查看: 3589|回復(fù): 1
基于stm8單片機的DHT11溫濕度測量儀程序
ID:438219 發(fā)表于 2018-12-3 11:00 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
程序代碼
1)函數(shù)聲明、變量定義代碼:
Wsdcl_main.h文件:
#include"stm8s.h"
#define u8 unsigned char
#define u16 unsigned char
#define u32 unsigned long
#define KEY_PORT  GPIOE
#define KEY_PIN   GPIO_PIN_0
extern unsigned int   temp_1,temp_2, temp_4,temp_5;
extern unsigned int  humi_1, humi_2, humi_4, humi_5;
void CLK_Configuration(void);
void GPIO_Configuration(void);
void KEY_Init(void);
void TIM2_Configuration();
void ceshi_on(void);
void Alarm_Beep();
void ceshi_off(void);
DHT11.h文件:
#include"stm8s.h"
#define DHT11_IO_IN  GPIO_Init(GPIOE, GPIO_PIN_6, GPIO_MODE_IN_PU_NO_IT)//輸入模式
#define DHT11_IO_OUT GPIO_Init(GPIOE, GPIO_PIN_6, GPIO_MODE_OUT_PP_LOW_FAST)//輸出模式
#define GPIO_PIN_UP  GPIO_WriteHigh(GPIOE, GPIO_PIN_6)//拉高電平
#define GPIO_PIN_DOWN GPIO_WriteLow(GPIOE, GPIO_PIN_6)//拉低電平
#define        DHT11_DQ_IN  GPIO_ReadInputPin(GPIOE, GPIO_PIN_6) //讀取引腳信號
extern unsigned char Table_Data[4];
unsigned char DHT11_Get_Data(void);
int start_DHT11(void);
7219.h文件:
#include"stm8s.h"
#include"wsdcl_main.h"
/*定義7219各個地址*/
#define MSB       0x80
#define LSB       0x01
#define DECODE_MODE   0x09
#define INTENSITY     0x0A
#define SCAN_LIMIT    0x0B
#define SHUT_DOWN     0x0C
#define DISPLAY_TEST  0x0F
#define   GPIO_PORT    GPIOD
void Init_Max7219();
void clear_7219();
void Write_Max7219(unsigned char address,unsigned char dat);
void Display_Error(void);
void Display_Temp(void);
void Display_Humi(void);
Delay.h文件:
#include"stm8s.h"
void Delay_ms(u32 ms);
void Delay_us(u32 us);
2)主函數(shù)代碼:
Wsdcl_main.c文件:
#include"stm8s.h"
#include"7219.h"
#include"Delay.h"
#include"DHT11.h"
int _Turn;
int main()
{   _Turn=1; //先顯示溫度
   CLK_HSIPrescalerConfig(CLK_PRESCALER_HSIDIV1); //時鐘配置16MHz
   KEY_Init();  //按鍵切換顯示初始化
    TIM2_Configuration();//TIM2時鐘配置
   if(start_DHT11()==1)//檢測是否有響應(yīng),結(jié)果有響應(yīng)往下執(zhí)行
     DHT11_Get_Data();  //從DHT11取數(shù)據(jù)
        /*設(shè)置溫濕度警戒 蜂鳴器報警*/
        if((Table_Data[2]>30)|(Table_Data[0]>60))
          Alarm_Beep();
        else   GPIO_WriteLow(GPIOD,GPIO_PIN_4);
           Init_Max7219(); //初始化Max7219
            /*取溫度數(shù)據(jù)各個位數(shù)值*/
            temp_1=Table_Data[2]/10;
            temp_2=Table_Data[2]%10;
            temp_4=Table_Data[3]/10;
            temp_5=Table_Data[3]%10;
            /*取濕度數(shù)據(jù)各個位數(shù)值*/
            humi_1=Table_Data[0]/10;
            humi_2=Table_Data[0]%10;
            humi_4=Table_Data[1]/10;
            humi_5=Table_Data[1]%10;
        /*按鍵切換顯示溫濕度*/
        if(_Turn>0)
         Display_Temp();
         Display_Humi();
/*蜂鳴器報警函數(shù)*/
void Alarm_Beep()
  GPIO_Init(GPIOD, GPIO_PIN_4, GPIO_MODE_OUT_PP_LOW_FAST);
  BEEP_DeInit();
  BEEP_Init(BEEP_FREQUENCY_1KHZ);
  BEEP_LSICalibrationConfig(12800);
  BEEP_Cmd(ENABLE);
  GPIO_WriteHigh(GPIOD,GPIO_PIN_4);//蜂鳴器響
void ceshi_on(void)//用LED燈來測試程序運行情況
GPIO_Init(GPIOE, GPIO_PIN_5, GPIO_MODE_OUT_PP_LOW_FAST);
GPIO_WriteLow(GPIOE, GPIO_PIN_5);
GPIO_WriteHigh(GPIOE, GPIO_PIN_5);
/*********************TIM2配置*****************************/
   TIM2_DeInit();
   TIM2_ClearITPendingBit(TIM2_IT_UPDATE);
   TIM2_TimeBaseInit(TIM2_PRESCALER_8192,0xF42);//2秒產(chǎn)生一次中斷
   TIM2_ITConfig(TIM2_IT_UPDATE, ENABLE);
   TIM2_Cmd(ENABLE);//啟動定時器2
   enableInterrupts();//開總中斷
/*********************按鍵配置*****************************/
void KEY_Init(void)
  GPIO_Init(KEY_PORT,KEY_PIN,GPIO_MODE_IN_PU_IT);
  EXTI_SetExtIntSensitivity(EXTI_PORT_GPIOE, EXTI_SENSITIVITY_FALL_ONLY);//只有下降沿觸發(fā)
  enableInterrupts();
/*********************中斷服務(wù)函數(shù)*****************************/
#pragma vector=9
__interrupt void EXTI_PORTE_IRQHandler(void)//按鍵中斷切換顯示服務(wù)函數(shù)
  _Turn=-_Turn;
#pragma vector=15
__interrupt void TIM2_UPD_OVF_BRK_IRQHandler(void)//定時中斷更新數(shù)據(jù)服務(wù)函數(shù)
  start_DHT11();
  DHT11_Get_Data();//更新溫濕度數(shù)據(jù)
3)DHT11溫濕度傳感器模塊代碼:
DHT11.c文件:
#include"stm8s.h"
#include"DHT11.h"
#include"Delay.h"
int count_1,count_2;
unsigned char sbuf;
/**********************喚起DHT11**************************************/
         GPIO_Init(GPIOE, GPIO_PIN_6, GPIO_MODE_OUT_PP_LOW_FAST);
         GPIO_WriteLow(GPIOE, GPIO_PIN_6);//拉低18ms以上
         Delay_ms(10000);//Delay_ms(18);
         GPIO_WriteHigh(GPIOE, GPIO_PIN_6);
         Delay_us(30);  //拉高20~40us
         GPIO_Init(GPIOE, GPIO_PIN_6, GPIO_MODE_IN_PU_NO_IT); ceshi_on();
         while(!DHT11_DQ_IN);//等待80us低電平結(jié)束
         while(DHT11_DQ_IN); ceshi_off();//等待80us高電平結(jié)束
         return(1); //應(yīng)答成功返回1
/************************讀取8位字節(jié)***********************************/
void com(void)
        u8 i;
        sbuf=0;
        for(i=8;i>0;i--)
           count_1=2;
          while((!DHT11_DQ_IN)&&count_1++); //等待傳送數(shù)據(jù)開始50us低電平結(jié)束并記錄所用時間count_1
           count_2=2;
while((DHT11_DQ_IN)&&count_2++) ;//等待"1"或"0"高電平結(jié)束并記錄所用時間count_2
        if(count_2>(count_1))  //比較count_2與count_1來判斷輸入是"1"還是"0"
          {        sbuf<<=1;
                        sbuf|=0x01;
          {  sbuf<<=1;
                   sbuf|=0x00;
/**********************讀取數(shù)據(jù)**************************************/
unsigned char DHT11_Get_Data()
{        u32 check,sum;
                com();
                Table_Data[0]=sbuf;//濕度8位整數(shù)
                com();
                Table_Data[1]=sbuf;//濕度小數(shù)部分
                com();
                Table_Data[2]=sbuf;//溫度整數(shù)部分
                com();
                Table_Data[3]=sbuf;//溫度小數(shù)部分
                com();
                check = sbuf;//校驗部分
                sum =(Table_Data[0]+Table_Data[1]+Table_Data[2]+Table_Data[3]);
        if(check == sum)//校驗正確則返回1
         return(1);
        else  return (0);
4)MAX7219顯示模塊程序代碼:
7219.c文件:
#include"stm8s.h"
#include"DHT11.h"
#include"7219.h"
unsigned int   temp_1,temp_2,temp_4,temp_5;
u8 LEDcode[10]={0x7e,0x30,0x6d,0x79,0x33,0x5b,0x5f,0x70,0x7f,0x7b};
/**********************IO口配置************************************/
void Dispaly_GPIO_LoadOn()
  GPIO_Init(GPIO_PORT, GPIO_PIN_1, GPIO_MODE_OUT_PP_LOW_FAST);
  GPIO_WriteHigh(GPIO_PORT,GPIO_PIN_1);
void Dispaly_GPIO_LoadOff()
  GPIO_Init(GPIO_PORT,GPIO_PIN_1, GPIO_MODE_OUT_PP_LOW_FAST);
  GPIO_WriteLow(GPIO_PORT,GPIO_PIN_1);
void Dispaly_GPIO_ClkOn()
  GPIO_Init(GPIO_PORT,GPIO_PIN_2, GPIO_MODE_OUT_PP_LOW_FAST);
  GPIO_WriteHigh(GPIO_PORT,GPIO_PIN_2);
void Dispaly_GPIO_ClkOff()
  GPIO_WriteLow(GPIO_PORT,GPIO_PIN_2);
void Dispaly_GPIO_INPUT()//載入數(shù)據(jù)
  GPIO_Init(GPIO_PORT,GPIO_PIN_0,GPIO_MODE_OUT_PP_LOW_FAST);
/*******************向Max7219寫入8位數(shù)據(jù)************************/
void Write_Max7219_byte(unsigned char temp)
  unsigned char i,x;
  for (i=0;i<8;i++)
       Dispaly_GPIO_ClkOff();//GPIOD_PIN_2推挽輸出,寫低電平
       x=temp&MSB;
       if(x==0)
         Dispaly_GPIO_INPUT();//GPIOD_PIN_0推挽輸出
         GPIO_WriteLow(GPIO_PORT,GPIO_PIN_0);//輸入數(shù)據(jù)為"0"
         GPIO_WriteHigh(GPIO_PORT,GPIO_PIN_0);//輸入數(shù)據(jù)為"1"
       temp<<=1;
Dispaly_GPIO_ClkOn();//GPIOD_PIN_2推挽輸出,寫高電平,數(shù)據(jù)載入16位移位寄存器
/***********************向7219寫入16位數(shù)據(jù)*************************/
    Dispaly_GPIO_LoadOff();//GPIOD_PIN_1推挽輸出,寫低電平
    Write_Max7219_byte(address);
    Write_Max7219_byte(dat);
    Dispaly_GPIO_LoadOn(); //GPIOD_PIN_1推挽輸出,寫高電平,鎖存16位數(shù)據(jù)
/***********************初始化Max7219***************************/
void Init_Max7219(void)
    Write_Max7219(SHUT_DOWN, 0x01);                   //正常操作模式
    Write_Max7219(DISPLAY_TEST, 0x00);           //正常顯示
    Write_Max7219(DECODE_MODE, 0x00);           //不采用B譯碼模式
    Write_Max7219(SCAN_LIMIT, 0x07);                   //設(shè)置顯示的數(shù)據(jù)位數(shù)
    Write_Max7219(INTENSITY, 0x0A);                   //設(shè)置顯示的亮度
/**************************清除顯示******************************/
void clear_7219(void)
unsigned char i;       //變量i,用來選擇數(shù)碼管位選
for(i=8;i>0;i--)     //i自減,選擇完所有的8位
{  Write_Max7219(i,0x00);  //對應(yīng)位選的段全部清除顯示
/*********************溫度顯示***************************************/
   Init_Max7219();//MAX7219初始化
   clear_7219();   //MAX7219清除顯示,免去干擾
    Write_Max7219(0x01,0x4e);//顯示攝氏度符號℃
    Write_Max7219(0x02,0x63);
    Write_Max7219(0x03,LEDcode[temp_5]);
    Write_Max7219(0x04,LEDcode[temp_4]);
    Write_Max7219(0x05,LEDcode[temp_2]|0x80);
    Write_Max7219(0x06,LEDcode[temp_1]);
/************************濕度顯示************************************/
    Write_Max7219(0x01,0x37);//顯示濕度符號RH
    Write_Max7219(0x02,0x77);
    Write_Max7219(0x03,LEDcode[humi_5]);
    Write_Max7219(0x04,LEDcode[humi_4]);
    Write_Max7219(0x05,LEDcode[humi_2]|0x80);
    Write_Max7219(0x06,LEDcode[humi_1]);
5)延時函數(shù)程序代碼:
#include"stm8s.h"
#include"Delay.h"
  void Delay_ms(u32 nCount)
  for(char i=0;i<10;i++)
  {    while (nCount != 0)
    {      nCount--;
/*微秒延時函數(shù)*/
void Delay_us(u32 nCount)
{  for(char i=0;i<5;i++)
    {      nCount--;
收藏收藏2 分享淘帖 頂 踩
ID:1 發(fā)表于 2018-12-4 04:35 | 只看該作者
補全原理圖或者詳細說明一下電路連接即可獲得100+黑幣
主站蜘蛛池模板: 午夜婷婷 | 国产精品美女久久久久av爽 | 三级黄色片| 青青青在线视频 | 综合色婷婷一区二区亚洲欧美国产 | 免费看黄色录像 | a级片毛片 | 人与拘一级a毛片 | 日韩在线视频免费观看 | 欧美成人精品欧美一级乱黄 | 日本毛片在线观看 | 欧美色综合网 | 免费看黄色av | 欧美成人一区二区 | 免费国产网站 | 久久久精品影院 | 少妇搡bbbb搡bbb搡毛茸茸 | 国产精品第二页 | 日本精品国产 | 中文在线观看视频 | 国产精品二区一区二区aⅴ污介绍 | 日韩精品少妇 | 亚洲成人毛片 | 看片地址 | 天天操免费视频 | 午夜无遮挡 | 91综合网| 天天天天干 | 国产又色又爽又黄又免费 | 神马午夜视频 | 大尺度做爰呻吟舌吻网站 | 播播激情网 | 亚洲精品一区二区三区精华液 | 成人自拍视频在线观看 | 91蝌蚪少妇偷拍 | 国产欧美成人 | 亚洲最大黄色网址 | 在线一级片 | 国产欧美一区二区精品忘忧草 | 亚洲一区亚洲二区 | 一级中国毛片 |
