查看: 6176|回復: 4
dsp6713源碼及CADENCE原理圖與PCB文件
ID:432228 發表于 2018-11-24 22:40 | 顯示全部樓層 |閱讀模式
cadence視頻和PDF于爭博士教程
  1. /* ------------------------------------------------------------------ */
  2. /* Copyright declaration                                              */
  3. /* ------------------------------------------------------------------ */
  4. /* ------------------------------------------------------------------ */
  5. /* FileName:        DSP6713_CHIP.c                                    */
  6. /* Writen by:       Yu zheng                                          */
  7. /* ------------------------------------------------------------------ */
  8. #define CHIP_6713
  9. /* Include header files */
  10. #include <c6x.h>
  11. #include <csl.h>
  12. #include <csl_irq.h>
  13. #include <csl_pll.h>
  14. #include "DSP6713_CHIP.h"
  15. /* ------------------------------------------------------------------ */
  16. static void PLLDelay(Uint32 count)
  17. {
  18.    Uint32 i = count;
  19.    while(i--)
  20.    {
  21.      asm(" NOP 1");
  22.    }
  23. }
  24. /* ------------------------------------------------------------------ */
  25. static void initPLL()
  26. {
  27.         // temporarily disable global interrupts
  28.         Uint32 gie;
  29.         gie = IRQ_globalDisable();
  30.         //******************  Initialize PLL Registers *****************
  31.         // Put PLL in bypass
  32.         PLL_bypass();
  33.         PLLDelay(20);
  34.
  35.         // Reset PLL
  36.         PLL_reset();
  37.         PLLDelay(20);
  38.
  39.         // Set main multiplier/divisor
  40.     PLL_RSET(PLLDIV0,
  41.                      PLL_PLLDIV0_RMK(PLL_PLLDIV0_D0EN_ENABLE, PLL_PLLDIV0_RATIO_OF(0))
  42.                      );                           // 12.288/1 = 12.288 MHz
  43.         PLL_RSET(PLLM, PLL_PLLM_PLLM_OF(17)); // 12.288*17 = 208 MHz
  44.
  45.     // Set DSP clock
  46.     PLL_RSET(PLLDIV1,
  47.                      PLL_PLLDIV1_RMK(PLL_PLLDIV1_D1EN_ENABLE, PLL_PLLDIV1_RATIO_OF(0))
  48.                      );                                                  // 208/1 = 208 MHz
  49.     PLLDelay(20);
  50.     // Set peripheral clock
  51.     PLL_RSET(PLLDIV2,
  52.                      PLL_PLLDIV2_RMK(PLL_PLLDIV2_D2EN_ENABLE, PLL_PLLDIV2_RATIO_OF(1))
  53.                      );                                                  // 208/2 = 104 MHz
  54.     PLLDelay(20);
  55.
  56.     // Set EMIF clock
  57.     PLL_RSET(PLLDIV3,
  58.                      PLL_PLLDIV3_RMK(PLL_PLLDIV3_D3EN_DISABLE, PLL_PLLDIV3_RATIO_OF(1))
  59.                      );                                                 // 208/2 = 104 MHz
  60.     PLLDelay(20);
  61.
  62.     PLL_RSET(OSCDIV1,
  63.                      PLL_OSCDIV1_RMK(PLL_OSCDIV1_OD1EN_ENABLE,PLL_OSCDIV1_RATIO_OF(1))
  64.                      );                                                 // 208/2 = 104 MHz
  65.
  66.     // Take PLL out of reset. Wait for PLL to lock
  67.     PLL_deassert();
  68.     PLLDelay(1500);
  69.
  70.     // Enalbe PLL
  71.     PLL_enable();
  72.     PLLDelay(20);
  73.         // restore global interrupts back
  74.         IRQ_globalRestore(gie);
  75. }  // end of initPLL
  76. /* ------------------------------------------------------------------ */
  77. void DSP6713_chipinit()
  78. {
  79.         /* register DEVCFG */
  80.         CHIP_Config MyChipConfig =
  81.         {
  82.                 CHIP_DEVCFG_RMK(
  83.                                                 CHIP_DEVCFG_EKSRC_SYSCLK3,
  84.                                                 CHIP_DEVCFG_TOUT1SEL_TOUT1PIN,
  85.                                                 CHIP_DEVCFG_TOUT0SEL_TOUT0PIN,
  86.                                                 CHIP_DEVCFG_MCBSP0DIS_0,
  87.                                                 CHIP_DEVCFG_MCBSP1DIS_0
  88.                                                    )
  89.         };
  90.         CHIP_config(&MyChipConfig);
  91.         initPLL();
  92. }
  93. /* ------------------------------------------------------------------ */
  94. /* end of DSP6713_init.c                                              */
  95. /* ------------------------------------------------------------------ */
于博士CADENCE視頻教程之相關配套資料.rar (3.42 MB, 下載次數: 72)
ID:570549 發表于 2019-6-24 10:55 | 顯示全部樓層
正好可以拿來參考學習,非常感謝分享。
ID:344020 發表于 2020-5-30 16:21 | 顯示全部樓層
正在學習,非常感謝。
ID:1090939 發表于 2023-8-8 14:52 | 顯示全部樓層
這塊板子是帶FPGA部分的嗎
ID:1092015 發表于 2023-8-26 19:41 | 顯示全部樓層
這么老了!
主站蜘蛛池模板: 超碰在线中文字幕 | 日韩黄色录像 | 亚洲精品www | 午夜视频网 | 一级黄视频 | 日韩中文字幕视频 | 久久精品国产视频 | 九九久久精品视频 | 国产香蕉av | 亚洲av毛片成人精品 | 一级看片免费视频 | 2017天天干 | 中文在线观看免费网站 | 成年人一级片 | 午夜网址| 九九九久久久 | 国产一级一片免费播放放a 男男成人高潮片免费网站 精品视频在线观看 | 国产午夜免费视频 | 日本伊人网 | 好色婷婷 | 最新av在线| 精品在线播放 | 亚洲精品福利 | 日韩毛片网站 | 日日操视频 | 天天干天天干天天干 | 中文字幕99 | 国内精品一区二区三区 | 国产三级在线播放 | h片免费看 | 四川一级毛毛片 | 久久免费看 | 天天拍夜夜操 | 欧美日韩成人在线观看 | 国产视频一区二区在线观看 | 国产精品国产三级国产 | 国产理论片 | 日韩视频免费在线观看 | 日韩精品免费看 | 国产精品美女久久久久久久久 | 一区二区三区四区视频 |
