上位機(jī)運(yùn)行界面:
下載附件
2018-12-23 20:26 上傳
下載附件
2018-12-23 20:26 上傳
代碼示例:
- using System;
- using System.Collections.Generic;
- using System.ComponentModel;
- using System.Data;
- using System.Drawing;
- using System.Linq;
- using System.Text;
- using System.Threading.Tasks;
- using System.Windows.Forms;
- namespace 步進(jìn)電機(jī)調(diào)試
- public partial class Form1 : Form
- public Form1()
- InitializeComponent();
- System.Windows.Forms.Control.CheckForIllegalCrossThreadCalls = false;
- static Int16 speed_add = 0x01;
- static Int16 direction_data_clockwise = 0x11; //順時(shí)針
- static Int16 direction_data_anticlockwise = 0x12; //逆時(shí)針
- private void button1_Click(object sender, EventArgs e)
- if (textBox2.Text != "" & textBox3.Text != "" & (radioButton1.Checked | radioButton2.Checked) & comboBox1.Text != "" & comboBox2.Text != "")
- if (button1.Text == "打開串口")
- serialPort1.PortName = comboBox1.Text;
- serialPort1.BaudRate = Convert.ToInt32(comboBox2.Text);
- try
- { serialPort1.Open(); }
- catch { MessageBox.Show("串口不存在"); }
- button1.Text = "關(guān)閉串口";
- //label3.Text = serialPort1.ReadExisting();
- else
- button1.Text = "打開串口";
- serialPort1.Close();
- else
- { MessageBox.Show("請(qǐng)?zhí)钊胂嚓P(guān)參數(shù)"); }
- byte[] data = new byte[5];//方向+(速度1+速度2)+圈數(shù)+路程
- private void trackBar1_Scroll(object sender, EventArgs e)
- ushort y, x;
- if (radioButton1.Checked)
- data[0] = Convert.ToByte(direction_data_clockwise);//將方向數(shù)據(jù)放入data中
- else
- data[0] = Convert.ToByte(direction_data_anticlockwise);
- serialPort1.Write(data, 0, 1);
- //速度1
- textBox1.Text = trackBar1.Value.ToString(); //滾動(dòng)條的值轉(zhuǎn)為字符串顯示于Textbox1
- y = Convert.ToUInt16(trackBar1.Value);
- data[1] = Convert.ToByte((y & 0xff00) >> 8);
- serialPort1.Write(data, 1, 1);
- //速度2
- data[2] = Convert.ToByte(y & 0x00ff);
- serialPort1.Write(data, 2, 1);
- //圈速
- data[3] = Convert.ToByte(textBox2.Text);
- serialPort1.Write(data, 3, 1);
- //角度
- data[4] = Convert.ToByte(textBox3.Text);
- serialPort1.Write(data, 4, 1);
- label10.Text = "轉(zhuǎn)動(dòng)";
- private void textBox1_TextChanged(object sender, EventArgs e)
- try
- trackBar1.Value = Convert.ToInt32(textBox1.Text);
- catch
- private void serialPort1_DataReceived(object sender, System.IO.Ports.SerialDataReceivedEventArgs e)
- Int16 a;
- a = Convert.ToInt16(serialPort1.ReadExisting());
- if (a == 0x88)
- label10.Text = "停止";
- private void Form1_Load(object sender, EventArgs e)
- private void radioButton2_CheckedChanged(object sender, EventArgs e)
- private void radioButton2_Click(object sender, EventArgs e)
- /* try
- ushort y;
- else
- catch { MessageBox.Show("出錯(cuò),檢查串口"); }*/
- private void radioButton1_Click(object sender, EventArgs e)
- /* ushort y;
- else
- serialPort1.Write(data, 2, 1);*/
- private void button2_Click(object sender, EventArgs e)
- try
- ushort y, x;
- else
- //速度1
- //速度2
- //圈速
- //角度
- catch
- MessageBox.Show("請(qǐng)檢查錯(cuò)誤");
全部資料51hei下載地址:
步進(jìn)電機(jī)調(diào)試.zip
(87.01 KB, 下載次數(shù): 67)
2018-12-23 20:26 上傳
點(diǎn)擊文件名下載附件
源代碼 下載積分: 黑幣 -5
評(píng)分
查看全部評(píng)分
