查看: 17528|回復(fù): 11
error C264: intrinsic '_nop_': declaration/activation error keil編譯錯誤
ID:444914 發(fā)表于 2018-12-12 15:43 | 顯示全部樓層 |閱讀模式
這個問題怎么解決,單片機程序keil編譯出錯
錯誤內(nèi)容:error C264: intrinsic '_nop_': declaration/activation error
#include <reg51.h>
#include <reg51.h>
sbit LCM_RS=P3^0;
sbit LCM_RW=P3^1;
sbit LCM_EN=P3^7;
#define BUSY                  0x80
#define DATAPORT         P1
#define uchar                 unsigned char
#define uint                   unsigned int
#define L                        50
uchar str0[16],str1[16],count;
uint speed;
unsigned long time;
void ddelay(uint);
void lcd_wait(void);
void display();
void initLCM();
void WriteCommandLCM(uchar WCLCM,uchar BusyC);
void STR();
void account();
void int0_isr(void) interrupt 0
    unsigned int temp;
        time=count;
    TR0=0;
        temp=TH0;
        temp=((temp << 8) | TL0);
    TH0=0x3c;
    TL0=0xaf;
        count=0;
    TR0=1;
        time=time*50000+temp;
void time0_isr(void) interrupt 1
   TH0 =0x3c;
   TL0 =0xaf;
   count++;
void main(void)
           TMOD=0x01;
    IP|=0x01;
    TCON|=0x11;
    IE|=0x83;
    TH0=0x3c;
    TL0=0xaf;
        initLCM();
           WriteCommandLCM(0x01,1);
        for(;;)
                account();
                display();
void account()
        unsigned long a;
        if (time!=0)
                a=L*360000000/time;
        speed=a;
void STR()
        str0[0]='S';
        str0[1]='p';
        str0[2]='e';
    str0[3]='e';
        str0[4]='d';
        str0[5]=' ';
        str0[6]=(speed%100000)/10000+0x30;
        str0[7]=(speed%10000)/1000+0x30;
        str0[8]=(speed%1000)/100+0x30;
        str0[9]='.';
        str0[10]=(speed%100)/10+0x30;
        str0[11]=speed%10+0x30;
        str0[12]='k';
        str0[13]='m';
        str0[14]='/';
        str0[15]='h';
void ddelay(uint k)
    uint i,j;
    for(i=0;i<k;i++)
        for(j=0;j<60;j++)
    if(BusyC)lcd_wait();
        DATAPORT=WCLCM;
    LCM_RS=0;
    LCM_RW=0;
    LCM_EN=1;
        _nop_();
        _nop_();
        _nop_();
    LCM_EN=0;
void WriteDataLCM(uchar WDLCM)
    lcd_wait( );
        DATAPORT=WDLCM;
    LCM_RS=1;
    LCM_RW=0;
    LCM_EN=1;
    _nop_();
        _nop_();
        _nop_();
    LCM_EN=0;
void lcd_wait(void)
    DATAPORT=0xff;
        LCM_EN=1;
    LCM_RS=0;
    LCM_RW=1;
    _nop_();
    _nop_();
        _nop_();
    while(DATAPORT&BUSY)
        {  LCM_EN=0;
           _nop_();
           _nop_();
           LCM_EN=1;
           _nop_();
           _nop_();
           LCM_EN=0;
void initLCM( )
        DATAPORT=0;
        ddelay(15);
        WriteCommandLCM(0x38,0);
    ddelay(5);
    ddelay(5);
    ddelay(5);
    WriteCommandLCM(0x38,1);
    WriteCommandLCM(0x08,1);
    WriteCommandLCM(0x06,1);
    WriteCommandLCM(0x0c,1);
void DisplayOneChar(uchar X,uchar Y,uchar DData)
    Y&=1;
    X&=15;
    if(Y)X|=0x40;
    X|=0x80;
    WriteCommandLCM(X,0);
    WriteDataLCM(DData);
void DisplayListChar(uchar X,uchar Y,uchar *DData)
    uchar ListLength=0;
    Y&=0x01;
    X&=0x0f;
    while(X<16)
        DisplayOneChar(X,Y,DData[ListLength]);
        ListLength++;
        X++;
void display()
        STR();
        DisplayListChar(0,0,str0);
           DisplayListChar(0,1,str1);
ID:1 發(fā)表于 2018-12-25 23:43 | 顯示全部樓層
#include <intrins.h> 添加這個頭文件就可以了。因為你用到了 _nop_();
ID:449525 發(fā)表于 2018-12-26 08:34 | 顯示全部樓層
嗯,添加
ID:385774 發(fā)表于 2022-10-10 13:27 | 顯示全部樓層
admin 發(fā)表于 2018-12-25 23:43
#include  添加這個頭文件就可以了。因為你用到了 _nop_();
謝謝哥們
ID:76027 發(fā)表于 2024-2-22 19:44 | 顯示全部樓層
我這里也出現(xiàn)同樣的問題,加了#include < intrins.h> 頭文件,還是報錯。.\Core\eeprom.h(25): warning C206: '_nop_': missing function-prototype
ID:883242 發(fā)表于 2024-2-22 19:53 | 顯示全部樓層
bd5fna 發(fā)表于 2024-2-22 19:44
我這里也出現(xiàn)同樣的問題,加了#include < intrins.h> 頭文件,還是報錯。.\Core\eeprom.h(25): warning C20 ...
你是分不清什么是C51什么是MDK造成的錯誤。
ID:76027 發(fā)表于 2024-2-23 06:29 | 顯示全部樓層
Hephaestus 發(fā)表于 2024-2-22 19:53
請指教!
ID:76027 發(fā)表于 2024-2-23 08:32 | 顯示全部樓層
F:\Keil_v5\C51\Inc\intrins.h(19): error C231: '_nop_': redefinition
ID:155507 發(fā)表于 2024-2-23 11:47 | 顯示全部樓層
MDK 中插入空操作NOP
__asm void nop(void)
        NOP
nop();
ID:76027 發(fā)表于 2024-2-23 12:04 | 顯示全部樓層
我這個是C51
ID:155507 發(fā)表于 2024-2-23 16:50 | 顯示全部樓層
如果要幫你查看問題,你就要吧程序貼出來
什么都沒有,人家想幫你也幫不上呀
ID:195496 發(fā)表于 2024-2-24 14:00 | 顯示全部樓層
貼上全文才能幫你編譯一下,查一下錯誤原因
主站蜘蛛池模板: 99久久综合 | 黄色一级片免费看 | 欧美日日夜夜 | 国产精品福利在线观看 | 国产高清91 | 日韩欧美视频 | 亚洲视频在线观看免费 | 国产青青操| 久久黄色网址 | 亚洲在线一区二区 | 国产精品免费一区二区三区 | 欧美不卡在线 | 日韩一级黄色片 | 国产精品久久一区二区三区 | 欧美视频免费在线观看 | 中文字幕免费av | 免费av观看 | 一道本在线 | 国产一级黄色录像 | 亚洲激情欧美激情 | 在线一区视频 | 国产三级黄色片 | 精品欧美日韩 | 国产av毛片 | 国产欧美精品 | 欧美一区二区三区在线 | 香蕉视频一区二区三区 | a视频在线观看 | 精品第一页 | 玖玖视频在线 | 天天干狠狠干 | 亚洲一区二区三区中文字幕 | 一级黄色片免费 | 134vcc影院免费观看 | 欧美综合一区二区 | 国产成人精品一区二区三区福利 | 亚洲精品a | 免费理论片 | 成人毛片网 | 日韩精品一区二区视频 | 丁香婷婷网|
