新唐N7600E003輸入捕獲解碼無線遙控
- #include "N76E003.h"
- #include "Common.h"
- #include "Delay.h"
- #include "SFR_Macro.h"
- #include "Function_define.h"
- #include <stdio.h>
- #include <string.h>
- // Leader code range 13.5ms
- #define IR_LDC_MAX 14500 //14.5ms
- #define IR_LDC_MIN 12500 //12.5ms
- // Bit = 1 range 2.25ms
- #define IR_BIT_1_MAX 2500 //2.5ms
- #define IR_BIT_1_MIN 2000 //2ms
- // Bit = 0 range 1.12ms
- #define IR_BIT_0_MAX 1250 //1.25ms
- #define IR_BIT_0_MIN 1000 //1ms
- volatile uint8_t IR_State = 0; // IR State
- volatile uint8_t IR_LDC_Ready = 0; // LeaDer Code is Ready
- volatile uint8_t IR_CTC_Ready = 0; // CusTomer Code is Ready
- volatile uint8_t IR_CTC0 = 0; // Received CusTomer Code 0
- volatile uint8_t IR_CTC1 = 0; // Received CusTomer Code 1
- volatile uint8_t IR_DAC = 0; // Received DAta Code
- volatile uint8_t IR_DAB = 0; // Received DAta Bar code
- volatile uint8_t IR_cnt = 0;
- uint8_t IR_CODE[4] = {0x00, 0x00, 0x00, 0x00};
- void IrDa_NEC_Rx(uint16_t Capture_Time)
- if(IR_State == 0)
- IR_LDC_Ready = 0; // Clear LeaDer Code Ready
- IR_CTC_Ready = 0; // Clear CusTomer Code Ready
- IR_State++;
- // Leader or Repeater code
- else if(IR_State == 1)
- // Leader code
- if((Capture_Time >= IR_LDC_MIN) && (Capture_Time <= IR_LDC_MAX))
- IR_LDC_Ready = 1; // Set LeaDer Code Ready
- IR_State++;
- else
- IR_State = 1;
- // Customer code 0
- else if((IR_State >= 2 && IR_State < 10) && (IR_LDC_Ready == 1))
- IR_State++;
- IR_CTC0 = IR_CTC0 >> 1;
- if((Capture_Time >= IR_BIT_0_MIN) && (Capture_Time <= IR_BIT_0_MAX)) // 1.12ms = 0
- IR_CTC0 &= 0x7f;
- else if((Capture_Time >= IR_BIT_1_MIN) && (Capture_Time <= IR_BIT_1_MAX)) // 2.25ms = 1
- IR_CTC0 |= 0x80;
- else
- IR_State = 0;
- // Customer code 1
- else if((IR_State >= 10 && IR_State < 18) && (IR_LDC_Ready == 1))
- IR_State++;
- IR_CTC1 = IR_CTC1 >> 1;
- IR_CTC1 &= 0x7f;
- IR_CTC1 |= 0x80;
- else
- IR_State = 0;
- // Data
- else if((IR_State >= 18 && IR_State < 26) && (IR_LDC_Ready == 1))
- IR_State++;
- IR_DAC = IR_DAC >> 1;
- IR_DAC &= 0x7f;
- IR_DAC |= 0x80;
- else
- IR_State = 0;
- // Data bar
- else if((IR_State >= 26 && IR_State < 34) && (IR_LDC_Ready == 1))
- IR_State++;
- IR_DAB = IR_DAB >> 1;
- IR_DAB &= 0x7f;
- IR_DAB |= 0x80;
- else
- IR_State = 0;
- if(IR_State == 34)
- if((IR_DAC ^ IR_DAB) == 0xff)
- IR_CODE[0] = IR_CTC0;
- IR_CODE[1] = IR_CTC1;
- IR_CODE[2] = IR_DAC;
- IR_CODE[3] = IR_DAB;
- IR_cnt++;
- printf("IR_cnt=%Bd,CTC0=%bX,CTC1=%bX,DAC=%bX,DAB=%bX\n", IR_cnt,IR_CTC0,IR_CTC1,IR_DAC,IR_DAB);
- IR_State = 0;
- * Timer2 Capture interrupt subroutine
- void Capture_ISR (void) interrupt 12
- uint16_t T2_count;
- T2_count =(C0H<<8)+C0L;
- IrDa_NEC_Rx(T2_count);
- clr_CAPF0; // clear capture0 interrupt flag
- clr_TF2;
- * Main function
- void main(void)
- Set_All_GPIO_Quasi_Mode;
- InitialUART0_Timer3(115200);
- P15_Input_Mode;
- P15 = 1;
- T2MOD = 0XA9; // 定時器2時鐘定義為16分頻,捕獲事件發生后計數值自動清0
- T2CON&=~SET_BIT0; //定義定時器2功能為自動重裝載模式
- IC7_P15_CAP0_FallingEdge_Capture; //下降沿捕獲
- TL2 = 0;
- TH2 = 0;
- set_EA;
- set_ECAP; //Enable Capture interrupt
- set_TR2; //Triger Timer2
- while(1);
N76E003_necR_samplecode_time2_capture.zip
(1.11 MB, 下載次數: 69)
2018-12-14 21:17 上傳
點擊文件名下載附件
