查看: 3759|回復: 1
TI藍牙天線設計資料(官方英文PDF下載)
ID:468467 發表于 2019-1-15 13:13 | 顯示全部樓層 |閱讀模式
TI 藍牙天線設計,很全,英文版。
Any structure that is resonant at 2.45 GHz with bandwidth more than 100 MHz and efficiency >50% can
be considered a Bluetooth antenna. Therefore, a countless variety of antennas can be used, and they are
application-specific. Some common types are:
• Wire Monopole — This consists of a simple wire soldered at one end from which it is fed against a
ground plane. It is trimmed to be resonant at 2.45 GHz and provides good performance and high
efficiency. The disadvantage of this antenna is that it is not low profile because it projects above the
PCB.
• PIFA — The Printed Inverted F Antenna is like a monopole printed on a PCB, but it has a ground point
and feed point along the main resonant structure.
• Helix — Similar to the wire monopole, except that it is coiled around a central core (usually air) making
the physical dimensions smaller. It provides excellent performance, but projects above the PCB.
• Ceramic — Surface mount dielectric antennas are the smallest types of antennas available, because
they are printed on a high-dk ceramic slab, which makes the electric field concentrated allowing the
antenna to be made small while keeping a high resonant frequency.
This application note only describes PIFA and ceramic antennas because they are the most common, lowprofile,
smallest, and inexpensive types available.
AN-1811 Bluetooth Antenna Design.pdf
3.26 MB, 下載次數: 32, 下載積分: 黑幣 -5
ID:474351 發表于 2019-1-31 14:25 | 顯示全部樓層
學習學習。。。。
主站蜘蛛池模板: 国产成人免费观看 | 中文字幕免费在线观看 | 成人小视频在线 | 色天堂视频| 国产日韩欧美在线 | 黄色一级免费视频 | 97色伦图片 | 黄色av日韩| 欧美日韩一区二区三区 | 成人网av | 亚洲砖区区免费 | 三级在线视频 | 日韩欧美在线观看视频 | 欧美成人精品一区二区 | 91麻豆精品视频 | 小sao货撅起屁股扒开c微博 | 亚洲女人毛茸茸 | 午夜成人影视 | 看真人一级毛片 | 久操福利 | 国产激情小视频 | 国产操操操| 91片黄在线观看 | 四虎黄色片 | 亚洲成人免费在线观看 | 成人一级毛片 | 激情91 | 免费日韩视频 | 国产一区二区三区免费 | 在线看的av | 国产中文字幕在线播放 | 精品视频国产 | 免费黄色一级 | 欧美丰满少妇 | 久久久久国产精品夜夜夜夜夜 | 免费观看成人 | 色网站在线观看 | 91久久奴性调教 | 欧美激情国产精品 | 日韩av一区二区三区四区 | 欧美日韩成人一区二区三区 |
