查看: 3014|回復: 0
STM32步進電機加減速曲線程序
ID:168655 發表于 2019-2-19 17:56 | 顯示全部樓層 |閱讀模式
基于STM32控制步進電機加減速曲線程序
  1. #include"stm32f10x_lib.h"
  2. #include"main.h"
  3. TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure;
  4. GPIO_InitTypeDef GPIO_InitStructure;
  5. ErrorStatus HSEStartUpStatus;
  6. TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure;
  7. int pulse;
  8. int StepCount;
  9. int pulse1;
  10. int pulse2;
  11. int t1;
  12. int t2;
  13. int r1;
  14. int r2;
  15. void RCC_Configuration(void);
  16. void NVIC_Configuration(void);
  17. void GPIO_Configuration(void);
  18. void TIM2_Configuration(void);
  19. void f(int Vt,int a,int d,int S);
  20. #define VECT_TAB_RAM
  21. int main(void)
  22. {
  23.   #ifdef DEBUG
  24.     debug();/*[初始化外圍設備指針]*/
  25.   #endif
  26.   RCC_Configuration(); //初始化時鐘與復位
  27.   NVIC_Configuration();//初始化中斷嵌套
  28.   TIM2_Configuration();//初始化定時器
  29.   GPIO_Configuration();
  30.
  31.   GPIO_WriteBit(GPIOD, GPIO_Pin_7, (BitAction)(0));
  32.   GPIO_WriteBit(GPIOD, GPIO_Pin_6, (BitAction)(0));  //DCY1 DCY2為00,即Normal %0 DECAY
  33.
  34.   GPIO_WriteBit(GPIOE, GPIO_Pin_7, (BitAction)(1));
  35.   GPIO_WriteBit(GPIOB, GPIO_Pin_1, (BitAction)(0));  //M1M2為10,即1-2-phase
  36.   //GPIO_WriteBit(GPIOA, GPIO_Pin_4, (BitAction)(1));  //正向旋轉
  37.   //GPIO_WriteBit(GPIOA,GPIO_Pin_4,(BitAction)(1-GPIO_ReadOutputDataBit(GPIOA,GPIO_Pin_4)));正、反向旋轉控制
  38.
  39.   GPIO_WriteBit(GPIOB, GPIO_Pin_0, (BitAction)(0));
  40.   GPIO_WriteBit(GPIOC, GPIO_Pin_5, (BitAction)(1));  //TQ1 TQ2為01,即Current Ratio為50%
  41.
  42.   GPIO_WriteBit(GPIOA, GPIO_Pin_7, (BitAction)(1));  //StepReset位
  43.   GPIO_WriteBit(GPIOC, GPIO_Pin_4, (BitAction)(1));  //StepEn 使能位
  44.
  45. while(1)
  46.   {
  47.   r1=0;
  48.   r2=10;
  49.   StepCount=0;
  50.   GPIO_WriteBit(GPIOA,GPIO_Pin_4,(BitAction)(1-GPIO_ReadOutputDataBit(GPIOA,GPIO_Pin_4)));
  51.   TIM2_Configuration();
  52.   do
  53.   {
  54.   }while(r2);
  55.
  56.   TIM_Cmd(TIM2, DISABLE);
  57.   Delay(7000000);
  58.   }
  59. }
  60. void GPIO_Configuration(void)
  61. {
  62.   GPIO_InitTypeDef GPIO_InitStructure;
  63.   GPIO_InitStructure.GPIO_Pin=GPIO_Pin_3 | GPIO_Pin_4 | GPIO_Pin_7;   //PA的3.4.7接CLK,CW/CCW,StepReset
  64.   GPIO_InitStructure.GPIO_Mode=GPIO_Mode_Out_PP;
  65.   GPIO_InitStructure.GPIO_Speed=GPIO_Speed_50MHz;
  66.   GPIO_Init(GPIOA,&GPIO_InitStructure);
  67.   GPIO_InitStructure.GPIO_Pin= GPIO_Pin_5 | GPIO_Pin_6;   //PA的6.7接Protect和Mo
  68.   GPIO_InitStructure.GPIO_Mode=GPIO_Mode_IPU;
  69.   GPIO_InitStructure.GPIO_Speed=GPIO_Speed_50MHz;
  70.   GPIO_Init(GPIOA,&GPIO_InitStructure);
  71.   GPIO_InitStructure.GPIO_Pin=GPIO_Pin_4 | GPIO_Pin_5;   //PC的4.5接StepEn和TQ2
  72.   GPIO_InitStructure.GPIO_Mode=GPIO_Mode_Out_PP;
  73.   GPIO_InitStructure.GPIO_Speed=GPIO_Speed_50MHz;
  74.   GPIO_Init(GPIOC,&GPIO_InitStructure);
  75.   GPIO_InitStructure.GPIO_Pin=GPIO_Pin_0 | GPIO_Pin_1;   //PB的0.1接TQ1和M2
  76.   GPIO_InitStructure.GPIO_Mode=GPIO_Mode_Out_PP;
  77.   GPIO_InitStructure.GPIO_Speed=GPIO_Speed_50MHz;
  78.   GPIO_Init(GPIOB,&GPIO_InitStructure);
  79.   GPIO_InitStructure.GPIO_Pin=GPIO_Pin_7;   //PE7接M1
  80.   GPIO_InitStructure.GPIO_Mode=GPIO_Mode_Out_PP;
  81.   GPIO_InitStructure.GPIO_Speed=GPIO_Speed_50MHz;
  82.   GPIO_Init(GPIOE,&GPIO_InitStructure);
  83.   GPIO_InitStructure.GPIO_Pin=GPIO_Pin_6 | GPIO_Pin_7;   //PD的67接DCY2和DCY1
  84.   GPIO_InitStructure.GPIO_Mode=GPIO_Mode_Out_PP;
  85.   GPIO_InitStructure.GPIO_Speed=GPIO_Speed_50MHz;
  86.   GPIO_Init(GPIOD,&GPIO_InitStructure);
  87. }
  88. void NVIC_Configuration(void)
  89. {
  90.   NVIC_InitTypeDef NVIC_InitStructure;
  91. #ifdef  VECT_TAB_RAM
  92.   NVIC_SetVectorTable(NVIC_VectTab_RAM, 0x0);
  93. #else
  94.   NVIC_SetVectorTable(NVIC_VectTab_FLASH, 0x0);
  95. #endif
  96.   NVIC_InitStructure.NVIC_IRQChannel = TIM2_IRQChannel;  //設置TIM2通道輸入中斷
  97.   NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0; /*配置優先級組*/
  98.   NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;
  99.   NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;      /*允許TIM2全局中斷*/
  100.   NVIC_Init(&NVIC_InitStructure);
  101. }
  102. void TIM2_Configuration(void)
  103. {
  104.   TIM_SetCounter( TIM2, 0x0000);
  105.   TIM_ClearFlag(TIM2, TIM_FLAG_Update);        /*清除更新標志位*/
  106.   TIM_ClearITPendingBit(TIM2, TIM_FLAG_Update); //清除TIM2等待中斷更新中斷標志位
  107.   TIM_ARRPreloadConfig(TIM2, ENABLE);        /*預裝載寄存器的內容被立即傳送到影子寄存器 */
  108.   TIM_ITConfig(TIM2, TIM_IT_Update, ENABLE); //使能TIM2的更新
  109.   TIM_TimeBaseInitTypeDef  TIM_TimeBaseStructure;
  110.   TIM_TimeBaseStructure.TIM_Period = 2000;      //設定的最大計數值2000,最大計數值是0xffff
  111.   TIM_TimeBaseStructure.TIM_Prescaler = 72;     //分頻72
  112.   TIM_TimeBaseStructure.TIM_ClockDivision = 0;     // 時鐘分割
  113.   TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;  //計數方向向上計數
  114.   TIM_TimeBaseInit(TIM2, &TIM_TimeBaseStructure);
  115.   TIM_Cmd(TIM2, ENABLE);       //TIM2 enable counter
  116. }
  117. void RCC_Configuration(void)
  118. {
  119.   RCC_DeInit();
  120.   RCC_HSEConfig(RCC_HSE_ON);
  121.   HSEStartUpStatus = RCC_WaitForHSEStartUp();
  122.   if(HSEStartUpStatus == SUCCESS)
  123.   {
  124.     FLASH_PrefetchBufferCmd(FLASH_PrefetchBuffer_Enable);
  125.     FLASH_SetLatency(FLASH_Latency_2);
  126.     RCC_HCLKConfig(RCC_SYSCLK_Div1);
  127.     RCC_PCLK2Config(RCC_HCLK_Div1);
  128.     RCC_PCLK1Config(RCC_HCLK_Div2);
  129.     RCC_PLLConfig(RCC_PLLSource_HSE_Div1, RCC_PLLMul_9);
  130.     RCC_PLLCmd(ENABLE);
  131.     while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET)
  132.     {
  133.     }
  134.     RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);
  135.     while(RCC_GetSYSCLKSource() != 0x08)
  136.     {
  137.     }
  138.   }
  139.   RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA | RCC_APB2Periph_GPIOB | RCC_APB2Periph_GPIOC
  140.                                 | RCC_APB2Periph_GPIOD | RCC_APB2Periph_GPIOE,ENABLE);
  141.   RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2, ENABLE); //打開TIM2的時鐘
  142. }
  143. void Delay(u32 nCount)
  144. {
  145.   do{
  146.     }
  147.   while(nCount--);
  148. }
  149. void f(int Vt,int a,int d,int S)
  150. {
  151.   int pulse1;
  152.   int pulse2;
  153.   t1=Vt/a;
  154.
  155. if(StepCount<t1)                 //加速階段,分t1級加速
  156.   {
  157.   r1++;
  158.   pulse1=(150000*t1)/(r1*Vt);
  159.   TIM_SetAutoreload(TIM2,pulse1);
  160.   }
  161.
  162. if(t1<=StepCount<=4*S)          //勻速階段運行要求的步數或者距離
  163. {
  164.   pulse=150000/Vt;
  165.   TIM_SetAutoreload(TIM2,pulse);
  166. }
  167. if(StepCount>4*S)                            //減速階段,走完S步后開始減速,分t2-1級減速
  168.   {
  169.     r2--;
  170.
  171.   if(t2>=1)
  172.   {
  173.   pulse2=(150000*t2)/(r2*Vt);
  174.   TIM_SetAutoreload(TIM2,pulse2);
  175.   }
  176.   }
  177. }
  178. main.h文件內容:
  179. #define StepEnPin GPIO_Pin_4
  180. extern int S;
  181. extern int t1;
  182. extern int r2;
  183. extern int pulse1;
  184. extern int pulse2;
  185. extern int StepCount;
  186. extern TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure;
  187. void Delay(u32 nCount);
  188. void f(int Vt,int a,int d,int S);
  189. TIM2中斷函數程序:
  190. void TIM2_IRQHandler(void)
  191. {
  192.   if (TIM_GetITStatus(TIM2, TIM_IT_Update) == SET)
  193.   {
  194.     TIM_ClearFlag(TIM2, TIM_FLAG_Update);
  195.     GPIO_WriteBit(GPIOA,GPIO_Pin_3,(BitAction)(1-GPIO_ReadOutputDataBit(GPIOA,GPIO_Pin_3)));
  196.     StepCount=StepCount+1;
  197.     f(300,10,10,4000);
  198.
  199.   }
  200. }
STM32_motor.rar (2.12 KB, 下載次數: 67)
ID:58925 發表于 2019-5-9 20:04
下了打不開,解壓失敗
主站蜘蛛池模板: 亚洲视频在线一区 | 在线观看亚洲视频 | 欧美日韩大片 | 欧美黄色一级大片 | 亚洲无av在线中文字幕 | 国产日韩精品在线 | 永久黄网站色视频免费观看w | 一级片免费观看 | 国产精品国产精品国产专区不卡 | av日韩精品 | 成年人午夜视频 | 亚洲高清免费视频 | 特级特黄aaaa免费看 | 成人国产网站 | 色av吧| 婷婷久久久 | 欧美一二 | 亚洲一级黄色 | 成人福利网站 | 日韩精品三级 | 一区二区高清视频 | 日韩欧美中文字幕在线观看 | 精品一二区 | 一级黄片毛片 | 91片黄在线观看 | 久久久亚洲精品视频 | 夜夜嗨av一区二区三区网页 | 欧美日韩亚洲视频 | 久久久久久成人 | 欧美一级淫片 | 91免费黄| 97国产精品人人爽人人做 | 日韩精品视频在线 | 在线日韩欧美 | 黄色影视在线观看 | 国产高清一区二区三区 | 亚洲伦理在线观看 | 啊v在线| 亚洲视频不卡 | 欧美久久久久 | 在线观看的av |
