查看: 3235|回復(fù): 0
STM32_ILI9341 LCD_SD卡存儲串口接收到的數(shù)據(jù)源碼
ID:473081 發(fā)表于 2019-1-26 12:39 | 顯示全部樓層 |閱讀模式
STM32_LCD_SD卡存儲串口接收到的數(shù)據(jù)
單片機(jī)源程序如下:
  1. #include "delay.h"
  2. #include "sys.h"
  3. #include "usart.h"
  4. #include "usart2.h"
  5. #include "lcd.h"
  6. #include "malloc.h"
  7. #include "exfuns.h"
  8. #include "fontupd.h"
  9. #include "flash.h"
  10. #include "mmc_sd.h"
  11. #include "text.h"
  12. #define FILE_MAX_SIZE 512
  13. int main() //主函數(shù)
  14. {
  15.         u8 font_updata;
  16.         u8 rxlen;
  17.         u16 i;
  18.         u8 *write_buf=0;
  19.         //u8 *read_buf=0;
  20.         FIL file;  //文件對象
  21.         FRESULT res;
  22.         u16 pointer=0;
  23.         Stm32_Clock_Init(9);//系統(tǒng)時(shí)鐘設(shè)置
  24.         delay_init(72);                  //延時(shí)初始化
  25.         uart_init(72,9600);        //串口1初始化
  26.         uart2_init(36,9600);//串口2初始化
  27.         LCD_Init();         //初始化LCD
  28.         LCD_Display_Dir(0); //設(shè)置LCD顯示方向 0豎屏 1橫屏
  29.         SPI_Flash_Init();   //初始化Flash
  30.         if(SD_Initialize())
  31.         {
  32.                 LCD_ShowString(0,0,240,16,16,"SD CARD ERROR");
  33.         }
  34.         mem_init(SRAMIN);        //初始化內(nèi)部內(nèi)存池
  35.         exfuns_init();                //為fatfs相關(guān)變量申請內(nèi)存
  36.         f_mount(0,fs[0]);         //掛載SD卡
  37.         f_mount(1,fs[1]);         //掛載FLASH
  38.         if(font_init())       //檢查字庫
  39.         {
  40.                 LCD_ShowString(0,0,240,16,16,"FONT ERROR");
  41.                 LCD_ShowString(0,16,240,16,16,"UPDATA FONT FROM SD CARD...");
  42.                 font_updata=update_font(20,110,16,0);//從SD卡更新
  43.                 while(font_updata)//更新失敗
  44.                 {
  45.                         LCD_ShowString(0,32,240,16,16,"UPDATA FONT ERROR");
  46.                 }
  47.                 LCD_ShowString(0,32,240,16,16,"UPDATA FONT SUCCESS");
  48.         }
  49.         Show_Str(0,0,240,16,"程序正常啟動(dòng)",16,0);
  50.         while(1)
  51.         {
  52.                 if(USART2_RX_STA&0X8000)//串口2收到數(shù)據(jù)了
  53.                 {
  54.                         Show_Str(0,0,240,16,"串口收到數(shù)據(jù)了",16,0);
  55.                         rxlen=USART2_RX_STA&0X7FFF;        //得到數(shù)據(jù)長度
  56.                         write_buf=mymalloc(SRAMIN,FILE_MAX_SIZE); //申請F(tuán)ILE_MAX_SIZE字節(jié)的空間
  57.
  58.                         for(i=0;i<rxlen;i++)
  59.                         {
  60.                                 write_buf[i]=USART2_RX_BUF[i];
  61.                         }
  62.                         for(i=rxlen;i<FILE_MAX_SIZE;i++)
  63.                         {
  64.                                 write_buf[i]=' ';
  65.                         }
  66.                         LCD_Clear(WHITE);
  67.                         Show_Str(0,16,240,16,write_buf,16,0);
  68.                         //打開文件,如果文件不存在,則創(chuàng)建一個(gè)新文件;用此種方式,可以用f_lseek 在文件后追加數(shù)據(jù)
  69.                         //(讀寫模式可同時(shí)生效)
  70.                         res=f_open(&file, "0:/yiyi.txt", FA_OPEN_ALWAYS | FA_WRITE);
  71.                         switch(res)
  72.                         {
  73.                                 case FR_OK:
  74.                                         Show_Str(0,0,240,16,"磁盤正常",16,0);
  75.                                         break;
  76.                                 case FR_INVALID_DRIVE://驅(qū)動(dòng)器號無效
  77.                                         Show_Str(0,0,240,16,"驅(qū)動(dòng)器號無效",16,0);
  78.                                         break;
  79.                                 case FR_NOT_READY://由于驅(qū)動(dòng)器中沒有存儲介質(zhì)或任何其他原因,而導(dǎo)致磁盤驅(qū)動(dòng)器無法工作
  80.                                         Show_Str(0,0,240,16,"磁盤驅(qū)動(dòng)器無法工作",16,0);
  81.                                         break;
  82.                                 case FR_DISK_ERR://由于底層磁盤I/O接口函數(shù)中的一個(gè)錯(cuò)誤,而導(dǎo)致該函數(shù)失敗
  83.                                         Show_Str(0,0,240,16,"底層磁盤I/O錯(cuò)誤",16,0);
  84.                                         break;
  85.                                 case FR_NO_PATH:  //找不到該路徑
  86.                                         Show_Str(0,0,240,16,"找不到該路徑",16,0);
  87.                                         break;
  88.                                 case FR_INVALID_NAME: //文件名無效
  89.                                         Show_Str(0,0,240,16,"文件名無效",16,0);
  90.                                         break;
  91.                                 case FR_NO_FILE: //找不到該文件
  92.                                         Show_Str(0,0,240,16,"找不到該文件",16,0);
  93.                                         break;
  94.                                 case FR_EXIST: //文件已存在
  95.                                          Show_Str(0,0,240,16,"文件已存在",16,0);
  96.                                         break;
  97.                                 default: //其他的為Disk error
  98.                                         Show_Str(0,0,240,16,"其它Disk error",16,0);
  99.                                         break;
  100.                         }
  101.                         pointer=file.fsize; //獲得文件大小
  102.                         res=f_lseek(&file,pointer);//移動(dòng)文件指針
  103.                         res=f_write(&file,write_buf,rxlen,&br);//向文件內(nèi)寫入字符串
  104.                         res=f_close(&file);   //關(guān)閉打開的文件
  105.                         myfree(SRAMIN,write_buf);
  106.                         USART2_RX_STA=0; //啟動(dòng)下一次接收
  107.                 }
  108.         }
  109. }
STM32_LCD_SD卡存儲串口接收到的數(shù)據(jù).rar (140.93 KB, 下載次數(shù): 55)
主站蜘蛛池模板: 久久精品久久久 | 国产不卡一区 | 国产小视频在线观看 | 一区二区三区免费观看 | 天天操夜夜摸 | 久草福利在线观看 | 懂色av一区二区夜夜嗨 | 在线综合网 | 亚洲天堂欧美 | 午夜视频福利 | 天天操一操 | a级片网站 | 欧美不卡一区二区三区 | 日本加勒比视频 | 另类小说第一草 | 久艹视频在线观看 | 日韩高清精品免费观看 | 欧美日韩一区二区三区视频 | 精品国产三级 | 91午夜精品 | 日韩一区二区视频在线观看 | 国产成人av一区二区三区在线观看 | 精品少妇一区二区三区免费观 | 中文字幕精品在线观看 | 一区二区三区视频 | 亚洲精品资源 | 天天干天天色 | 日本美女一级片 | 亚洲视频二区 | 亚洲国产成人91精品 | 久久久久久久国产精品 | 亚洲一区免费 | 亚洲精品国产精品国自产观看浪潮 | 国产一级黄色录像 | 成人黄色免费视频 | 在线视频成人 | 午夜av在线播放 | 欧美精产国品一二三区 | 美女视频一区二区 | 99黄色 | 玖玖久久 |
