
void CH450_I2c_Start( void );
*Input         :None
*Output        :None
*Return        :None
void CH450_I2c_Stop( void );
*Input         :c 待寫字節數據
*Output        :None
*Return        :None
void CH450_I2c_WrByte(u8 c);
*Input         :None
*Output        :None
*Return        :dat
u8  CH450_I2c_RdByte( void );
*Input         :command 寫命令
*Output        :None
*Return        :None
void CH450_Write(u16 command);
*Input         :None
*Output        :None
*Return        :val
u8 CH450_Read( void);
*Input         :None
*Output        :None
*Return        :None
void CH450_Init( void );
#endif
收藏收藏3 分享淘帖 頂 踩
ID:548956 發表于 2021-7-19 13:34 | 只看該作者
好東西,程序可以用,正確的,可惜怎么沒人關注呢!
主站蜘蛛池模板: 欧美一区二区 | 亚洲色综合 | 国产精品一区久久 | 中文字幕av网站 | 亚洲精品1区2区 | 欧美在线免费观看视频 | 日本三级大片 | 国产激情网 | 成人精品福利 | 天天干狠狠操 | 亚洲国产成人av | 伊人色综合网 | 18成人免费观看网站 | 五月天激情综合网 | 夜夜操天天操 | 精品国产aⅴ麻豆 | av免费资源| 黄色大片免费观看 | 日韩精品视频在线免费观看 | 欧美日韩亚洲视频 | 国产精品二区一区二区aⅴ污介绍 | 午夜aaa| 久久久国 | 一区二区三区欧美日韩 | 久久毛片视频 | 亚洲激情在线 | 日韩三级精品 | 波多野结衣在线观看一区二区 | 中文字幕av片 | 在线色网站 | 国产激情久久 | 五月天婷婷综合网 | 久久久久久久网 | 天堂一区二区三区 | 免费国产精品视频 | 天天操一操 | 国内av在线 | 蜜桃91丨九色丨蝌蚪91桃色 | 欧美三级又粗又硬 | 91av免费在线观看 | 天天操夜夜干 |
