查看: 11236|回復: 11
手機通過wifi內網控制ESP12E輸出LED及DHT22溫度濕度在手機顯示
這個手機的wifi 小玩意的英文從這個randomnerdtutorials點com  網站下載的裡面有詳細資
我加入了
1. 一個 DHT22
2. 加多一個 LED
3. 更改固定 IP 地圵
4. 更攺按鍵顏色
這是用手機通過無線網絡內網控制 ESP12E 輸出 3 LED 1 DHT22 溫度濕度在手機顯示
LED 輸出可更攺為繼電器輸出控制家電開關
如有須要可加入其它功能曾加或減少
下載用 Arduino 便可以。要 Arduino IDE 中安裝 ESP12 板。
如何 Arduino IDE 中安裝ESP8266
  從這個網更改的,詳細請看這網
  Completeproject details at http://randomnerdtutorials點com
// Load Wi-Fi library
#include <ESP8266WiFi.h>
unsigned long previousMillis = 0;
unsigned long currentMillis = 0;
const long interval = 4100;
float temp;
float humi;
float temp1;
float humi1;
#include <Wire.h>
#include <DHT.h>
#define DHTPin 2
#define DHTTYPE DHT
DHT dht(DHTPin, DHT22);
// Replace with your network credentials
const char* ssid     = "xxxxxxxx";                   //????更攺自巳的wifi名稱
const char* password ="xxxxxxxx";                  //????更攺自巳的密碼
// Set web server port number to 80
WiFiServer server(80);
// Variable to store the HTTP request
String header;
// Auxiliar variables to store the currentoutput state
String output0State = "OFF";
String output1State = "OFF";
String output2State = "OFF";
// Assign output variables to GPIO pins
const int output0 = 14;
const int output1 = 4;
const int output3 = 5;
// Set your Static IP address
IPAddress local_IP(192, 168, 1, 167);//????更改自已IP,這里是固定IP地址,每次開機都是這個地圵.
// Set your Gateway IP address
IPAddress gateway(192, 168, 1, 1);
IPAddress subnet(255, 255, 255, 0);
IPAddress primaryDNS(8, 8, 8, 8);   //optional 可不用更改
IPAddress secondaryDNS(8, 8, 4, 4);//optional  可不用更改
void setup() {
  //Initialize the output variables as outputs
pinMode(output0, OUTPUT);
pinMode(output1, OUTPUT);
pinMode(output3, OUTPUT);
  //Set outputs to LOW
digitalWrite(output0, LOW);
digitalWrite(output1, LOW);
digitalWrite(output3, LOW);
//////////Serial.begin(9600);   //要不要都可以,試機時加入
  dht.begin();
// Configures static IP address
  if(!WiFi.config(local_IP, gateway, subnet, primaryDNS, secondaryDNS)) {
  /////////// Serial.println("STA Failed to configure");
  //Connect to Wi-Fi network with SSID and password
///////////Serial.print("Connecting to ");
///////////Serial.println(ssid);
WiFi.begin(ssid, password);
while (WiFi.status() != WL_CONNECTED) {
   delay(500);
   ////////////Serial.print(".");
  //Print local IP address and start web server
/////////////Serial.println("");
////////////Serial.println("WiFi connected.");
////////////Serial.println("IP address: ");
////////////Serial.println(WiFi.localIP());
server.begin();
void loop(){
            //4sec read dhl22 one time
       currentMillis = millis();
       if(currentMillis - previousMillis >= interval)
        previousMillis = currentMillis;
        temp1 = dht.readTemperature();
        humi1 = dht.readHumidity();
                      if (!(isnan(humi1) ||isnan(temp1)))
                        temp=temp1;
                        humi=humi1;
   WiFiClient client = server.available();                 // Listen for incomingclients
  if(client)
{                                                        // If a new client connects,
   //////////////Serial.println("New ClientX1.");          // print a message out in the serialport
   String currentLine ="";                                // make aString to hold incoming data from the client
    while (client.connected())
   {                                                    // loop while the client's connected
                                                         // Serial.println("New ClientX2.");
     if (client.available())
      {                                                  // if there's bytes to read from the client,
       char c = client.read();                           // read a byte, then
     ///////////////Serial.write(c);                     // print it out the serialmonitor
       header += c;
       if (c == '\n')
       {        // if the byte is anewline character
                // if the current line isblank, you got two newline characters in a row.
                // that's the end of the clientHTTP request, so send a response:
         if (currentLine.length() == 0)
            // HTTP headers always start with a response code (e.g. HTTP/1.1 200 OK)
           // and a content-type so the client knows what's coming, then a blankline:
           client.println("HTTP/1.1 200 OK");
           client.println("Content-type:text/html");
           client.println("Connection: close");
           client.println("Refresh: 10");
           client.println();
              // turns the GPIOs on and off
           if (header.indexOf("GET/0/on") >= 0)     {
           //////////// Serial.println("GPIO 0 on");
              output0State ="ON";
              digitalWrite(output0, HIGH);
           else if (header.indexOf("GET /0/off") >= 0){
           ////////////Serial.println("GPIO 0 off");
              output0State ="OFF";
           else if (header.indexOf("GET /1/on") >= 0) {
           //////////// Serial.println("GPIO 1 on");
              output1State ="ON";
              digitalWrite(output1, HIGH);
           else if (header.indexOf("GET /1/off") >= 0) {
          //////////// Serial.println("GPIO 1 off");
              output1State ="OFF";
           else if (header.indexOf("GET /2/on") >= 0) {
             ////////////Serial.println("GPIO 3 on");
              output2State ="ON";
              digitalWrite(output3, HIGH);
           else if (header.indexOf("GET /2/off") >= 0) {
          ////////////// Serial.println("GPIO 3 off");
              output2State ="OFF";
              // Display the HTML web page
           client.println("<!DOCTYPE html><html>");
           client.println("<head><meta name=\"viewport\"content=\"width=device-width, initial-scale=1\">");
           client.println("<link rel=\"icon\"href=\"data:,\">");
              // CSS to style the on/offbuttons
              // Feel free to change thebackground-color and font-size attributes to fit your preferences
           client.println("<style>html { font-family: Helvetica;display: inline-block; margin: 0px auto; text-align: center;}");
           client.println(".button { background-color: #195B6A; border-radius:8px; color: white; padding:16px 40px;");
           client.println("text-decoration: none; font-size: 14px; margin:2px; cursor: pointer;}");
           client.println(".button2 {background-color:#c3352b;}</style></head>");
              // Web Page Heading
           client.println("<body><h4>CONTROL 1 DHT 3 LED</h4>");
           client.println("Temp: ");
           client.println(temp);
           client.println("C");
           client.println("<br>");
           client.println("Humi: ");
           client.println(humi);
           client.println("%");
           // Display current state, and ON/OFF buttons
          // If the output0State is off, it displays the ON button
           if (output0State=="OFF")
             client.println("<p><ahref=\"/0/on\"><button class=\"button\">LED0_OFF</button></a></p>");
             client.println("<p><ahref=\"/0/off\"><button class=\"buttonbutton2\">LED0_ON</button></a></p>");
            // If the output1State is off, it displays the ON button
         if (output1State=="OFF")
           client.println("<p><ahref=\"/1/on\"><buttonclass=\"button\">LED1_OFF</button></a></p>");
           client.println("<p><a href=\"/1/off\"><buttonclass=\"buttonbutton2\">LED1_ON</button></a></p>");
            if (output2State=="OFF")
               client.println("<p><ahref=\"/2/on\"><buttonclass=\"button\">LED2_OFF</button></a></p>");
           client.println("<p><ahref=\"/2/off\"><button class=\"buttonbutton2\">LED2_ON</button></a></p>");
           client.println("</body></html>");
            // The HTTP response ends with another blank line
           client.println();
           // Break out of the while loop
           break;
         {  // if you got a newline, thenclear currentLine
           currentLine = "";
       else if (c != '\r')
       {   // if you got anything elsebut a carriage return character,
         currentLine += c;     // add it tothe end of the currentLine
     // Clear the header variable
   header = "";
     // Close the connection
   client.stop();
   //////////////Serial.println("Client disconnected.");
收藏收藏13 分享淘帖 頂1 踩
ID:63317 發表于 2019-1-25 20:59 | 只看該作者
謝謝分享資料
ID:359281 發表于 2019-4-3 14:20 | 只看該作者
謝謝分享資料!!!!!!!!!!!!!
ID:553016 發表于 2019-6-2 15:05 | 只看該作者
謝謝分享
ID:412814 發表于 2019-6-4 19:05 | 只看該作者
請問我想學習這方面的,該怎樣入手呢
ID:416108 發表于 2019-6-16 10:49 | 只看該作者
不錯,感謝分享
ID:282095 發表于 2019-7-17 09:14 | 只看該作者
樓主真厲害
ID:236710 發表于 2019-10-8 19:56 | 只看該作者
感謝分享
ID:93341 發表于 2020-2-8 12:14 | 只看該作者
小白物聯網入門教程,2步把傳統節能燈改為智能物聯網節能燈    [復制鏈接]
ID:184813 發表于 2020-2-15 23:08 | 只看該作者
謝謝分享資料
ID:458472 發表于 2021-5-20 16:13 | 只看該作者
app哪里下載的
ID:137736 發表于 2021-8-2 18:20 | 只看該作者
工程文件做成個壓縮包吧
主站蜘蛛池模板: 国产一区二区av | 亚洲黄色三级 | 天天爽天天干 | 秋霞午夜伦理 | 国产精品主播一区二区 | 欧美色影院 | 国产精品免费一区二区 | 五月天婷婷网站| 成人午夜影院 | 欧美成人激情视频 | www.久久久久久 | 亚洲亚洲人成综合网络 | 小镇姑娘国语版在线观看免费 | 日韩视频在线观看免费 | 亚洲免费婷婷 | 国产传媒在线播放 | www.免费视频. | 99在线精品视频 | 手机看片日韩 | 日韩免费观看视频 | 国产对白videos麻豆高潮 | 一级黄色片网站 | 成人a毛片 | 人人爽人人澡 | 国产成人在线观看免费网站 | 91看黄 | 中文有码在线 | 六月丁香综合 | 欧美精品二区 | av免费在线观看网站 | 久久久蜜桃 | 国产伦精品一区二区三区视频网站 | 九九久久精品视频 | 亚洲高清毛片一区二区 | 欧美在线激情 | 免费观看黄色大片 | 国产网站视频 | 亚洲另类色综合网站 | 成年人免费看视频 | 在线中文字幕 | 久久综合伊人 |
