查看: 5359|回復: 5
N76E003新唐mcu做從機模擬AT24C02程序(已測試)
ID:435160 發表于 2018-12-4 15:27 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
單片機源碼:
  1. #include "N76E003.h"
  2. #include "Common.h"
  3. #include "Delay.h"
  4. #include "SFR_Macro.h"
  5. #include "Function_define.h"
  6. #define EEPROM_SLA              0xA0   //AT24C02
  7. UINT8 data_received[64]= 0;    //change to 256 if the rom space is enough
  8. UINT8 data_num = 0;
  9. UINT8 irxdata =0;
  10. UINT8 isubaddr =0;
  11. void I2C_ISR(void) interrupt 6
  12. {
  13.     static UINT8 islavecount=0;
  14.
  15.     switch (I2STAT)
  16.     {
  17.         case 0x00:
  18.             STO = 1;
  19.
  20.             break;
  21.         case 0x60:
  22.             AA = 1;
  23.
  24.             islavecount=0;
  25.
  26.             break;
  27.
  28.         case 0x68:
  29.                                 P02 = 0;
  30.
  31.             while(1);
  32.             break;
  33.
  34.
  35.         case 0x80:
  36.
  37.             if(islavecount==0)
  38.             {
  39.                isubaddr = I2DAT;
  40.                AA = 1;
  41.                islavecount++;
  42.
  43.                data_num = isubaddr;
  44.
  45.             }
  46.             else
  47.             {
  48.                irxdata = I2DAT;
  49.                AA = 1;
  50.
  51.                data_received[data_num++]=irxdata;
  52.
  53.                islavecount++;
  54.             }
  55.
  56.             break;
  57.
  58.         case 0x88:
  59.
  60.             data_received[data_num] = I2DAT;
  61.             data_num = 0;
  62.             AA = 1;
  63.
  64.             break;
  65.         case 0xA0:
  66.
  67.             AA = 1;
  68.             break;
  69.
  70.         case 0xA8:
  71.
  72.             data_num=isubaddr;
  73.
  74.             I2DAT = data_received[data_num];
  75.             data_num++;
  76.             AA = 1;
  77.
  78.             break;
  79.
  80.         case 0xB8:
  81.
  82.             I2DAT = data_received[data_num];
  83.             data_num++;
  84.             AA = 1;
  85.
  86.             break;
  87.         case 0xC0:
  88.             AA = 1;
  89.             break;
  90.         case 0xC8:
  91.
  92.             AA = 1;
  93.             break;
  94.     }
  95.     SI = 0;
  96.
  97. }
  98. void Init_I2C_SLAVE(void)
  99. {
  100.     P13_Quasi_Mode;                         //set SCL (P13) is Quasi mode
  101.     P14_Quasi_Mode;                         //set SDA (P14) is Quasi mode
  102.
  103.     SDA = 1;                                //set SDA and SCL pins high
  104.     SCL = 1;
  105.
  106.     //--set_P0SR_6;                             //set SCL (P06) is  Schmitt triggered input select.
  107.
  108.     set_EI2C;                               //enable I2C interrupt by setting IE1 bit 0
  109.     set_EA;
  110.     I2ADDR = EEPROM_SLA;                    //define own slave address
  111.     set_I2CEN;                              //enable I2C circuit
  112.     set_AA;
  113. }
  114. void main(void)
  115. {
  116.    Set_All_GPIO_Quasi_Mode;
  117.    Init_I2C_SLAVE();
  118.    while (1);
  119. }
IIC_slave_24c02.rar (56.5 KB, 下載次數: 73)
收藏收藏3 分享淘帖 頂 踩
ID:553514 發表于 2019-6-3 10:35 | 只看該作者
看看,學習
ID:412497 發表于 2019-7-30 11:05 | 只看該作者
怎么用呀,主函數沒有
ID:216667 發表于 2019-9-13 18:10 | 只看該作者
壓根兒就不是模擬!瞎扯淡
ID:138649 發表于 2019-9-23 18:00 | 只看該作者
中斷的 下載看看 最近搞個項目IIC等很久
ID:450849 發表于 2021-1-29 10:45 | 只看該作者
有人成功了嗎? 急需要調試
主站蜘蛛池模板: av网站免费在线观看 | 亚洲一级片 | 国产91在线看| 欧美日韩免费在线观看 | 黄色小说视频 | 国产一区欧美 | 99在线观看视频 | 日韩影音| 五月激情网站 | 国产又爽又黄免费视频 | www.一区| aaa亚洲 | 欧美精品99 | 精品自拍视频 | 亚洲福利视频一区 | 日韩免费一区 | 日韩欧美在线播放 | 国产一级一片免费播放放a 国产黄色大片 | 欧美三级精品 | 黄色片视频 | 亚洲欧美精品一区二区 | 日本www在线观看 | 国产成人综合视频 | 国产精品一级二级三级 | 色婷婷成人 | 黄色福利视频 | 97在线免费 | 999久久久精品 | 一级毛片国产 | 免费看a级片 | 男女av在线| 国产小视频在线观看 | 国产成人精 | 亚洲国产二区 | 欧美伦理一区二区 | 久久久精品一区二区三区 | 国产不卡在线观看 | 91在线观 | 91片黄在线观看 | 成av人片在线观看www | ass亚洲尤物裸体pics |
