查看: 4334|回復(fù): 2
MSP430實現(xiàn)計時器的源代碼
ID:436127 發(fā)表于 2018-11-30 22:08 | 只看該作者 回帖獎勵 |正序瀏覽 |閱讀模式
和上一篇文章一樣,用到了 TM1638。計時器初值設(shè)為 23:57:45,計時到 23:59:59 時重置為 0點 0分 0秒。
(和上次的定時器一樣,主函數(shù)中的delay是我自己寫的,是為了便于調(diào)試,并沒有真正起到延時1s的作用)
源の代碼:
#include "TM1638.h"
#include "msp430f6638.h"
#include "stdint.h"
uint8_t num[8];    //各個數(shù)碼管顯示的值
uint8_t led_flag[8];
const uint8_t tab[] = {0x3F,0x06,0x5B,0x4F,0x66,0x6D,0x7D,0x07,0x7F,0x6F,0x77,0x7C,0x39,0x5E,0x79,0x00};
void init_port(void) {
    P3DIR |= BIT5;
    P3DIR |= BIT4 + BIT2;
    P1DIR |= BIT0;    // ACLK set out to pins
    P1SEL |= BIT0;
const uint8_t tab2[] = {0x3F,0x06,0x5B,0x4F,0x66,0x6D,0x7D,0x07,0x7F,0x6F,0x77,0x7C,0x39,0x5E,0x79,0x71};
void TM1638_Write(unsigned char DATA) {    //寫數(shù)據(jù)函數(shù)
    unsigned char i;
    DIO_OUT;
    for(i=0;i<8;i++) {
      CLK_low;
      if(DATA & 0x01)
          DIO_high;
          DIO_low;
      CLK_high;
      DATA >>= 1;
unsigned char TM1638_Read(void) {    //讀數(shù)據(jù)函數(shù)
    unsigned char i;
    unsigned char temp=0;
    DIO_IN;
    STB_low;
    for(i=0;i<8;i++) {
          temp >>= 1;
          CLK_low;
          _delay_us(100);
          if(DIO_READ)
              temp |= 0x80;
              temp &= 0x7f;
          CLK_high;
    return temp;
void Write_COM(unsigned char cmd) {    //發(fā)送命令字
    CLK_high;
    STB_high;
    STB_low;
    TM1638_Write(cmd);
    STB_high;
void Write_DATA(unsigned char add,unsigned char DATA) {    //指定地址寫入數(shù)據(jù)
    Write_COM(0x44);
    STB_low;
    TM1638_Write(0xc0|add);
    TM1638_Write(DATA);
    STB_high;
void init_TM1638(void) {
    unsigned char count = 0;
    unsigned char times = 1;
    while(times--) {
        Write_allLED(tab2[count]);
        count++;
        if(count == 16)
            count = 0;
        _delay_ms(100);
    Write_allLED(0xff);
    _delay_ms(100);
    Write_allLED(0);
void delay() {
    for (int i=0; i<10; i++)
      for (int j=0; j<1000; j++);
void Write_allLED(unsigned char DATA) {
    unsigned char i;
    Write_COM(0x8F);//顯示控制
    Write_COM(0x40); //數(shù)據(jù)命令
    STB_low;
    TM1638_Write(0xc0);
    for(i=0;i<16;i++)
    TM1638_Write(DATA);
    STB_high;
void main(void) {
    WDTCTL = WDTPW+WDTHOLD;
    init_port();
    init_TM1638();
    int hourA = 2;
    int hourB = 3;
    int minuteA = 5;
    int minuteB = 7;
    int secondA = 4;
    int secondB = 5;
    while(1) {
        secondB++;
        if(secondB == 10) {
            secondB = 0;
            secondA++;
            if(secondA == 6) {
                secondA = 0;
                minuteB++;
                if(minuteB == 10) {
                    minuteB = 0;
                    minuteA++;
                    if(minuteA == 6) {
                        minuteA = 0;
                        hourB++;
                        if(hourB == 10) {
                            hourB = 0;
                            hourA++;
                        if(hourA == 2 && hourB == 4) {
                            hourA = 0;
                            hourB = 0;
        Write_DATA(4*2,tab[hourA]);
        Write_DATA(5*2,tab[hourB]);
        Write_DATA(6*2,tab[15]);
        Write_DATA(7*2,tab[minuteA]);
        Write_DATA(0*2,tab[minuteB]);
        Write_DATA(1*2,tab[15]);
        Write_DATA(2*2,tab[secondA]);
        Write_DATA(3*2,tab[secondB]);
        delay();
shiy2-3-2.zip
1.95 KB, 下載次數(shù): 5, 下載積分: 黑幣 -5
收藏收藏 分享淘帖 頂1 踩
ID:588621 發(fā)表于 2019-8-7 08:50 來自觸屏版 | 只看該作者
劉旭0625 發(fā)表于 2018-12-30 16:36
很好,++++++
能不能給我發(fā)個定時一分鐘燈亮的程序
ID:458641 發(fā)表于 2018-12-30 16:36 | 只看該作者
很好,++++++
主站蜘蛛池模板: 亚洲天天看 | 国产美女91呻吟求 | 国产三级在线观看 | www.色婷婷| 国产又粗又大又爽 | 亚洲高清在线 | 午夜影院在线观看视频 | 天堂网亚洲 | 中文字字幕在线 | 色婷婷免费视频 | 日日舔 | 老女人性生活视频 | 久国产| 免费在线成人网 | avtt久久| 日本不卡视频 | 中文字幕自拍 | 精品视频在线免费 | 欧美综合一区 | 精品亚洲国产成人av制服丝袜 | 亚洲高清在线视频 | 欧美日韩国产成人 | 婷婷激情综合网 | 日韩av在线不卡 | 精品一区二区三区免费 | 日韩黄色免费视频 | 91伦理| 1024日韩| 欧美一区二区三区四区五区 | 五月婷婷色综合 | 国产中文字幕在线观看 | 久久精品久久久久 | 天天天天操 | 色婷婷国产 | av在线资源网 | 91丨porny丨成人蝌蚪 | 久久精品一区二区三区四区 | 免费视频a| 中国农村毛片免费播放 | 一区在线视频 | 一二三四区在线观看 |
