查看: 7290|回復: 3
自制MWC飛控2.3固件Arduino源碼
ID:79544 發表于 2019-1-14 15:19 | 顯示全部樓層 |閱讀模式
好用的固件
  1. #include "Arduino.h"
  2. #include "config.h"
  3. #include "def.h"
  4. #include "types.h"
  5. #include "MultiWii.h"
  6. #include "IMU.h"
  7. #include "Sensors.h"
  8. void getEstimatedAttitude();
  9. void computeIMU () {
  10.   uint8_t axis;
  11.   static int16_t gyroADCprevious[3] = {0,0,0};
  12.   int16_t gyroADCp[3];
  13.   int16_t gyroADCinter[3];
  14.   static uint32_t timeInterleave = 0;
  15.   //we separate the 2 situations because reading gyro values with a gyro only setup can be acchieved at a higher rate
  16.   //gyro+nunchuk: we must wait for a quite high delay betwwen 2 reads to get both WM+ and Nunchuk data. It works with 3ms
  17.   //gyro only: the delay to read 2 consecutive values can be reduced to only 0.65ms
  18.   #if defined(NUNCHUCK)
  19.     annexCode();
  20.     while((uint16_t)(micros()-timeInterleave)<INTERLEAVING_DELAY) ; //interleaving delay between 2 consecutive reads
  21.     timeInterleave=micros();
  22.     ACC_getADC();
  23.     getEstimatedAttitude(); // computation time must last less than one interleaving delay
  24.     while((uint16_t)(micros()-timeInterleave)<INTERLEAVING_DELAY) ; //interleaving delay between 2 consecutive reads
  25.     timeInterleave=micros();
  26.     f.NUNCHUKDATA = 1;
  27.     while(f.NUNCHUKDATA) ACC_getADC(); // For this interleaving reading, we must have a gyro update at this point (less delay)
  28.     for (axis = 0; axis < 3; axis++) {
  29.       // empirical, we take a weighted value of the current and the previous values
  30.       // /4 is to average 4 values, note: overflow is not possible for WMP gyro here
  31.       imu.gyroData[axis] = (imu.gyroADC[axis]*3+gyroADCprevious[axis])>>2;
  32.       gyroADCprevious[axis] = imu.gyroADC[axis];
  33.     }
  34.   #else
  35.     #if ACC
  36.       ACC_getADC();
  37.       getEstimatedAttitude();
  38.     #endif
  39.     #if GYRO
  40.       Gyro_getADC();
  41.     #endif
  42.     for (axis = 0; axis < 3; axis++)
  43.       gyroADCp[axis] =  imu.gyroADC[axis];
  44.     timeInterleave=micros();
  45.     annexCode();
  46.     uint8_t t=0;
  47.     while((uint16_t)(micros()-timeInterleave)<650) t=1; //empirical, interleaving delay between 2 consecutive reads
  48.     if (!t) annex650_overrun_count++;
  49.     #if GYRO
  50.       Gyro_getADC();
  51.     #endif
  52.     for (axis = 0; axis < 3; axis++) {
  53.       gyroADCinter[axis] =  imu.gyroADC[axis]+gyroADCp[axis];
  54.       // empirical, we take a weighted value of the current and the previous values
  55.       imu.gyroData[axis] = (gyroADCinter[axis]+gyroADCprevious[axis])/3;
  56.       gyroADCprevious[axis] = gyroADCinter[axis]>>1;
  57.       if (!ACC) imu.accADC[axis]=0;
  58.     }
  59.   #endif
  60.   #if defined(GYRO_SMOOTHING)
  61.     static int16_t gyroSmooth[3] = {0,0,0};
  62.     for (axis = 0; axis < 3; axis++) {
  63.       imu.gyroData[axis] = (int16_t) ( ( (int32_t)((int32_t)gyroSmooth[axis] * (conf.Smoothing[axis]-1) )+imu.gyroData[axis]+1 ) / conf.Smoothing[axis]);
  64.       gyroSmooth[axis] = imu.gyroData[axis];
  65.     }
  66.   #elif defined(TRI)
  67.     static int16_t gyroYawSmooth = 0;
  68.     imu.gyroData[YAW] = (gyroYawSmooth*2+imu.gyroData[YAW])/3;
  69.     gyroYawSmooth = imu.gyroData[YAW];
  70.   #endif
  71. }
  72. // **************************************************
  73. // Simplified IMU based on "Complementary Filter"
  74. // Inspired by http://starlino.com/imu_guide.html
  75. //
  76. // adapted by ziss_dm : http://www.multiwii.com/forum/viewtopic.php?f=8&t=198
  77. //
  78. // The following ideas was used in this project:
  79. // 1) Rotation matrix: http://en.wikipedia.org/wiki/Rotation_matrix
  80. // 2) Small-angle approximation: http://en.wikipedia.org/wiki/Small-angle_approximation
  81. // 3) C. Hastings approximation for atan2()
  82. // 4) Optimization tricks: http://www.hackersdelight.org/
  83. //
  84. // Currently Magnetometer uses separate CF which is used only
  85. // for heading approximation.
  86. //
  87. // **************************************************
  88. //******  advanced users settings *******************
  89. /* Set the Low Pass Filter factor for ACC
  90.    Increasing this value would reduce ACC noise (visible in GUI), but would increase ACC lag time
  91.    Comment this if  you do not want filter at all.
  92.    unit = n power of 2 */
  93. // this one is also used for ALT HOLD calculation, should not be changed
  94. #ifndef ACC_LPF_FACTOR
  95.   #define ACC_LPF_FACTOR 4 // that means a LPF of 16
  96. #endif
  97. /* Set the Gyro Weight for Gyro/Acc complementary filter
  98.    Increasing this value would reduce and delay Acc influence on the output of the filter*/
  99. #ifndef GYR_CMPF_FACTOR
  100.   #define GYR_CMPF_FACTOR 600
  101. #endif
  102. /* Set the Gyro Weight for Gyro/Magnetometer complementary filter
  103.    Increasing this value would reduce and delay Magnetometer influence on the output of the filter*/
  104. #define GYR_CMPFM_FACTOR 250
  105. //****** end of advanced users settings *************
  106. #define INV_GYR_CMPF_FACTOR   (1.0f / (GYR_CMPF_FACTOR  + 1.0f))
  107. #define INV_GYR_CMPFM_FACTOR  (1.0f / (GYR_CMPFM_FACTOR + 1.0f))
  108. typedef struct fp_vector {
  109.   float X,Y,Z;
  110. } t_fp_vector_def;
  111. typedef union {
  112.   float A[3];
  113.   t_fp_vector_def V;
  114. } t_fp_vector;
  115. typedef struct int32_t_vector {
  116.   int32_t X,Y,Z;
  117. } t_int32_t_vector_def;
  118. typedef union {
  119.   int32_t A[3];
  120.   t_int32_t_vector_def V;
  121. } t_int32_t_vector;
  122. int16_t _atan2(int32_t y, int32_t x){
  123.   float z = (float)y / x;
  124.   int16_t a;
  125.   if ( abs(y) < abs(x) ){
  126.      a = 573 * z / (1.0f + 0.28f * z * z);
  127.    if (x<0) {
  128.      if (y<0) a -= 1800;
  129.      else a += 1800;
  130.    }
  131.   } else {
  132.    a = 900 - 573 * z / (z * z + 0.28f);
  133.    if (y<0) a -= 1800;
  134.   }
  135.   return a;
  136. }
  137. float InvSqrt (float x){
  138.   union{
  139.     int32_t i;
  140.     float   f;
  141.   } conv;
  142.   conv.f = x;
  143.   conv.i = 0x5f3759df - (conv.i >> 1);
  144.   return 0.5f * conv.f * (3.0f - x * conv.f * conv.f);
  145. }
  146. // Rotate Estimated vector(s) with small angle approximation, according to the gyro data
  147. void rotateV(struct fp_vector *v,float* delta) {
  148.   fp_vector v_tmp = *v;
  149.   v->Z -= delta[ROLL]  * v_tmp.X + delta[PITCH] * v_tmp.Y;
  150.   v->X += delta[ROLL]  * v_tmp.Z - delta[YAW]   * v_tmp.Y;
  151.   v->Y += delta[PITCH] * v_tmp.Z + delta[YAW]   * v_tmp.X;
  152. }
  153. static int32_t accLPF32[3]    = {0, 0, 1};
  154. static float invG; // 1/|G|
  155. static t_fp_vector EstG;
  156. static t_int32_t_vector EstG32;
  157. #if MAG
  158.   static t_int32_t_vector EstM32;
  159.   static t_fp_vector EstM;
  160. #endif
  161. void getEstimatedAttitude(){
  162.   uint8_t axis;
  163.   int32_t accMag = 0;
  164.   float scale, deltaGyroAngle[3];
  165.   uint8_t validAcc;
  166.   static uint16_t previousT;
  167.   uint16_t currentT = micros();
  168.   scale = (currentT - previousT) * GYRO_SCALE; // GYRO_SCALE unit: radian/microsecond
  169.   previousT = currentT;
  170.   // Initialization
  171.   for (axis = 0; axis < 3; axis++) {
  172.     deltaGyroAngle[axis] = imu.gyroADC[axis]  * scale; // radian
  173.     accLPF32[axis]    -= accLPF32[axis]>>ACC_LPF_FACTOR;
  174.     accLPF32[axis]    += imu.accADC[axis];
  175.     imu.accSmooth[axis]    = accLPF32[axis]>>ACC_LPF_FACTOR;
  176.     accMag += (int32_t)imu.accSmooth[axis]*imu.accSmooth[axis] ;
  177.   }
  178.   rotateV(&EstG.V,deltaGyroAngle);
  179.   #if MAG
  180.     rotateV(&EstM.V,deltaGyroAngle);
  181.   #endif
  182.   accMag = accMag*100/((int32_t)ACC_1G*ACC_1G);
  183.   validAcc = 72 < (uint16_t)accMag && (uint16_t)accMag < 133;
  184.   // Apply complimentary filter (Gyro drift correction)
  185.   // If accel magnitude >1.15G or <0.85G and ACC vector outside of the limit range => we neutralize the effect of accelerometers in the angle estimation.
  186.   // To do that, we just skip filter, as EstV already rotated by Gyro
  187.   for (axis = 0; axis < 3; axis++) {
  188.     if ( validAcc )
  189.       EstG.A[axis] = (EstG.A[axis] * GYR_CMPF_FACTOR + imu.accSmooth[axis]) * INV_GYR_CMPF_FACTOR;
  190.     EstG32.A[axis] = EstG.A[axis]; //int32_t cross calculation is a little bit faster than float
  191.     #if MAG
  192.       EstM.A[axis] = (EstM.A[axis] * GYR_CMPFM_FACTOR  + imu.magADC[axis]) * INV_GYR_CMPFM_FACTOR;
  193.       EstM32.A[axis] = EstM.A[axis];
  194.     #endif
  195.   }
  196.
  197.   if ((int16_t)EstG32.A[2] > ACCZ_25deg)
  198.     f.SMALL_ANGLES_25 = 1;
  199.   else
  200.     f.SMALL_ANGLES_25 = 0;
  201.   // Attitude of the estimated vector
  202.   int32_t sqGX_sqGZ = sq(EstG32.V.X) + sq(EstG32.V.Z);
  203.   invG = InvSqrt(sqGX_sqGZ + sq(EstG32.V.Y));
  204.   att.angle[ROLL]  = _atan2(EstG32.V.X , EstG32.V.Z);
  205.   att.angle[PITCH] = _atan2(EstG32.V.Y , InvSqrt(sqGX_sqGZ)*sqGX_sqGZ);
  206.   #if MAG
  207.     att.heading = _atan2(
  208.       EstM32.V.Z * EstG32.V.X - EstM32.V.X * EstG32.V.Z,
  209.       (EstM.V.Y * sqGX_sqGZ  - (EstM32.V.X * EstG32.V.X + EstM32.V.Z * EstG32.V.Z) * EstG.V.Y)*invG );
  210.     att.heading += conf.mag_declination; // Set from GUI
  211.     att.heading /= 10;
  212.   #endif
  213.   #if defined(THROTTLE_ANGLE_CORRECTION)
  214.     cosZ = EstG.V.Z / ACC_1G * 100.0f;                                                        // cos(angleZ) * 100
  215.     throttleAngleCorrection = THROTTLE_ANGLE_CORRECTION * constrain(100 - cosZ, 0, 100) >>3;  // 16 bit ok: 200*150 = 30000
  216.   #endif
  217. }
  218. #define UPDATE_INTERVAL 25000    // 40hz update rate (20hz LPF on acc)
  219. #define BARO_TAB_SIZE   21
  220. #define ACC_Z_DEADBAND (ACC_1G>>5) // was 40 instead of 32 now
  221. #define applyDeadband(value, deadband)  \
  222.   if(abs(value) < deadband) {           \
  223.     value = 0;                          \
  224.   } else if(value > 0){                 \
  225.     value -= deadband;                  \
  226.   } else if(value < 0){                 \
  227.     value += deadband;                  \
  228.   }
  229. #if BARO
  230. uint8_t getEstimatedAltitude(){
  231.   int32_t  BaroAlt;
  232.   static float baroGroundTemperatureScale,logBaroGroundPressureSum;
  233.   static float vel = 0.0f;
  234.   static uint16_t previousT;
  235.   uint16_t currentT = micros();
  236.   uint16_t dTime;
  237.   dTime = currentT - previousT;
  238.   if (dTime < UPDATE_INTERVAL) return 0;
  239.   previousT = currentT;
  240.   if(calibratingB > 0) {
  241.     logBaroGroundPressureSum = log(baroPressureSum);
  242.     baroGroundTemperatureScale = (baroTemperature + 27315) *  29.271267f;
  243.     calibratingB--;
  244.   }
  245.   // baroGroundPressureSum is not supposed to be 0 here
  246.   // see: https://code.google.com/p/ardupilot-mega/source/browse/libraries/AP_Baro/AP_Baro.cpp
  247.   BaroAlt = ( logBaroGroundPressureSum - log(baroPressureSum) ) * baroGroundTemperatureScale;
  248.   alt.EstAlt = (alt.EstAlt * 6 + BaroAlt * 2) >> 3; // additional LPF to reduce baro noise (faster by 30 ?s)
  249.   #if (defined(VARIOMETER) && (VARIOMETER != 2)) || !defined(SUPPRESS_BARO_ALTHOLD)
  250.     //P
  251.     int16_t error16 = constrain(AltHold - alt.EstAlt, -300, 300);
  252.     applyDeadband(error16, 10); //remove small P parametr to reduce noise near zero position
  253.     BaroPID = constrain((conf.pid[PIDALT].P8 * error16 >>7), -150, +150);
  254.     //I
  255.     errorAltitudeI += conf.pid[PIDALT].I8 * error16 >>6;
  256.     errorAltitudeI = constrain(errorAltitudeI,-30000,30000);
  257.     BaroPID += errorAltitudeI>>9; //I in range +/-60
  258. ……………………
  259. …………限于本文篇幅 余下代碼請從51黑下載附件…………
全部資料51hei下載地址:
MultiWii.zip (152.07 KB, 下載次數: 62)
ID:205027 發表于 2019-9-18 19:58 | 顯示全部樓層
親,具體是怎么用呢?
ID:79544 發表于 2019-9-21 10:48 | 顯示全部樓層
ycb83523 發表于 2019-9-18 19:58
親,具體是怎么用呢?
很簡單的飛控制作。
ID:514567 發表于 2019-11-9 17:16 | 顯示全部樓層
謝謝分享,拿走了
主站蜘蛛池模板: 亚洲日本天堂 | 69av在线播放| 国产免费无遮挡 | 青娱乐福利视频 | 青青草免费在线 | 欧美一级欧美三级 | 亚洲视频不卡 | 国产一级黄| 天天澡天天狠天天天做 | 在线观看黄色网 | 色婷婷av一区二区 | 久久久久久国产 | 精品欧美一区二区精品久久 | 国产永久在线 | 中文字幕在线一区二区三区 | 天堂a√ | 国产毛片视频 | 国产小视频在线观看 | 亚洲欧美视频 | 久久久精品国产sm调教网站 | 天堂√ | 亚洲精品视频在线播放 | 中文字幕www | 日韩免费在线观看视频 | 在线日韩一区 | 国产一区二区福利 | 精品| 久久av片| 国产精品久久久久久妇女6080 | 国产一级在线 | 日韩欧美视频在线 | 国产激情一区二区三区 | 欧美日韩视频 | 日韩视频免费在线观看 | 日本三级视频在线观看 | 久久成人毛片 | 中文字幕网址在线 | 午夜国产在线 | 香蕉视频在线播放 | 欧美顶级黄色大片免费 | 成人av一区二区三区在线观看 |
