查看: 3546|回復: 1
MSP430實現定時器的源程序
ID:436127 發表于 2018-11-30 22:00 | 顯示全部樓層 |閱讀模式
該程序使用到了TM1638,附件中有。
(上一篇文章中的程序包含了此程序的公共代碼部分,但是我忘了把 tm1638.h 放到附件里面了,這次補上)
定時器初值設為00:02:15,結束后重置為23:59:59
源の代碼:
#include "TM1638.h"
#include "msp430f6638.h"
#include "stdint.h"
uint8_t num[8];    //各個數碼管顯示的值
uint8_t led_flag[8];
const uint8_t tab[] = {0x3F,0x06,0x5B,0x4F,0x66,0x6D,0x7D,0x07,0x7F,0x6F,0x77,0x7C,0x39,0x5E,0x79,0x00};
void init_port(void)
    P3DIR |= BIT5;
    P3DIR |= BIT4 + BIT2;
    P1DIR |= BIT0;    // ACLK set out to pins
    P1SEL |= BIT0;
const uint8_t tab2[] = {0x3F,0x06,0x5B,0x4F,0x66,0x6D,0x7D,0x07,0x7F,0x6F,0x77,0x7C,0x39,0x5E,0x79,0x71};
void TM1638_Write(unsigned char DATA)   //寫數據函數
    unsigned char i;
    DIO_OUT;
    for(i=0;i<8;i++)
      CLK_low;
      if(DATA & 0x01)
          DIO_high;
          DIO_low;
      CLK_high;
      DATA>>=1;
unsigned char TM1638_Read(void)     //讀數據函數
    unsigned char i;
    unsigned char temp=0;
    DIO_IN;
    STB_low;
    for(i=0;i<8;i++)
          temp>>=1;
          CLK_low;
          _delay_us(100);
          if(DIO_READ)
              temp |= 0x80;
              temp &= 0x7f;
          CLK_high;
    return temp;
void Write_COM(unsigned char cmd)  //發送命令字
    CLK_high;
    STB_high;
    STB_low;
    TM1638_Write(cmd);
    STB_high;
void Write_DATA(unsigned char add,unsigned char DATA)  //指定地址寫入數據
    Write_COM(0x44);
    STB_low;
    TM1638_Write(0xc0|add);
    TM1638_Write(DATA);
    STB_high;
void init_TM1638(void)
    unsigned char count = 0;
    unsigned char times = 1;
    while(times--){
        Write_allLED(tab2[count]);
        count++;
        if(count == 16)
            count = 0;
        _delay_ms(100);
    Write_allLED(0xff);
    _delay_ms(100);
    Write_allLED(0);
void delay(){
    for (int i=0; i<10; i++)
      for (int j=0; j<1000; j++);
void  Write_allLED(unsigned char DATA){
    unsigned char i;
    Write_COM(0x8F);//顯示控制
    Write_COM(0x40); //數據命令
    STB_low;
    TM1638_Write(0xc0);
    for(i=0;i<16;i++)
    TM1638_Write(DATA);
    STB_high;
int main(void)
    WDTCTL = WDTPW+WDTHOLD;
    init_port();
    init_TM1638();
    int hourA = 0;
    int hourB = 0;
    int minuteA = 0;
    int minuteB = 2;
    int secondA = 1;
    int secondB = 5;
    while(1) {
        secondB--;
        if(secondB == -1) {
            secondB = 9;
            secondA--;
            if(secondA == -1) {
                secondA = 5;
                minuteB--;
                if(minuteB == -1) {
                    minuteB = 9;
                    minuteA--;
                    if(minuteA == -1) {
                        minuteA = 5;
                        hourB--;
                        if(hourB == -1) {
                            hourB = 9;
                            hourA--;
                            if(hourA == -1) {
                                hourA = 2;
                                hourB = 3;
        Write_DATA(4*2,tab[hourA]);
        Write_DATA(5*2,tab[hourB]);
        Write_DATA(6*2,tab[15]);
        Write_DATA(7*2,tab[minuteA]);
        Write_DATA(0*2,tab[minuteB]);
        Write_DATA(1*2,tab[15]);
        Write_DATA(2*2,tab[secondA]);
        Write_DATA(3*2,tab[secondB]);
        delay();
sy2-3-1.zip
1.94 KB, 下載次數: 7, 下載積分: 黑幣 -5
定時器
ID:436127 發表于 2018-11-30 22:17 | 顯示全部樓層
補充說明一下,主函數中的delay是我自己寫的,是為了便于調試,并沒有真正起到延時1s的作用
主站蜘蛛池模板: 一级片免费在线观看 | 亚洲视频精品 | 成人午夜又粗又硬又大 | 97色婷婷 | 成人在线视频免费观看 | 成人毛片100免费观看 | 国产欧美综合一区二区三区 | 亚洲小视频在线观看 | 日韩免费高清 | 日本黄色视屏 | 伊人网在线播放 | 国产免费高清 | 在线观看亚洲一区 | 久久日av| 在线观看欧美日韩 | 亚洲成人黄色 | 亚洲欧美另类在线观看 | 日韩欧美国产成人 | 亚洲欧洲在线观看 | 国产中文在线 | 久久精品视频一区二区 | 国产精品美女久久久久av爽 | 国产一区二区欧美 | 欧美日本在线观看 | 日韩视频在线播放 | 日韩综合久久 | 成人深夜| 俺去俺来也在线www色官网 | 欧美一级网站 | 成人毛片在线 | 97免费在线视频 | 成人免费毛片嘿嘿连载视频 | 国产欧美成人 | 欧美成人极品 | 欧美在线不卡 | 综合久久99 | 黄色三级在线 | 色婷婷av一区二区三区之e本道 | 日本色图视频 | 高hnp失禁3p小公主 | 青娱乐福利视频 |
