查看: 4818|回復(fù): 1
avr單片機定時與中斷做的電子琴(仿真+程序)
ID:21069 發(fā)表于 2018-12-13 18:23 | 顯示全部樓層 |閱讀模式
avr單片機源碼:
  1. #include <iom16v.h>
  2. #include <macros.h>
  4. #define uint unsigned int
  5. #define LED1_ON() PORTA=0xFE
  6. #define LED2_ON() PORTA=0xF7
  7. #define LED3_ON() PORTA=0xBF
  8. #define LED4_ON() PORTA=0x7F
  9. uchar key_0=16;
  10. uint Fr[]= {0,262*8,294*8,330*8,349*8,392*8,440*8,
  11. 494*8,523*8,587*8,659*8,698*8,784*8,880*8,988*8 ,1046*8};
  12. uchar SEG_CODE[]=
  13. { 0xC0,0xF9,0xA4,0xB0,0x99,0x92,0x82,0xF8,
  14. 0x80,0x90,0x88,0x83,0xC6,0xA1,0x86,0x8E
  15. };
  16. uint Tone_Delay_Table[] =
  17. { 64021,64103,64260,64400,64524,64580,64684,64777,
  18. 64820,64898,64968,65030,65058,65110,65157,65178};
  19. uchar spe1_Tone[] = { 3,5,5,3,2,1,2,3,5,3,
  20. 2,3,5,5,3,2,1,2,3,2,1,1,0xFF };
  21. uchar spe1_Time[] =
  22. { 2,1,1,2,1,1,1,2,1,1,1,2,1,1,2,1,1,1,2,1,1,1,0xFF };
  23. uchar spe2_Tone[] =
  24. { 1,3,3,3,3,5,4,2,5,3,7,6,5,5,7,4,4,3,6,7,2,1,0xFF };
  25. uchar spe2_Time[] =
  26. { 2,1,1,2,1,1,1,2,1,1,3,2,1,1,2,4,1,1,2,1,1,1,0xFF };
  27. uchar spe3_Tone[] = { 0,1,2,3,4,5,5,6,7,8,9,10,11,12,13,14,15,
  28. 15,14,13,12,11,10,9,8,7,6,5,4,3,2,1,0xFF};
  29. uchar spe3_Time[] =
  30. { 1,1,1,1,1,1,1,1,1,1,1, 1, 1, 1, 1, 1, 1, 1, 1, 1,
  31. 1, 1, 1,1,1,1,1,1,1,1,1,1,0xFF};
  32. uchar spe4_Tone[] =
  33. { 1,2,3,1,1,2,3,1,3,4,5,3,4,5,5,6,5,4,3,1,5,6,
  34. 5,4,3,1,1,5,1,1,5,1,0xFF };
  35. uchar spe4_Time[] =
  36. { 2,1,1,1,2,1,1,1,2,1,1,2,1,1,3,0.5,0.25,0.5,0.25,1,1,
  37. 0.5,0.25,0.5,1,1,1,1,3,1,1,3,0xFF };
  38. uchar *spe_Tone_Ptr[]={
  39.         spe1_Tone,spe2_Tone,spe3_Tone,spe4_Tone},
  40.                 *spe_Time_Ptr[]=
  41.         {spe1_Time,spe2_Time,spe3_Time,spe4_Time};
  42.
  43.         uint Tone_Idx = 0;
  44.
  45.         uint i = 0,j=1,spe_Idx = 0;
  46.
  47.         uint FALSE = 0, TRUE = 1, Pause = 1;
  48.
  49.         void delay_1ms(void)
  50.         {
  51.                 uint i;
  52.                 for(i=1;i<(uint)(153*143-2);i++)
  53.                         ;
  54.         }
  55.
  56.         void delay(unsigned int n)
  57.         {
  58.                 unsigned int i;
  59.
  60.                 for(i=0;i<n;i++)
  61.
  62.                         delay_1ms();
  63.         }
  64.
  65.         uchar KeyMatrix_Down()
  66.         {
  67.                 DDRB=0XF0;
  68.                 PORTB=0X0F;
  69.                 delay(1);
  70.                 return PINB!=0x0f? 1:0;
  71.         }
  72.
  73.         void Keys_Scan()
  74.         {
  75.                 switch(PINB)
  76.                 {
  77.                 case 0B00001110: key_0=0; break;
  78.                 case 0B00001101: key_0=1; break;
  79.                 case 0B00001011: key_0=2; break;
  80.                 case 0B00000111: key_0=3; break;
  81.                 default:key_0=0xFF;
  82.                 }
  83.
  84.                 DDRB=0x0F;
  85.                 PORTB=0xF0;
  86.                 delay(1);
  87.
  88.                 switch(PINB)
  89.                 {
  90.                 case 0B11100000: key_0+=0; break;
  91.                 case 0B11010000: key_0+=4; break;
  92.                 case 0B10110000: key_0+=8; break;
  93.                 case 0B01110000: key_0+=12; break;
  94.                 default: key_0= 0xFF;
  95.                 }
  96.         }
  97.
  98.         int main()
  99.         {
  100.                 DDRB=0xFF;
  101.                 PORTB=0xFF;
  102.
  103.
  104.                 DDRA=0xFF;
  105.                 PORTA=0xFF;
  106.                 DDRC=0xFF;
  107.                 PORTC=0xBF;
  108.
  109.                 DDRD|=BIT(PD7);
  110.                 PORTD&=~BIT(PD7);
  111.
  112.                 DDRD=~(BIT(PD2)|BIT(PD3));
  113.                 PORTD=BIT(PD2)|BIT(PD3);
  114.
  115.                 MCUCR=0x82;
  116.                 GICR=BIT(INT0)|BIT(INT1);
  117.
  118.                 TCCR1A=0x00;
  119.                 TCCR1B=0x09;
  120.                 SREG=0x80;
  121.
  122.                 while(1)
  123.
  124.                 {
  125.                         if(KeyMatrix_Down()==0)
  126.
  127.                         {
  128.                                 if(Pause)
  129.                                 {
  130.                                         continue;
  131.                                 }
  132.                                 TCCR1B=0x01;
  133.
  134.                                 Tone_Idx=spe_Tone_Ptr[spe_Idx][i];
  135.                                 if(Tone_Idx==0xFF)
  136.                                 {
  137.
  138.                                         delay(200);
  139.                                         i=0;
  140.                                         continue;
  141.                                 }
  142.
  143.                                 TIMSK=BIT(TOIE1);
  144.
  145.                                 delay(spe_Time_Ptr[spe_Idx][Tone_Idx]*200/26);
  146.
  147.                                 TIMSK=0x00;
  148.
  149.                                 i++;
  150.                         }
  151.                         else
  152.                         {
  153.                                 if(Pause==0)
  154.                                 {
  155.                                         continue;
  156.                                 }
  157.                                 if(key_0==0 || key_0>16);
  158.                                         continue;
  159.
  160.                                 PORTC=SEG_CODE[key_0];
  161.
  162.                                 OCR1A=153/2/Fr[key_0];
  163.
  164.                                 TCNT1=0;TIMSK|= BIT(OCIE1A);
  165.
  166.                                 while(KeyMatrix_Down());
  167.
  168.                                 TIMSK &=~BIT(OCIE1A);
  169.                         }
  170.                 }
  171.         }
  172.
  173. #pragma interrupt_handler timer1_ovf_isr:9
  174.
  175.         void timer1_ovf_isr(void)
  176.         {
  177.
  178.                 if(Tone_Idx==0xFF)return;
  179.
  180.                 TCNT1=Tone_Delay_Table[Tone_Idx];
  181.
  182.                 PORTD^= BIT(PD7);
  183.         }
  184.
  185. #pragma interrupt_handler int0_isr:2
  186.
  187.         void int0_isr(void)
  188.         {
  189.                 TIMSK=0x00;
  190.
  191.                 if(spe_Idx==3)spe_Idx=0;
  192.
  193.                 else spe_Idx++;
  194.
  195.                 i=0;
  196.
  197.                 switch(spe_Idx)
  198.                 {
  199.                 case 0:LED1_ON();PORTC=SEG_CODE[1]; break;
  200.
  201.                 case 1:LED2_ON(); PORTC=SEG_CODE[2];break;
  202.
  203.                 case 2:LED3_ON(); PORTC=SEG_CODE[3];break;
  204.
  205.                 case 3:LED4_ON(); PORTC=SEG_CODE[4];break;
  206.
  207.                 }
  208.                 delay(10);
  209.         }
  210.
  211. #pragma interrupt_handler int1_isr:3
  212.
  213.         void int1_isr(void)
  214.         {
  215.                 Pause= !Pause;
  216.                 if(Pause)
  217.                 {
  218.                         PORTC=0xFF;
  219.                         PORTA=0xFF;
  220.                         TIMSK=0x00;
  221.                 }
  222.                 }
  223.         }
  224.
  225. #pragma interrupt_handler timer1_compa_isr:7
  226.
  227.         void timer1_compa_isr(void)
  228.         {
  229.                 PORTD^=BIT(PD7);
  230.         }
        全部源碼附件中
       定時與中斷做的電子琴.zip (14.79 KB, 下載次數(shù): 52)
參與人數(shù) 1黑幣 +8 收起 理由
yoxi + 8 很給力!
ID:716924 發(fā)表于 2020-4-27 22:45 | 顯示全部樓層
程序不難可以
主站蜘蛛池模板: 日韩一级黄 | 秋霞午夜鲁丝一区二区老狼 | av在线播放不卡 | 99视频在线播放 | 91精品国产综合久久久久久 | 久久精品视频网站 | 特级淫片裸体免费看 | 日本不卡一区二区 | 91av视频| 天堂网av在线 | 欧美日韩成人一区二区 | 日日操夜夜 | 亚洲精品99 | 成人性生活免费视频 | 成人免费看片98欧美 | 久久综合五月天 | 日韩成人在线播放 | 久久国产精品视频 | 日韩亚洲一区二区 | 欧美亚洲日本 | 91成人精品一区在线播放 | 国产欧美日韩一区 | 日韩特级毛片 | 欧美综合视频 | 亚洲成人精品 | 国产成人三级一区二区在线观看一 | 一区二区三区日韩 | 一区二区三区四区在线 | 亚洲www啪成人一区二区麻豆 | 九九热在线视频 | 成人激情视频 | 播播激情网 | 午夜激情福利视频 | 亚洲在线免费 | 国产网友自拍 | 亚洲a级片 | 欧美福利一区二区 | 成人免费小视频 | 国产黄色av | 日韩视频在线观看免费 | 久久精品一区二区三区四区 |
