查看: 4122|回復: 0
使用C51單片機實現舞臺燈控制效果的源程序
ID:444712 發表于 2019-1-4 09:38 | 顯示全部樓層 |閱讀模式
基于51單片機的8通道舞臺電腦燈控臺硬件進行研究。系統采用AT89C51單片機作為控制器,
用ADC0809作為主要芯片設計A/D轉換電路,并利用差分收發芯片75176BP進行通信口設計。
//本示例在Keil開發環境下請選擇Intel的8058芯片型號進行編譯
//若無特別說明,工作頻率一般為11.0592MHz
#include "reg51.h"
#define CYCLE   0x1000L     //定義PWM周期(最大值為32767)
#define PWMC        (*(unsigned int  volatile xdata *)0xfff0)
#define PWMCH       (*(unsigned char volatile xdata *)0xfff0)
#define PWMCL       (*(unsigned char volatile xdata *)0xfff1)
#define PWMCKS      (*(unsigned char volatile xdata *)0xfff2)
#define PWM2T1      (*(unsigned int  volatile xdata *)0xff00)
#define PWM2T1H     (*(unsigned char volatile xdata *)0xff00)
#define PWM2T1L     (*(unsigned char volatile xdata *)0xff01)
#define PWM2T2      (*(unsigned int  volatile xdata *)0xff02)
#define PWM2T2H     (*(unsigned char volatile xdata *)0xff02)
#define PWM2T2L     (*(unsigned char volatile xdata *)0xff03)
#define PWM2CR      (*(unsigned char volatile xdata *)0xff04)
#define PWM3T1      (*(unsigned int  volatile xdata *)0xff10)
#define PWM3T1H     (*(unsigned char volatile xdata *)0xff10)
#define PWM3T1L     (*(unsigned char volatile xdata *)0xff11)
#define PWM3T2      (*(unsigned int  volatile xdata *)0xff12)
#define PWM3T2H     (*(unsigned char volatile xdata *)0xff12)
#define PWM3T2L     (*(unsigned char volatile xdata *)0xff13)
#define PWM3CR      (*(unsigned char volatile xdata *)0xff14)
#define PWM4T1      (*(unsigned int  volatile xdata *)0xff20)
#define PWM4T1H     (*(unsigned char volatile xdata *)0xff20)
#define PWM4T1L     (*(unsigned char volatile xdata *)0xff21)
#define PWM4T2      (*(unsigned int  volatile xdata *)0xff22)
#define PWM4T2H     (*(unsigned char volatile xdata *)0xff22)
#define PWM4T2L     (*(unsigned char volatile xdata *)0xff23)
#define PWM4CR      (*(unsigned char volatile xdata *)0xff24)
#define PWM5T1      (*(unsigned int  volatile xdata *)0xff30)
#define PWM5T1H     (*(unsigned char volatile xdata *)0xff30)
#define PWM5T1L     (*(unsigned char volatile xdata *)0xff31)
#define PWM5T2      (*(unsigned int  volatile xdata *)0xff32)
#define PWM5T2H     (*(unsigned char volatile xdata *)0xff32)
#define PWM5T2L     (*(unsigned char volatile xdata *)0xff33)
#define PWM5CR      (*(unsigned char volatile xdata *)0xff34)
#define PWM6T1      (*(unsigned int  volatile xdata *)0xff40)
#define PWM6T1H     (*(unsigned char volatile xdata *)0xff40)
#define PWM6T1L     (*(unsigned char volatile xdata *)0xff41)
#define PWM6T2      (*(unsigned int  volatile xdata *)0xff42)
#define PWM6T2H     (*(unsigned char volatile xdata *)0xff42)
#define PWM6T2L     (*(unsigned char volatile xdata *)0xff43)
#define PWM6CR      (*(unsigned char volatile xdata *)0xff44)
#define PWM7T1      (*(unsigned int  volatile xdata *)0xff50)
#define PWM7T1H     (*(unsigned char volatile xdata *)0xff50)
#define PWM7T1L     (*(unsigned char volatile xdata *)0xff51)
#define PWM7T2      (*(unsigned int  volatile xdata *)0xff52)
#define PWM7T2H     (*(unsigned char volatile xdata *)0xff52)
#define PWM7T2L     (*(unsigned char volatile xdata *)0xff53)
#define PWM7CR      (*(unsigned char volatile xdata *)0xff54)
sfr P_SW2   =   0xba;
sfr P0M1    =   0x93;
sfr P0M0    =   0x94;
sfr P1M1    =   0x91;
sfr P1M0    =   0x92;
sfr P2M1    =   0x95;
sfr P2M0    =   0x96;
sfr P3M1    =   0xb1;
sfr P3M0    =   0xb2;
sfr P4M1    =   0xb3;
sfr P4M0    =   0xb4;
sfr P5M1    =   0xC9;
sfr P5M0    =   0xCA;
sfr P6M1    =   0xCB;
sfr P6M0    =   0xCC;
sfr P7M1    =   0xE1;
sfr P7M0    =   0xE2;
sfr PWMCFG  =   0xf1;
sfr PWMCR   =   0xf5;
sfr PWMIF   =   0xf6;
sfr PWMFDCR =   0xf7;
sbit PWM2   =   P3^7;
sbit PWM3   =   P2^1;
sbit PWM4   =   P2^2;
sbit PWM5   =   P2^3;
sbit PWM6   =   P0^7;
sbit PWM7   =   P0^6;
void PWM_config(void);
void PWM2_SetPwmWide(unsigned short Wide);
void PWM3_SetPwmWide(unsigned short Wide);
void PWM4_SetPwmWide(unsigned short Wide);
void PWM5_SetPwmWide(unsigned short Wide);
void PWM6_SetPwmWide(unsigned short Wide);
void PWM7_SetPwmWide(unsigned short Wide);
    PWM_config();
    PWM2_SetPwmWide(0);         //輸出全低電平
    PWM3_SetPwmWide(1);         //輸出1/2550高電平
    PWM4_SetPwmWide(CYCLE);     //輸出全高電平
    PWM5_SetPwmWide(CYCLE-1);   //輸出2549/2550低電平
    PWM6_SetPwmWide(CYCLE/2);   //輸出1/2高電平
    PWM7_SetPwmWide(CYCLE/3);   //輸出1/3高電平
    while (1);
    P0M0 &= ~0xc0;
    P0M1 &= ~0xc0;
    P0 &= ~0xc0;                    //設置P0.6/.P0.7電平
    P2M0 &= ~0x0e;
    P2M1 &= ~0x0e;
    P2 &= ~0x0e;                    //設置P2.1/P2.2/P2.3電平
    P3M0 &= ~0x80;
    P3M1 &= ~0x80;
    P3 &= ~0x80;                    //設置P3.7電平
    P_SW2 |= 0x80;
    PWMCKS = 0x00;
    PWMC = CYCLE;                   //設置PWM周期
    PWM2T1 = 1;
    PWM2T2 = 0;
    PWM2CR = 0x00;                  //PWM2輸出到P3.7
    PWM3T1 = 1;
    PWM3T2 = 0;
    PWM3CR = 0x00;                  //PWM3輸出到P2.1
    PWM4T1 = 1;
    PWM4T2 = 0;
    PWM4CR = 0x00;                  //PWM4輸出到P2.2
    PWM5T1 = 1;
    PWM5T2 = 0;
    PWM5CR = 0x00;                  //PWM5輸出到P2.3
    PWM6T1 = 1;
    PWM6T2 = 0;
    PWM6CR = 0x08;                  //PWM6輸出到P0.7
    PWM7T1 = 1;
    PWM7T2 = 0;
    PWM7CR = 0x08;                  //PWM7輸出到P0.6
    PWMCFG = 0x00;                  //配置PWM的輸出初始電平
    PWMCR = 0x3f;                   //使能PWM信號輸出
    PWMCR |= 0x80;                  //使能PWM模塊
    P_SW2 &= ~0x80;
    if (Wide == 0)
        PWMCR &= ~0x01;
        PWM2 = 0;
    else if (Wide == CYCLE)
        PWMCR &= ~0x01;
        PWM2 = 1;
        P_SW2 |= 0x80;
        PWM2T1 = Wide;
        P_SW2 &= ~0x80;
        PWMCR |= 0x01;
    if (Wide == 0)
        PWMCR &= ~0x02;
        PWM3 = 0;
        PWMCR &= ~0x02;
        PWM3 = 1;
        P_SW2 |= 0x80;
        PWM3T1 = Wide;
        P_SW2 &= ~0x80;
        PWMCR |= 0x02;
    if (Wide == 0)
        PWMCR &= ~0x04;
        PWM4 = 0;
        PWMCR &= ~0x04;
        PWM4 = 1;
        P_SW2 |= 0x80;
        PWM4T1 = Wide;
        P_SW2 &= ~0x80;
        PWMCR |= 0x04;
    if (Wide == 0)
        PWMCR &= ~0x08;
        PWM5 = 0;
        PWMCR &= ~0x08;
        PWM5 = 1;
        P_SW2 |= 0x80;
        PWM5T1 = Wide;
        P_SW2 &= ~0x80;
        PWMCR |= 0x08;
    if (Wide == 0)
        PWMCR &= ~0x10;
        PWM6 = 0;
        PWMCR &= ~0x10;
        PWM6 = 1;
        P_SW2 |= 0x80;
        PWM6T1 = Wide;
        P_SW2 &= ~0x80;
        PWMCR |= 0x10;
    if (Wide == 0)
        PWMCR &= ~0x20;
        PWM7 = 0;
        PWMCR &= ~0x20;
        PWM7 = 1;
        P_SW2 |= 0x80;
        PWM7T1 = Wide;
        P_SW2 &= ~0x80;
        PWMCR |= 0x20;
實現舞臺燈控制效果.zip
13.61 KB, 下載次數: 30, 下載積分: 黑幣 -5
主站蜘蛛池模板: 日日干av| 久久av网站 | 亚洲一级二级三级 | 亚洲 欧美 激情 另类 校园 | 久久午夜精品 | 国产福利视频在线 | 久久亚洲免费视频 | 日本伊人 | 在线亚洲天堂 | 亚洲一区在线观看视频 | 黄在线观看 | 在线观看日韩精品 | 91午夜精品亚洲一区二区三区 | 亚洲久久久 | 黄色一级大片在线免费看国产一 | 亚洲国产精品久久久久久久 | 亚洲一区免费观看 | 日韩免费一区二区 | 欧美顶级黄色大片免费 | 久久精品视频免费看 | av毛片在线看 | 午夜男人影院 | 在线观看网址你懂的 | 97成人在线| 欧美日韩免费一区二区三区 | 亚洲一区日韩 | 性免费视频 | 超碰av在线播放 | 久久久久久国产精品 | 在线观看a视频 | 高清一级片 | 少妇视频网站 | 国产精品一区二区三区四区 | 性做久久久久久 | 成人在线视频观看 | 久久久久久久久久国产 | 国产午夜一区二区三区 | 国产黄色一级片 | 99福利 | 亚洲精品色 | 影音先锋在线视频 |
