查看: 7493|回復(fù): 1
Arduino電子秤代碼與制作
ID:426684 發(fā)表于 2018-12-18 16:32 | 顯示全部樓層 |閱讀模式
代碼:
//電子秤
#include "LCD12864RSPI.h"
#define AR_SIZE( a ) sizeof( a ) / sizeof( a[0] )
#include "HX711.h"
int Weight = 0;
unsigned char show0[]={0xB5, 0xE7,  0xD7, 0xD3,  0xB3, 0xD3};  //電子秤
unsigned char show1[]="================";//橫隔線
unsigned char show2[]={ 0xD6, 0xD8,  0xC1, 0xBF,  0x3D, 0x00}; //重量=
unsigned char show3[]={0xBF, 0xCB};           //[克]
unsigned char show4[]={0xCC, 0xBD,  0xCB, 0xF7,  0xC8, 0xED,  0xBC, 0xFE,  0x20, 0x00,  0xD6, 0xC6};  //探索軟件 制
char str[4];                               //定義重量值存儲(chǔ)數(shù)組,5位,其中4位為數(shù)字,1位為小數(shù)點(diǎn)
int temp =0;                       //定義重量值中間變量,,用于將獲取的float型重量值轉(zhuǎn)變?yōu)閡nsigned char數(shù)組
void setup(){
Serial.begin(9600);
LCDA.Initialise();                     // 屏幕初始化
delay(100);
LCDA.DisplayString(0,2,show0,AR_SIZE(show0));  //第1行第2格開始,顯示文字"電子秤"
LCDA.DisplayString(1,0,show1,AR_SIZE(show1));//第2行第2格開始,顯示橫隔線
LCDA.DisplayString(2,1,show2,AR_SIZE(show2));//第4行第2格開始,顯示文字濕度
LCDA.DisplayString(2,7,show3,AR_SIZE(show3));
LCDA.DisplayString(3,1,show4,AR_SIZE(show4));
Init_Hx711();                                //初始化HX711模塊連接的IO設(shè)置
Get_Maopi();                //獲取毛皮
delay(3000);
Get_Maopi();                //獲取毛皮
void loop(){
Weight = Get_Weight();        //計(jì)算放在傳感器上的重物重量
temp =Get_Weight();
if(temp<0){  temp =0; }
dtostrf(temp,4,0,str);
LCDA.DisplayString(2,4,(unsigned char *)str,AR_SIZE(str));//第3行第4格開始值
//Serial.print("W="); //串口顯示重量
//Serial.print(Weight);        //串口顯示重量
//Serial.print(" g\n");        //顯示單位
   delay(1000);                //延時(shí)1s
HX711.h
#ifndef __HX711__H__
#define __HX711__H__
#include <Arduino.h>
#define HX711_SCK 6
#define HX711_DT 7
extern void Init_Hx711();
extern unsigned long HX711_Read(void);
extern unsigned int Get_Weight();
extern void Get_Maopi();
#endif
HX711.cpp
#include "hx711.h"
#define ValueGap 630
//該數(shù)值可用砝碼校準(zhǔn)
long HX711_Buffer = 0;
long Weight_Maopi = 0,Weight_Shiwu = 0;
//初始化HX711
void Init_Hx711()
        pinMode(HX711_SCK, OUTPUT);
        pinMode(HX711_DT, INPUT);
//獲取毛皮重量
void Get_Maopi()
        Weight_Maopi = HX711_Read();
//稱重
        HX711_Buffer = HX711_Read();
        Weight_Shiwu = HX711_Buffer;
        Weight_Shiwu = Weight_Shiwu - Weight_Maopi;                                //獲取實(shí)物的AD采樣數(shù)值。
        Weight_Shiwu = (int)((float)Weight_Shiwu/ValueGap+0.05);
        return Weight_Shiwu;
//讀取HX711
unsigned long HX711_Read(void)        //增益128
        unsigned long count;
        unsigned char i;
        bool Flag = 0;
        digitalWrite(HX711_DT, HIGH);
        delayMicroseconds(1);
        digitalWrite(HX711_SCK, LOW);
          count=0;
          while(digitalRead(HX711_DT));
          for(i=0;i<24;i++)
                  digitalWrite(HX711_SCK, HIGH);
                  count=count<<1;
                  if(digitalRead(HX711_DT))
                        count++;
        count ^= 0x800000;
        return(count);
評(píng)分
查看全部評(píng)分
ID:799984 發(fā)表于 2020-7-8 22:41 | 顯示全部樓層
大哥還在嗎,我今天用了你的程序很多報(bào)警能幫忙解決下嗎
主站蜘蛛池模板: 亚洲啪啪网 | 国产福利在线看 | 在线观看国产小视频 | 国产精品久久久久久久久久 | 不卡av在线播放 | 欧美精品一二三区 | 免费黄网站在线观看 | 黄色国产精品 | 能看的av | 国产探花视频在线观看 | 午夜视频在线免费观看 | 国产精品国产三级国产专区52 | 国产精品久久久久久中文字 | 天天综合网站 | 日本黄a三级三级三级 | 成人一区在线观看 | 久久青| 国产偷自拍 | 特级淫片裸体免费看 | 亚洲天堂网址 | 福利网站在线观看 | 成人午夜在线视频 | 538精品视频 | 亚洲网站在线 | 国产精品久久久一区二区 | 免费在线看a | 国产精品手机在线观看 | 天天干夜夜草 | 51调教丨国产调教视频 | 中文字幕有码在线 | 欧美日韩国产在线观看 | 国产精品久久久精品 | 欧美日韩成人一区二区三区 | 三上悠亚一区 | 日韩在线视频一区二区三区 | 日韩欧美黄色片 | 黄色片免费看 | 免费国产精品视频 | 一区二区三区免费观看 | 国产美女一区二区三区 | 午夜影院在线观看 |
