在做LPC1788開發板的主從機開發,分享下代碼
下載附件
2018-12-6 17:33 上傳
- * $Id[ DISCUZ_CODE_1 ]nbsp; mcu_main_new.c 2012-05-04
- * @file mcu_main_new.c
- * @brief User program.
- * @version 1.0
- * @date 04. May. 2012
- * @author NXP MCU SW Application Team
- * Copyright(C) 2011, NXP Semiconductor
- * All rights reserved.
- * Software that is described herein is for illustrative purposes only
- * which provides customers with programming information regarding the
- * products. This software is supplied "AS IS" without any warranties.
- * NXP Semiconductors assumes no responsibility or liability for the
- * use of the software, conveys no license or title under any patent,
- * copyright, or mask work right to the product. NXP Semiconductors
- * reserves the right to make changes in the software without
- * notification. NXP Semiconductors also make no representation or
- * warranty that such application will be suitable for the specified
- * use without further testing or modification.
- * Permission to use, copy, modify, and distribute this software and its
- * documentation is hereby granted, under NXP Semiconductors'
- * relevant copyright in the software, without fee, provided that it
- * is used in conjunction with NXP Semiconductors microcontrollers. This
- * copyright, permission, and disclaimer notice must appear in all copies of
- * this code.
- #include "includes.h"
- #define VTOR_OFFSET (0x00001000)
- SBL_FirmVerion_Type firm_vers __attribute__((section("firmware_id_section")))= {0,1,'b'};
- /************************** PRIVATE DEFINITIONS *************************/
- #ifdef __MCU_LPC17xx
- #define MCB_1700
- //#define IAR_LPC_1768
- #elif defined (__MCU_LPC11xx)
- #define MCB_1100
- #endif
- #if defined (MCB_1700)
- /* Number of user LEDs */
- #define LED_NUM 4
- const unsigned long led_mask[] = { 1<<3, 1<<4, 1<<5, 1<<6 };
- #elif defined(MCB_1100)
- #define LED_NUM 4
- const unsigned long led_pin[] = { 3, 4, 5, 6 };
- #endif
- /************************** PRIVATE VARIABLES *************************/
- /* SysTick Counter */
- volatile unsigned long SysTickCnt;
- /************************** PRIVATE FUNCTIONS *************************/
- void SysTick_Handler (void);
- void ReAllocateNVIC(void);
- /*----------------- INTERRUPT SERVICE ROUTINES --------------------------*/
- * @brief SysTick handler sub-routine (1ms)
- * @param[in] None
- * @return None
- void SysTick_Handler (void) {
- SysTickCnt++;
- /*-------------------------PRIVATE FUNCTIONS------------------------------*/
- * @brief Re-allocate vector interrupt table
- * @param[in] None
- * @return int
- __disable_irq();
- NVIC_SetVTOR(VTOR_OFFSET);
- __enable_irq();
- uint32_t* src,*dst;
- int32_t size;
- __disable_irq();
- // copy vector table
- src = (uint32_t*)VTOR_OFFSET;
- dst = (uint32_t*)0x10000000;
- size = 192;
- while(size > 0)
- *dst++ = *src++;
- size -= 4;
- LPC_SYSCON->SYSMEMREMAP = 0x1; /* remap to internal RAM */
- __enable_irq();
- #endif
- /*-------------------------MAIN FUNCTION------------------------------*/
- * @brief c_entry: Main program body
- * @param[in] None
- * @return None
- void c_entry(void)
- int num = 0;
- uint32_t systickcnt;
- SBL_SlaveInit();
- /* Relocate NVIC */
- ReAllocateNVIC();
- SystemCoreClockUpdate();
- SysTick_Config(SystemCoreClock/1000 - 1); /* Generate interrupt each 1 ms */
- GPIO_SetDir(2, 0x0000007C, 1); /* LEDs on PORT2 defined as Output */
- GPIO_ClearValue(2, 0x0000007C);
- for(num = LED_NUM-1;num>=0;num--)
- GPIO_SetDir(2, led_pin[num],1);
- GPIO_SetValue(2, led_pin[num]);
- #elif defined(IAR_LPC_1768)
- GPIO_SetDir(1, (1<<25), 1);
- GPIO_ClearValue(1, (1<<25));
- #endif
- while(1)
- if(SBL_SlaveCmdRecv())
- SBL_SlaveCmdHandler(SBL_SlaveGetRecvCmd());
- else
- if(((SysTickCnt - systickcnt) < 500))
- GPIO_SetValue(2, led_mask[num]);
- #else
- GPIO_SetValue(2,(1<<25));
- #endif
- else if(((SysTickCnt - systickcnt) < 1000))
- #ifdef MCB_1700
- GPIO_ClearValue(2, led_mask[num]);
- GPIO_ClearValue(2, led_pin[num]);
- #else
- GPIO_ClearValue(1,(1<<25));
- #endif
- else
- systickcnt = SysTickCnt;
- //SBL_DeInit();
- /* With ARM and GHS toolsets, the entry point is main() - this will
- allow the linker to generate wrapper code to setup stacks, allocate
- heap area, and initialize and copy code and data segments. For GNU
- toolsets, the entry point is through __start() in the crt0_gnu.asm
- file, and that startup code will setup stacks and data */
- int main(void)
- c_entry();
- return 0;
AN11257.zip
(637.92 KB, 下載次數: 11)
2018-12-6 13:19 上傳
點擊文件名下載附件
下載積分: 黑幣 -5
