- //MLX90614 Pin Config
- //GND-----1.5.....I/O supply the MLX90614
- //SCL-----2.0
- //SCL-----2.1
- //POW-----2.2.....I/O supply the MLX90614
- #include <msp430g2553.h> // System define for the micro that I am using
- unsigned int A4,A5,A6,A7,A8;
- unsigned char dis_code[10] = {48,49,50,51,52, //段碼表
- //0 1 2 3 4 對應內容
- 53,54,55,56,57};
- //5 6 7 8 9
- void Delay(unsigned int n);
- void start_bit();
- void stop_bit();
- void send_bit(unsigned char bit_out);
- unsigned char receive_bit();
- unsigned char slave_ack();
- void TX_byte(unsigned char TX_buffer);
- unsigned char RX_byte(unsigned char ack_nack);
- unsigned char PEC_cal(unsigned char pec[],int n);
- unsigned long int MEM_READ( unsigned char slave_addR, unsigned char cmdR );
- void CALTEMP(unsigned long int TEMP);
- void mlx90614_POW_0() { P1OUT &= ~0x20;} // define P1.5 ---> POW
- void mlx90614_POW_1() { P1OUT |= 0x20;}
- void mlx90614_GND_0() { P2OUT &= ~0x04;} // define P2.2 ---> GND
- void mlx90614_GND_1() { P2OUT |= 0x04;}
- void mlx90614_SCL_0() { P2OUT &= ~0x01;} // define P2.0 ---> SCL
- void mlx90614_SCL_1() { P2OUT |= 0x01;}
- void mlx90614_SDA_0() { P2OUT &= ~0x02;} // define P2.1 ---> SDA
- void mlx90614_SDA_1() { P2OUT |= 0x02;}
- #define _SDA_OUTPUT P2DIR |=0x02; //Set SDA as Output
- #define _SDA_INPUT P2DIR &=~0x02; //Set SDA as Input
- #define SDA ((P2IN & BIT1)>>1) //define input pin
- #define RXD BIT1
- #define TXD BIT2
- void SendByte(unsigned char Data);
- void UartTXdata(void);
- void main(void)
- WDTCTL = WDTPW + WDTHOLD; // Stop Watch dog timer
- BCSCTL1 = CALBC1_16MHZ; // Set DCO to 16 MHz
- DCOCTL = CALDCO_16MHZ;
- P1DIR = 0xFF; // All P1.x outputs
- P1OUT = 0; // All P1.x reset
- P2DIR = 0xFF; // All P2.x outputs
- P2OUT = 0; // All P2.x reset
- P1SEL = RXD + TXD ; // Select TX and RX functionality for P1.1 & P1.2
- P1SEL2 = RXD + TXD ; //
- UCA0CTL1 |= UCSSEL_2; // Have USCI use System Master Clock: AKA core clk 1MHz
- UCA0BR0 = 131; // 16MHz 9600, see user manual
- UCA0BR1 = 6; //
- UCA0MCTL = UCBRS0; // Modulation UCBRSx = 1
- UCA0CTL1 &= ~UCSWRST; // Start USCI state machine
- mlx90614_GND_0(); //powr supply
- mlx90614_POW_1();
- while(1) // While 1 is equal to 1 (forever)
- unsigned long int DATA;
- DATA=MEM_READ(0x5a,0x07);
- CALTEMP(DATA);
- //Delay(1); //delay 340nS
- //Delay(10); //delay 4uS
- //Delay(60); //delay 20uS
- //Delay(100); //delay 34uS
- //SendByte(0x55);
- SendByte('T');
- SendByte(':');
- SendByte(32);
- SendByte(dis_code[A4]);
- SendByte(dis_code[A5]);
- SendByte(dis_code[A6]);
- SendByte('.');
- SendByte(dis_code[A7]);
- SendByte(dis_code[A8]);
- SendByte('\n');
- Delay(32000);
- Delay(32000);
- Delay(32000);
- Delay(32000);
- Delay(32000);
- Delay(32000);
- Delay(32000);
- Delay(32000);
- Delay(32000);
- while ((UCA0STAT & UCBUSY));
- UCA0TXBUF = Data;
- // USER CODE BEGIN (MAIN_General,10)
- unsigned int i;
- for(i=0;i<n;i++)
- _NOP();
- //Name: start_bit
- void start_bit()
- _SDA_OUTPUT; //Set SDA as output
- Delay(5);
- mlx90614_SDA_1();
- //Delay(30);
- mlx90614_SCL_1();
- Delay(30);
- mlx90614_SDA_0();
- Delay(30);
- mlx90614_SCL_0();
- Delay(30);
- //Name: stop_bit
- void stop_bit()
- Delay(5);
- //mlx90614_SCL_0();
- mlx90614_SDA_0();
- Delay(30);
- mlx90614_SCL_1();
- Delay(30);
- mlx90614_SDA_1();
- //Name: send_bit
- Delay(5);
- if(bit_out==0) {mlx90614_SDA_0();}else{mlx90614_SDA_1();}
- Delay(5);
- mlx90614_SCL_1();
- Delay(30);
- mlx90614_SCL_0();
- Delay(30);
- //Name: receive_bit
- unsigned char bit_in;
- _SDA_INPUT; //Set SDA as input
- Delay(5);
- mlx90614_SCL_1();
- Delay(5);
- if(SDA==1){bit_in=1;}else{bit_in=0;}
- Delay(10);
- mlx90614_SCL_0();
- Delay(30);
- return bit_in;
- //Name: slave_ack
- //1 - ACK
- //0 -NACK
- unsigned char ack;
- ack=0;
- Delay(5);
- mlx90614_SCL_1();
- Delay(10);
- if(SDA==1){ack=0;}else{ack=1;}
- Delay(10);
- mlx90614_SCL_0();
- Delay(30);
- return ack;
- //Name: TX_byte
- unsigned char Bit_counter;
- unsigned char bit_out;
- for(Bit_counter=8;Bit_counter;Bit_counter--)
- if(TX_buffer&0x80){bit_out=1;}else{bit_out=0;}
- send_bit(bit_out); //Send the current bit on SMBus
- TX_buffer<<=1; //Get next bit to check
- //Name: RX_byte
- //Parameters: unsigned char ack_nack (acknowledgment bit)
- //0 - Master device sends ACK
- //1 - Master device sends NACK
- unsigned char RX_buffer;
- if(receive_bit()==1) //Read a bit from the SDA line
- RX_buffer<<=1; //If the bit is HIGH save 1 in RX_buffer
- RX_buffer|=0x01;
- else //If the bit is LOW save 0 in RX_buffer
- RX_buffer<<=1;
- RX_buffer&=0xfe;
- send_bit(ack_nack); //Sends acknowledgment bit
- return RX_buffer;
- //CALCULATE THE PEC PACKET
- unsigned char crc[6];
- unsigned char Bitposition=47;
- unsigned char shift;
- unsigned char i;
- unsigned char j;
- unsigned char temp;
- do{
- crc[5]=0; //Load CRC value 0x000000000107
- crc[4]=0;
- crc[3]=0;
- crc[2]=0;
- crc[1]=0x01;
- crc[0]=0x07;
- Bitposition=47; //Set maximum bit position at 47
- shift=0; //Find first 1 in the transmitted bytes
- i=5; //Set highest index (package byte index)
- j=0; //Byte bit index, from lowest
- while((pec[i]&(0x80>>j))==0 && (i>0))
- Bitposition--;
- if(j<7){ j++;}
- else {j=0x00;i--;}
- }//the position of highest "1" bit in Bitposition is calculated
- shift=Bitposition-8; //Get shift value for CRC value
- while(shift)
- for(i=5;i<0xFF;i--)
- if((crc[i-1]&0x80) && (i>0)) //Check if the MSB of the byte lower is "1"
- { //Yes - current byte + 1
- temp=1; //No - current byte + 0
- } //So that "1" can shift between bytes
- else { temp=0;}
- crc[i]<<=1;
- crc[i]+=temp;
- shift--;
- //Exclusive OR between pec and crc
- for(i=0;i<=5;i++) { pec[i]^=crc[i]; }
- while(Bitposition>8);
- return pec[0];
- //READ DATA FROM RAM/EEPROM
- unsigned long int MEM_READ(unsigned char slave_addR, unsigned char cmdR)
- unsigned char DataL; //
- unsigned char DataH; //Data packets from MLX90614
- unsigned char PEC; //
- unsigned long int Data; //Register value returned from MLX90614
- unsigned char Pecreg; //Calculated PEC byte storage
- unsigned char arr[6]; //Buffer for the sent bytes
- unsigned char ack_nack;
- unsigned char SLA;
- SLA=(slave_addR<<1);
- begin:
- start_bit(); //Send start bit
- TX_byte(SLA); //Send slave address, write
- if(slave_ack()==0){stop_bit();goto begin;} //Send command
- TX_byte(cmdR);
- if(slave_ack()==0){stop_bit();goto begin;}//Send Repeated start bit
- start_bit(); //Send slave address, read
- TX_byte(SLA+1);
- DataL=RX_byte(0); //
- //Read two bytes data
- DataH=RX_byte(0); //
- PEC=RX_byte(ack_nack); //Read PEC from MLX90614
- if(ack_nack==1) //Master sends ack or nack
- //This depends on the pec calculation,
- //if the PEC is not correct, send nack and goto begin
- {stop_bit();goto begin;} //Send stop bit
- stop_bit();
- arr[5]=(SLA);
- arr[4]=cmdR;
- arr[3]=(SLA+1);
- arr[2]=DataL;
- arr[1]=DataH;
- arr[0]=0;
- Pecreg=PEC_cal(arr,6); //Calculate CRC
- if(PEC==Pecreg){ ack_nack=0;}
- else{ ack_nack=1;}
- Data=(DataH*256)+DataL;
- return Data;
- //Name: CALTEMP
- //Temperature data is T=(Data)*0.02-273.15
- unsigned long int T;
- unsigned int a,b;
- T=TEMP*2;
- if(T>=27315)
- T=T-27315;
- a=T/100;
- b=T-a*100;
- if(a>=100){A4=a/100;a=a%100;A5=a/10;a=a%10;A6=a;}
- else if(a>=10){A4=0;A5=a/10;a=a%10;A6=a;}
- else {A4=0;A5=0;A6=a;}
- if(b>=10){A7=b/10;b=b%10;A8=b;}
- else{A7=0;A8=b;}
- else
- T=27315-T;
- a=T/100;
- b=T-a*100;
- A4=9;
- if(a>=10){A5=a/10;a=a%10;A6=a;}
- else{A5=0;A6=a;}
- if(b>=10){ A7=b/10;b=b%10;A8=b;}
- else{A7=0;A8=b;}
復制代碼 |
